Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Remove Ok / Cancel in Dialog
Remove Ok / Cancel in Dialog [message #444646] Mon, 18 October 2004 20:47 Go to next message
Originally posted by: manish.garg.gmail.com
I have a class MessageSearchDialog that overrides the
org.eclipse.jface.dialogs.Dialog. A code snippet for this class where the
view gets created is:
protected Control createDialogArea(Composite parent) {
mViewer = new MessageSearch(parent);
return mViewer.getControl();
The MessageSearch draws its own UI and there are my own buttons in there.
However, when I run the program there are also OK and Cancel buttons
provided by the Dialog. Is there some way to remove these buttons? I just
want my buttons.
thanks
P
Re: Remove Ok / Cancel in Dialog [message #444656 is a reply to message #444646] Tue, 19 October 2004 12:18 Go to previous messageGo to next message
If I don't want the OK and Cancel button I usually don't use Jface, and I
end up extending the SWT Dialog class.
At the end Jface is a wrapper around SWT that adds more features.
If you don't want it, don't use it... better than using and trying to find
a workaround to the extra stuff you don't want.
Fabrizio
On Mon, 18 Oct 2004 17:47:18 -0700, Piranha wrote:
> want my buttons.
> thanks
> P
Re: Remove Ok / Cancel in Dialog [message #444658 is a reply to message #444656] Tue, 19 October 2004 14:10 Go to previous messageGo to next message
Thanks Fabrizio,
The swt dialog comes with its own complexity so I want to use the jface
dialog. However, I realized it was quite easy. I guess I had not looked into
it properly.
I just over ride the createButtonsForButtonBar(Composite ...)
-P
"Fabrizio Bertocci" <fabrizio@rti.com> wrote in message
news:pan.2004.10.19.16.18.32.189771@rti.com...
> Fabrizio
> > Hi,
the
there.
just
> > want my buttons.
> > thanks
> > P
Re: Remove Ok / Cancel in Dialog [message #444661 is a reply to message #444658] Tue, 19 October 2004 17:38 Go to previous message
Ha... that works too!
SWT's Dialog is not so bad at the end... I've been using it without too
much "pain".
Fabrizio
On Tue, 19 Oct 2004 11:10:20 -0700, Piranha wrote:
> Thanks Fabrizio,
> it properly.
> -P
>> Fabrizio
>> > Hi,
> the
> there.
> just
>> > want my buttons.
>> > thanks
>> > P
Previous Topic:Button with image & text - Is it possible??
Next Topic:Focus problem on Mac
Current Time: Wed Nov 05 14:38:16 EST 2025
Powered by FUDForum. Page generated in 1.24383 seconds
