Home » Eclipse Projects » Rich Client Platform (RCP) » Update Manager does not work with org.eclipse.ui.examples.rcp.texteditor
Update Manager does not work with org.eclipse.ui.examples.rcp.texteditor [message #446582] Wed, 22 March 2006 07:12 Go to next message
Hello!
Have tried to implement the Update Function in the rcp example:
org.eclipse.ui.examples.rcp.texteditor but it does not work! It only
works in the debug- Mode! But I cannot export my Project! I have zipped
the whole workspace...you can download it:
http://blog.herrderringe.at/user/admin/TextEdit.zip
thanx
karl
!ENTRY org.eclipse.osgi 2006-03-22 13:03:46.625
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/update/standalone/UpdateCommand
org.eclipse.ui.examples.rcp.texteditor.TextEditorApplication .run(TextEditorApplication.java:27)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Update Manager does not work with org.eclipse.ui.examples.rcp.texteditor [message #446595 is a reply to message #446582] Wed, 22 March 2006 08:33 Go to previous messageGo to next message
Have you added the org.eclipse.* plugins associated with the
UpdateCommand to both your RCP app plugin manifest and to your Product
Configuration definition (and/or your feature, if you are using features)?
Later,
PW
Re: Update Manager does not work with org.eclipse.ui.examples.rcp.texteditor [message #446638 is a reply to message #446595] Wed, 22 March 2006 09:18 Go to previous messageGo to next message
> Later,
> PW
Of corse! I think so...I have done it that way: File -> New -> Product
Configuration -> use a launch configuration (the launch configuration
wich works!)
Karl
Re: Update Manager does not work with org.eclipse.ui.examples.rcp.texteditor [message #446764 is a reply to message #446638] Thu, 23 March 2006 10:56 Go to previous message
>> features)?
>> Later,
>> PW
> wich works!)
> Karl
I have got it! It works....error was: i have tried to run an
product...in Debug mode there ws no Problem, but when I wanted to build
it...I had an Problem with the Update Plugin...working Textedit example:
http://blog.herrderringe.at/user/admin/TextEdit.rar
thanx
Previous Topic:REPOST because of no response ... Eclipse 3.2 M5 Workingsets button on toolbar
Next Topic:Opening more two files with same editor
Current Time: Wed Jul 30 02:55:50 EDT 2025
Powered by FUDForum. Page generated in 0.04924 seconds
