Home » Eclipse Projects » Rich Client Platform (RCP) » How to set Minimum Java Version for RCP
How to set Minimum Java Version for RCP [message #439927] Mon, 21 November 2005 10:42 Go to next message
Originally posted by: no.no.no
i am using Java5 Syntax in my project. When starting the Launcher of my RCP Application it
only checks against Java 1.4.x.
Is there a way to set a minimum java version in config.ini ?
thx
Dennis
Re: How to set Minimum Java Version for RCP [message #440135 is a reply to message #439927] Thu, 24 November 2005 07:27 Go to previous messageGo to next message
I don't know a solution. But did you try the latest additions provided
in 3.2M3? There are additional options on the Overview page of the
plugin.xml editor.
A possible workaround is to ship the JRE with your RCP. The launcher
will pick it up automatically if it's placed inside a directory called
"jre". This is also the best option if you want to limit your support to
only a specific JRE on the target platform and thus, reduce your QA
effort because you don't need to test all JRE variants.
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: How to set Minimum Java Version for RCP [message #440748 is a reply to message #440135] Wed, 07 December 2005 03:20 Go to previous messageGo to next message
I am also using Java 5, bt I have the luxury of shipping the JRE with my
app, and explicitly set it in the product ini file. Used Java 5 only
because I knew I could ship the JRE.
If you are not shipping the JRE, DO NOT USE JAVA 5.
And practically, i think in the launch parameters you shouldbe able to
specifiy a JVM minimum version in the product ini file. I think this is
using the -version flag.
Re: How to set Minimum Java Version for RCP [message #440756 is a reply to message #439927] Wed, 07 December 2005 07:58 Go to previous messageGo to next message
If you need to force it to stop if there's a lower version than you expect/want, you could always write a plugin that checks to see if there's a minimum version and displays appropriate error messages yourself. You could even hook this into the intro window with suitable directions/download links of where to get a better version.
Failing that, you could always ship a version with you, if you know what target architectures you're going to be on. You can put it in the 'jre' directory, but you can also specify a different location (e.g. -vm /usr/local/java15) if you know where it's going to be.
Alex.
View in EZ forum: http://www.eclipsezone.com/eclipse/forums/m91972899.html
Re: How to set Minimum Java Version for RCP [message #440896 is a reply to message #440748] Sat, 10 December 2005 19:37 Go to previous messageGo to next message
You want to set in the config.ini (or in the <launcher>.ini)
osgi.requiredJavaVersion=1.5
Re: How to set Minimum Java Version for RCP [message #441796 is a reply to message #440896] Fri, 06 January 2006 04:56 Go to previous message
Is there by, any change, a way to specify the maximum supported java
version?
Previous Topic:Encoding - label text
Next Topic:How to get a plugin context
Current Time: Mon Oct 27 16:18:51 EDT 2025
Powered by FUDForum. Page generated in 0.05287 seconds
