Home » Archived » XML Schema Definition (XSD) » Resource notifications
Re: Resource notifications [message #44628 is a reply to message #44597] |
Mon, 17 May 2004 15:15 |
Lance,
The resource delta support is part of the platform so you'll need to ask them
about it.
Lance Phillips wrote:
> Ed,
> I am pretty sure this is not an XSD specific issue, but it is
> manifesting itself with XSDResources, so we'll start there. If I right
> click an XSDResource in the workspace and bring up the resource properties.
> Changing the read only status of the resource does not seem to produce any
> notifications. I have breakpoints is the delta processor for the resources
> as well as the notification processor... neither receive anything when I
> change that state. Is that expected, or are we missing something?
> thanks,
> lp
Re: Resource notifications [message #45470 is a reply to message #44659] |
Tue, 25 May 2004 15:24 |
Lance Phillips Messages: 210 Registered: July 2009 |
Ed,
I finally got a chance to get back to this. Here is the problem... the
events ARE getting processed, but the resource is never marked as dirty and
no notifications come out of the change.
The method in question is elementAttributeChanged on
XSDConcreteComponentImpl. It seems that notifications need to fired here
and at a minimum the resource needs to be marked as dirty???
thanks,
lp
"Lance Phillips" <lphillips@metamatrix.com> wrote in message
news:c8amte$f8h$1@eclipse.org...
> Thanks Ed!
> lp
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:40A8D71D.33FC8542@ca.ibm.com...
> > Lance,
> them
> > about it.
> > > Ed,
right
> properties.
> any
> resources
I
> > > thanks,
> > > lp
Re: Resource notifications [message #45588 is a reply to message #45470] |
Tue, 25 May 2004 16:16 |
Lance,
The sample editor doesn't do resource delta listening. Is that what you are
getting at?
> Ed,
> thanks,
> lp
> > Thanks Ed!
> > lp
> > > Lance,
> > them
> > > about it.
> > > > Ed,
> right
> > properties.
> > any
> > resources
> I
> > > > thanks,
> > > > lp
Re: Resource notifications [message #45618 is a reply to message #45588] |
Tue, 25 May 2004 17:01 |
Wrong thread.... sorry.
My issue was actually with changing the value of one of the DOM attributes
we've added to our objects. When we change one of those values in the
property editor we don't get a notification or resource dirty change. As
refresher for you, we hang some user properties as DOM Attr entities under
the XSDAnotation for our XSDSimpleTypeDefinitions. We see the properties
fine in our editor and are able to change them fine. It gets into the
method mentioned above fine, but we end up with no notifications and the
resource still shows as not dirty.
Sorry for the confusion.
thanks,
lp
news:40B3715B.F66AC009@ca.ibm.com...
> Lance,
are
> getting at?
> > Ed,
the
and
here
> > thanks,
> > lp
> > > Thanks Ed!
> > > lp
> > > > Lance,
ask
> > > them
> > > > about it.
> > > > > Ed,
> > right
> > > properties.
produce
> > > any
> > > resources
when
> > I
> > > > > thanks,
> > > > > lp
Re: Resource notifications [message #45678 is a reply to message #45618] |
Tue, 25 May 2004 17:09 |
Lance,
Did you modify the DOM without using a command?
> thanks,
> lp
> > Lance,
> are
> > getting at?
> > > Ed,
> the
> and
> here
> > > thanks,
> > > lp
> > > > Thanks Ed!
> > > > lp
> > > > > Lance,
> ask
> > > > them
> > > > > about it.
> > > > > > Ed,
> > > right
> > > > properties.
> produce
> > > > any
> > > > resources
> when
> > > I
> > > > > > thanks,
> > > > > > lp
Re: Resource notifications [message #45997 is a reply to message #45678] |
Wed, 26 May 2004 14:40 |
Yes! Could you point me at a code example of how to use a set command for a
DOM entity?
thanks,
lp
news:40B37DDF.3FF74443@ca.ibm.com...
> Lance,
attributes
As
under
properties
> > thanks,
> > lp
> > > Lance,
you
> > are
> > > getting at?
> > > > Ed,
problem...
> > the
dirty
> > and
> > here
> > > > thanks,
> > > > lp
> > > > > Thanks Ed!
> > > > > lp
> > > > > > Lance,
need to
> > ask
> > > > > them
> > > > > > about it.
> > > > > > > Ed,
is
If I
> > > > right
resource
> > > > > properties.
> > produce
> > > > > any
the
> > > > > resources
anything
> > when
> > > > I
something?
> > > > > > > thanks,
> > > > > > > lp
Re: Resource notifications [message #46030 is a reply to message #45997] |
Wed, 26 May 2004 15:09 |
Lance,
You need to write your own command to do this. You can follow the way the
emf.edit commands are written.
