Home » Eclipse Projects » Rich Client Platform (RCP) » Treeviewer = updating + adding + removing nodes
Treeviewer = updating + adding + removing nodes [message #445009] Sat, 25 February 2006 17:22 Go to next message
Originally posted by: lukaszgrobelny.poczta.onet.pl
Hi All,
I got stuck with Treeviewer in my RCP app. I am having problems with refreshing tree while adding new nodes to the tree.
I suppose that I have something messed in my code, but I can't find it :(
My domain objects are: category(Box) + network switch(Switch) (Box can have many Switches and other Boxes). After adding new switch and calling viewer.refresh() nothing changes. While removing Boxes tree looks ok (is updated), but doing the same on Switch objects I get an error:
Unhandled event loop exception
Reason:
com.microsens.midem.GUI.model.Switch
I have tried to follow this topic, but it didn't work for me (problem with adding listeners)
http://www.eclipsezone.com/eclipse/forums/m91953194.html
I would appreciate any help, clues, ideas. This model should support adding and removing objects via popup menu.
This is my code:
public class Box{
	private String name;
	private Box parent;
	private ArrayList<Box> boxes;
	private ArrayList<Switch> switches;
	public Box(Box parent, String name) {
		this.parent = parent;
		boxes = new ArrayList<Box>();
		switches = new ArrayList<Switch>();
		this.name = name;
	public ArrayList<Box> getBoxes() {
		return boxes;
	public ArrayList<Switch> getSwitches() {
		return switches;
	public String getName() {
		return name;
	public void addBox(Box box) {
		boxes.add(box);
		box.setParent(this);
	public void addSwitch(Switch sw) {
		switches.add(sw);
	public boolean removeBox(Box box) {
		return boxes.remove(box);
	public boolean removeSwitch(Switch sw) {
		return switches.remove(sw);
	public Box getParent() {
		return parent;
	public void setParent (Box box) {
		this.parent = box;
	public void remove(Object model) {
		if (model instanceof Box)
			removeBox((Box)model);
		if (model instanceof Switch)
			removeSwitch((Switch)model);
public class Switch {
	private Box parent;
	private ExtendedSwitch extendedSwitch; // This is my wrapped object
	public Switch(Box parent, ExtendedSwitch extendedSwitch) {
		this.extendedSwitch = extendedSwitch;
		return extendedSwitch.getDescription();
		return parent;
	public ExtendedSwitch getSwitch() {
		return extendedSwitch;
public class BoxContentProvider implements ITreeContentProvider {
	private static Object[] EMPTY_ARRAY = new Object[0];
	public void dispose() {}
	public void inputChanged(Viewer viewer,
				Object oldInput, Object newInput) { }
	public Object[] getChildren(Object parentElement) {
		if(parentElement instanceof Box) {
			Box box = (Box)parentElement;
			return concat(box.getBoxes().toArray(),
				box.getSwitches().toArray());
		return EMPTY_ARRAY;
	protected Object[] concat(Object[] object, Object[] more) {
		Object[] both = new Object[object.length + more.length];
		System.arraycopy(object, 0, both, 0, object.length);
		System.arraycopy(more, 0, both, object.length, more.length);
		return both;
	public Object getParent(Object element) {
		if(element instanceof Box) {
			return ((Box)element).getParent();
		if(element instanceof Switch) {
			return ((Switch)element).getParent();
		return null;
	public boolean hasChildren(Object element) {
		return getChildren(element).length > 0;
	public Object[] getElements(Object inputElement) {
		return getChildren(inputElement);
And code responsible for adding and removing in ViewPart:
	public static void addNewSwitch(ExtendedSwitch extendedSwitch) {
		root.addSwitch(new Switch(root,extendedSwitch));
		viewer.refresh();
	public static void removeSelected() {
		if (viewer.getSelection().isEmpty()) {
			return;
		IStructuredSelection selection = (IStructuredSelection) viewer
				.getSelection();
		viewer.getTree().setRedraw(false);
		for (Iterator iterator = selection.iterator(); iterator.hasNext();) {
			Box model = (Box) iterator.next();
			Box parent = (Box)model.getParent();
			parent.remove(model);
		viewer.getTree().setRedraw(true);
		viewer.refresh();
Best Regards,
Lukasz Grobelny
Re: Treeviewer = updating + adding + removing nodes [message #445063 is a reply to message #445009] Mon, 27 February 2006 14:23 Go to previous messageGo to next message
------=_Part_4202_26113039.1141068291678
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Lukasz
Its quite hard to find your problem just by looking at your code.
Some time ago, I built a small tree viewer application named "MyContacts" to get a good understanding of tree viewers and it covers most cases in a tree.
I suggest you to do the following:
1. Download the zip file attached here and unzip it somewhere.
2. Create a new empty project called "MyContacts"
3. Import all the contents of the MyContacts app from the place you unzipped it.
4. Run the app to try it.
5. Get a look at the code (The ContactsView class) has an explanation of the data model and providers used in the viewer.
6. If you have problems, questions, suggestions just post them in this tread. I'll be watching it for a few days.
I hope this helps you with your problems.
Bye
Content-Type: application/zip; name=MyContacts.zip
Content-Disposition: attachment; filename=MyContacts.zip
UEsDBAoAAAAAAPKhWTQAAAAAAAAAAAAAAAALAAAATXlDb250YWN0cy9QSwME FAAAAAgA7KBZNNUc
nNKlAAAAMwEAABUAAABNeUNvbnRhY3RzLy5jbGFzc3BhdGidjz0LwjAURWcF /0PIbqqbQ2sRqaBD
lVJnqcmjjcaXmA/Rf29Vii46uL17OZzLi9PrSZELWCc1JnTMRpQAci0k1gnd lovhhKbTQT/mqnLO
VL5pQ++dAL29kaNEkVBnOSWP8nVG30musSO1rRlwJY0DdhCeqSogb9p1tiqy 3Xydl7NlnhV/2IwA
xrUFZuEcpAWxUaGW6H6pdPAm+M62l/iE4+jz+ztQSwMEFAAAAAgA7KBZNBp6 9O7oAAAAnwIAABMA
AABNeUNvbnRhY3RzLy5wcm9qZWN0vZLBTgMhEIbPmvgOzd4FvXmg28QabzUm bR+ADuNKswwE2Ebf
XqC0rqlpejCemP+f+fkIIGYfpp/s0Adtadrcs7tmggRWaeqmzXr1fPvQzNqb a+G83SLEJwzgtYtp
OrlXgqTBdvE5txQlxCB4NkoHrDFIsRW8Vtk9bBOK4D/UZtC9WjqErKqcp6gk VZwKs75jCL12AdlW
RQbWp0LuZAmg3x+hJqTvhswOVfOxkfWYcjnXKWQLSfoNQ3z8X+wS3tHIP4Fm 5/vKMy8OHst0Faf4
137oNL2UZqKXdRQ48zx0kkn1kSj4rx/sC1BLAwQKAAAAAADtoFk0AAAAAAAA AAAAAAAADwAAAE15
Q29udGFjdHMvYmluL1BLAwQKAAAAAADtoFk0AAAAAAAAAAAAAAAAEwAAAE15 Q29udGFjdHMvYmlu
L2NvbS9QSwMECgAAAAAA7aBZNAAAAAAAAAAAAAAAABoAAABNeUNvbnRhY3Rz L2Jpbi9jb20vbWFn
dXJpL1BLAwQKAAAAAAB9u1k0AAAAAAAAAAAAAAAAJQAAAE15Q29udGFjdHMv YmluL2NvbS9tYWd1
cmkvbXljb250YWN0cy9QSwMECgAAAAAAFoFaNAAAAAAAAAAAAAAAAC0AAABN eUNvbnRhY3RzL2Jp
bi9jb20vbWFndXJpL215Y29udGFjdHMvYWN0aW9ucy9QSwMEFAAAAAgAIVBb NKuqDk7CBgAAaQ4A
AEMAAABNeUNvbnRhY3RzL2Jpbi9jb20vbWFndXJpL215Y29udGFjdHMvYWN0 aW9ucy9BZGRDb250
YWN0QWN0aW9uLmNsYXNznVZrcxPXGX6OLSMhq+AISEK4eLkEJNlYKW2aBBMn RNigRDgQGxNDm2at
PUhrVrvO7sqGpG3ShlCguTS9xuktaTPD5EM/dKaY0kwy4UOnM53px37pTDvT /oH+gybPOWvJgCgW
HWn3nD3nvb/P+57zl//+8RMAA/iNwEDZq+VrZqXu2/nambLnhmY5DPJ82Z4b 5PdZViFa26dX4hAC
vZ5fycuyY88EMj990izLRfp8g6hT4MHrier2kkQ9jvDT889sLx7z/FNT0i1X G6xdAltuYi2OSUfq
7ZIdhNKVfhxxgRVztmt5c6Qv3cSwJPWYJhkU6CjuF0iXps1ZM++YbiU/Fvq2 W+HOFwo0KzTdcMJ0
6lIgw4gMRBEZWIrIQGQ/R8taXEtglUA8kM6oZ5HvgVJrWGZtOSf9IF+ktno5 rPvSavpC1UmzGV4B
cZxWeqfo117btcMhge2ZZR3LTgjEClp/ZyY7kcI63JtEDOtTSGPNSnRgQwpr o9mmFFYiqWa9Al2B
DIuWwLpMa0yUnC3YmiTlNoFuYsAoNFy+X7scjsvTYQo7I6IMg0aiwDANV84Z i+ExQs8Iq9IItMPS
Miq+V59JICewSknwPGfcnokE9UeCdhFby3gcR15gTUWGzTiOSX/WLksVrmxL vG6mGkzhi9jdjQfw
JQFjOeo4HhRYyyS1AFBgR6a0LEx1JB/Cw934Ch4RWF2yXTlar01Jf9yccqQC pFc2nQnTt9X34mIs
rNqBwtOdleYgIeDX3RR6cJdK8uMs7jtDZBxP0EjGdsT2g3DYkTXphgxAJnsd Rp6emiY147gfw90o
YITJv7WhNcLSyRcWP/eboRnHQYorurOmYzcxZaidBJ4U6Jv06kbZdHeGBmNO NBWWkGS6HsHkN5a2
JFAS2Nnqn2WbjlcJ8odkEJgVuV9/xjEqsNKbke6w73tM3siNyQvmwvycbVUk rR6rSscZbC2KW5fJ
YRxJ4mk8I5BtJwgHVAnEMU5rqOyw6esA72KA2+Zm5CdwLImjeFYg1xKxG2vP 97wwqjsG7DgbDrUO
uzRfBrQ4kz3Rll6q/Cq+plQ+JzB0uyRFuqjaDKM2YLuBESVOGx/QjOf/16HT zN0SshvpmxJI0HSd
G/b7TPb26aPBFqSq8pMCW5fLddQ2q0mUYbP6FEx0Ny2mcAqOWq4JpBplMWrW pK6JFkBQq4cZRf8C
TxXdouiapRhSCKKdMMoBPfQJ0BRmo+U59kQFiKrXaBApnIm2XoxKcrhm2k6T 7RvR3jcFLmTaSqGO
fluo/v9WClEQX06iiFeYLEJD4ewMUdaegToL38GrCmVnWR5VM6hoxDAV3tQ0 e/6J1ibEQ9PmU+TB
aZZVx7wzXJE/wXjOsJuqtmuHkolO30rNipnFUu1ry5ko2jwpLZvSlfB7fFnz ZmXLCZHCD6Pj4UcC
PUFjt1CldsnT+eBtbgDsHuHg7e4cTWXRLSGwXyQO34GjuvY8j8t2PInjZ2Sl 9/S9dxlbmLWmBzwf
