Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Setting the widget size while using GridLayout
Setting the widget size while using GridLayout [message #442546] Tue, 07 September 2004 15:42 Go to next message
Originally posted by: kevin.clark.accessbc.com.nospam
I'm making a subclass of the JFace dialog. The dialog requires that I use
GridLayout to set up the dialog area. For some reason though, I am unable
to set the size of my widgets. It's extremely frustrating. I'm used to
designing with FormLayout, and have never run into this problem.
I'm likely overlooking something small (or perhaps it's just inexperience
with GridLayout). But I'd like to know how I can set the size of each of
my widgets.
The code sample below illustrates what I'm doing:
protected Control createDialogArea(Composite parent){
Composite comp = new Composite(parent, SWT.NONE);
// Create a new layout using GridLayout
GridLayout layout = new GridLayout();
layout.numColumns = 4;
layout.marginHeight = 3;
layout.marginWidth = 3;
layout.verticalSpacing = 5;
comp.setLayout(layout);
Label lAmount = new Label(comp, SWT.WRAP);
lAmount.setText("Amount:");
GridData data = new GridData();
data.horizontalSpan = 2;
data.horizontalIndent = 10;
lAmount.setLayoutData(data);
Label lDescription = new Label(comp, SWT.WRAP);
lDescription.setText("Description:");
lDescription.setLayoutData(data);
//Row two
Label lDollar = new Label(comp, SWT.WRAP | SWT.RIGHT);
lDollar.setText("$");
//This line has no effect on the widget at all.
lDollar.setSize(50, SWT.DEFAULT);
lDollar.setLayoutData(data);
Text _tAmount = new Text(comp, SWT.BORDER | SWT.SINGLE);
//Again, this line has no effect
_tAmount.setSize(60, SWT.DEFAULT);
_tAmount.setLayoutData(data);
//One more widget that spans two columns, and then another couple rows
//Return this Composite
return comp;
The dialog box won't be resized or anything, so I don't have a problem
with hardcoding width and height. Can anyone tell me how to set the size
of my widgets (since widget.setSize(width, height) doesn't work in this
case)? Or alternatively, could anyone tell me how to set the size of each
column?
Thank you,
Kevin
Re: Setting the widget size while using GridLayout [message #442551 is a reply to message #442546] Tue, 07 September 2004 17:04 Go to previous messageGo to next message
Hi, Kevin.
Don't use setSize() on the widget. Instead, set the widthHint/heightHint
fields of the GridData.
Carolyn
"Kevbo" <kevin.clark@accessbc.com.nospam> wrote in message
news:chl2ud$a6b$1@eclipse.org...
> my widgets.
> //Row two
> return comp;
> column?
> Thank you,
> Kevin
Re: Setting the widget size while using GridLayout [message #442553 is a reply to message #442546] Tue, 07 September 2004 19:28 Go to previous message
You try :
data.widthHint = 50;
data.heightHint=20;
widget.setLayoutData(data);
regards
Kevbo wrote:
> my widgets.
> //Row two
> return comp;
> column?
> Thank you,
> Kevin
Re: Setting the widget size while using GridLayout [message #442556 is a reply to message #442551] Tue, 07 September 2004 17:32 Go to previous message
Carolyn,
Thank you for the tip! It works as I want it to now. =)
Kevin
Carolyn MacLeod wrote:
> Hi, Kevin.
> Carolyn
> > Hi,
> > my widgets.
> > //Row two
> > return comp;
> > column?
> > Thank you,
> > Kevin
Re: Setting the widget size while using GridLayout [message #442557 is a reply to message #442553] Tue, 07 September 2004 17:32 Go to previous message
I did try and it works. Thank you for your help!
Kevin
snpe wrote:
> You try :
> data.heightHint=20;
> regards
> Kevbo wrote:
> > Hi,
> > my widgets.
> > //Row two
> > return comp;
> > column?
> > Thank you,
> > Kevin
Previous Topic:transparent pngs in 3.0?
Next Topic:Is a restricted minimum size of a shell possible ?
Current Time: Thu Nov 06 10:13:14 EST 2025
Powered by FUDForum. Page generated in 0.04725 seconds
