| Problems with Eclipse 3.1.1 RCP Deployment [message #437980] |
Mon, 10 October 2005 04:52  |
Originally posted by: eclipse.newsgroups.anegma.com
I discovered some problem while trying to export my eclipse RCP product
using the exporter. First of all I created a new product configuration
file for my rcp application. Then I exported it into a zip file.
After opening the zip file I wondered why there is no (!!) launcher
executable and no startup.jar in there. So I take those files from the
rcp delta pack an added it. After unpacking everything to a directory
I tried starting by clicking the launcher executable. Shortly after
that I got an error response and in the error log was the following:
java.io.IOException: Unable to initialize osgi.frameworkClassPath
at org.eclipse.core.launcher.Main.addBaseJars(Main.java:567)
at org.eclipse.core.launcher.Main.getDevPath(Main.java:466)
at org.eclipse.core.launcher.Main.getBootPath(Main.java:646)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
So I changed into the plugin directory and directly into the
org.eclipse.osgi_3.1.1 directory. I wondered about the zip file
which contains the source of the osgi plugin (that isn't required
for an deployment, so why is it in there?).
After copying the org.eclipse.osgi_3.1.1.jar to the parent
directory and deleting the whole org.eclipse.osgi_3.1.1 directory
my application is working fine.
In 3.1 I hadn't that problems and I would like to know if I'm doing
something wrong or is this a new bug ??
| Re: Problems with Eclipse 3.1.1 RCP Deployment [message #439285 is a reply to message #437980] |
Thu, 03 November 2005 16:05  |
I know it's been a while since you posted this, but I can report the sam=
e =
problem and can thank you for the workaround. I didn't have this =
deployment problem with 3.1.
Another difference I've noticed is that now many more of the plugins are=
deployed as folders rather than as jars - for example =
org.eclipse.core.commands_3.1.0 is now being deployed as a folder, where=
as =
before it was being deployed as a jar. Have we somehow gone back since =
3.1, or is there something else about my environment that may have chang=
ed =
to cause this?
Ian Graham
On Mon, 10 Oct 2005 02:52:59 -0600, Gunnar Pietz =
<eclipse.newsgroups@anegma.com> wrote:
> Hello,
> I discovered some problem while trying to export my eclipse RCP produc=
t
> using the exporter. First of all I created a new product configuration=
> executable and no startup.jar in there. So I take those files from the=
FUDForum. Page generated in 0.03446 seconds