2zON9TDm1f2yHLHV2bfu5lNtQGUDW3iexfisQAJdSKt7DC+w69GNFFhrnHdg NR8efWqu7j56XKtG
clIw7ub7Hn6d43oHx925K7gv13kZG9Vrc67vMoxcevUCtufSOxaQzaX7FjDQ dxVfZp+9ij0d+J2W
Ocj3Dqzku4+Sd3KWxSr0U9MuWjSAXuRxPx7mPeMR7CXV3ZE2PIohjpxp6wV/ j+HeyCbxd650ce/f
ud9j4zz+kYvRIs73XcUBgWsozmONSD+VPvQHjGlrL8Fqbn+KowuY5P/PEdGJ JaLHOvfeSPb1Q51D
l3BX/6bd13B0Hl2xvWc7xab+T97/7D8b5tGj2M0GOzk3z+PIRyhPcmpcRUXg CqZLDIv76MZ38VBT
9OguCt8TWx/7CMXJ9TES+HzqfE7zeYnPt3oKV/DtBby2FMM3sY3vJxAnHNVt YgOGsRkjMDhuwwFG
90k8jqe4W8Iwx4M4hMP8PYMjmOK7gjHMYBw+5y/hGF7Gs2wgkzjL8bs4jtfx HIvreXwAEx+S47ew
aL7ExziJP5H7r6jib7DxT37/C67KFSUlVBZUrvTXHpxjXgW5c5R5npZbzNcF XEQnPiDV9/A6dz9k
tt/gWgfl5+jXW9z9GNvxfbytsfeDRp4xRBrBsUcFtIGsH1+PrKRGyxzRfFpb lIroI4s4/wl+uijr
HVJ2Kpkaw/3XUJhHPtf/KQqXsS9Kzbus3ffQex2Qfs4kK3BtvISE5lvSvFX7 /ipx+Bq1nmPtnGfd
XeAhepH+vUkL3tYWGZHWyCI9+wV+CaFnv8J72sP3tdRffw5QSwMEFAAAAAgA 21BbNL9OfxUaBgAA
/gwAAEkAAABNeUNvbnRhY3RzL2Jpbi9jb20vbWFndXJpL215Y29udGFjdHMv YWN0aW9ucy9BZGRD
b250YWN0c0dyb3VwQWN0aW9uLmNsYXNznVZbVxNXFP4OBIOQKuIVQRm8EQIS a71VEEsjaDTiBUUR
bTskxzCYzMSZCYi1tRe0tff2Sfpkn2zXah+6VsVS13Lpa/9M/0Hbb84QQEOF urJmzp5z9vXb++yd
P//+4zGAVnwrsCtpZaNZPZ23jWh2LGmZrp50nShfhmU60c5UKja9d9i28rlO tR+EEKi37HRUJjNG
zpHR4ct6Uk5LRQtMpQINc5nyRjTeKzNSHScMx5WmtIMoE9j9LNusebV289Oy x7bEz1n2lUFpJocK
FoICS0YNM2WN0lTiOSWz7OcUS5tASfyQQHViWB/RoxndTEd7Xdsw0zx5JUZ7 rm66fXomLwVaiUur
j0vrLC6tvmNcU6nCXtrDpRzLBIKOzPRYKUrvSBSDM2LIUWk70Tht5pNu3pap GTDoQDlVKogFxAV6
al1hbO2GabgdAlvCCwbX1CcQiCnrpeGmvhBWY10FAqgJoRorl6IEtSGs8qkN ISxFhUfVC5Q50o2n
BFaHi3Hx9DRgUwU5NwssZTVoh/1wt6pw3TPymhtCo88SZlHEbKm70tF0zZSj msJGsy5rBbDKERFY
5glaVuaMkfPlW3z57ZRfIMwgogIr09Kdga5X2iNGUnoYNRWB9DxXWwivYmcl duA1AW0h7iB2C6xi
XoqKVmBbOLFgaSv49mJfJfbgdYHlCcOUPfnsoLTP6IMZ6VWildQzfbpteN/T mwF3yHAE9iRe5ma2
Mft23gyhCiu8/L7BSv5/pRjEm3SVCHcbtuN2ZWRWmi5hCDfNKY8Tg8PkJpqH 0FWJGLoFwvO7m2VF
ZqIFTw/prh7EERZb3BzRM0ZKmz4plNVRgc39Vl5L6majqxF6TfePNNciOc3d UI6EQGNxYClDz1hp
J3pcOo6elofUZxA9rF0rJ80u27aYu+5nc+eMutFRI5WWdLd3SGYybcUXYf6r cRKnKnACpwWaFhO9
CiSIMwIVNNZlUpF0KBtuGkgsRp549+FcBc7ivMC+F8CU9skh3fUvnmE6WkEJ sbvwX21/Gr/i4ioA
eZF9iq4rlNhxw00vBpIOv4W3vev2jsCmhVD3m9ZgBS4hyWvgJUz1sngIEpe9 7bRAiALKpR49K1VZ
FqWGVg0Me/xsoZ3hRUGrVM6T5ZjvVNYD3fSbtJe3MWZtcYpVVDlc9RSw9CqH dKfAyeCswWG2s4Hi
m8UhYPCJcxCkU14zeJl8eVPFlk6O7cLrK4Yrs2r6FRtbktNtdc2bFxWUskGx KqfQNWJD1Cfp6ZEX
TKqTuu22vXAyFtT508wxrssQPsJlr8V8zA6/GN+CuEVRxsNo6hfwhW1hJgK2 9MW5xsGXMgiqh+la
W2atEVnU+UP4wm/7X/Ku91p5Oym7Da+5187ftlu9nKCBDTvAZwnKUYZqb0bz b1oNKhEC/6GQLsFy
PuztHu3NdbWuUmuAPKuxhu+1/LrN/RKuOyMPsT5S+gB13mtjpPkBtEj18kls iVRvm0RTpLp5Eq3N
U9glEJnC/hL8qnS28b0NS/mOUPNWUo1YhmZaaqFH21GPVu7u5Tjdh3ZyrfGt 4QA6uJJS3gv+DmKd
75O4w8jKePZL5DfUTeDHSIAeke6cwmGBp4hPYKWoPlZ9/Hf0Km/v42Bp+wzD E5ydRP/x0o77WNGy
YafiLwu0j5eKDS2Pf/jnr9oJVHniAwVxSm6cQOcjXOonqU1BF3iIVIIRDx2o +x6NM6p7tlP5/kBN
4BHO9tcEyJCpOvwQ1iScWThs1PHdCU5IJiSGWk6/jeiCxnUzugnOEQITJwRH yXGMvwSOk+7jiLiA
k+xHp/A210GcRtrrJziHmziPcfTjUwzgO1zEXXLdY9P8ievP5CS05C73QPOh pYX9cJkGwe8I8hih
dwcJ7yiuoRQ3eT6G6zwdRxjvcq+EetfjBt7j6V2Wyvvk8UrlA3w4XSp3yVPK tUOVSctTxCYQjbQ8
QewBOn2Ixnml7qF+Tq5uE2wvf3X3Ua7kZnHapPw1meoccbpKmzZL2+EUcFks Y/T7hopL8636cSnq
E+IgFHUHn6GE9Od+8ai9EnVW5aWyUK5fzS3XClWC47wit5T+kM/v6yf9teL8 5l9QSwMEFAAAAAgA
hlJbNIuxJa49BQAAQgsAAEQAAABNeUNvbnRhY3RzL2Jpbi9jb20vbWFndXJp L215Y29udGFjdHMv
YWN0aW9ucy9Ecm9wQ29udGFjdEFjdGlvbi5jbGFzc5VWW3cTVRT+ThtISMPF UIqASLgISVoyoFzU
QilNW4iEFk0tghecZk7TaZOZODNpKV7wfvddfPLNZ9eSYGUtF6zlkz/K5Xdm khaTSsvqypxz9uyz
97e/fZn+/c8ffwLI4AcBrWhXtIpeqjmmVlks2panFz1X48O0LVcbduxqNhCe 90VhCIF9tlPSZLFs
Vl2pzU7rRdm4oDWVOgVOPqpUM5smGyqjPNrO4qHcVduZm5JWcaZ5dYPA/par uYIsS/913nQ9aUkn
jLBAR25YIJ6f1ed1raxbJa3gOaZV6hfYnKUnT7e8Sb1ckwIpRpkJosysRJlp QMoYjLIhjCAmsHHB
tAx7gUDyLUhW4F71Vegr7MrymG3Qy7F8Oy/zplyQjqvliK1W9GqONJaD4eUu Y4VgAXGdvs+YlukN
CBxKruk8NSkQyvq+O5OpyRi6sTOKEJ6OIY7tm9CB3TFswVa1e0Zggyu9nCGw I9nOmbr9LPZFqZkQ
iKm8J7JNSg74UXoT8qYXw6FA6zmBI0rLTeiJBneJaceuJLwZmXD9EKWRKDl2 rRrBEYEtyoBtlyfM
amAnFdhJs5zWiDOMPoHtJektM1eQzrxZlIqkVBtLrVr9MZa61oWjOCaQWEs7 jOcFunXDaKs5gcPJ
/JqV6TN5Aie78AJOCWzNm5Ycq1WmpDOhT5WlKli7qJcndcdU54Yw5M2YrsDx /BO2Yz8z79SsGLbh
KZXlswKZJyvCMM4RJckdNR3XGynLirQ8MpBMPVIk41Oz1CaR5zHUhUFkBZKr I62wGstatnEc1j09
jJH/HTOGqZft0n/iGvZFYVwQiKiUz8hymY3Ykmd3wdMWTIMKruarEFsOr6gk XxLoaS3vodr0tBoa
l1nazVDH9IoM4mzVpq1xXIliFK8KbGt5S2gFtsO8Gizj06om2nla1eTrmIxi AlfZparyx3CNDZ+I
4E32vF6tSoud2bdaZ+ZXj4Ym38Y7ytANDjy/O8irocKKQQ/wT5FEzw5uxWBQ SHVGfSK5BpvtMILx
UoriImZYrzYB+1MnF8Ms5pSYadpEE1d0x6+go2R2PTVyQY0IBmPBVpCrnNbr vhYGu7LLkRV7Xo5Y
nrPIy8l1efXj8VCLwsU881lszuD0uq6rwmbvdRhF1bRPWNy8GHGkW2VHMxci R/eGyaM67QyCaRsr
MdwOZsrHLEm3+TY7wwxJFs7Fx3wsmBCv/3GfpmVnwQfFNW+xgj7HnOr0Lyio 0gCn9BoemP1lXGyL
9TkUiBbsmlOUo6Yagz1tAy6jChH7OdpC/G1EhOsubEIUTDxA2WbE1TdO7dUU VKv6+nENUacbO/js
4elDyju4Hk3fw650513sSffexd50fHMd+9Pxg3UcTseTdfT2LuE462AJpzvw q2/uRT4PIMJnikYP
0n2aLntpvA+7OXISOMXdabxEjZ7ACV5GP1fufHCCf2ewswHlLwYS4jqR/g17 7mCcy8AS+M/MA4zm
7+PiNQr2LiEvcB9j13rreO13vHEP1+Nv1fEuj0UudUzfg3m5r47KwN6f0EXx e/wtrCDO+ASdQxiD
RDpEErP8MA2jn+sAhvg3ggvsuEvs3QKfCn06wNVA383bN7FI1EMk9hbeRwdv xPAByeyk9KPliAb4
RnDdppA3+fvkUf6iPi8FcjHhe4oF+oEn7j/FZw1bP1KzU9n0k9T3EIN3oKX7 HmDwLmU+VV+yKn/G
vmXeHmL0Dn2HqP8LIv691szdwAbo9DrFqIrkwsAxSL43cRZzPqJE4DVA5O++ wtcQ/u4bfOtH+J1v
9ft/AVBLAwQUAAAACACAUls0IeKVBEgFAABXCwAASgAAAE15Q29udGFjdHMv YmluL2NvbS9tYWd1
cmkvbXljb250YWN0cy9hY3Rpb25zL0Ryb3BDb250YWN0c0dyb3VwQWN0aW9u LmNsYXNznVVbdxNV
FP5OG0iaBqjhWi005dYkLRlE7sUqpheioVxaCkVFp5nTdNrJTJyZtBQvqA/+ BuuTbz67lhSra7ng
ybX8O767/M5M0gIBWlhtzjlzZp+9v/2db+/5578//gKQw/cCp0pORavo5Zpr apWlkmP7esn3NA6m
Y3vakOtU8/XNUdepVS8GL6IQAt2OW9ZkyTKrntTmZvSSrB/TGkat9P+kUc1s OK6bjPDRcZcOF246
7vy0tEuzjaNbBHqeOVoYl5YMXhdNz5e2dKOICrQUhgSSxTl9Qdcs3S5r475r 2uUBgW15RvJ125/U
rZoU0JhrLsw1t55rrg4pZzDXxmZZ5RpDQmDromkbziLhFJ/Bsw76ZmDCiFFP WmOOwVjHi83sLJhy
UbqeViDCWsmvudJYS4mH2xSAgGQBcZuJOfMMf8G0TX9Q4HB6w/iZSYFIPgjf ms5MJrAb++KIoDOB
JHa2oQVvJbArXO1PYDt2qFW3wBZP+gVDYHe6mUblpwcH47Q8JLBTCSLVUERq NKTpSJC5PyHv+gn0
hsZpMqaMvZQ/K1NekKc0UqXG0TrDWYHt6qjjWBNmNfTQH3o4RoltkHIUGjGV pb/G47h0F8ySVHxl
mgh71moggbdxoh3H8Y5AaiPrKE4J7NINo0mHAkfTxQ3VGlB5BmfbcRrnBHYU TVuO1SrT0p3Qpy2p
ROyUdGtSd031XN+M+LOmJ3Cm+FqFOkApuDU7gQ68oS77fYHcqwkzig+IlRSP mK7nD1uyIm2fPKQz
T2jlyvQcrUnnEIbbkceIQOb5eCuUp6U9hTSKSxQ/I1zV3cD3Mfre9GkG/RAf xVFAkQwW7AXdMo1Q
mClFSgxjAgemnFqqpNu9fkoVWSBJ13H8UIU9MVwV6G3mxTB1yyl72mXpeXpZ DgWPUVwnXKcq7WHX
dXj3I0/fvbfoa4umUZbEOz4rLWuguaieX2YTuBHHOCZf1JUbeJovu4HslkCM gYOwrL90ZgNkCdzG
x0r/n7CCuT+mV2Rwt00AaXoHnymaPxc4+eoZh+1oOo4plChqRV/QpQoJSMyo 7bJAuysrzoIctn13
iQpKb0oFgWsTcwrbPHtZOeygfZs6HEqIvdYoqxp7Ldp5POZKr8oyJHmiINDh NaonP0sOJFvrpZe0
b+reH3jp96LhLmzxnnlPJlDDjCq1BW5U6YDNcoMIVO0aLnaszQWkLgyTuanU 9obX09TYEvg67Grf
CMTHnZpbkiOm6l1dL+hKOSUP9LAfRfjbihi2oBNtiIMaALi3DUn1fVJr1brU rL5hwbwrmCO03Y09
HPfy6Qfut3A+kX2IN7OtD9ClhgPZvgdIZZPbVnA4mzy6gkw22beCXN8qTgpk V3G+Bb8GPgc4HkUb
x3567uUqw/jHGClHZBq6WSNHcI6fi/O4QKs9YTS8i0HOXAVoBf/ew746pn/p KcJ5PvsbupYxk40Q
EdcXVzEq8AiFIrFc5v/f6BDJK8lrv+NmtjW0ObCM00+Z/ompKW6kVvGpAM/p D2Fc7l/B7OD+n9Cu
HPFnrSczEpCWR5QtOYFhdHLnEEaZ5CWkOfehwJSK/B6N0eIKruEqbnCe4uoO rmOa3WgOt4Jks2Ea
9WQ7aVGBzSSnGMNBlRHvMMYXcNHKXQ9+nYAf+aaV82BwIf2PkV+Glu1/hPwD XAyzW6R6f0b3WqqP
UVhGh2Kq6xfEgnPrOR1EjKNBscwwXplCmEUPS/84kZ6FTXzVAG8qjBriDVZ3 sQQRrO7hS7Rw/dXa
NQ2qZ84dit6GMO4/KYx4cNl3ecFLgf9EaB/65/rbwPK7/wFQSwMEFAAAAAgA VVNbNIiHUeZABAAA
8wgAAEgAAABNeUNvbnRhY3RzL2Jpbi9jb20vbWFndXJpL215Y29udGFjdHMv YWN0aW9ucy9TaG93
Q29udGFjdERhdGFBY3Rpb24uY2xhc3OdVW1TE1cUfi4EEyAVjCgVawkWMCyY Ra19i9JiIDVtimgo
VPq6ZK/J0s0us7shtTP9H+Vbv/WzMwWHdqajX/ujOn3ubgIMMKAdJnvPvfec 85zznHMu//z7598A
spACtypuXa8b1YZn6fWnFdcJjErg6/xYruPr5ZrbzEeHc0ZgzIbHcQiBYder 6rJiWxu+1NefGBXZ
MtLbSp0Ctw8qNay225ZKgVvXezpaXHG9H9ekU6m1TbsERg6ZFsvSluF1yfID 6UgvjrjAmablmG6T
+qVDBvteV0KVnEBHcU4gVVo3Ng3dNpyqXg48y6ny5o08wwoMJ1g27AZpyZCW bERLdp+WbBQ/V9Ns
nSVwViDuS3vBNWk3XTpKy6Ylm9Lz9SLRGpWg4UlzLxdC9/r7HAuIVeZ0x3Ks YEZgNHNqUhPLArF8
iN2ZmVhOYgCDPYjhzSRSON+NDgwl0Y0eJb0l0OXLoGgKXMgcZUFZv43hHmqm Bc6p0qdbcaVV8RO4
GqYaLMmfgiRGI9UxhqlU/bRJnfQTz62ng5pM+2GK0kzvEXVN4Kyydl17ydqI nExETjT20ymZxjEl
cL4qgz3uytLbtCpS0TRxhKfDWrkk+13vxXVMC6RP047jpsAAq3yk6QTGM6VT WzPk8l3c7sUtvCfQ
V7IcudCor0lvyVizpWpCt2LYy4ZnqX3rMBbULJ9DU/ofM5lj/b2GI5A93ti0 DNutcvJMs20bnsRx
VyChaK1J2+YYHeLSbwZ60zKpQGClQiI/xieKyNkk+nFONVaesK/X93HMkxZ6 LVieH8zbsi6dgJQT
fb8vH6ytU5uAn+J+Lwooci6Pz67OAbD1fGurWInjc4FS5pRcSq/qLheN1hc9 mMECK+VuSCecuGIS