> DOM entity?
> thanks,
> lp
> > Lance,
> attributes
> As
> under
> properties
> > > thanks,
> > > lp
> > > > Lance,
> you
> > > are
> > > > getting at?
> > > > > Ed,
> problem...
> > > the
> dirty
> > > and
> > > here
> > > > > thanks,
> > > > > lp
> > > > > > Thanks Ed!
> > > > > > lp
> > > > > > > Lance,
> need to
> > > ask
> > > > > > them
> > > > > > > about it.
> > > > > > > > Ed,
> is
> If I
> > > > > right
> resource
> > > > > > properties.
> > > produce
> > > > > > any
> the
> > > > > > resources
> anything
> > > when
> > > > > I
> something?
> > > > > > > > thanks,
> > > > > > > > lp
Re: Resource notifications [message #46060 is a reply to message #46030] |
Wed, 26 May 2004 18:04 |
OK... I've written my own command to perform this change within a command.
I modeled my command after the SetCommand.
What do I have to do in my doExecute method to cause some notifications to
get fired? I have the XSDSimpleType definition that owns the Annotation.
But, it does not think that it has changed at the end of this process.
thanks,
lp
news:40B4B330.F7C465DB@ca.ibm.com...
> Lance,
for a
> > DOM entity?
> > thanks,
> > lp
> > > Lance,
> > attributes
the
change.
> > As
> > under
> > properties
the
the
> > > > thanks,
> > > > lp
> > > > > Lance,
what
> > you
> > > > are
> > > > > getting at?
> > > > > > Ed,
> > problem...
> > > > the
as
> > dirty
> > > > and
fired
> > > > here
> > > > > > thanks,
> > > > > > lp
> > > > > > > Thanks Ed!
> > > > > > > lp
> > > > > > > > Lance,
> > need to
> > > > ask
> > > > > > > them
> > > > > > > > about it.
> > > > > > > > > Ed,
but it
> > is
there.
> > If I
> > > > > > right
> > resource
> > > > > > > properties.
seem to
> > > > produce
> > > > > > > any
for
> > the
> > > > > > > resources
> > anything
> > > > when
> > > > > > I
> > something?
> > > > > > > > > thanks,
> > > > > > > > > lp
Re: Resource notifications [message #46088 is a reply to message #46060] |
Wed, 26 May 2004 18:21 |
Nevermind... I've got it.
Thanks for the help Ed!
lp
news:c92lpf$p8$1@eclipse.org...
> thanks,
> lp
> > Lance,
the
> for a
> > > DOM entity?
> > > thanks,
> > > lp
> > > > Lance,
> > > attributes
> the
> change.
> > > As
entities
> > > under
> > > properties
> the
and
> the
> > > > > thanks,
> > > > > lp
> > > > > > Lance,
> what
> > > you
> > > > > are
> > > > > > getting at?
> > > > > > > Ed,
> > > problem...
> > > > > the
> as
> > > dirty
> > > > > and
> fired
> > > > > here
> > > > > > > thanks,
> > > > > > > lp
> > > > > > > > Thanks Ed!
> > > > > > > > lp
> > > > > > > > > Lance,
you'll
> > > need to
> > > > > ask
> > > > > > > > them
> > > > > > > > > about it.
> > > > > > > > > > Ed,
> but it
> > > is
> there.
> > > If I
> > > > > > > right
> > > resource
> > > > > > > > properties.
> seem to
> > > > > produce
> > > > > > > > any
processor
> for
> > > the
> > > > > > > > resources
> > > anything
> > > > > when
> > > > > > > I
> > > something?
> > > > > > > > > > thanks,
> > > > > > > > > > lp
Re: Resource notifications [message #587138 is a reply to message #44597] |
Ed Merks Messages: 33142 Registered: July 2009 |
Lance,
about it.
> Ed,
> thanks,
> lp
Ed Merks
Re: Resource notifications [message #587497 is a reply to message #44659] |
Ed,
thanks,
lp
> Thanks Ed!
> lp
> > Lance,
> them
> > about it.
> > > Ed,
right
> properties.
> any
> resources
I
> > > thanks,
> > > lp
Re: Resource notifications [message #587562 is a reply to message #45470] |
Lance,
getting at?
> Ed,
> thanks,
> lp
> > Thanks Ed!
> > lp
> > > Lance,
> > them
> > > about it.
> > > > Ed,
> right
> > properties.
> > any
> > resources
> I
> > > > thanks,
> > > > lp
Ed Merks
Re: Resource notifications [message #587570 is a reply to message #45588] |
thanks,
lp
> Lance,
are
> getting at?
> > Ed,
the
and
here
> > thanks,
> > lp
> > > Thanks Ed!
> > > lp
> > > > Lance,
ask
> > > them
> > > > about it.
