| Multi line label [message #443631] |
Tue, 28 September 2004 17:02  |
I have to show some name value pairs in a dialog.
The dialog has a fixed size (PPC).
I used GridLayout with two columns.
The scheme is as folowing:
date label (1. column) | concrete date (2. column)
descr label | description text
An example:
date: 09.25.04
description: Now a longer description which
contains many words.
date: 09.28.04
The problem is the label with the description, which needs
often more than one row. I need a multi line label but SWT
declared SWT.MULTI not for labels.
Thats why, I tried a text field with text.setEnabled(false);
for showing the description. But that causes two problems:
1. I have to set the height of the description text field so
that the height is sufficient but not bigger.
GridData.FILL_VERTICAL lets free space and gridData.heighHint
demands the optimal height of the label which I don't know.
I tried also with pack() but had no success.
2. The font looks disabled and because I set
setEnabled(false) setForeGround(black) and so on has no
effect.
That seems to be a simple problem but I searched a solution
for a long time without result. Does anybody know how I
can display multi line labels?
Regards, Tobi
text = new Text(shell, SWT.MULTI | SWT.WRAP);
text.setText(buffer.toString());
gridData = new GridData(GridData.FILL_HORIZONTAL
| GridData.FILL_VERTICAL);
text.setLayoutData(gridData);
| Re: Multi line label [message #443692 is a reply to message #443689] |
Wed, 29 September 2004 06:57   |
Hi Richard,
thank you for your answer. I also tried:
text.setEditable(false);
text.setBackground(white);
instead:
Then the background and foreground color is ok but
the text has a cursor and can marked.
While the problem 2 is 'only' ugly, the first one is more important
because the app is for Pocket PC and there space is thinly distributed.
Regards, Tobi
"Richard Moore" <rmoore@infometis.ch> schrieb im Newsbeitrag
news:cje0mk$3hg$1@eclipse.org...
> Hi Tobi,
> Try using a text and setting the editable to false, you could even change
> the background color to gray... looks like a label then... I think setting
> enable to false stops the scrolling of a text ? editable I do not know if
> the scrolling still works... try it out.
> Regards
> Richard
> "Tobi Wink" <tobi.winkesf@lycos.com> wrote in message
> news:cjck1d$uh1$1@eclipse.org...
>> Hello,
>> An example:
>> date: 09.25.04
>> date: 09.28.04
>> effect.
>> Regards, Tobi
| Re: Multi line label [message #443696 is a reply to message #443692] |
Wed, 29 September 2004 08:04   |
Here is a possible solution that is using the StyledText widget
from the SWT custom package:
public class Main {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
final StyledText st = new StyledText(shell, SWT.MULTI | SWT.READ_ONLY);
st.setText("Hello World");
st.setCursor(display.getSystemCursor(SWT.CURSOR_ARROW));
st.setCaret(null);
st.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
st.setSelection(0);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
Just set the background to gray or something like that.
> Hi Richard,
> instead:
> Regards, Tobi
> > Hi Tobi,
> > Regards
> > Richard
> >> Hello,
> >> An example:
> >> date: 09.25.04
> >> date: 09.28.04
> >> effect.
> >> Regards, Tobi
| Re: Multi line label [message #443793 is a reply to message #443722] |
Thu, 30 September 2004 13:26  |
Why is the same algorithm not necessary using a Text control with SWT.WRAP.
news:cjescp$1ab$1@eclipse.org...
> "Steve Northover" <steve_northover@ca.ibm.com> schrieb im Newsbeitrag
> news:cjergm$v7q$1@eclipse.org...
> > Why not just use SWT.WRAP for your label?
> That helps not much because then the label is one row high without settig
> GridData.
> And if I set gridData.heightHint=50 or so the label is often too big (or
> better too many rows high). I need then an algorithm to
> calculate this height.
> Tobi
FUDForum. Page generated in 0.04938 seconds