i3iojh/xfTEq6gl4vQqwcv1+m5d8jYlLDuj9E0Z/0fCC3IkPTdtd9Dz41s8y ia/wUJH4mAcbdMCJ
OxmBcXXvxcW2fzVAvhCm5W+4Pvt50JN1d1MemY4kfohGwxDoKbsNryILlhqA oWNbO6s6AiPssxh/
Z5DgmlJvGv+HXUIvkuD7TbkDffyxJZWsXj+uMd4N4AK/F7n7hecdXK9rz3FJ 69zGZW1yG1e0VN8O
RrTUOzsY11KZHUxO7uKGgLaL9zvwLHT3Ab9XkeB3lE5HCD+Gsxin82sYQgZp 3MAUbuJDalyMQPAR
clwphcEK/t3BYCsUTyXDVdP+wOUtjP2FmccUr+zingCFuV18JvACped4UJrc QXllP44hkgB6j2OW
+PeIPcuo8nxM5w/gaxE+b7qwhC9D/GWstPB/pU4n15mQhqmXKGxB16ZeoLCN uQh/lZ3yG4b3gnmJ
0hb6tRj1f0citDvMzSKxHrEgZQwQc4So01jm/Sru4pswtnSEGsUWSl/zRoTS t/gOHZS/32NpRu25
9itq2jVZO1iTnjBXk6WXof9kpB/5p1wJNc3/AFBLAwQUAAAACABOsVk0AvsV 1a4CAADIBAAANgAA
AE15Q29udGFjdHMvYmluL2NvbS9tYWd1cmkvbXljb250YWN0cy9BcHBsaWNh dGlvbi5jbGFzc4VS
TVMTQRB9QzZZiAFiECUgQkQxCZgFv0ksqihAa8sIGALqiZpsxjC42U3tB8i/ 8Yg35SCUVundH2XZ
m4BJwSGHne599ab7zev+8/fHLwA5FBhShl3X6rzmO1KrHxq25XHDc7WlRsOU BvekbalgDPE9vs81
k1s1bb2yJwxPRYghazs1TRimbLhCM2xHaI5vebIuNH3D5N4H26mXfMviFVOo CDP0bRS3XuprO/oK
Q6LYLrnpOdKqkZr+ZdtyPW5529z0BcMwqcu11OXa6noRZYg8l5b0FhlC6cw2 g7JsV0UMMfRHoWCQ
YbAoLbHm1yvCKQcCgo62wc1t7sjg/wxUvF3pMkwVu/pQoFb0PIbpdPGiG4XM JYjo0dVPhmgEd6nD
UJvwH1YxwpDsNNGX2rlzW7qKUbLEcAT3xIp0GyY/JKXpTLHzhnvgaQeyWhOk 9oxUiOEmxqMYwy2G
+a4Pe2s7HyvCMnaXqvvStR0Vk1GkAg+HW72XrGrJb9MY3qS7SiheeBVv99Mu Nixk9BimcCdQfJch
tvpOL++UVjfLS6UyGddhrW55oiYceuA9pPsQQYZBbdLXX8Uw08JmGSa6yFOR o4tV+rFd2pq5YGs0
zNM6cKdGw0pcHmfAP59BquvzafiO8HzHCtaSgekEbNq+Y4gXMli7eIf/uaAX Gd5Di0t7TV8SKnop
9gGEXqGPBZtN5wAhGkVGMZw9Qfxbk3KVzkgTjCJBZ6xFwBCuUaRB4jqxblCu BOWbZU4QgkqxcIqJ
17M/kXp/gtunmF4cVz5j4BjZfOQIyWTk6zHuB+kApfnwESLJ8O+8MvsdD74o Tc3jmKEyk0hTPBeT
JSEgKQoJiFN7EkCMEWIkMUdjfkjxMUaxQHmiyVcCKS3BQUaMR2CEPiXeE/RQ lTHKnyFE6EKzT/4f
UEsDBBQAAAAIAOiGWjRoAi1dlQMAAHwJAABGAAAATXlDb250YWN0cy9iaW4v Y29tL21hZ3VyaS9t
eWNvbnRhY3RzL0FwcGxpY2F0aW9uQWN0aW9uQmFyQWR2aXNvci5jbGFzc52W /1ITSRDHvxMi0SUq
ev48T+WnJBtk5Qwgot5BUIgG9Q4O5O78Y9gsYTXJpjYbKV/n3uCqjBZa5QP4 UFfXPbvZ8EPDYlHs
9PZ2f7p7umfgy38fPwMYw18C46ZTMSqy1HBto/LWdKqeNL26MVurlW1TerZT nTX5OSfd2eIbu+64
CQiBjOOWDMss27W6ZTRsQ7btjYMOXQIXZLGYC+gLrtOo+VYCk4WvZyDVd8rk q34zAr1tYot1KzIr
pJwpuk5tH2b8EMx86NLmXAw4Bwucik7bV+H5+pazHXyal55sEScOIS7vdQt5 3ffsqu09EMimCh36
lw8bSJBNm6JY7kx6VSCec4pWEqfRqyGOswKnC3bVetqobFjuitwoWwJnC44p y6vStfk9UMa9Lbsu
cLtw5FmjpDUzTII6c+S8BXoq8rXlf6Ikhg6Unl9z3NcbVtXcWrOrRWdblZqN Oki7W5bAT7w7VzRc
xbUkjqH7BGLoEzjuWiW77nEFw3vjv9qUpqWw7QIogSQGMKiR85DAWNRUWknc 0DDC8RM4zvHTAkbk
CWwxMhpGmXECGjPGaOgiM/ZuyS0N40zqQZJJt2kOvmN6E5jQMMmckzjFnDs0 ztuqXwL9h7aUpmDT
LpeXrGpjTlIX9E5dYKslWZWlYOwTlZbbSESvIFzOccrK72ancIHV7ogj37Re 2WOcwJxAKio6gXka
xZLlLXtv+Vh2pdL5JB5hoQcPsUjHNJVPr/IAP9aQw5OO5P15LBGO7uMknmGw B0/xXBUd1Z+KZs/f
OZFl2nCztXF69H0jN480G8otemS6YJadhmtaj2zek74Ol9HYK/lGop+GL05/ PY/RSiecpBifNF75
tPDKs84rzyqtcQi+M+l5ht4ekD5Ga7ee+YAf/lV25+ipKe01Yl7HeZIu+Fa0 XqSVpUu4DEG0H3El
YDXpja1e6p9wdZ1415vo1/V36H+PYdKNsC7VhM463deNsu5mEwbrDF83zrqf m8iyLuvrJlk31cR0
O0VdlTdAxQ3S+xD6MIwUbiBL9809khaRxnOy+huZXSW89EtQ0l3McAlkfT8o YYJ+2Uq0w3TTJ/7v
pI0QIULQ/v2iEL9iNkD8gy76ARY/Ibee2UFe4AMKS6O8Dzv4LQaW9FDKhpIR StNKyozuYCWGdiYD
qq9Z6uIE7f4kvU/RtXiHpGmKfxcLmFFZ9vnx/SyV9AdWKbtTZLOGF4iRvK6o f/4PUEsDBBQAAAAI
AO6gWTRWWf0b2AEAAPwDAABGAAAATXlDb250YWN0cy9iaW4vY29tL21hZ3Vy aS9teWNvbnRhY3Rz
L0FwcGxpY2F0aW9uV29ya2JlbmNoQWR2aXNvci5jbGFzc51T227TQBA9m6Rp Y9ILoYRbC+1bQoUt
xAMSBaQqBMmShSJSpeoT2myWdMHxWut1EH8FT5VA4gP4KMTYjhIUUFX6MrM7 M+fM8cz6569vPwC4
2GN4LPTEm/BxapQ3+Sx0ZLmwiXcUx6ES3CodnWjzcSgjcXY0mqpEm1UwhgNt xp4UoYoT6aXK44t6
729AmWGj133b73U7x/6g+85/xdAIPvAp90Iejb2+NSoaHzKsd3SUWB7ZAQ9T ybBP6txCnbtQ58bS
JLEUVk3lGtYYqs9VpOxLhnKrPWCodPRI1uHgmoMK1hk2AxXJN+lkKM0xH4Yy 664FDwfcqOw+C1bs
mUoYngT/PROSviOM5FbOMycqGulPszxD2AouGJm/BKMxvFfUX5rDdnCZURew hZqnl/+EAjrf1U2G
Z1fWOsimfstBE7cZHDHPkKArUjLsjqX1ab2Kh0W2t9i+P2LYbrX/9ZScvk6N kK9Vttm9C3bnZmDs
o4QK/RQMd7GCKvlVupVQQ5nO9JTI1inikWfkVx6eY+NrXrJJtpoFCbJFtl4U 4DoaOeENbM/AL4is
RL72Hc3Tg3Pc+bJEUM8JmkVRQZCdSNO9vO8OdmdUj2Y6yo3aMsnWHyrKcxX3 86oHvwFQSwMEFAAA
AAgAbwZaNKG/VjJ6AgAAtwUAAEwAAABNeUNvbnRhY3RzL2Jpbi9jb20vbWFn dXJpL215Y29udGFj
dHMvQXBwbGljYXRpb25Xb3JrYmVuY2hXaW5kb3dBZHZpc29yLmNsYXNznVPr ThNREP5OW1q6XMtN
RAURxaXVriiIipIgiUmT9ZKUQPCXh+XYHt3uNrunEHwKH0X/SCqJD+Dz+Ns4 p1u3hMQS2ybntt98
M/PNzM/f338AKOIRw5rj16warzQCadWOHd9T3FGhtVmvu9LhSvrerh983Bee U92V3oF/tHlwKEM/
yIAxLPtBxRKOK+uhsBrS4h0r619mSYb0U+lJtcHwxLS7MJTOUWz53ntJgYpg fWmHIbXlH4hB9CFt
IIV+hhFbeuJVo7Yvgm2+7wqGMdt3uLvDA6nv7ceUqsqQ4bHdY+brDIYTh0IK 9pgDw5QTCK7EpqOh
z3kQOSDKd911iQ3OKtLNIjbopLB8YfaxUVy6MYaVHiLb0UWaMDCOSfL73/YM Q/VARPK9rguPIWnq
+o9XhDovKpXVXOqxHoOYwRUDCVxlmD1LER4pqxLwelU6ofXGl57KYJahzyyV otyuG5jDPMNqT44z
WGAYDoUq0VBI7pblJ+rSBdPuHkNL11tYHMBN3I4IylXN67ukH7W5+VYjlpDX iAJDro0oK64aoZ6V
QdyNvhappV8eb7WboB/3GPoJvS2VHphJ0/7AD7nlcq9ilVUgvUrL+X080MYr ZFz2G4EjXkgNX7xw
goqaDvMkdQr6lwTTY0xrhm4b9J6gPZ0vnCD7FaCbQavRetV6D2GATlMRil6G aNenYYyA0X8UuTbX
M+LWqOwpxveIburLXzrtjtbRM1TZmCpLVJdaVNO43KY6IscaZeW/4ZpdOMXc Xo79yrHPJ7jRhJlA
IdXEHdqSTVi0jS03sZpAJ/4ZpGmdIJpJTJPLOXKxSKciuegEYUVBECof5/Ow xbH2B1BLAwQKAAAA
AAB7ZFo0AAAAAAAAAAAAAAAALQAAAE15Q29udGFjdHMvYmluL2NvbS9tYWd1 cmkvbXljb250YWN0
cy9kaWFsb2dzL1BLAwQUAAAACACaVFs0IY9PieQIAACuEwAAQwAAAE15Q29u dGFjdHMvYmluL2Nv
bS9tYWd1cmkvbXljb250YWN0cy9kaWFsb2dzL0FkZENvbnRhY3REaWFsb2cu Y2xhc3OVVlt0VNUZ
/jaZMMnkADEl2gjCRG7JJDDUtlYTxIZJAiNjiA2EJipwMnOYHJhLcuZMQrTe oQqCSFFaaEW8VKu9
AZIBSaW1V7W12svq6otr9aGrXe1D+9a+dHX122efGeIwIenKyvz/vvzff//P fu+/Fy8BWIXfC6yK
ppPBpB7PWmYwORZNp2w9ameCMVNPpOOZYFssFlJ77c6OF0LAn7biQSOaMIcy RnDXTj1qFO7nb5UJ
aDtNK2N36Ulj8x5bYFFkslRm1A6OmrG4QV2bjT12q8CcjEH1sYKAT4/FLCOT cRZzhwbTKaMrmxww
LGdjnpHUzUTbpCuVBX0CNZFd+ogeTOipeLDHtsxUvJWASoG64XXRBaomQdPq ybiUyQ7FdNvQBxKU
Ef2UUyGivkCkdOiS6ZiRCIbcZbtu69Q9e42ZMu21Ajc2TBmHnkEjkWht7BXw hIihoRbX+uDBJzVc
g5pKzML19DtiFuJAqxxf01E90atbply7mx570KT5qyP/X3pbZTh0y0jZjjEC i69uLe9HpnNo5mFq
7NXwCcyXni4RaC4AX64zQqdi6dFg2IHuttIjZsywHMFaLJPBWi7QOGM51hXt 2WnSNsM50dCoYh4Q
mB+yDKber/tTxqjfNbQCzQI3XNVhL1axTDKGvdmQZVnbcEUtOvauxqd8COIm Fn4+CH4ZhQp8RqCC
Kt0MVEcdM1R+2sgLdE4d8lA6OZTOmLbR2jjlHanOSsvc1U8L48WtAitmoi+s ktDqQwvWXAlN/8fS
WTu43jJjEYf1gu1Q3hDuV4Kf9+F2tLEBk7oVN1MbDDM+yPCJsIYQ2it52MHi VIdbzZg9qGG92t/A
3me4HVRKLJnaWnXFCf8d2CgtjTCbU98eMJjNLh82SY+qOuV88ac4PloqcBd3 ZfIWX8VPmU4vNrMa
GsLhftfPXh+2YCuzXjBZXiuqk00Du4yoMrQP/VLV3QILrzZAvbjXh21Yo6Ec s2UH7aAAi3vEsGwV
y3AqNKhbmc3pbnOPkchwRjSEGxndAUR9vB9jFEdlXDeYKVvDTsaWhsYJKnVr Pc7szHu/S4NXqUmw
WN1pyf2Uhgq1P0QPu+Vg9aecYcVDS0OlOrQZEmOlHLTcHtHgU9t7WO2JtB7L 94MKTFmDDMN9uF9a
+SWOUmdAyUTPoCrpVDS/oKiTHEd02vKkaHmCFeAMwauWCG9WxN10s/Aj01SE tCm9u1tGzIgxEPH8
pJjf0HjlqNDwBPbLJBzQUAVNhumghjmKe0rDXMU9rWGe4r6ioVpxzwgwG8cY 1GJUL77GYBjDWT2R
maLy+jWcwNd9OI5vSPeM/AehvqHx6vOeFp/E8zJXp+hSODWiJ8xYfny6E+5F gTva06kVtn/A8Gey
0UG/nvIHli9bUu9rs/0JQ2efMcWG5WfkLH80Px+dLzzvxvyZy+VYX4GXOaOm fpPcyUjrcSP/NHlF
xn/ISHVYVtriMJ32+3VFTkoP9G/hNR9exesaHpe16sF3BBpm+u3z4ntsMmrt zD9iNJyWif8+zjD7
zmeCp6oL1fE5dTzORwpP3B7UcF5tX+C3jdvdl982Gi6qowm+InjUIfuvIPaW OrvEOZfhWcy03YdE
gzO3foS3pRk/FqhT36N1WdtOpzKdaUtx63TGcvlMPhTygROYOlthlacQwW09 ZWe8+DkLcNPG7ZG2
dR0RDe/I4v4F3mW4Jlsi0DcT5eErc9c/dUEraFb0L/ErWdHvU2morSvUEclb 84Gy5kMmoYelGjU6
TRm12uKH1SqpFvXE8PDlrZFyTAOkXpdWuLTSpT5FZdM7dI5L57p0nkurFZVP REnlA4p0DoR8PvL3
Oq66uT+LtDrQdB51Ac84Fjg/ZxyJhfytcey6hVatouZbid6CG7hzrZLDIiwm lZyfXggH/UYXPco7
ZaS1k9DL5E/zOJa6Khyocv6GXBXtVNFBUzsdNX4FUFBTq9RIznFolqNwmatw vetOlVS4osiTuQ5U
2FWzcZIXVQX4KsI3EMyDxkKMdrigCyVoU+AcFhyH1lSzModPv4rKpprPkil2 ZhN/uxn/u2hcDxZg
yyRtC5U2h7sZ9Y62z+EWpW3Wn1XexakJtPQ1lZ3HbXdO4Pa+cnLrulZWLxpH 58rqeeMIN9MAHm3q
a+ZRd4unzlPzhRx66jwT2NI3u7yMu1/M4Z7ABLb1NV9TwfbfPg5dHnq9HnnY Ul5XHqien4MxjkG6
pdeV52B+HHH3tIjJjyESJlkCJj0tzHAxzHAJmMy0MNlimGwJmNFpYcaKYcYc GJn7E/AGzuOB5tOF
jP8Drfy9hzV1LwtyG67HdlbRDhblAN/yUeY2xreogXbS9Xw+9SLOm4O8Geep iRR2YRQJPIok9nN1
BGkcIz2OIX46hjl7LZwmHUcGl5DFuxjBh5T4I/bgI9I/YQz/5DPoX7gf/yb9 D99C5XhQVOMhcR0e
FovxiFhKugKPipvxmLgNe8Va0hD2iQgeF1vxhNiG/WInDojdpCk8KR7AQbEX h8Q+0gN4ShzF0+IE
joiTeMap5LWqRlUlO9yDeIgV7BPH8DC5WZgvDuIR+lSG1WIIj2EvqzxK3fvw ZfaGR34K3f7K8Y6Q
fRaQRZjDk+M4JNmkwx6W7LDDHpFs1mGPSnbMYZ8ld6jmqzk8dxwLyB92+XmB HF6oeanmmxfw7TNM
2Xcv9+hNzmR8jt1+kj35PHvwFJrxAjP1Ijv3JXbry9hK2o9XcDdeYz5fd7zW lJ3SawfrvoIP73Ml
z0alC/xfmsPZHN6QXqhVTq2G1epNtcqq1Q/UakytfqhWelkOP5HyLh12adal Y5Lm7xW7dprD7gzX
ZxHAGxwt59DJ8uliqHtxnoV3gWX4JkvsIktpYpJro65rQj4WXNeCpPJMtsGR y1U/29l8e5JweUH4
rZLCzxYLv1NS+HRJ4UPFwh+UFL5YUvhosfAfSgqfKyl8uFj4oxLCHvwUP3OF t3FXzvlF6lMxN9BU
