Home » Archived » M2M (model-to-model transformation) » [ATL] Problems to reference a non-default target pattern of a matched rule
[ATL] Problems to reference a non-default target pattern of a matched rule [message #44751] |
Wed, 06 June 2007 09:02 |
Originally posted by: erik_becker.gmx.de
I have a matched rule that has two target elements:
rule Activity {
from
element : XML!Element(
element.isFunction()
to
activity : XML!Element(
name <- 'Activity',
children <- ...
transition : XML!Element(
name <- 'Transition',
children <- ...
This rule dedicated to some elements that are linked another rule:
rule WorkflowProcess {
from
element.isEPK();
to
workflowProcess : XML!Element(
name <- 'WorkflowProcess',
children <- Sequence{activities, transitions}
activities : XML!Element(
name <- 'Activities',
children <- element.getElemsByName('ObjOcc')
->select(e | e.representsActivity())
transitions : XML!Element(
name <- 'Transitions',
If I do so both elements resulting from my rule 'Activity' are attached
to the transitions element.
What I want is that the default - activity - is attached to activities
and the transition elements to transitions.
In XML it should look like this:
<WorkflowProcess>
<Activities>
<Activity ...>
<Activity ...>
</Activities>
<Transitions>
<Transition ...>
<Transition ...>
</Transitions>
</WorkflowProcess>
I've already tried serveral this with and without resolveTemp() but
nothing worked.
Is there a solution for my problem?
Greetings
Erik
Re: [ATL] Problems to reference a non-default target pattern of a matched rule [message #45083 is a reply to message #44751] |
Fri, 08 June 2007 09:40 |
Originally posted by: rchevrel.sodius.com
--------------050107050005050808030603
I Eric,
You try to set children properties two times, but children is a
container features, so, it cannot work.
Instead of trying attach children node (Attributes -> children =
{attribute}), try to attach an Attribute to its container like:
-- We suppose that there is only one EPK. This helper allow us to refer
this specific element
helper def: EPK_Element : XML!Element =
M_in.getInstances(XML!Element)->select(e | e.isEPK())->first();
-- We change this rule in order to delegate the composition tree
construction to the children nodes
rule Activity {
from
to
-- we attach the child with its parent
parent <- thisModule.resolveTemp(thisModule.EPK_Element,
"activities"),
name <- 'Activity',
children <- ...
"transitions"),
children <- ...
-- We remove the problematic double children feature set
from
element.isEPK();
to
*R
Re: [ATL] Problems to reference a non-default target pattern of a matched rule [message #45174 is a reply to message #45083] |
Fri, 08 June 2007 09:58 |
--------------060306030905070009010807
Please replace the double quotes, with simple quote.
thisModule.resolveTemp(thisModule.EPK_Element, 'activities'),
thisModule.resolveTemp(thisModule.EPK_Element, 'transitions'),
R
Re: [ATL] Problems to reference a non-default target pattern of a matched rule [message #45296 is a reply to message #45174] |
Fri, 08 June 2007 12:30 |
Many thanks Regis! That works fine for me!
> Régis a écrit :
>> I Eric,
>> refer this specific element
>> rule Activity {
>> from
>> to
>> "activities"),
>> name <- 'Activity',
>> children <- ...
>> "transitions"),
>> children <- ...
>> from
>> element.isEPK();
>> to
>> Regards,
>> *Régis CHEVREL* <mailto:rchevrel@sodius.com>
>> SODIUS*
>> *6, rue Cornouaille
>> 44319 Nantes - France
>> Phone: +33 (0)2 28 23 54 34
>> ***www.mdworkbench.com* <http://www.mdworkbench.com/>* *
>> Draw more value from your model
>> Erik Becker a écrit :
>>> Hello,
>>> rule Activity {
>>> from
>>> to
>>> name <- 'Activity',
>>> children <- ...
>>> children <- ...
>>> from
>>> element.isEPK();
>>> to
>>> attached to the transitions element.
>>> activities and the transition elements to transitions.
>>> <WorkflowProcess>
>>> <Activities>
>>> <Activity ...>
>>> <Activity ...>
>>> </Activities>
>>> <Transitions>
>>> <Transition ...>
>>> <Transition ...>
>>> </Transitions>
>>> </WorkflowProcess>
>>> nothing worked.
>>> Greetings
>>> Erik
Current Time: Fri Apr 26 17:06:15 GMT 2024
Powered by FUDForum. Page generated in 0.03799 seconds
