Re: Eclipse crashing with SWT, gtk and linux. [message #446459 is a reply to message #446380] |
Thu, 25 November 2004 11:42 |
Originally posted by: kannenbe.informatik.uni-kl.de
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi there!
| An unexpected exception has been detected in native code outside the VM.
| Unexpected Signal : 11 occurred at PC=0x4DACB172
| Function=XSetTile+0x12
| Library=/usr/X11R6/lib/libX11.so.6
| Current Java thread:
| at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(Native
Method)
| at org.eclipse.swt.widgets.Display.eventProc(Display.java:879)
| at
| org.eclipse.swt.internal.gtk.OS.gtk_container_resize_childre n(Native
| Method)
| at org.eclipse.swt.widgets.Control.setBounds(Control.java:532)
| at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:6 93)
| at org.eclipse.swt.widgets.Tree.setBounds(Tree.java:985)
| at org.eclipse.swt.widgets.Control.setBounds(Control.java:461)
| Any sugguestions on how I should proceed?
Are you using gtk-qt-engine? This could be the problem. Read this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=77928
Ciao, Branko.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.6 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFBpcUXLUFCdqgeaZcRAjtzAJ46vVPuvIidT3Z0BTs7JcHmVIfFagCg 5lX3
WWB5K++i0xUyEYoWtar4JtY=
=i3OU
-----END PGP SIGNATURE-----
Re: Eclipse crashing with SWT, gtk and linux. [message #446551 is a reply to message #446380] |
Fri, 26 November 2004 01:54 |
will Messages: 5 Registered: July 2009 |
As Bug 77928 indicates, the issue was resolved by fixing a bug in the
gtk-qt-engine library. I downloaded the code (cvs) but have not been
able to get the .configure script to complete. It fails as follows:
checking for kde-config... /opt/kde3/bin/kde-config
checking for meinproc... /opt/kde3/bin/meinproc
checking for xmllint... /usr/bin/xmllint
../configure: line 30819: syntax error near unexpected token `GTK1,'
../configure: line 30819: `PKG_CHECK_MODULES(GTK1, gtk+ >= 1.2.0,
use_gtk1="yes",use_gtk1="no")'
Does anyone have a SuSE 9.2 compiled version or know what the problem
with the .configure script is?
-Will.
will wrote:
> Hello,
> Has anyone been having a problem with Eclipse (3.0.1 gtk) running under
> gtk2? P.S. It also crashes with 3.1Mn as well. I am using the new SuSE
> (9.2) and it has gtk2. Eclipse keeps crashing after switching between
> the debug and java perspectives repeatedly. Eventually it crashes with
> the following error:
> QPixmap: Invalid pixmap parameters
> QPainter::begin: Cannot paint null pixmap
> QPainter::setPen: Will be reset by begin()
> QPainter::setBrush: Will be reset by begin()
> at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(Native Method)
> at
> Method)
> I think it is something with SWT not managing memory, resources or
> something with Gtk. I noticed that the lower right area of an editor has
> some obvious drawing problems which could possibly be what is going on.
> SuSE also comes with the older version of gtk (1.2) and I trying to
> figure out how to launch Eclipse with this version. In the mean time I
> have had to switch to motif to continue working, but motif lacks features.
FUDForum. Page generated in 0.03809 seconds