dhbveXL49dZAk+csflMm2eIv7F849/9K/m9E//ukr8UipUFyqsf491tH9nf/ A1BLAwQUAAAACAC0
VFs0VPMU3AcFAACqCgAASQAAAE15Q29udGFjdHMvYmluL2NvbS9tYWd1cmkv bXljb250YWN0cy9k
aWFsb2dzL0FkZENvbnRhY3RzR3JvdXBEaWFsb2cuY2xhc3OdVetW20YQ/hZs ZBQlEIdcCCEY0gbb
GJQ0lyZASQkEcOMQGigp9CqkRRaxJSLJOPR+eYq+RXNOMT3lnD5AH6qnsytj ckIMOf0h7ezuzDcz
3+zO/vPvX38DGMGvDDdNr6yXDbviO3p52/Tc0DDDQLcco+TZgT5pWVP1tVnf q2xOy3UFjCHl+bbO
zZKzGXB9Y90wecNqX6uV4aQtzOaNMl/iL0KGy4VXzYJqqFcdy+bkUuyPMbQ3 DBiShQ1jy9BLhmvr
i6HvuDYptI07rhNOMAykm2ItFnmpNJZZZohNeRbX0A5VRQwaQ0fBcfl8pbzG /SVjrSS9eKZRWjZ8
R8zri7Gw6AQMtwv/hx+K8sSm4XM3lIEw9B0dKennGskc8ElKruVV9bxUWvC9 LcfiPqUl8ukS+Zxl
yLy1HcMpin/doVy43NFwIaKlm6FnyudGyFNGyuXV1H5OKZlUAj0MvUdmoKCX QQl4GFX5bPpQ5WTY
fUipuIx+hgS5qZPTaUrXEXWTJDPMNC/tlFfe9AIn5GOZpjoifN8TtPYfC6Pg KsPg2/jLR8SnVQwi
cxiakt32KqE+6ztWQYoKhhji6fxqZDisIocRBq1s+LbjznHHLhJXLK/hGq63 0+Z7dG6izaeOFRY1
3IzWb9G1IG4lKllcaR5tpCK5fh93RKR3qXTNtdc4lW5MxbjI6ISsdsqluzea wAStikr1HZHntBEa
Ciap9Ol8frWe55SK+5imq98IWai9diger21wMwp0BrPC1RzDpaN6g4KPVDxE RkMcbe1owSMyoAO9
xf0w4jLvThUNP1jyFpwXvBTQJU7nM8TuYyyopP8xsVgVvM45bqhhkbilQJcI VPhukxdWsPsWR4GQ
zP0JmUpGpOmxZ2JM8GIWednIW4L+I5uDVCCLhF3nmk5d4ZhyiNi8Zws+DwJu MbSmRRdU7P2b2ZXO
HL6aGtZgCh4sDQoSgtx1BiRQpNv5uraCDUqZP68YpaBJUVc1lFBW8QyuCJ7v t8F+cn5kG6FINvFc
FMunvpx3t4ySY6WiYymehAQohcGFEjcCnktRubgvOhbtpNY9PxUWuWxf8gkZ SWCLlJu/Uo+IIsPm
+4/VC0HcJncf+L5H3meOe10O0/jmnvcNvlWxje80fA1DdNsfqAUQzuzBO6cu ehXf5DOOeHl63vym
jAhw9KOFEED/FnENhCQqRmMbmHjl6H+CZhNCQ6xmh3Zx8qXUO0V/Va72kG0v Okg6F2mhE6dpFFIS
ZwhDYHW9Cevc61gpwhpoinWeMGK40Ihrro6lCayLQ8lLNQw0EOlrpf+7hHiV tAdfQdUiVCldwRmJ
+g5pSlR2ForkYnsPgytDrbvIPtpDbiVOkj4/3Hl5BzeGOzt2cDs3XMPoHsZX crT1wWisO5a8V8OH
3bE93F9pi7fS6oMa8tk9PFzJnU5gF4UdzItNRYmJzdF4dzzb2VXDkx18kv0D 893xGpZzvzdSmJFh
DlPCI0Sgjou4RhRdp1BvkHSTuvIt3MNtTNM4S7Nl3MEXuIsvaTQxChdjqGJc pj4RJRWlLqWn+BSM
sD2skNRCHjhW8RlaCTuPzwkpRijnCO0rIjEmTlydeJd0GI3prIi6Br4DmyQ7 6dTg/YaObA1BspKs
/onvX2Z38eNBUQbk8XpAKDM4TzH3UhH7aBwgj1fwkMpUkNFqEX4ULck/waz7 1mkUe3Hh8ICqNrn4
5BXjeMP4Z6n1y39QSwMEFAAAAAgA0lRbNP+lCGgHBAAAhwgAAEQAAABNeUNv bnRhY3RzL2Jpbi9j
b20vbWFndXJpL215Y29udGFjdHMvZGlhbG9ncy9Ecm9wQ29udGFjdERpYWxv Zy5jbGFzc5VU/1Lb
RhD+zj8wCAUcN0BCS1CANMYYBIGmbZyG8KMENw6hhZCaNk2FdLZFbcsjyaF5 q3ammJkw0wfoG/Rl
Ot07CejgGOg/d3t7u9/ut7t3f/3z/k8AM6gw6KZT02tGuenaeu2d6dR9w/Q9 3bKNqlP29FXXaawE
ylWpSoAxaI5b1rlZtRse1/dLhslPHU6sogyJEI0hVdg33hp61aiX9S3ftevl HEPXI7tu+48ZFtKF
/+J5B75+YFtlTmlsVXi1mmv3ntxhiK04FmcYu8SbbFUkoCiIoZcB3bimIo6u HkTQz9BfsOt8o1nb
4+62sVflIlnHNKo7hmuLc6iM+RXbY5gr/M9yEc/ehuHyui+TYRi9OFuyz54S OisvGdUt50DPS6NN
13lrW9wNqQ0JajcZJq/sx9BHqZdsosHljYqPgwp9wjAsSHiaX+Gax6vc9Lml hZy6cZth5EICCWjU
eY/72/xX6vxAuq15MusxjCu4gwmG7jo/CGuTNF1u+Dyo3BLJDGudu7vi1BqO Z/s8N9nRRuTtOqKq
dy6FSWCS4d5V4uWDuk8pyCDbDk1k3zlNX3/q2lZBignMMMTT+d3AcVaBjjkG tWa4Zbu+zu1yhWrF
8irmsdBDl5/R2ASXr2zLr6j4PNB/wdBDtZWo5DHeOdvARNb6IXIi00fUus7W e5xa91jBomA0eL5n
y81SibsJLBEGNUYjbM1rkuA7mkXjcjIgWjdWiKFo7jK+pjduNBq8bsmhbp+D wofD5FQ8xbpAyDNE
FxWlG89oTnwnMGK4kW53Jafn2BBOLwSJCXppF7Rl1fCNBL6jSU3n87thW7YV bOElw7XTCguzczP8
Ym+fm0FdX+F7EapINOUTFw25wvRQC82TA7nKrKTrpWNErmr45YiGXfibSAMR y/ll0+Wexy2qZVqk
vQdTvHQ6K1tO0zX5mi1+uMG2v2tGsKZHGiFrgNFO3yZJcZIT9I8SOJ1+IH2U 9uuZqSOomVTfIZKZ
LC2/A3R1ndaUBBgixxvoxU0kMYwUabTAER+RHlIawCDBkiRDRWSgoTDQOp0j tKsi0K0g0FmMPok1
EsYYlfiDgX2AL6UBikyfufjtPoQ6MpUabeHuedQxQh0n1IkOqJ+STqDeQzpE /ZvyjtP+5hiZ4lT0
CNPPj6EXYyTd35hO3j7Eg+lk/yG+zE638NUxFotZunryMHYrdozlYmr1CGuZ P5Bs4ZtUgZYWNlv4
VlxuFbviUbLdaWE3+9tpojPopXWKaGUprWkMk0ajD+Mu5jCL+/Q25vESC9il /TUeSCILQYqnRN5Q
L38kAgpZviYpQvpn+In0UcwS1s8wiGRMDFBIc5520a545gj8rGqKrNATMl2S gdTAKAhEcklalv8F
UEsDBBQAAAAIACxVWzRKJuWX2QMAABkIAABKAAAATXlDb250YWN0cy9iaW4v Y29tL21hZ3VyaS9t
eWNvbnRhY3RzL2RpYWxvZ3MvRHJvcENvbnRhY3RzR3JvdXBEaWFsb2cuY2xh c3OdVH9TU0cUPUsC
gcdTYopYFDVo1QCBhwWUGquVUCAlIC2IDdbaR7KER5O8zMuL1G/VzpQwU2b6 AfoN+mU6Pbsvho6R
H9N/du/uPffHuXf3/vXPH38CmMBPAjN5t2yV7WLdc6zyu7xb8e28X7MKjl1y izVr3nOr6ebloufW
q/NaEYEQiLte0ZL5klOtSWtvx87Lltl7VEigs6jMBGLZPfutbZXsStFa9z2n UkwJdD12Ko7/RGA6
kf2vt9q+b+07haJkKuu7slRKtVuPbAqE025BCtw6w5pYExEYBsLoFUA3Lpjo RFcPOtAn0Jd1KnK1
Xt6W3oa9XZIqWTdvlzZtz1Hn5mXY33VqAg+z/6tkZNtbtT1Z8XVKAjdPz5n4 ZIvWcYkJqhTcfSuj
QWue+9YpSK9J8Ioi+KnAyLntBLoZcjFoUX9i5GNNiuY9afsyoPGMssDCyQVP u+WqW3N8mRo5BVPx
PVdRHD7TTQQ3Be6dJ14mKMKwgThutbsmq3du3bcWPaeQ1WIEn/F9JjJbgeFd A3dwT8As217RqSxJ
p7jrC4iMiRGM9lA5xh4GypdOwd81MR7cTwj01KSvvdLi9snZBhDdrkncV5l+ LnD9ZPS2LEUwbWBG
MRr4sDlz9Z0d6UXwUOAaGxOn73itTsF34wU+w7hubLwbXwhcTrT3NuCdMjCL x/yMdrUqKwX97tqh
2Y8HT5l4gqfKw1cCoaeG0Y05PirfDUAm5jGktF8LRFiiDfmLb2KRMUlpiZ/g lCbN274dwTc0TGQy
W80mZQ0sY0XgQqveCvYBvefbezIfVPk51lSob0lP/z7VnnO8JTY0//5AU52V Nj3zUdHUbM4E1b5T
P7oGqFjuz2uerNVkgTVMqLS38Er95R8EjHW37uXlgqNG0NAJw2VCcccwx1mY g11w53Sj1Ek5wnHH
EDy94n2I+6XRsUOYo7GLB4iOJrn8BlB1iWtMOxik4WX04iqiuIYYb+KBIT5B P3dK1A/QLSUdqkMH
utIMtMRzB3dTBRoMAh3HuKh93WjGiGv/AwG+5d+k7iq9CcYfanq11FmRGv0d 0V9b7rr05V3txgwA
gRtSuc4wgfHfTK+T+5sjxHNjoUPcXjnCnVyYUmJ1PHrjAMnxaN8BrOR4A1NH mMklqXrwKDwYPsJs
LvboEF+quA08i6W5NLDQQEYpl3NdnSFiVxv4Lnmc1gS5gQPCoNQPi2wmyfU+ p8UUpWms8FW+wANs
cX+NWZ3+dJBikL6W1rFBAgaRLyh18H4Zm3jJCk7S5/fIkWRYvZYmzalWjQ7x +rjkhi7vHKHp9jpR
/lEj3/wLUEsDBAoAAAAAAEe2WTQAAAAAAAAAAAAAAAArAAAATXlDb250YWN0 cy9iaW4vY29tL21h
Z3VyaS9teWNvbnRhY3RzL21vZGVsL1BLAwQUAAAACABpVVs0r3EHIyUBAADN AQAAOQAAAE15Q29u
dGFjdHMvYmluL2NvbS9tYWd1cmkvbXljb250YWN0cy9tb2RlbC9Db250YWN0 cy5jbGFzc41Py04C
QRCshoUVBFF83E2MgonMB2i8kOhlgyQQ7sM4rkN2dsgwa8JneTLx4Af4UcZe xDt9qOrqd3//fH4B
GOCMcKGcFVamhTfCrpXLg1RhJax71pkYbmUMIlw5nwqtMrNcaaGc18IXeTBW i3Emw4vz9mm+0CrE
qBLqdyY34Z5Q7fVnhGjI81qood5EhD1CJzG5HhV2rv1UzjNN6CZOyWwmvSn1 NhiFV7MiXCa7XHlL
iFMdRtJy50mvnyzkmxSZzFMxCd7k6bZgul7qzWFDQoP1WHqdB8JNr7/Tnkfv iiXPak5c4ZV+MOWl
7f/soNwanaPCj7IxUvk3Y8xKMBNz7foDjXd2Kmgy1ssge/uMrb8C5jZ3Ew7Q 2fAhjjbcxTHn+cNN
9+kvUEsDBBQAAAAIAK9bWzTXvUParwMAAMQIAABJAAAATXlDb250YWN0cy9i aW4vY29tL21hZ3Vy
aS9teWNvbnRhY3RzL21vZGVsL0NvbnRhY3RzQWRhcHRlckZhY3RvcnkkMS5j bGFzc51UbXPTRhB+
zk6QIwQJLriEtJBSN5HsxEp4p04pwRDq1nkpCaE0fTsrF0dBljySzIw/84fa mdZk2hmmn/ujOt2T
TAKxhprII9/e3u6ze/us9p9//3wFoATOcM3ymmaTN9q+bTY7lueG3AoDs+lt C8es9LaL27wVCn+J
ZM/v5OcVMIaxPf6cmw53G+ZqfU9YoYI0w5TnN0xhOXYrEGbb7gFVn3j+s7pw rd0elIJhhhPhrh3k
5yiJ2vtnUWYYWe+44a4IbYuwFmzXDu8w3NSPA2ZsMgxVyIIhrRubGlScUjGE 0xoUZEaQwhjDaM12
xUq7WRf+Bq87ZJuteRZ3Nrlvy31POSSvxXDjGHnk5+W1GiJc475wQyqnXjta 5rLRpyInY5BgD32v
3VJwnmFWNwZKL/Ioa8jhgopxTDAwj66dlEGG0q7xunD+P+v10LfdBvmo5PPA pZ0I6Aq6sTVQUpTP
J7gs8/mUIXcU9l57Z0c22GcMCsGv8CZxclbvj08w09AljHHQzYenCooE8Jw7 bbG6o2EWkypmUGI4
p/cjxR0zp2IK8wypST2Dq9STvNUS7jbDTJJLLTlxyuo6bkikmwwTevWddrel 3edEipHBAlEQerGJ
hjvQ5dmXDMMNySFDcaDaxoTTzcVrWqYHJIXagspdJTtxXwSWb7eooxnuJvbC m1Nib4dbwvRF4LV9
Eo4glGMaNzqt+NusaHiIryRrVYYrg2T29iem4BsqFLcsEUSzp3qseVFJbKdl rKioYZWahDBLMWbp
EDODb/snZMtpN2zXXKwHoU9Gj6trkULBOsO4/XYxlnyvGR8zPEpoqj7N+5Va w2NsqtjAE2peL+KK
av5MdIjbpM/3JBFT2bWdbRpW1ChJTG8ljQp1PYq/ZMtxOZFc4pL0Y9Cqriv8 isODQASYQ4qGMiVH
75iczLSOQD7D9Ko4SXuNpFtkl5KawkuMFop/4MxvtEshK3XRyWiE8wFJGq1S exbnaGU06j7soSzQ
Km0zxb8x3sVHvx5gnIh8cpF/LraJ/SPpY1wEo98lTPaQXiCNIVqLEml5pov8 yl+YekpCYR/mS1zJ
Xuvi1uyrLsrZL0jq4u5hsFx0uYv0fwkqQV6m6TdNqwxeiGEPghd7wYfp21/E PUJQybqC+0iT9gGW
egn9QCdpiV34HWfi6329j7Xl7KOZfXx3GPt0ZGVQuYq0L0QxJ2PPOGYkPY1i jhIh32OLPBnh/5hc
xPzRIl59VxFJ+1Nk/zN+kSRFGvlk/wNQSwMEFAAAAAgAr1tbNHzbIIr+AgAA GwcAAEkAAABNeUNv
bnRhY3RzL2Jpbi9jb20vbWFndXJpL215Y29udGFjdHMvbW9kZWwvQ29udGFj dHNBZGFwdGVyRmFj
dG9yeSQyLmNsYXNznVRrTxNBFD1DKVtK5VEBRXygIrblsYjIq4hgCdqkIALi B/kyXcaysN1tZrcm
/VeYKBoTjZ/9UcY7uxtebSKwzWZm7p577rlnZvrn749fAMaQY5g0nLJe5qWq NPVyzXBsjxueq5ed
XWHpuXC5tMsrnpArNHdkbXBCA2Po3OefuG5xu6S/Ke4Lw9MQYRhyZEkXhmVW XKFXzZAo/96RB0Vh
G3shlYYoQ4u3Z7qD4ySicHkVWYbWzZrt7QnPNIhr3rRNb4FhOnUVsvQ2Q3OO EAyRVHo7gTiuxdGM
9gQ0xFrRhE6GjoJpi7VquSjkFi9ahE0WHINb21yaah0Gm1VbDFNX0DE4odoq CW+dS2F7ZGeqcN7m
bLouREmpixRb5h7XcJNhNJW+kLpX0qlWsgn04lYcfehnYA513UhAjFQXeFFY /xe96UnTLlGORjlr
vEyedafqAVT3Ph6oug8ZomSHrDFkLqRbNUr8SeLPE1YsC9eQZoUsZlhsqO70 sd3/yA2hS+E6VUmT
cwyh7q1aJTgsuQTSyCiZwwwTF1F3ds81jJJ73DCE61+G/JUOcK6hfzrG43TP nzD0EOdYwDl2whnD
0/orW7GqJdPWl4quJwn0Lr/uBzQ8Y+gzz5qxIp1y8JlhI1UvoS5yOasTmMZM HFOYpRvu+HtFnh+I
Gu1towPVRhuT2zOtXSlI0ONGO/2h0eGNb/r1V0x1f/sbWzym8hgSedsWMmdx 1xUuxtFE/xIkjt5O
9VdBYyvUE6U3jjZaJ2g2Q7gmFcl8Q0dm+Cu6PtOqCUkV87/M+TzXaZagUUW7 0UMjo8t3I2SZp1Fh
