Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problem in table selection color
problem in table selection color [message #441760] Tue, 24 August 2004 02:06 Go to next message
Originally posted by: david_danie.hotmail.com
Hi Friends,
I want to set the background color for each table's rows. So i used
setBackround(Color.gray) method in TableItem and i am not doing anything
for selection color. So i am expecting the default selection color(blue)
in the selected row.but whenever i select the row the selection color is
not changed it always shows with gray color.
any solution?
David Danie.
Re: problem in table selection color [message #441825 is a reply to message #441760] Wed, 25 August 2004 15:26 Go to previous messageGo to next message
The following example works for me. Note that when the table does not have
focus, the selection is not shown in blue but in a light gray (on Windows
2000). Alternatively you can create a table with SWT.HIDE_SELECTION to not
show the selection at all when the table does not have focus.
public static void main (String [] args) {
Display display = new Display ();
Color gray = display.getSystemColor(SWT.COLOR_GRAY);
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
Table table = new Table(shell, SWT.BORDER);
//Table table = new Table(shell, SWT.BORDER | SWT.HIDE_SELECTION);
for (int i = 0; i < 10; i++) {
TableItem item = new TableItem(table, SWT.NONE);
item.setText("item "+i);
item.setBackground(gray);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"David Danie" <david_danie@hotmail.com> wrote in message
news:cgelo7$rgt$1@eclipse.org...
> Hi Friends,
> any solution?
> David Danie.
Re: problem in table selection color [message #441859 is a reply to message #441825] Thu, 26 August 2004 06:22 Go to previous messageGo to next message
Yes. You are correct.
The selection shown in blue only if table have the focus.
But if i edit the column in the table the selection shown in gray not in
blue.
David Danie.
> shell.open ();
> display.dispose ();
>>Hi Friends,
>>any solution?
>>Thanks,
>>David Danie.
Re: problem in table selection color [message #441860 is a reply to message #441825] Thu, 26 August 2004 06:39 Go to previous message
blue.
David Danie.
> shell.open ();
> display.dispose ();
>>Hi Friends,
>>any solution?
>>Thanks,
>>David Danie.
Previous Topic:[ANN] v2.1 - SWT Designer, Swing Designer & WindowBuilder
Next Topic:SWT Browser (Eclipse 3.0) gets stuck in Eclipse 3.0 Runtime Workbench
Current Time: Sat Jul 05 06:39:34 EDT 2025
Powered by FUDForum. Page generated in 0.04423 seconds
