Home » Eclipse Projects » Rich Client Platform (RCP) » Connect to JBOSS ejb3 via RMI
Connect to JBOSS ejb3 via RMI [message #444005] Tue, 07 February 2006 20:12 Go to next message
Hi everyone,
I'm trying to connect my RCP application to my back end EJB3 server
application running on JBOSS4.0.3sp1.
I have read the earlier postings regarding connecting from an RCP client
to an ejb via rmi.
the code that i am using is:
> try{
> Context ctx = new InitialContext();
> ms = (MaseSystem) ctx.lookup(MaseSystem.class.getName());
> }catch(Exception e){
> e.printStackTrace();
where MaseSystem is my remote interface. I have included the server
application code as a dependency for my Rcp application.
This code works fine when i use it in a command line application client
however i get the following error inside my RCP application:
javax.naming.NoInitialContextException: Cannot instantiate class:
org.jnp.interfaces.NamingContextFactory [Root exception is
java.lang.ClassNotFoundException: org.jnp.interfaces.NamingContextFactory]
I have tried the proposed solution that is mentioned in the thread
"problem accessin ejbs on jboss from rcp" but this did not work.
-Is there something that I'm missing?
-does the fact that I'm using ejb3 standard have an impact on how things
work?
Please help.
Robert.
Re: Connect to JBOSS ejb3 via RMI [message #444012 is a reply to message #444005] Wed, 08 February 2006 05:35 Go to previous messageGo to next message
Hi Robert,
if you have some time, try to take a look at the sources of
http://sourceforge.net/projects/paperdog
Here we connect a RCP frontend to EJBs on a JBoss Server. It is even
possible to hook up the RCP-client to JBoss transparently over http,
which makes it interesting for firewalled environments :)
Stephan
www.imedic.de
www.rcp-training.com
Robert wrote:
> Hi everyone,
> to an ejb via rmi.
> > try{
> work?
> Please help.
> Robert.
Re: Connect to JBOSS ejb3 via RMI [message #444029 is a reply to message #444012] Wed, 08 February 2006 12:00 Go to previous messageGo to next message
Thanks for the link Stephan, I've looked at the code for a bit but i
still think that I'm missing something. are you using a jndi.properties
file? where do you specify this information? It doesn't appear like you
are using the EJB3 standard in the linked application? Do you know if
there is a difference on how connection is done with ejb3 and RCP clients?
In my code when i go to create the initial context:
this is throwing the the naming exception i mentioned in my earlier
post. The error message says that this is caused by:
Caused by: java.lang.ClassNotFoundException:
do i need to include a specific lib? if so which one?
now I'm still new to RCP development so i was wondering if there is a
much simpler example out there that i could look at or if there is a
tutorial or book that explains how to connect to EJB's from and RCP client.
Thanks Again,
Robert.
Stephan Wilczek wrote:
> Hi Robert,
> Regards
> Stephan
Re: Connect to JBOSS ejb3 via RMI [message #444303 is a reply to message #444029] Mon, 13 February 2006 12:09 Go to previous message
Hello!
It seems to be a very common problem for those, who tries to access
J2EE server from RCP clients. We decided to create a small example, that
illustrates how to overcome RCP class loading behavior in such cases.
This example can be downloaded from here:
http://www.rcp-training.com/examples/JNDIBrowserExample.zip
Please take a closer look at JNDIView.getInitialContext() implementation. If
you have any further questions - feel free to ask.
Aleksey Aristov
www.imedic.de
Previous Topic:Split the editor area
Next Topic:RCP app wont start after update
Current Time: Mon Jul 07 08:15:51 EDT 2025
Powered by FUDForum. Page generated in 0.11898 seconds