Y8O/0XeE24fHHC1+zqKf3xtggnx/dgd3weh3DwMhU4HGiKqimFZHjjB4eE7P a+og7/MNBMhjvnjI
F6XfIwwRmqxGKmTeobXC92a+oCvQOfIdE6vJSRrmTqq0+6i36MAmrTdOVeoN KvmzrKpEGI16f+5X
WsCLsNJs6EY08hPN563YOWVF9JgwGkin6KKPX8JL1ZAfUU/yH1BLAwQUAAAA CACvW1s05HSlcMMD
AAAMCAAARwAAAE15Q29udGFjdHMvYmluL2NvbS9tYWd1cmkvbXljb250YWN0 cy9tb2RlbC9Db250
YWN0c0FkYXB0ZXJGYWN0b3J5LmNsYXNznVRbc9tEFP7WdiNHNXHqJKXkUtKS BtltrSQUAqQEinPB
resCzqST9gFkZSOr2JJHl7R+4IfwxhO8mksbhg4wPMHwo5ieXal1xs5M09ij 3bO75/Kdc77d//7/
/U8ARdQYlky3pbcMK/RsvdUxXScwzMDXW+4ub+qleHlj12gH3Nsg2fU6ChjD 6ANj39CbhmPpd+oP
uBkoSDJormfp3GzabZ/rputx3QudwG5xvdzv4xRDxvLcsB0fkHHlsHVoxyDK d13vmzp3zEasucIw
9hzomhEYLxwoZtPw/bkFhjOVHryS2CSb4VrHCRo8sE2Goeu2YwerDEktv82Q KlGkDF7DiIoURhmu
vXpV5hYV5BiWtcqr267kt0X0cRVjmMhAQXoYCbx+MhxLCt5QMSkcDUeOphmy Fdvh1bBV596WUW9y
hlzFNY3mtuHZYh1vpoKG7VPYk+TAMOIY+7Zl0GrLvcU7DBNaKX+oE7XAsx2L FLM2ufR12f6iZe+l
MccwHm3S4BCdbNeJTuYFqk6bwLESg2rxII4ra93PwpWBxucHdTJQcVoU5grD PHGuGHOuGNpFmWJx
gHNpFAl2n28FC0S6PderGi3Cd0kbzDXfj4eCL+EdFYu4xnC+d1h15fEa39tw Q2d33fNcT8F7RPWe
zlbDcx+KRil4PyrFbe77hkWxx7XBQlOoD7Gi4gNcF60YOI9Zt6piGR8z5I/T 803RMgU36LYeR11c
TwXUt9m+MlTdIMrzkcnbotkK1qnAhqi2yDDqFLF0sHsMp6UaMVnSYqRHiYrt B7IW94+4/2nDNHn0
PJRPdElLR5b4It5SiUpVakjNDT2Tb9jiJk0d7aQoPNDLVyaSexIZ93GB7FOg VwlJkuj2AzQPyzkt
uEpnGYjfKZLolaIxS6uasKJ5pnCAM4WnGNsh4exjnCN5UshTjzHzk3R2nsYc qYPcpch4lKgxTfKb
tJOJnGAWF4SuyCgO8BmtEkJjanTzewzlLnVzb3ef+yMYSRo5wd4jsA3p62yk H/mSkoY8GP0LuBx7
/ZfshGX9ys+4uvMPpu/m9N/w7s4vuPojsk+xfO+rJ/joAJ/89QOyl//Gp98h XfgV57rH1F+L9Ge6
rCvKSDgnsEG3YBXrNEvs9Ck0+phDQLhCLGAfW3iI+3iEr9GRucxGKKNcpLRJ FWFSKlNTEiTfxK04
q3uiOTRrqT+wuJN8GdRal7RH6L2ffIFpSNp/e6gnWhw7jQpuk5YkgYw2H3dm qDB1gDtRT3o+dqWP
hPw+l+MX+FIyIEERIaXJaH4GUEsDBBQAAAAIAABYWzTJ0BB17AIAAC8HAAA9 AAAATXlDb250YWN0
cy9iaW4vY29tL21hZ3VyaS9teWNvbnRhY3RzL21vZGVsL0NvbnRhY3RzRGF0 YS5jbGFzc61U204T
URRdh16GlkHuSBHLRcTp9DIoeANEodweGjBCmvhiMrTTMqSdaaZTEj7Bf/FB EwtGjR/gRxn3mRmw
DvNQE19mr7PPXvusfWl//vr6A0AOewxSyawrdbXasnSlfl4yDVst2U2lbpa1 mpL3jluqrQpgDPPd
RAsIMUQbqqUZNkO60A1n1zJbjVWGWEW3mva+WtcYhgun6pmq1FSjqhzalm5U KSDe1ChF2Y0Q1HLZ
0ppNhr7GiWlo+636sWYxiFpd1WsbV5e9Br11dN4gBsuTtDXd0O11hvfSP2i7 Iea/efKpIkM4T28y
hKRUUcQAhuMIY0REBNEYejAmQkAvR7dFxFyUEBF30R0RfS66K0J00bSIftzi aJZhoKBfNedIPa45
vTVLaq2oWjo/e86wfaJTu+SuusJ3gs+jqtnXjR6VUkEzG6CY7b8mIpJn58+k b9HxdecA+8lx2Dlo
Orto3J9/s1WpaJaAHMOg/07AInHP1FpLO6gwLEgd6g6OT7WSvRogWMQjLMXx EMsMY9LNe3dCT+JQ
8JQ2aqYXz2mp1EZDM8oMmSBGIVg1PbWKNZ7oBW2pbbp3Il5C4s5X9HvgnfF+ SVkp1dVk3H11m0Zb
725VnkZ1aLaskraj81kPdc4xx+VhlpYlTP8LAlnaO0I9fOscG/Ns3LN9nhVd y3eNbAyMOjNI3yE6
fSc/v83IlxiV022My5k2JuRsG5NyItzGlJyItJGUE9E2ZuQxoY25T062e/Rd QIy+MinKEspRfgUj
WESCBjNNE7qPJaSxjHmKeuO+Q74FsoQc/Ywjp4IejpwaQhw5VYQ5cuqIcORU EuXIqUUg9gNIXiUK
WZ4tIn/G1Mcrid4TK44E0Q1wJRBOBZJn/OSNQLIcSJ7wk/cCyelActJPPggk ZwLJk35yMZCcdcmO
spBzl/wG5S2X/gWPL/FseOUC6zwfmQts+LO+68iavM66iXyApHE/uRIoaQvb AeS5Dz6yEUjecaJ2
fwNQSwMEFAAAAAgAdFZbNFAvrG4cBQAA1AsAAD4AAABNeUNvbnRhY3RzL2Jp bi9jb20vbWFndXJp
L215Y29udGFjdHMvbW9kZWwvQ29udGFjdHNHcm91cC5jbGFzc5VWW3MURRT+ OrvJ5jIGJBAgEhBJ
YGdzWRJQkSAawsVgCEhCAkTQyWaymbg7G2ZnweDlCS0vVb5piZcqfcqLD1Bl QKSkeIIq/4l/Qv1O
z2STbFZr85Dunu5zzved75zuzZ9///4IQDcKCmYql01mrXTBc5LZ+VTO9a2U n09mc1N2JjkQfp7y
coW5GJRCWyXmMUQUjNSMk5k64fqeY+cVNg7NWtetZMF3MskhJ+/3KdTMWZ7t +godQ5VE1SToFnWt
rK2wKQiYsdx0coQgbppntS5dRufneK4GFOoyRLJd2yOB9qGcl07aqYwzl7eT s9NWyg7ZhDZLrI44
ruMfVeiPr4PWWjID5hi5DtBWIRI3xwxswKZ6RNFkIIbaOlRhi4E61Mtqq4EG GLLarrBhyHHt4UJ2
0vZGrcmMzjWXsjJjlufId7gZ9Wcc5hVL2/6wVmRz3FxLIzCgJAENEYXf50Ll u+LmOpKkOHTTWFvi
a6Ek4Y3TjmcP0zc/MMMje4oYlel43PKtPpFpL/bVU4g4mbv2jSC1WmtKt9I8 G7aycDpUNWpE0y6F
puXu6/c8a16KHUOSKsYHg9r01GM/ehUaly0Do4MUjvAlOZ+dnLVTfp952cBL eLkBL+KQQrUdcNxb
GUWFBs/O5q7bYWo1wZeBV4OIRymBkz+RnfPnpXiC9Tr65eSYQj3LWLxdZtyc qBQzmnduBs0waOAk
Tkm8N4jk50QZIsXjE2USLbNn4DTeFPchhX0V4scwzC6hnrpJlu6eQu//l3Uw DFD00PU9h7ekVc4b
eAaNUulRhT0VXPMYxuoxjqb/qOmY1PSSWFxm62WKHJPrpMi2Cyq6KlcDVwPa 77DQAYzFQWpqsKZL
ZnkhV171KdjiMM27tS5CMcwQw111Oy9Wdp2CB6Ai0+JFnsV7DXCQUUhU7sjG 9DLMvalM5nzUHf4N
svlHcgUvZZ909Ou4imS3uGE39Y3yN66aM18Brqrk1ZVZ3lyZ5cWVWXqHcwMU X4GNHJ/lVyb035y4
z7+ORTQnOhexLdG6iJa72us5js2o5riflr2MeoBxDqKJ92EHdxOBP1oFVVYa X8lKM6iSleYQ4e5O
7AqRk5zFqjrxK7bdKULV6M0+HdoIDILQXD/PdNc6t/xS4jxQ1vkF7Cnj3FyK fLqscxvaQ+dTtJaU
GhIdopO6B3NZp0ZEOJ6n4wgzH9WhmgPzIJReJXgmDDrQGQadQVRbtZFR91Ns SDzE/ku193FgEd2y
1fEAr1RhXKOVVuUy9Z5gNd6mtleY49UVqG0Bql4dRp9GPVJEvRamYgrEE+wK kV4jkiwfgD+it1Gb
UGRRAt2iW22K0DY2YZrQaUI7iGN2BbxZhDeL8MdxIoQfp42o3B7A75ApwGXj /4HoA5ypwmOcvRPh
x50Sja8R2mND5FeUq32pXPJehiAFWguVLqn1EzTK1HEPIwto5fLCU+48xPil +7i4iAuyw8OJ0jxv
EOx95nkT2/EBpfyQEn68Is+uYp5dLMMVnefVIoWPQpl7VlN4dwG7BfAJWkLc SZnvIRVqfmGZxk7E
OH7C8VPS+Iw0PudV+IId9CVv5VcrqPQUqfSEVKLyj0ZI5TdEdM8cW03FXEBv oEb0bsAhfSZydAFb
O1t7H8M5HN0eTbAxshHciqjWzkc///PXMreEfmW+JrdvyO1bcrtN2b7jffue uD/wtv2IQ1z34yfN
82DAoMjzGFvD1fdzF3KYY1Tp2musboS+dTqLKM/zGtH/F1BLAwQUAAAACABD WVs0Js0FLWYBAACu
AgAAQAAAAE15Q29udGFjdHMvYmluL2NvbS9tYWd1cmkvbXljb250YWN0cy9t b2RlbC9Db250YWN0
c1Nlc3Npb24uY2xhc3OVUU1LAlEUPU9HRydLGzU1bdFODZ1FSyMIITeDQYbQ cpwe9sSZF+Mz6F8V
FEJB26AfFd1R+6DVtLnf59zz7nv/eH4F0MYew4ErPctzxvNAWN6dK33luGpm efKKT63uOh3w2UxI
XwdjyE2cW8eaOv7YOhtNuKt0xBm0QEpFbHYUul4g5zcdhuSR8IU6ZojXG0Pi 6NJUBjpSBjQYDFlb
+Lw/90Y8uHBGU85g2tJ1pkMnEGG+LmrqWswYWpF2r59C2/UxV+dL1a16IxJ2 pTuDBJJpxGAyNCLD
dBRIabgvhR2Gk/o/Nto/Jx+oQPjjTrcxDA9VNlBEhcEYyHng8lMRnqPw56nt EI19EqzRpzPypJ+i
GMV0a7Jpyg7JM/KJ5gIbD8t2hqyBGNltgprYpCizGsIWskuyHPVWBH0iDXu1 5iPyb8g3X1C8ZGYp
11tg94lyKt9/8RI+TrZMAiooofqLu/bNXV1O1z4BUEsDBBQAAAAIANdbWzS0 dWXApgAAAAEBAABC
AAAATXlDb250YWN0cy9iaW4vY29tL21hZ3VyaS9teWNvbnRhY3RzL21vZGVs L0lDb250YWN0c0xp
c3RlbmVyLmNsYXNzjY4xCsJAEEX/xJioWFh5Bi3MHiBlRBECFoLYrpslJmR3 ZbMRvJqFB/BQYgJa
CeIvhv+Hmc97PG93ABGGhIUwiimeN7Zg6iqMdly4mimTyYptkndOi9pJLW0I IkxKfuGs4jpn22Mp
hQvRI4x1+1Inp3YtM8Jhlv5q/hSvrWnO8V+nS+54PN8TRjvTWCFXRSUJ0y/G qMMLCB58dCKf0EfQ
OYTt9DB4AVBLAwQUAAAACAD5W1s0prHnBc0AAAAHAQAAOwAAAE15Q29udGFj dHMvYmluL2NvbS9t
YWd1cmkvbXljb250YWN0cy9tb2RlbC9JSW1hZ2VLZXlzLmNsYXNzTY5BbsIw EEX/QCEUWqgqNlyA
ZXyArlAkKgQiqNDujXEto8RGiVOJq3XRA3AoxBAWdPM1f/7ozT+df/8AxBgQ xsrnIpemKqzIj8q7
IFUoRe53OhOzGSd6ro9lBCK87OWPFJl0RqTbvVYhQpPQev9IP1eE18U9XofC OvNGeE68K4N04Utm
lSYMrOKFMIWvDrGx3x10CFGSLjeTZEMY3mIWx3jr3e2mR+iufVUoPbXZlXIv Fl+ftgkNPACsI7TQ
BjNr98i++88/sXKpeu5fAFBLAwQUAAAACADyo1k05BJrFMoBAAAPAwAANgAA AE15Q29udGFjdHMv
YmluL2NvbS9tYWd1cmkvbXljb250YWN0cy9QZXJzcGVjdGl2ZS5jbGFzc4VR 7WoTQRQ9N9l0a7Jp
a1JrW6ttWj82BnYfIFKQYiCwqFDZH4I/JpvpOmWzW/Yjksfyl8QfPoAP4mOI d7KBBILKwL1zv845
c+fn7+8/ADh4QegEycSdiLBIlTuZBUmciyDP3Pcyze5kkKupNEGEvVsxFW4k 4tB9N7rlgokq4TxJ
Q1cGkbrLpFsod7g2NmCcJJ2ZqBG2XqlY5ZeEqt31CcZVMpYWTGzXYaBO2PVU LN8Wk5FMP4hRJAkt
LwlE5ItU6XiZNPLPKiNceP/V3Ce0g1SKXA6ZWInIE7OkyAmntrehWYSyLPe1 uOO/1vnNLcJ+JvM3
Y8Vve80EvspUqc3+2PUt7ONBA20cEGwW6ZQinZVIZ6rkl8y5WoY+R9s4NC5/ 3dwQmuE6NFPZXW+1
9+s8VXHYt/AIJ5rjMcEU47GGIHTtzc7hYDOnNZ7iTM93+F+i5VpO/rUVQv06 KdJADpR+6d7anh1N
gA4q/I8MB/CN9MeyvceRy57Y115+Q+Promyx3dJJbmqytcoG7GCXPcPj/nL4 E2cr7I961TkeVtBr
HRmt494cTwhznNewAjxAjW2DmZt8dtBme8iATV0rQUqCxe0CTxe6ni3mn/8B UEsDBAoAAAAAANBu
WzQAAAAAAAAAAAAAAAArAAAATXlDb250YWN0cy9iaW4vY29tL21hZ3VyaS9t eWNvbnRhY3RzL3Zp
ZXdzL1BLAwQUAAAACAAGcVs0BI/i/ukBAAAxBAAAPwAAAE15Q29udGFjdHMv YmluL2NvbS9tYWd1
cmkvbXljb250YWN0cy92aWV3cy9Db250YWN0c1ZpZXckMS5jbGFzc5VTW2sT QRT+pkndJl1tEu/3
qlGTVLvtmxDxJaIUVgVbgq+T6WkyYbNbZjaV/CjBgjd88Af4o8Qzk1RERNaB 4Vz2nG++c9nvP75+
A7CJjkBHZZNoIodTo6PJTGVpLlVuoyNNb23UW5h9tprbAYRAbSyPZJTIdBi9 GoxJ5QFKAg//jjLJ
9imJdk5gYm1zSskEWBY4lY+0bW4xg7goha5AZXeW5iPKtWKExzrV+RN+vVUc ot0XKPeYl0Cp1e6H
qOJ0FWWcCRFgpYIl1ATWYp3Sy+lkQGZPDhKObcSZkklfGu3shbPsShB4UPj1 5jaXEKb8uu2NuIW0
L/CmFf+jeb/Sn5tsetgtFPpU5tLX2SrKK8AlgRWpFFk/ktf/09A4M8OIVKIP LUXjA6nIh5Gx0Z4h
6nu9G+IKrlZxGdcEmkUyAtwQCAwdGLKjEOtuTDdxi3mesBHYKNSPeesElinN zYwXrlCW6yInVXez
qVH0TLuB13+vfNP9CTzOnZRXupdIa8liC0u8TLybfGtuo1hW4M4S3ypW2Q5Z e8S293Q+Y62z8RH1
Yx/TcD7/5Z3HOctayNJ5z+E8S4ELuLhAecGyxHK18wH1L7j+Cbf/hHnP8tjD rM9D5zBeu4MmAzjt
Lu55Qvd9dgttny9Yd6fxE1BLAwQUAAAACAAGcVs0laOdohADAADEBgAAPwAA AE15Q29udGFjdHMv
YmluL2NvbS9tYWd1cmkvbXljb250YWN0cy92aWV3cy9Db250YWN0c1ZpZXck Mi5jbGFzc5VUW1PT
UBD+TikGQpW2goKiIhboBRpuKlK8YLmIlDoC9sEXDeFYwqQJJikOP4Vf4LMz ioiKMKMP+gP8OY57
UgSnKBMyk5zdPWe/3f12T3782t4BkEaeIalZJaWkFsu2rpTWNct0Vc11lDWd v3KU7L5aIC02IIEx
hFfUNVUxVLOoPFpc4ZoroYZh0LKLCtcMfdXhysoLVeMeArcdZXqeG3RMt8zs MnnxpZzuuNzktoRa
