Building ready-to-use RCP product with org.eclipse.releng.basebuilder [message #446353] |
Sun, 19 March 2006 17:09 |
Originally posted by: mehow.remove.neurosoft.net
I'm following an article at
http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html
as well as a document at
http://dev.eclipse.org/viewcvs/index.cgi/*checkout*/org.ecli pse.releng.basebuilder/readme.html?rev=HEAD&content-type =text/html
trying to setup an automated headless build for my RCP application.
Most of the steps are already working, but I have problems configuring
packaging step.
Although the documents don't describe product branding, it seems to be
supported with a "product" property, which I had properly set in my
build.properties. Unfortunately, during packaging I get
java.io.EOFException from eclipse.brand task located in generated
assemble.<my.feature>.win32.win32.x86.xml script. This seems to be
caused by the fact that eclipse.exe is not copied to the target
directory (set in root attribute of the task) before the task is executed.
I guess I could just copy it there in one of the customTargets.xml
targets, but I believe there's already some infrastructure for that in
the org.eclipse.releng.basebuilder itself.
In particular packaging.properties files that I found in
org.eclipse.releng.eclipsebuilder project seem to leverage that
infrastructure. Unfortunately I couldn't find any documentation about
how to setup it in existing customTargets.xml.
Can anyone please tell me how to do this?
Thanks in advance,
Michal
Re: Building ready-to-use RCP product withorg.eclipse.releng.basebuilder [message #454867 is a reply to message #454125] |
Fri, 08 September 2006 19:32 |
Originally posted by: VaughnWi.attachmate.com
Looks like BrandingIron is creating an empty eclipse.exe and then later,
when it attempts to read the existing icons in the file, throws the
EOFException. I might be able to get around this by copying the executable
before the build...
Has anybody else seen this issue. Looks like a bug, but I might be doing
something wrong in my PDE Build setup...
Thanks!
Vaughn
"Stefan L
FUDForum. Page generated in 0.03000 seconds
