Home » Eclipse Projects » Standard Widget Toolkit (SWT) » StyledText layout problem
StyledText layout problem [message #444076] |
Wed, 06 October 2004 17:33 |
Originally posted by: jca.micromuse.com
I am trying to add multiple StyledText widgets to a single scrollable
widget. The idea is that I can add text to each StyledText and they
all scroll together within a single scrollbar. I am using multiple StyledTexts
because I will later add images between them. I have not found a way to embed images
to a StyledText widget.
This is the composite hierarchy I have right now :
Shell
ScrolledComposite
Group
StyledText1
StyledText2
StyledTextN
My problem is that even just having a single StyledText in the group does
not display across the entire window. The StyledText is only
big enough to display its text and I don't know how to set the size of
the StyledText, I have tried setSize() and setBounds() to large numbers
but that did not work, here is a code sample :
public Composite getComposite(final Composite aParentComposite)
gScrolledComposite = new ScrolledComposite(aParentComposite,
SWT.V_SCROLL | SWT.H_SCROLL);
gGroup = new Group(gScrolledComposite, SWT.SHADOW_NONE );
gScrolledComposite.setContent(gGroup);
aParentComposite.setBackground(new Color(gDisplay, 0, 255, 0));
gGroup.setBackground(new Color(gDisplay, 255, 0, 0));
RowLayout aRowLayout = new RowLayout(SWT.VERTICAL);
aRowLayout.wrap = false;
aRowLayout.spacing = 0;
gGroup.setLayout(aRowLayout);
StyledText aStyledText = new StyledText(gGroup, SWT.NONE);
aStyledText.setText("xxx");
aStyledText.setSize(600, 400);
gGroup.layout(true);
gGroup.setSize(600, gGroup.computeSize(SWT.DEFAULT, SWT.DEFAULT, true).y);
return gScrolledComposite;
SO all I get is a StyledText that displays 'xxx' and which does not
have room for me to add any more text.
Any help is much appreciated,
thanks,
John.
Re: StyledText layout problem [message #444151 is a reply to message #444076] |
Thu, 07 October 2004 20:23 |
Lynne Kues Messages: 1 Registered: July 2009 |
Since you're using layouts, you need to specify any sizes in the layout data
for the widget. Something like the following should work:
Test test = new Test();
Shell shell = new Shell(SWT.TITLE | SWT.MENU | SWT.MIN | SWT.RESIZE |
SWT.MAX);
shell.setLayout(new RowLayout(SWT.VERTICAL));
Composite group = new Composite(shell, SWT.NULL);
group.setLayout(new RowLayout());
StyledText text = new StyledText(group, SWT.NONE);
text.setText("xxx");
RowData data = new RowData();
data.height = 400;
data.width = 600;
text.setLayoutData(data);
shell.pack();
shell.open();
Display display = shell.getDisplay();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
"John Carroll" <jca@micromuse.com> wrote in message
news:ck19tb$sm9$1@eclipse.org...
StyledTexts
embed images
> Shell
> ScrolledComposite
> Group
> StyledText1
> StyledText2
> StyledTextN
true).y);
> thanks,
> John.
Re: StyledText layout problem [message #444192 is a reply to message #444151] |
Fri, 08 October 2004 13:42 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
If you don't want to hard code widths, you can use GridLayout or FormLayout:
public static void main (String [] args) {
Display display = new Display ();
Image image = new Image(display,
Newsgroup.class.getResourceAsStream("../images/image.bmp"));
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
ScrolledComposite sc = new ScrolledComposite(shell, SWT.V_SCROLL |
SWT.H_SCROLL);
Composite c = new Composite(sc, SWT.NONE);
c.setLayout(new GridLayout());
for (int i = 0; i < 10; i++) {
StyledText text = new StyledText(c, SWT.MULTI | SWT.WRAP |
SWT.BORDER);
text.setText("paragraph 1");
GridData data = new GridData(SWT.FILL, SWT.TOP, true,
false);
data.heightHint = 50;
Label label = new Label(c, SWT.NONE);
label.setImage(image);
label.setLayoutData(new GridData(SWT.CENTER, SWT.TOP, false,
false));
label.setText("Figure "+i);
false));
c.layout();
sc.setContent(c);
Point size = c.computeSize(SWT.DEFAULT, SWT.DEFAULT);
sc.setExpandHorizontal(true);
sc.setExpandVertical(true);
sc.setMinSize(size);
shell.setSize(400, 300);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Lynne Kues" <lynne_kues@oti.com> wrote in message
news:ck48b2$6o7$1@eclipse.org...
> data
> public static void main(String[] args) {
> SWT.MAX);
> data.height = 400;
> data.width = 600;
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
> StyledTexts
> embed images
>> Shell
>> ScrolledComposite
>> Group
>> StyledText1
>> StyledText2
>> StyledTextN
> true).y);
>> thanks,
>> John.
Current Time: Fri Apr 26 13:59:15 GMT 2024
Powered by FUDForum. Page generated in 0.03715 seconds