hlPusu7E+iiPnN9EMgz18+umu8xdXSOEUd3U3TsMvXH/EIkCQzBrLXGGmnii EIKM0zKCOBOChLp6
BBBmaMzpJs+XS4vcXlAXDTobzVmaahRUWxf6vjEoSmDo8R09NkAlhJ0qWhiG 4rn/01jN4sQaN12v
jrjfuBJaGOpUTeOOR/ncSQg7JrUFm/OCJ2dCuICLMlrRxhDz4yHhMkOoyN2D +qigeCLnZ54oWjuu
yriCDob0cR6uXdbcss2XDnwlxKjBFHdStx13wuAlopOhiUJXDziF6UJ3AzoR Z0j8m7ESjZJxwNiU
bZVXJSQZJIqQV0u8Gpky0s0iIfegV0YKaYaG2fX2PwB1oPaEq49LGKBx5y/L qkHz1hw/mmniaQhD
uC5jEDcOW91P7Jyg1VlxH4ZxS7RxpFLCwvpq5aZkQxjFbZHxHeqTHy7GVVeV cE/GmHBhBNN/4imn
C+8cjkeXv+GgfK3FFbqzR2gSW4THkMr5qcDrJvnI81bZ1vikLi595G/K0iIC jfG0Sb+1rKE6DnfQ
hwD9UKhh9IbFX4XWeognQK+MBtJDJA2T7lmS79GYTL1D5I13Jips3s6Wh3OW pBCtwtqEZloZzuH8
PspPOllL6/PkW0S2cGkT12Z7dtH5AQmGfO8eUhvo791FaiTYGtyEEu3fxM0N CkjHw3NbyLxGt5DF
5l1PbSGnsQ1EhJUcxzZxn+yHuSUh03eb6vhI2XxCGz6jAztQ8AUZ7OEhvuIx vuEZvnu5D1Xyq+Tu
SVmMg5H/E0xgEgGyz2AKD1BDOHFME0KQrDNexBxmvcoZyeKJ/gZQSwMEFAAA AAgABnFbNAqqHm62
AQAAfQMAAD8AAABNeUNvbnRhY3RzL2Jpbi9jb20vbWFndXJpL215Y29udGFj dHMvdmlld3MvQ29u
dGFjdHNWaWV3JDMuY2xhc3OVUttuEzEQPU4D2ywLTQKU+z2CNIW6oi9IRUhV JKRKW3hIlHfHmMTR
ro3Wu636WUggEA98AP+A4EsQYycPiAe0WLJmztmZM7Mz/vbry1cAO3jAMJA2 57mYVYXm+am0phSy
dPxYqxPHhys4IdTbi8AY2gtxLHgmzIy/ni6ULCOsMTy0xYwrmel3TvHFWyEV pzxtDT88UqZKtSuV
UUWEMwxny7l2vV0qndatvc/QGp2acq5KLUnhuTa6fMHwpF9fYmvC0BzaN4ph rb81SRDjfIwmLiSI
sN5CA22GjVQb9arKp6oYi2lGsd3USpFNRKE9XpFN/wsMj2tX7+3tk3hOoziY 2qoc29HcntAE+um/
B3ckjJipIjTfr1sswlWGdSGlcq73lGH8H1Oq3U+C67gR4xpuMkT5kmZ4VDOf IR7ZqpDqpfbz7PzZ
w45/YQzJoaEXM8yEc8phFw3aFa2ebtsvjGwL/jToxjhHOCHvGeHADD5hY7D9 EZ33IabrufDle9C5
SF5C1rOXcJkswyaurFQOViqtwQd0tj/j1t8iP6iBn0Fkcxm4FAnebdwBI/Zu yLmH+z4rMP50fwNQ
SwMEFAAAAAgABnFbNM6dxI4IAwAAoAYAAD8AAABNeUNvbnRhY3RzL2Jpbi9j b20vbWFndXJpL215
Y29udGFjdHMvdmlld3MvQ29udGFjdHNWaWV3JDQuY2xhc3OVVGtPE0EUPQPV pQ8FERQU5FWxFNqt
CooUUSyg1QWNYIlfjNPt0C5ud8nuFsJP8bO/wER5aGLwqz/KeGdpCgGBsslm Zu6ce87cmXvvn78/
fgFIYp4hrttltcyLFcdQy5u6bXlc91x13RAbrpqpLnO0io4qYAw9tlNUhW4a a65QV1e4LlRCGLal
TvuDgkaGi17JcKMpYtfqpU8zBBc3La8kPEMnhknDMrwphkSsfoqhHEMgYxcE Q2NsKBdBE8IhBBCJ
4AIuBtGAywzNmmGJhUo5L5wlnjcJ26rZOjdz3DHkumoMyBAYRupWj46mSdap WAyxen0UtDM0cV0X
rn9db88TrHbsJXyYcFx1yREi58/TEVxHRwjX0MkQrcdDwU2GSFF4i8IU8kll QLHT1LI1JKl141YI
XehhSJ7m4TkV3as4olDzVdBHj0O6c4bjerOmKAvLY2gj6VW+zlWTW0X1dX6V 0CQzgGgY/bh94mWX
KQ3M2o3NcI8ruEOH+j+6YHDTLrrqdKFQdZnxLQqGGDoPB1Ix1Dcm91Zsp/wu q2B4/66WbedTXlh6
iaGbDnzEIVvbppMnkAxhBOoB73GYgrsMHcQra2pd1OzLhlWwNxgGTtI4AJHS fYyGcQ9jVLRngBU8
pDyUb14SpsnQd4Tf3fDUDaNAAFf1IcT+CBNhjIOSXoudAdbqfaL0ftE+DiGO KapBe01Yfi1nI3iK
aWl+Rn3CPcjMwfrykkjs/CqV+rFcoq0GTg0npZ0vM8gvtGhXHF3MGbJfXDlc nEmpQpmRtSzhZEzu
usJFivpPgNouQ4tsRzQqkF8D/U0I0jpEs3FaS0sovo1L8eHvaP7qY1qkTe6w D8RCerSO0Citrbjq
87YhXGX5QhiplY5/Q/MObmyhVxveQ/8uBhnmR34j9hl9PxF/v4PULh4w7GKS mt0eYtt4spDYQmb5
QHYQQWL/iDDj1K/y6GI6elkBCSYoT3VKsBVMsJJ/pPi+bPVIYQp6BrN0qHZi mcNzYhyj4F8gi0aa
v/Q1XkHzw2A0l1/rP1BLAwQUAAAACAAGcVs0gWq/b80BAAC5AwAAPwAAAE15 Q29udGFjdHMvYmlu
L2NvbS9tYWd1cmkvbXljb250YWN0cy92aWV3cy9Db250YWN0c1ZpZXckNS5j bGFzc5VSbWsTQRB+
Jk295nLaJGp9t9qemkbNFqQgVASJCoVYP1TyfbNd042Xu3J7F+nPEnzDD/4A f5Q4uw1YRDFdWGaf
2dlnZ56ZHz+/fQfQRZvQUdlETOSozI2YHKksLaQqrJga/d6K3gwOGMVbAYjQ GMupFIlMR+L1cKxV
EWCB0M3ykdAqMYdWi/FbqbRn0LkVO8+zcpjoXmLUu76xhU51HmCRcKY4MDbe 5BT68+awTajtHaXF
gS6MYoYnJjXFU8LD9vwUGwNCtZfta8JCe2MQIcTZEFWcixBgqYYKGoTlvkn1 bjkZ6vyNHCYc2+pn
SiYDmRuHZ86qK4HwYO7f4y0uob7/WxGCaPf/Ld4J7V5MdVr47Nvz/hbgMmFJ KqWtjR8RXp1Gpr9k
xZcmS8Uzb7YjXMW1EFdwnbD6n+AAN1nuvEwj3HJyr+I2YVG7kli+0whACPey Mlf6pXEdaJ5Muutm
kxDtpDxjvURaqy02UeHu8rDwbrgWs63BrQrvEHXGEZ8eM/aezhcsd+5/QvOD j2k5n7uhQ89znnHE
1nkv4CJbwgouzVh6bB1LvfMRza+48Rlrf9LkCMl6mpXj0GMaf1pH7Anu+Dd3 cc+98h63Wr8AUEsD
BBQAAAAIAAZxWzQoJdEWZQ0AAKEiAAA9AAAATXlDb250YWN0cy9iaW4vY29t L21hZ3VyaS9teWNv
bnRhY3RzL3ZpZXdzL0NvbnRhY3RzVmlldy5jbGFzc9VaeXxc11X+jmR75Kex LclLFjuWd480tibe
msROnciS5ciWZMdSpMgJDU+jZ2nsmXnqLHKUlBKSlkIDlIaW0KaUdCEhDS1N Go8sC1rWFgokZSlb
WwItZU9LKaULUPjOfU/zRqPFoz+xf9J9y1m/c+455137s9+/+kkALXK/IBJ3 U7GUPZLPJGKpibib
ztnxXDY2nnAuZWNt/m0/70IQwSY3MxJz4snEWNaJ5ROxMTuTi+nbM7wIoVpQ 1dkuaOi6YI/bsaSd
Hon15jKJ9MgRwSpKy+bsdK7fTuYdT3OLp7kl0NxiNLeUaq5BjSCUdbLZhJsW 7O2a3+SUO+wkiyb3
euTUu9oetsdyTqaDj93MhKC5q9SLuJtxYpl8OpdIObHO1lm05F6h9jgZwa5Z XBfO23En5r3Lxvoy
jtNvrslRN5xJJJPt7qW0ETbDOxe39ll0hrd+2M0PJZ22ZCJ+sTWeM/5unUex bd7FPBLy1WadZA/9
75sYI7LSRrziSTub3XEzZZYEo00fkn5l70Q6N+rkEnF6eHsincgdFVRHmvoF y9ooJ4wbcKOFZdgk
2F8J3LNxC2GzhUZsCiOMVStRha2CNV2JtNOTTw05mT6bPmqWuHE72W9nEnrv P1yWG01kNUaV5qWi
Fs84ds7RHNQ3GTdJyCOzYMteysUuJYZHnJxyp8bcbCLnHFF/69X7hJ1MPOT4 ORNGE52n1c2CHZUE
PYQ9gt2VKOxs6ldoWyzsRSyM1Vij6OyjnkoSJIQDgqZIZYnoaTpk4SBeF0Yd 6lXTrUwMmtRLWwQ7
I03ledk54GYuDjnp+CjBNGRHwjiMI4rG7UzFa5KHwERal6UKJ+mY7DyTcccT w7oL9i1meWcZg+/B
nWitxR04Fuieu2nPJO3ceTeTCqGd4aR7PlzddtoeUcV7Ik3X3vI+Nf3twAkL x3FXGBtwnaJ2kvGZ
v1iZTVAsVjXoYp6X7bYQegg67euxUwb0ubWxqXyH0ogzuNvCaZwVbA5e9rjm dbtzvsPNp4ePZzIu
k6JPsDag6RvNuJd0L4XA7LYIRzfTmq4xLpGmOcqp6l4MWhjAOcH6ucb5eXS/ hXvwAyzaleIYwgMs
hRlnJJHlQ/8dN/bRyLVDMVN9y2ExttgYqsUPgoUrOjsb/YpUTMkue8hJesmk 5jgWzms5q2NymleV
JuYxO+vMYjBmjCKhm/gCuec1Q7mKpmiCOOlcYEzSQkqNaaAx/svAnNii5gTk gTEuxtSYN4ZhoVYz
Nkt0KinbfsULIe8VhrOum2OHjTRV1GNPZNz8GBPoEh60MA621hr605key+fK cun00AVubmPrw3iT
2vpDrPGVlvgd+0L4YTWr8qbgZe2PWHgEj7JmVuxNCG9hitjDw9pNs12avGmN yf7Iooh0+kKKHMaA
H8XbLLwVP7YUV/eH8HYLj6vVG2lGsSq2jRJHZziw6NbKqmnAF9j1k/gpDcE7 ODek7IuON0Vkw3in
1/aeYBEbdd2LJtMeZPlI58N4l/fu3Qysvmsvn1PCeNKj+DnBBnUwkxjK55w+ 13t9zM5QwXs9kqcE
W8q2do+b80rag3FnLGdS8uc5mrANOmkm0/YKemvQROcOSupDsTB9gGVx+xl3 LD+mj2vwIQsf1Nq2
PssN4KTccac1mRwYddK9o+y9HEki5xS1Z/CsEv7SUqJ5IISPWHheo7mG0VR9 QQSjkYUnu06fNAja
R/ExVf8rpqYHc872SNOC2PhE3KEv4EWN+CeKs1JJbAWtkWuKWFiJiqCGyyio eZOCxmvICmHKjPO+
8q2RRUUb36fxqxau4tfY6GY6yiwHBiJdlYT+SEU7ZlZl/RR+XeeP36DFKRU0 otN8ZcqYOClj3ebF
HdTSuYlbsXtiSzBI/K5GZQlFeG7fbvNK4Ge1Av0+KzPT7zjxn2A1rEyw8f8P 8bIKeIWfb4n0eCKb
4K73mkS0IiHGOoUiY5hq6bZuDG8A3TTPADrzlin1p/i8Vos/E1y/EFUIf0HL KDSoMsR7HrHBewr+
K3yhFn+JLwpuXJguhL/mtyNFl8RUsWu6xqYN5si/wd/W4lV8mZvuPAd587Vz Ju9N9CwikQoFaRj+
Dl9VKP7em2/7XDdJE4P5dlGjfOrArn/EP6ld/8xGV7TLJ9ImW7kotexf8Zpa 9jWGeMigv2lx7Ndh
vQ4o/y44OG/++Lqysdbh4VlJ5EkJ4T8EN8zWUPwAuKczhP8UhAlRcfQS3LTY Zw4t+g6+a+Hb+F4g
dy5ZCP/NLPTzbDwY7AYS6WH3UrEKz2UOiKjp+/jfWvyPgJ0qck1ys32lysK3 pJqfDRXlSkiW8zOe
O50MC8dxJiKqQkJSUysrZKWgpdJ4+JGQWkvCatu2BRX1Omzgds6lYastWaNl LraYXW3+3KB3nTkn
5VtYrxY2CA4tbmF7xh2bL2VknSXr1dADi/Nru/f52+2cPcN9nSXXK3esYu0z nDdaslE5Q6mZnbq7
wj3PcUG35qwmt06nUns8MWIr/czQJlu0NByUrTzUIUHCPK2R7YTbfK9VuplD sqtWdstK/dWgUl9T
qc2sU5XXg6VMRgdDsteSFjwaRgPWsiTIzUthPxSS/ZYc0MFqA90uGUeD+erA ohPyPCwm3Q7J6zgq
yS16qMaEKH481+i5yaiTTHJkWWTmMiRHwnJY2Nivyu1sTzOGbzGHmXKUaTDX rmEeQbkj2Zivr93c
huROZoI75qQ701rgbO9EsCOyuPq508DcJ8bXY9JmSau0a4rO+BkaTmQ5UfOq IZ8u/34Py13m81s6
vW+9Djeez5qTw3NhOSVd6nK3DhvxuOOdPp5dykdbZSdbgfx9rFpLkM+RKODd L+hbAm+FG1dRbTTN
Wu4JdPHYrnsJupoqOPG1et18Ju50JPTQtL6UvUVDzS7YmWZKm48rJ4ut7LnL eOZfw5FwOVaAceZd
Fbjx9MxAr/WsVlc9ldRVzwx11f2pq7ZulaCnYuS/Hvqnnlc8Kubvjbw7hmoI 17rmSdzUPI3GwUls
uYxtLxj+7fy9GtX8/RhtuUQtb8EO3oU9HuzELq7cHYh48uQAba3is0nKi1Le 3sFofXXVJG6+jP28
PTjY/BL2T+KWy7ituYDX690U2qpwBZ283vYiTg1+BpsGGrqvoHfwEzj1LNZM 455zDxRw3yTe8Kkp
DFdDmaZxnpaOFHDRu0vxLl1ARu/4kyvgoQLe7F9N45FB2vNYAT/uUT+utz9R wE9z+Rn+/Cx/3sOf
971AN46iDSfxft/9DgPpO+j+EwT13diG9yCG9+E+fAAJPENQnuO0/VF+S0/i KbrxIa7P4GV8BJ/D
x/DHeJFDcQGfN7Bt8KDxYDNXv4CnIXz6rpmAUM4yA3jrND442PDhSfxiV3RZ Ac9Fp/G8Wv3LBXw8
ql4U8FIBV7r9yz0FfFIBjXqI/mY1gghuNpnzBWbNFxnBL1HNlxmxr2A/h9Q7 8VVj2hZPqWcaKW/B
b+G3NbI07HfwaVTxb1PRyByWG/pdDOk4kf/MZeR8rLum8dbBaMPv1Z2YxB90 R2nX5wJLNmA5f7/G
7P0awfw6tf4bNX6jxIJdvgVr+fePCJ/w+Qr8Ca/UgvcWLXhA77k20uk/n8KX BF3N0Sl8RQjqP+jV
v+jV1wPVDWYzfZuufYfb4rsE5XslMWksOr6eJn1DY6ITvJ/UJ8mrVFfp4zfr zj6NjYzGtwav4L+m
RKhHlk2JVYVn8ZQhOPE0zs5LEJ2WcMnDVTMP1wxOSt2UrDU360soNvhy24zc tqdxmATXlxDcMK+I
jSUUmwxFgMOQlgG+WSksG1LNgVX/rWc5/+VkBWISwmGud0gND+ZX4jTXPrFg Sy3OSxhv5Dohq9nC
1+BtUocnuD4p9fiwNOA5WYuXuE7JdSW4Xi3m+lW5STYrrtJYxPVhH9dX/9/i OouCwm6LFmSbebhW
dkzKTvM8AD9t3N5M8BsJ/haC30jwtxH87QR/B8HfTvB3EvxdBH8nwd9N8CME v4ngRwh+lODvIfh7
Cf4egt9C8GME/2aCHyP4B/FpOYSX5VZ+C99WEohXi4F4dSYQ+iHoB2LED8Qr iwQicq1AROYLRKQU
o6b5AhFZPBDlIuYGopyiGIhoAPwF3Eg37yTwrQT+GIFvJfDtBP44ge8g8McJ /AkCfxeBP0HgOwn8
SQJ/isCfJPDdBL6HwJ8m8D0E/gyBv5vAnyXwdxP4fgI/QODvLQH9lSLorxD0 PQb0dxZL2BEsM210
VfO0tLC0S+yy7AtMtlSEvAFhuVDSc1d5IvnuyaKgo76gOtPc5IDKOliQW8tl jWGN5Ofp31XMlPt9
Wf2oNqY3zLQYef1auSN6RY6XVXGZgCUPYZU8TEAfRL28qcTxhqLjDdJhZheR E0V7L/r27q206ctJ