> > > > > Ed,
> > right
> > > properties.
produce
> > > any
> > > resources
when
> > I
> > > > > thanks,
> > > > > lp
Re: Resource notifications [message #587591 is a reply to message #45618] |
Lance,
> thanks,
> lp
> > Lance,
> are
> > getting at?
> > > Ed,
> the
> and
> here
> > > thanks,
> > > lp
> > > > Thanks Ed!
> > > > lp
> > > > > Lance,
> ask
> > > > them
> > > > > about it.
> > > > > > Ed,
> > > right
> > > > properties.
> produce
> > > > any
> > > > resources
> when
> > > I
> > > > > > thanks,
> > > > > > lp
Ed Merks
Re: Resource notifications [message #587685 is a reply to message #45678] |
DOM entity?
thanks,
lp
> Lance,
attributes
As
under
properties
> > thanks,
> > lp
> > > Lance,
you
> > are
> > > getting at?
> > > > Ed,
problem...
> > the
dirty
> > and
> > here
> > > > thanks,
> > > > lp
> > > > > Thanks Ed!
> > > > > lp
> > > > > > Lance,
need to
> > ask
> > > > > them
> > > > > > about it.
> > > > > > > Ed,
is
If I
> > > > right
resource
> > > > > properties.
> > produce
> > > > > any
the
> > > > > resources
anything
> > when
> > > > I
something?
> > > > > > > thanks,
> > > > > > > lp
Re: Resource notifications [message #587696 is a reply to message #45997] |
Lance,
> DOM entity?
> thanks,
> lp
> > Lance,
> attributes
> As
> under
> properties
> > > thanks,
> > > lp
> > > > Lance,
> you
> > > are
> > > > getting at?
> > > > > Ed,
> problem...
> > > the
> dirty
> > > and
> > > here
> > > > > thanks,
> > > > > lp
> > > > > > Thanks Ed!
> > > > > > lp
> > > > > > > Lance,
> need to
> > > ask
> > > > > > them
> > > > > > > about it.
> > > > > > > > Ed,
> is
> If I
> > > > > right
> resource
> > > > > > properties.
> > > produce
> > > > > > any
> the
> > > > > > resources
> anything
> > > when
> > > > > I
> something?
> > > > > > > > thanks,
> > > > > > > > lp
Ed Merks
Re: Resource notifications [message #587704 is a reply to message #46030] |
thanks,
lp
> Lance,
for a
> > DOM entity?
> > thanks,
> > lp
> > > Lance,
> > attributes
the
change.
> > As
> > under
> > properties
the
the
> > > > thanks,
> > > > lp
> > > > > Lance,
what
> > you
> > > > are
> > > > > getting at?
> > > > > > Ed,
> > problem...
> > > > the
as
> > dirty
> > > > and
fired
> > > > here
> > > > > > thanks,
> > > > > > lp
> > > > > > > Thanks Ed!
> > > > > > > lp
> > > > > > > > Lance,
> > need to
> > > > ask
> > > > > > > them
> > > > > > > > about it.
> > > > > > > > > Ed,
but it
> > is
there.
> > If I
> > > > > > right
> > resource
> > > > > > > properties.
seem to
> > > > produce
> > > > > > > any
for
> > the
> > > > > > > resources
> > anything
> > > > when
> > > > > > I
> > something?
> > > > > > > > > thanks,
> > > > > > > > > lp
Re: Resource notifications [message #587713 is a reply to message #46060] |
lp
> thanks,
> lp
> > Lance,
the
> for a
> > > DOM entity?
> > > thanks,
> > > lp
> > > > Lance,
> > > attributes
> the
> change.
> > > As
entities
> > > under
> > > properties
> the
and
> the
> > > > > thanks,
> > > > > lp
> > > > > > Lance,
> what
> > > you
> > > > > are
> > > > > > getting at?
> > > > > > > Ed,
> > > problem...
> > > > > the
> as
> > > dirty
> > > > > and
> fired
> > > > > here
> > > > > > > thanks,
> > > > > > > lp
> > > > > > > > Thanks Ed!
> > > > > > > > lp
> > > > > > > > > Lance,
you'll
> > > need to
> > > > > ask
> > > > > > > > them
> > > > > > > > > about it.
> > > > > > > > > > Ed,
> but it
> > > is
> there.
> > > If I
> > > > > > > right
> > > resource
> > > > > > > > properties.
> seem to
> > > > > produce
> > > > > > > > any
processor
> for
> > > the
> > > > > > > > resources
> > > anything
> > > > > when
> > > > > > > I
> > > something?
> > > > > > > > > > thanks,
> > > > > > > > > > lp
Current Time: Fri Apr 26 20:39:13 GMT 2024
Powered by FUDForum. Page generated in 0.05021 seconds
