Re: application for pocket PC [message #443822 is a reply to message #443821] |
Fri, 01 October 2004 16:31 |
Originally posted by: skpeter.myrealbox.com
Hi Alberto!
Open Run/Run ... and select your run configuration, then open second tab folder
[(x)= Arguments] and add following to VM arguments:
-Djava.library.path=${system:ECLIPSE_HOME}/plugins/org.eclip se.swt.${system:WS}_3.0.1/os/${system:OS}/${system:ARCH}
Note, that if you are using different version of SWT then 3.0.1, change the
accordingly.
HTH,
Peter
Alberto wrote:
> and for this i have imported in my Class Path the
> library "Standard Widget Toolkit (SWT)" but when i
> run the application appear this error:
> "java.lang.UnsatisfiedLinkError: no swt-win32-3063 in
> java.library.path"
> Why ?
> Thanks at all !!
Re: application for pocket PC [message #444150 is a reply to message #444043] |
Thu, 07 October 2004 20:06 |
Originally posted by: skpeter._no_spam_.myrealbox.com
Hi Alberto,
just make sure you didn't forget to put minus sign at the beginning of the
string. This is JVM argument and they usually start with -.
HTH,
Peter
Alberto wrote:
> Peter Skopek wrote:
>>Hi Alberto!
> folder
>>accordingly.
>>HTH,
>>Peter
>>>java.library.path"
>>> Why ?
>>>Thanks at all !!
> Hello Peter,
> thank you for your answer , but when i have put in the VM folder
> the line
> " Djava.library.path=${system:ECLIPSE_HOME}/plugins/org.eclips e.swt.${system:WS}_3.0.1/os/${system:OS}/${system:ARCH} "
> compare this error message :
> "java.lang.NoClassDefFoundError:
> Djava/library/path=${system:ECLIPSE_HOME}/plugins/org/eclips e/swt/${system:WS}_3/0/1/os/${system:OS}/${system:ARCH}
> Exception in thread "main" "
> Hello,
> Alberto
FUDForum. Page generated in 0.03206 seconds