bWfC5rWOAt5fWtHlUf4Xhsewm+seKR1O9s4MJ3KqqPiwGqIURed6BspBejtq 5fESOWFfTo2cZsyr
vCHKSNvpS1uu0j5eFLPCPJwwIqoM491ydhbjLr93rWjeeBnffKGM880lnL3S twBndFL6yzjlphLO
Abl3IWNlX7mxDxcZq2TQ/D4n93FtZqAf8cKIx/31eT+sLf56wFv/D1BLAwQU AAAACADsoFk0nY8u
NFYAAABtAAAAGwAAAE15Q29udGFjdHMvYnVpbGQucHJvcGVydGllc23JMQqA MAyF4b2QO/QAmp7A
wUHBQSdHJ2uRQmxL24DHN7gJvuEfvlciZ+sQdadLtgZU5Jq4vrD7ICBFHyzx 4YpgIj5F7ouaDZT+
bh7Wvp2W0fx8COoBUEsDBAoAAAAAAFWyWTQAAAAAAAAAAAAAAAARAAAATXlD b250YWN0cy9pY29u
cy9QSwMEFAAAAAgAqItYNFGJqY20AAAAXgYAAB8AAABNeUNvbnRhY3RzL2lj b25zL2Nvbm5lY3Rp
b24uZ2lm7dOvC8JAFAfw53Bwcv4YrIooNjFom8y0oC5axTIWLf4FcmgYgojN eoiYjcYJosNmMxj8
E2YSMZx39wfYlfvA470vvPptuy2r4RlgwBMEIofIReQVcrdwc47rzoBnnkBR fhN7x5SuCSFMBGBy
MXEJpVcyAaBDVbyKTgSqEcp/+94IZANG+c6W7ifIrPSjBR0HOd2ZWcOVNjVx 4brrFk/zDO4d0MU7
auXUqHl/+NGy5mfTCOwPUEsDBBQAAAAIAKyJWDSuNRUfFAEAAJIGAAAaAAAA TXlDb250YWN0cy9p
Y29ucy9ncm91cC5naWbt0zFLw1AQB/BLEzFSqG0FLWrBoLRGHIqTRQetpWrH TA4dLIoIGQp9s/Js
LR1FCE4iQRKxdGiWjoUoEqJIpoKLe9Y4SXF47csHcBbJD46742797+4X1rPl OMThGyjsF/Yb9idz
5NN8ePPouSgCEqCblSRJlmVUFBBCo19FUXRd70HPsizHcVzXJeQWAoE/hvx4 qqphjAldgPiN0IkS
BhwDwMAqfaWZaAaJCPxvvyeCrwDLz+8Z6lOdn1opLRvMTi2R2HzZ+gqxAJET O4qfG1cz0wfGYYbl
+KT4qBlqrlFLpe1Sq8oULuaOHM0zt7mbxbG7ywW09Do+mcqfDtbw+z13fX4c 7Yv9emxi9szutj86
YTYEG0NQSwMEFAAAAAgA8qFZNJDb86COAgAA1wMAABsAAABNeUNvbnRhY3Rz L2ljb25zL3NhbXBs
ZS5naWbt01tPUgEAwPHDykazmLnqoVmirWabD1pt5v0uByQ6iCkgKhfnJa+I ihxRT4HGxQzbVEQk
wsvUabJlTpoPic7bqFxmzWEziVuJU5fZbBrNT9FLv7f/B/jj8Em3QllegBfw CwASo2JN+o8Hu+4V
zcG7V6t7DrdBZF4YsDutLjCG/H7BXJjQJcjQPK019TbNDWgMsuLxsTYHnKsa 7ngDFymoIS2JNzkV
dA0UXUyK4wwqlrNxTf2qSV9PAjm6KgWXDxeqyCDHMLTksG7ScCI64T6VIJjV H06Pr2USZUjx6FD3
VJ9On3hdmBzBB8PKKQkIi9xCvQ2/fD5PxcsZREUGqQHhjsSF08yfvhEihWmg jE5stll2wLBGcryi
gC3jlcjppNYsShcDas+mqGmQhJEqriqXa9Vjb00rDruLQ3u2vGSxWTcgUM6i 6jLTlHdJ7TmZIxzG
MDujn0nX5TH7crJepKWoOMzegrzBnt49i2XLYnGm00ZKuRM4oq602swTfqZn 93ArB6obtuCHO/wH
rsp6Z2W9vaLuK692nS+yqXSuJ8pFfIpSINnlN27XSH/Ckh988SZf/J0rXJa0 7tdJ10qqjZKOQ2Xf
YXCkMJ2tttk33G438N+/47d/HAUACBB4FEdPAOhRAHXSB9RrJ0XoGiKi1xo9 MJcxdiwTa3zkG0UH
IUifDMR4zL2e97dJMV5oNHwWmnl8PiBe7CrbQbQSFPN3kcHYgz5zKSjg1LQo 745PKM+pDqbMkjoj
BCfuffG2e7ZdSx2kStnWOShEuCjBd+ee7gzm704IbpTNoM5dzP8AsuKT0EAg +k8s17/Rw/sKUQgi
OfjJqwEXgrYRv2PNWAIGpq0zpzyxeDV21STgxQBA+F9QSwMECgAAAAAA7KBZ NAAAAAAAAAAAAAAA
ABQAAABNeUNvbnRhY3RzL01FVEEtSU5GL1BLAwQUAAAACADsoFk0BURHk6gA AAAQAQAAHwAAAE15
Q29udGFjdHMvTUVUQS1JTkYvTUFOSUZFU1QuTUZVjrsKAjEQRfv9inyACWq5 YqFi54q4YB/jGAby
WJOZYv16wz4Uu4Fz79zT6IBPyCRvkDLGUIuVWlZ7Dg8HcoZftp7JWXuoRdMf YiBtKIuLYysxzLzt
/T06NGPORK+8tpxQ+d5MlY3IGKwDKo+3lBim7p/Jz+UUjXb41jSgrsyVtSu8 GBPIIVOGYrIKjMMu
gzIxgUocCD0sqj/EWB3HU+6YYks6US0Ghw9QSwMEFAAAAAgAFqNZNOlRbiw2 AQAADAQAABUAAABN
eUNvbnRhY3RzL3BsdWdpbi54bWylU8tqwzAQvAfyD0b3yi299GA5hEBvhR7a 3oWyNQt6Iclu8veV
HT9kN00N1cF4H7OzM0LF7qRk1oDzaDQjD/SeZKCFOaKuGHl/e757Irtyuyl2 ICRaD1PvY+ztSlbW
Fer4t91kWVbAKYBuW2I4HDwywq2VKHiIFZKUrEEdGDGuoj0FFcYBdbUOqIAm ME/KAVgk6Uuyz0dY
H05HSO49I8IoqnhVO6TqLIwOXARP98las0l5HDXx5XPCLjUqLRfKb8urkdpo ogURsIFUVJKei9Bc
ASMv49bZ69QZzVwt9idsuqHfMDbBJH4k6f/70SB8pUZEn6Ey7rxyR3LNrcPg 1aEfRvKJoCWcgwbK
dRS3XL6ooQP/R4yWZov2AbVfn3uurARa4efqG/lz/sKAriO/dkvx9ebj8/0G UEsDBAoAAAAAAOyg
WTQAAAAAAAAAAAAAAAAPAAAATXlDb250YWN0cy9zcmMvUEsDBAoAAAAAAOyg WTQAAAAAAAAAAAAA
AAATAAAATXlDb250YWN0cy9zcmMvY29tL1BLAwQKAAAAAADsoFk0AAAAAAAA AAAAAAAAGgAAAE15
Q29udGFjdHMvc3JjL2NvbS9tYWd1cmkvUEsDBAoAAAAAAH27WTQAAAAAAAAA AAAAAAAlAAAATXlD
b250YWN0cy9zcmMvY29tL21hZ3VyaS9teWNvbnRhY3RzL1BLAwQKAAAAAAAV gVo0AAAAAAAAAAAA
AAAALQAAAE15Q29udGFjdHMvc3JjL2NvbS9tYWd1cmkvbXljb250YWN0cy9h Y3Rpb25zL1BLAwQU
AAAACAAhUFs0MpSY0CMGAAAVEwAAQgAAAE15Q29udGFjdHMvc3JjL2NvbS9t YWd1cmkvbXljb250
YWN0cy9hY3Rpb25zL0FkZENvbnRhY3RBY3Rpb24uamF2YaVYbW/bNhD+7AD5 Dzd3aOTUk7fPXYAF
edm8tkmAuCuGohho6WwzkUiBpOx5Rf/7ji9681sS1DEki7o7Hp977o5MwZJH NkdIZB7nbF4qHufr
RArDEqNjunAp9Nvjo+MjnhdSGZBqHmOS8UJj/DBjCQah+Nzd3h4QTDnL5FzH H1BrmvPSPR5SWHJc
odLx+B4zfNJ8I21UmZhSYfosvRUXqVzFn9xtt2DJWz6859qgQLVf9JNUj1MU yeKOKfMMscNTV1EI
CF/To1Trlrof36teZOWcU3ym2ijS/Ti+cwOtoO6J/nlRZDxhzvhh0Tq052l6 4cd8dJ/Sy2WKWXwR
Hl8mfckMe5nG70qWxfNUxmN6g+9w7ck/Oj09PoJT+I2VZiEVOC3NjOFumJat gYHAFQQ7YCSYBYKz
5mTcZbLgGpKMaQ3kRIY5CqNhm1ugJXDykAnI3BDZcwaSBRNzJG0BulLSIGfN ExRKLnlqM8FpjEnX
zco0DqGC4i9OvtKowrm1T7kCjJbQmLG6tSmI7hE7un4RAys1Oj4qyikxJSys 4cC5dwj/pQUQQP6x
vfBNDg+Pj3q9HWh8tTHoFYovmUGYccEy2EwfWFVZ1KOv9yiIasMMPVBd4GIO 40s4g/6hgkf3NA1j
fWewmXxHdXGhuKFAb4hOpcyQIshqQGjiGcv0PkH5WAl0VrGFaLRn7QP4agG0 4Q5Vjew1sPQ0mnEa
jS8H1dOEQhP1yXwV237zinya8MJL7OV34AuxZ25zK6iPRvBREMAUZCfIaAJu 88m9PK1csSOXqBPF
C6poEQ3TZ7NMxbwrdq1k7t9YBfdp1an47v3H38c3/4wvh9CkcHxxezM5v5gM vHunI3sNjtrFN7mT
tfJvhd38a8SqLLQmQveYo6npcI9qyROMBpZGW2SObHicI9+Oj+wfIQKRkOKn P9mSpTIZ0JAtNRrx
qW77SpUiCvL++gelss3r1YJ+uAh5BUp0lmVrSKUtHpR6D3LqNEYNzZaSp2At Bh7xGUQNd8Ngz5GU
csBx1AsF+lsQrrnS5srnN9nhgnJPJEgFql22K1u9zlYglgWKK6WIC6LMsiH0 x2LJMnKqSh+r2x9W
ce//LUsbohPjGMaCmKeckLR4VQ394JlJnybH/MA3QPrt/XGEuKaAgiwN8Jkv nPS1OPY/rME1EN0H
QaslhbD8KOo0mAHsxWNgh2hTYB86v+HsDOyaPTDfi8wBYNxSlJTGJ2yFyzYw LkG28OlVpWrBtDOg
N5R6t9MH4vvnLyCnD/TuhdhcCarRqKPaq5mk5sMFRYOM/fyWbr9ay3GGYm4W 9PzmTcCsiga9/cy/
bDKv8aCR7jWLaBhtPzYzq3tttxb2Fr47SIfp68ND0WLGl1xaDzhKBxKGyG2G rnE83Py1wuZx0GL6
Lfnrub25baPy58ZLTfPlbE1oFpQRKfnvtbcUWAJnrj9svolaBXKBWRYNKr9t VBXqQgri1xlZcAD6
0Ad/m9dn8MnbuX1XLaEq324Jdu4KM++7UYgdTlLZw5wm2sfAGs8OX6BwKUp6 G0x25ioVL2TrvWXw
OiJvOgUv8gJDqELGknr+G5ZTrxgSAL6LULhTP7YpToslRHQjfLeQAm/KfIpq W/oqZzxrqZxcnFTY
N8QIl5d3o33nkh8393SvUk5B1NjtU5MF7mq7eakNTBGCTmr7mGi3Ma7rdzvb Vz0ZfH2yOyvM5RIP
NegXArK9c31Vr/HCbRnS6OBZcfisQ3AXyNCiZtzu4XGJag2G59jey7dPDUQY Oi5YSL1+cwDYeYSA
ewlrWfrAEIygaefrypJTt3a8dbKaJKWydriPmHRZR5NZA4pG7SzaxBB1jiTe zsrZweTRtd3GKLdO
16kUTh3xztBvQd3FFgoHcANjoxDIsr1Pr3aztU5Vi+kc4QrMEAybZqgpbr46 t88HAQFd7aXq+VrN
aed5oqpwoVLZ2rNbTLf+vzEakcb9mmKZx7R9iQtFiGci6jsTF+5o1oc3+8uf HXFiVKK393aa/4d+
n/JLKDOvX8OLNn5hVV2cm75rs62z3egir30vTKU4cSd3OgbSSYD2eTsQh2hC sdFDmFBw7B1N4kiz
L8Y+0/2VLv8DUEsDBBQAAAAIANtQWzQXlXogcQUAAJMQAABIAAAATXlDb250 YWN0cy9zcmMvY29t
L21hZ3VyaS9teWNvbnRhY3RzL2FjdGlvbnMvQWRkQ29udGFjdHNHcm91cEFj dGlvbi5qYXZhpVdt
b9s2EP7sAPkPt3RA5NSTt89dgAVNm7ntkmBpVgxFMdDS2WYikQJJ2fOK/Pcd 3yTLlpN0Mww5Iu8e
3stzx0vFsns2R8hkmZZsXiuelutMCsMyo1N6cCn0q8ODwwNeVlIZkGqeYlbw SmN6N2MZBqH0zP28
ekQw56yQc53+hlrTmefu9TGFJccVKp1ObrDAJ+FbaaPqzNQK82fprbjI5Sr9 5H76BWu+YcMHrg0K
VPtFP0l1P0WRLa6ZMs8Qe/zomIUQ4bf0KtV6Q92vbySpP5tN/M/y/HVYu1Cy rkIintAuZY5FGhW/
TfqcGfZtGs4w59L45OTwAE7gF1abhVTgFDUzhrtl9yCPNDAQuIKIB3OLAEaC WSA48Fb+44JryAqm
NZBNBZYoSGM3xaAlcDKYCSjcEuE5gGzBxBxJW4COShpyKRCYaZegUnLJc8tK pzYhAHc00ziC6Osf
nOymVYVzewjxFhi508JY3QYKkhvEjq73ZGilxocHVT0teBa82071mTcL/yZf KGThtY3B4cFgsBuG
EWyTDb7a1AwqxZfMIMy4YAVsExpWkdcD+nq7gqg2zNALVSoXc5icwykcPdaC 6DfP45rL7JGDbU3o
qXqXm0vK/JboVMoCKaUE6YJCh89YofeJyfuuQOvMnvAmewIxhK82vpYBoekQ cBujgUYzyZPJ+TC+
faQ8JUd0CDj0o3aDTPvIK7//WiGZG/gfaC9nTSEErfEYbgWF2KaZWGydp7xT G3abJ/F8u3KOOlO8
oi6T0DJ9zqbaKMK6nVwX9ZyLlHfF3ipZ+h2n4FSqigLE3M1w/eH2YnL51+Sc eOQOeI9rnV78fnV7
PfTGnYztM5hp/W0rqNgoxRV2S7EViwVpIUI/n6NpiHCDaskzTIaWRjv0TmxG nCEPjtX0HZ9AIqT4
4R1bslxmQ1qyLUgjPnUBvlC1SIK8f/5KFW3Le7WgP1w38gpAeSuKNXUN20io /9zJqdMYtwRbSp6D
RQzc4TNIIm3D0sDxk8jv6OlFAu9tDN5ypc0bX96EwgWVnsiQCLLZnCPWoHM3 p7JC8UYpIoKoi2IE
RxOxZAXPo27g5Shm/ehPWdsUHRvHL+b3Hd2iyneej/Rp68ovPADS39GQWH0L piOTu+KDq+kd5fHz
F5DTO9pKkuhQiM7eIAzt0htBvQd1Eq2ZSeqsnGqDE9aPr+jnZwucFijmZkHv L1+GIIUY0+Zn/uXJ
gA4GXQ/aRA0s3cJPBN2Q9Qj/OyePpCRekQu6styp5EvjRMjTVqIag/0zhuI+ GOvq94oM1I7n/YMG
VbLbrTVVdcnWFMKqNpBT1DzGHrV5DqeuxfXvJxt1v8CiSIbRAZtVhbqSguh1 Sjguhj7zwYN2+xQ+
eZyr99Gp2JWcU9aC7mxhFNom2lKSihlLOmgfAZvAdryAiinaJb0tIju4qOKF bBuzBF4n1pqOeOIl
Rrb5+M88txa4zUtWUhMcwfHF8XC4m8yH2AKf3wF7J+MXTV9+7dpynjw6IY+e Nfq3PTUOcPSdcTst
4RLVGgwvcXNq2hzS7GAmZzZdXr8dtXqHNbiRsKa6KWttgIIHmuYKVyhO3eJ4 dELNsloRDp3ilqWj
AB1mARSt2lO0SSHpDH8eZ+VwMLsHPtsE5dboJq9hvkt7L4edUHdjC5ULcBvG ViHQe2cKCtdwoxF7
A01qjuuAzbAYbptGsm2GvfNYLKhQGJbq/WIN4u6Vpvk/RGFbpz95uP9y5UXN jvdkyE6D69xK3bBo
xwc78x+7f2loCqYxqOkINlv9wQ1TxsM3llnvf4Hfbw/mL3JOnUxjslUu2DNS eXpPEYJObvkoNicU
rpu9XvI1h8HXJycvhaVc4lPDFz3+BVBLAwQUAAAACACGUls0mqskIqcEAACQ DQAAQwAAAE15Q29u
dGFjdHMvc3JjL2NvbS9tYWd1cmkvbXljb250YWN0cy9hY3Rpb25zL0Ryb3BD b250YWN0QWN0aW9u
LmphdmGtVm1P40YQ/pxI+Q+jIF0djhr1M0IqIkeb3glQCeVjtbHHyYK9a+2u k0tP/PfOvvgliQNU
KgpOvDuvzzwzuyVLXtgSIZFFXLBlpXhcbBMpDEuMjunBpdAXo+FoyItSKgNS LWNMcl5qjJ8zlmAQ
iq/c18Ubggq1rBT9mBXkcoo6Ubw0Ur2ls+a4QaXj2QPm+K6HVtqoKjGVwvRD ehsuUrmJn9xXv2DF
OzF849qgQHVc9EmqlwWKZHXPlPmA2Nuu60IEkG/oVaptR92vd+p0pKApZ7lc 6niqZHntF6du6eId
xUKmmMfX4XXKDHPOzk9PR0M4hV9ZZVZSgdPTzBjult3jTyzkGjUwCNYgU7IA s0JwVlvJ+YprSHKm
NVAwORYojIZD2EFL4BQpE5C7JTDSGUhWTCyRtAXoWklDKgUCM+0SlEqueWqZ 4tRmZMC5ZhrPoE7y
LyIT0KrCpXVCXAJGWbRmrG5jCqIHxB1dn8nESp2PhmW1yHkSsuvAf+Ujwu+U RqrBv3bT3y/y2Wg4
GPRg8sPWYxDcZFywHLRhhl6oGbhYwmwKlzB+s9HjlAILi+MLMmctKr5mBoPJ fcaCb5092Z7+cxW5
pXrviS6kzJEKmbaQUJgZy7WT9B9Hs4HlWckUK4JTt3TeJH2IanQk2gn8sCDa mofWJ5dtIgONZpZG
s+mkfptTeaKxtV9XeNzuUQJzXrYifUwPpCEKLZWsyqB9fg6PggpiC00UBpam wO1sdJunwcHetIxo
mf6uFtoocvE4u8+rJRcx3xW7Ic9+xyk4lbIkmJib1vffHn+b3f49m57BzDn4 ilsdX9/dzq+u5xMf
nsN2EAK9otjaBso7nbjB3U5sxep+tCbCiF2iaRjxgGrNE4wmMSV+QOjIlscF 8joaOg5AJKT4+Q+2
ZqlMJoEQGvG9M+lEVSIK8v75O3Wzbe3Nin64+ngF6nWW51uaGHaIUPM9y8U+ y9aSp2AtBhbxDKIO
ecPqoDsqIWmIHXXXJ3VPWFhuuNLmi+/6yOXtcL8rUVhG+ckNmVQu3koj/ZDW csaV55iNIiTitA+G
PKQJhSBoNB1sRZ36rDDPo8lZoE2IvQnxlhVIuX+GMYyDyOc6QV9eekm9VEiD E73p8C9pwiBcUhSx
pKx8kh7AdvcSnnwkd189lB6GKdHDoLZ5Hj1G9qKlk9dBGSt3AH0RRm2jsB9c v9K//fH6X1n24SP5
JOWUmcZd/s1X2NdMRaUNLBCCTmr5Kbr05LrZ66NlvWmp+W7PeVT+r7brvR6d NDleu0GQRm9ek84+
dP/bA5IgoU/G7fGMa1RbMLzA7jHdvRXYm4DMLKRevz3be28H8CBhKytfGIIR dOXmBTNO3drx1slq
klTK2uG+YnLxTObImTWgaNV60SaGaOe24e1srBlMXoBnXZvcxdydGOFOEfdW /wDtXXihdBi3SLYK
gS/9Z7Drv0bJdx8X9kZhFLEAw0WlnoWNUYqdLiAiQZn1Xgjq9g4z0A7HfrHG Yjsv6rmp+T/EZTs1
fgmz6NOn40O1E9EOqiGSfQAoFp+/bQV6UKoaneguJNoxwl4zf3LXZ2wmk0PI Fus4tu3oGQ3p+19Q
SwMEFAAAAAgAgFJbNLbFeI4BBQAAJw8AAEkAAABNeUNvbnRhY3RzL3NyYy9j b20vbWFndXJpL215
Y29udGFjdHMvYWN0aW9ucy9Ecm9wQ29udGFjdHNHcm91cEFjdGlvbi5qYXZh nVdbTys3EH4OUv7D
NEc6Z4PSRX1GSEUETtNzDqACRX2qnN1JYtjYK9sbmiL+e8fjvebCpQE2u965 eeb7ZkwukkcxR0j0
Ml6KeWFkvFwnWjmROBvTRWplj/sH/QO5zLVxoM08xiSTucX4YSYSLIXiU/46 fkUwlSLTcxv/QGvJ
55gfX1MwaHVh6Gay9PJoEyNzp81rOiuJT2hsPLnBDN8MqZF2pkhcYTB9l96T VKl+iu/5a7dgIVsx
fJfWoUKzX/Rem8cpqmRxLYx7h9jrrqvKlVW5oEdt1i31sN4q7G4E1DUbG52f hcWybh9XtF+NLvL3
qS91illcKY6FEx/TYFe8vaPDw/4BHMKvonALbYAVrXBO8jJf/sClXqEFAZU5 mHsDMDN6CW6BwNYb
hduFtJBkwlqgoDJcoiKd7XqD1SApYqEg4yVwmg0kC6HmSNoKbKVkIdUKQbhm CXKjVzL1EGW1CRlg
18LiCKrN/kkoBlo1OPdOCMQgaDONGa9bm4LoBrGjG3Yy9FL+76h/kBfTTCbl DrdKeBpiw39oQ6mF
8NhOxCbORv2DXm9Hdp59gXqls5lUIgPrhKMH4qNUc5iM4QQGrzanOKXwqkWu 2uCYjHq7Rq6Ew9Lw
JnUgcHhDdkcj4ApdUv03RKdaZ0iF9f45LRTqTGR2n5x+3BCot74vw9GemIfw 7BPqkVB2IrLcbKdn
0U3SaDIeVk+3VKpo4L3UdQf2M2hEKMpbmTeS1uO+hBCmbWI0ekdHcKeoOr7q hGwQaQrS92p+eVia
3ujeES3T53RqnSGLd5PrrJhLFcuu2AVRL7xhBVbJc8qW4HFz/f3u6+Ty78l4 BBN28A3XNj67urw9
PbsdhvAOj/y1DPSUYmt4lbUI+oRdgjZiFU29ibLlz9HVwLhBs5IJRsOYNr6F 7sjXhwN56R/4H8oI
REqrn38XK5HqZEhLvjFZxLfG6idTqKiUD9ffiOae808LuuFSBQVqAiLL1tRK fHehej3oKWscNXBb
aZmCt1gCSc4gqlFcrvUYrkQGPObHDjwDCOh91FkeVkzxWbqQxrrz0BEiTkNw xKpegAYdv2rfw8kJ
qCLLqiB6nbNCrHNU58YQhrzQCAYTtRIZbYbdM40Go6A4+EsXvqxfHBOUM2S0 diH0nwKA6dNlJX34
+lKHqx/LWBhEVxSA76xhusFMGzZcWKQb7Ukyk4YnBnstaxLU/2fOensmKKRz Mqaoe+8RiFqIXWCW
RcNRRaS6BpdiSfCtPEliMZ25cuqqSLbTkPAQSJmO5vUJ3Af7V9/aGRoTDRyG 5sFuSp/bZTc8dM+V
M+sAisrPS6cKLx8n0M6j16ea1WdM6jR69Qg2etfZsqFkdSig35n0ExhXaNbg 5BLbk7g9+P2w1zOf
qaDfjO+dBwC40bAmUC8LSyhGOiUUzHzhWN3bCdbJapIUhuyQF17W0wcyR868 AUOr3ot1MUSdA0Ww
8+TNYPIIcta2KTnmDs7Kc0O8s79spbubX8g5yU0qG4USTltztRo5tUoYSlL5 k4IzBAIsDyBVU6tN
Uuh0sFAJ6tnOEV8huOSiZ+lusdpi09Aq/lr5L4YO9kuJ+c+f95O7FVE3qVUo zf7rPtxwgnZqkQW7
GbGMB3+O/MLnZKxPsJwgX6ldia159kGWve+/jE+ppKZhMdpgC+6YxwHdU4RS J/UDTrXnm7T1u524
q53B85tjO7SgtyY3Xf4DUEsDBBQAAAAIAFVTWzTlY0lFewQAANAMAABHAAAA TXlDb250YWN0cy9z
cmMvY29tL21hZ3VyaS9teWNvbnRhY3RzL2FjdGlvbnMvU2hvd0NvbnRhY3RE YXRhQWN0aW9uLmph
dmGdVm1v4zYM/pwC/Q9EC9ycIHOwz0WBK5p1y3boFWi7+zgoNpOotSVDkpNl xf33kZIcO6nb9Fak
SiTzTQ8fkq5E9iyWCJku01IsayPTcptp5UTmbEqL1MpenJ6cnsiy0saBNssU s0JWFtOnhcgwCqVX
/uviHUGDVteGfsxKcjlFmxlZOW3e01lL3KCx6eweCzzqoZV2ps5cbTA/olfL jukv0jpUaN4W/abN
8xxVtroTxn1A7JtUud68JdjgG7G7oa022456OO/A/0aecikKvSQ7eX4dzqb+ 5OKIXqlzLNLruJ0K
J7yvyWh0egIj+Cxqt9IGvJ4Vzkl/7JeHlbSQFcJaIBcFlqichddYgtUgyb9Q UPgjcNobyFZCLZG0
FdhGyUKuFYJw7RFURq9lzln1ajMy4F0Li2NoQv+LEg90anDJTijvICyI1gzr 7kxBco+4pxtuMmQp
/p+cnlT1vJBZvOH9Sm+iOIN0FSLDf+g6uYWw7cJwmMHx6clgMOgB54XhHlRG roVDWEglCjhkD2wa
Eg3oE+KKotYJRxtiu1RLmE3hEs7eq2T6zvN4duYNts57asZn5pY4ciA617pA QU9bWMjzQhQ2SraB
9kOXvHHHIbwwUpzgNJyQ3fb6A4tuliez6bDZPVAOkjP2AU0g7OWsFaBQH2TV yhHFSAAWRpdEJIwM
Ib5EWKLqZAKPiqDkfBJjgXADyW3LPxxF6weNLKFj+ruaW2fI1OPsrqiXUqVy X+yGfIcnXsGrVBWB
JXwjvfvy+Nvs9u/ZdAwz7+BP3Nr0+uvtw9X1wzCEN5rwGgOlqu/US9EpvA3u F14r1pQfmwgAp0t0
u8Tfo1nLDJMhE+YVbRNOkA/ku+fvZASJ0urnP8Ra5Dob0hF3D4t4bFycm1ol UT6sv1PxciVvVvTD
ZygoUGmLothSg+CeQTX2pOdeY9Jyba1lDmwx8kguIOlwNJw26WNnXytU3CZC /yTEvMPaovG40QX4
oKFGoE7aKD9atIFCosRognXzyJed2hjmtQMZGlfU9v2L78FSC7msY8tSGjCX TswLurjKifxuBU+1
dUCNke04wg6ikYn/9sth5yfUqHQUdbbDJ0kn3SssimQ4jixMuoNg2NQ+C95I Y92vobslkYIDkaWa
8EvC9vuPsqF38p7vCHrt+Zkn707g8YfeGFp+NXOLPgvJiOMazRacLLE7LDqz ycOuF5znoN9OmN4Z
BfcatrqGklNGyIGtPY2F8+psJ1gnq1lWG7ITmEH7+ROZI2dswNApe7EuhWRv 5gU7GzaD2TPIRdem
9DF38xgnW9pbK6/Q3ocXKo9xi2SrEGupZwI07XOnFOpAKh5RzhALMI7JXYk2 khQ7TTSVoV70jqOm
gCMzyWPSL7azyMEEJw2brfwXqT9cXsIvkfafPr1N9U5Ee6jGSA4BoFj8/X05 0EJXtehF9yGxnhH8
svOTfzXD3TzyCHGyerH935X2sRfN81zaSltMDioGe8ZLYPgcIerk3LFVt2FL u3vWS76dM3g5OoUM
lnqNxwYRLf8BUEsDBBQAAAAIAE2xWTS6tVLipAEAAEYDAAA1AAAATXlDb250 YWN0cy9zcmMvY29t
L21hZ3VyaS9teWNvbnRhY3RzL0FwcGxpY2F0aW9uLmphdmGVUW1r2zAQ/mz9 iqP9MDusyg8Ig4U1
DK+lLa5D961c5IujVpaMJDcNI/9959hdOhoYA+MT0nPPy12L6hlrAuUa2WDd eS2bnXI2oophJoRu
WucjOF9LUka3gaRynqTvbNQNyfzOYFw73xSdtbgyNDvVErZRbnVVUwzyUofW 4O4krtPyjW+Zs/p0
MhEwgXKjAyiDgf9szTsTAI0BDC2xTXBriBsCbFujFUbt7KcA9Eqq68/MMBVt t+K3kWR+BAK7MNSQ
ZZoPWeCXEMnYGSJGLmtt0cB99NrWcHe9/J7fPOaX8AXOTk7wbCYSkUwnkFpn L37gC1ZOZSLhUF8D
0X/M9Zxf0icmkAZtLW9XTxz9wDT943G4hB45HtHXIePheLcNsHhV1PahOVeS jHuAaqgc4Th6qTxh
pBGSZjPGR7879CXasgTFzttvrqJTfXNbse0H559XZNUmHSU+g6Xtu+EfEfPq RQfn04yVeoU1pO8V
/pIoFuWyuHksFvflvCizwVMywD+uUC5+5uUb+EC+F/+E3171yP2wbDPGHkPI vrpA/VB6Mv724jdQ
SwMEFAAAAAgA6IZaNOUGIxn9AQAAcAgAAEUAAABNeUNvbnRhY3RzL3NyYy9j b20vbWFndXJpL215
Y29udGFjdHMvQXBwbGljYXRpb25BY3Rpb25CYXJBZHZpc29yLmphdmGdVctu 2zAQPItfsUAvcoAy
HyAUqOsAhQvklAI50yStsJZIgqTsBoX/vRRFRbFekaKLLe7M7HJ27dWEnkjO gaoSlySvjMDlK1XS
EepshpAotTIOlMkxp4XQluM/R0I59nGhJN7vlCp+EPNIpJcx2ceERy6r5ejf K+UX4CuB98/KnA5c
0pdnIZm6TOGI1oWgJChvQwKvvWVnYZVZwtm/kXZKHoW3t64pEsc9jxexeMvY rjlrRLK1NPvTqEqv
Ij8YpT+TtOZ9PuvTi7pE9gNxpOUiXR28k0ALYi1sO1v7nQD+13HJPKYf+IdQ oo04E8dh3BggE34l
Y8wBZwQ98BCYP1mEjxV0rI8qG3UO7O1pxwP/NKbO2ZmOTS3Qt68bbyvEx1aa m/RdLAuhK2pyGeU4
dZzBWQkGJTnxRtqm/V8gXMJHq52Q8W59A8kvE61Mo0TWKBieC+t8deNSLayL TqRYKn4rG7o31A3d
XiRcC8wpd/cZ6K/wZkKsxQ0nqcs0nL0uz+wYHEVR1EvAz1f6fhtAGQ7r+WrZ yf0dpFLJr7/ImTBF
NyiBO/huOV/zT/2lzhj3VLp0k4VU9ygZFN9J9RhA/WusP0l6mwucfz0QE827 DaaRiXPuntxrwdPN
JvMakYP9kE1M8QxsHBA6vkSoxs0r9YejQ4XrRFRk1OdXdEX/AVBLAwQUAAAA CADsoFk0EWO7UAYB
AABmAgAARQAAAE15Q29udGFjdHMvc3JjL2NvbS9tYWd1cmkvbXljb250YWN0 cy9BcHBsaWNhdGlv
bldvcmtiZW5jaEFkdmlzb3IuamF2YZWQwU7DMBBEz/FXrHoqF/9A1ENVcsgt ahE9ItfZhlUT27I3
aRHKv2NISVETJNiTpfWb
Re: Treeviewer = updating + adding + removing nodes [message #445084 is a reply to message #445009] Mon, 27 February 2006 18:51 Go to previous message
This is the kind of exception that usually revolves around a ClassNotFoundException (except the exception type isn't displayed) or a ClassCastException.
My guess is that your UI code is wired up somehow, and you're getting an object which isn't a Switch being inserted into something that expects it (as a guess; your ArrayList).
I posted a recent hints-and-tips on EclipseZone regarding the use of the debugger to catch uncaught exceptions in the debugger; I strongly recommend that you set up a breakpoint and look out for ClassNotFoundException (unlikely) or ClassCastException (very likely) being thrown. You'll probably find it's an insert into the generic lists, or a result of one of them.
To be honest, your iterator in the last sample bit of code looks suspect; you're assuming that any selected item is a box without doing an instanceof check. I'd bet that's where the classcast is coming from.
Alex.
Previous Topic:The WorkBench objects
Next Topic:Getting SelectionProvider in an Action
Current Time: Thu Nov 06 09:40:48 EST 2025
Powered by FUDForum. Page generated in 0.25553 seconds
