Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWTDesigner
SWTDesigner [message #437197] |
Tue, 01 June 2004 00:13 |
Originally posted by: roberto.nucera.informatica.com
I just downloaded the 14 days trial.
We are considering porting some .NET apps to Eclipse.
There seem to be many things missing if compared with the .NET Visual
Studio design view.
Perhaps I was expecting too much :)
For example with no layout I was trying to right align some controls. Could
not find a way to do it.
Could no see how to set the tab order for the dialog. The layout pallete has
only two buttons.
I ended up using .NET and placing the coordinates by hand into the SWT
Designer.
I understand that this is all new so one has to wait.
Any idea if the SWT Designer will improve substantially? Are there other
designers for SWT?
I appreciate any help.
Roberto
Re: SWTDesigner [message #437238 is a reply to message #437202] |
Tue, 01 June 2004 15:25 |
Konstantin,
Thanks. I did find the buttons! Not sure why they were not there before. I
did go to preferences though.
As far as completness. There seem to be many properties that should be there
but are not.
For example for a text(box) (multiline) I could not find:
Accept Return
Accept Tab
Tab Index
Tab Stop
Password Char
Still couldn't find a way to prevent (accept) tabs programmatically..
These seem to be common selections for a text control. Are you planning to
add those?
Thanks again,
Roberto
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:N3oYaD5REHA.744@fairy.ao.nlmk...
> > Studio design view.
Could
> I suppose that you use "null" layout for SWT Composite. Plus it is
possible that
> you need to enable "null" layout in preferences: Designer | SWT | "Allow
absolute/null layout".
> There are buttons on toolbar inside of editor, but above palette and
> design canvas with alignment buttons, like "Align left edges", "Align
right edges",
> etc. Just select two controls and use these buttons.
> SY, Konstantin.
> Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: SWTDesigner [message #437253 is a reply to message #437197] |
Wed, 02 June 2004 02:56 |
Eric Clayberg Messages: 979 Registered: July 2009 Location: Boston, MA |
"Roberto Nucera" <roberto.nucera@informatica.com> wrote in message
news:c9gh99$5e9$1@eclipse.org...
Could
Assuming you are using null layout or form layout, you could just use the
alignment buttons on the toolbar.
BTW, did you get a chance to review the docs or read through the 85+ page
tutorial?
You can drag/drop the widgets in the widge tree to set the tab order (which
is the same as the z-order in SWT).
> The layout pallete has only two buttons.
What "layout palette" is that?
If you are refering to the palette of different layout managers, it contains
eight entries for use in SWT: GridLayout, FillLayout, RowLayout, FormLayout,
StackLayout, BorderLayout (AWT), FlowLayout (AWT) and GridLayout (AWT). It
also supports Null layout.
If you are referring to the Designer toolbar, it has options for left,
right, center, top, bottom and middle alignment plus options for centering
vertically and horizontally.
Designer.
You would get better results by using one of the layout managers support by
SWT (and SWT Designer). Null/absolute layout is generally the least useful
choice.
New? How so? What do you need to "wait" for?
It is improving all the time. It would be helpful to know what you are
looking for. The things you mentioned above (like alignment functions) are
already in the product.
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
mailto:cpsws-support@instantiations.com
http://www.instantiations.com
http://www.instantiations.com/codepro/ws
Re: SWTDesigner [message #437277 is a reply to message #437238] |
Wed, 02 June 2004 05:21 |
Konstantin Scheglov Messages: 555 Registered: July 2009 |
> but are not.
> Accept Return
> Accept Tab
AFAIK this can be implemented only with traverse listener, so is a little
more high level than I expect from designer.
> Tab Index
I think you mean "top index".
> Tab Stop
> Password Char
Ok, these three properties are added now to Text support.
You will able to use them in next build. ;-)
Here is simple example.
If you assign e.doit 'true', you allow SWT to select next control for this 'tab' press.
By default for multiline controls it is 'false', so you add tab character in Text.
All code for this sample for generated with SWT Designer, I've added only two lines
in keyTraversed method. :-)
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.swt.events.TraverseEvent;
* @author scheglov_ke
public class TestText {
private Text text;
TestText window = new TestText();
window.open();
public void open() {
final Display display = new Display();
final Shell shell = new Shell();
shell.setLayout(new GridLayout());
shell.setText("SWT Application");
text = new Text(shell, SWT.BORDER | SWT.MULTI);
text.addTraverseListener(new TraverseListener() {
public void keyTraversed(TraverseEvent e) {
if (e.keyCode == SWT.TAB)
e.doit = true;
text.setLayoutData(new GridData(GridData.FILL_BOTH));
final Button button = new Button(shell, SWT.NONE);
button.setLayoutData(new GridData(GridData.HORIZONTAL_ALIGN_FILL));
button.setText("button");
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
> add those?
Mmm... What kind of selections do you mean? Sorry, I don't understand.
> Thanks again,
> Roberto
>> > Studio design view.
> Could
> possible that
> right edges",
>> SY, Konstantin.
SY, Konstantin.
Konstantin Scheglov,
Google, Inc.
Re: SWTDesigner [message #437395 is a reply to message #437253] |
Thu, 03 June 2004 17:31 |
Thanks Eric,
Kosntantin helped with most of the choices already. I am impressed by the
clear responses he posted.
I am actually going to suggest we use Instantiations here, since w eare
moving some of the UI from .NET to Java/SWT.
On the NULL layout, it is absolutely key. You will attract more Windows
developers to Java if the resource
editors are powerful in absolute positioning, tabbing behavior, etc. The
more options are available the less time
it takes to write a simple dialog box.
roberto
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:c9jf5q$h2u$1@eclipse.org...
> Could
> tutorial?
(which
contains
FormLayout,
> Designer.
by
> choice.
> -Eric Clayberg
Re: SWTDesigner [message #440387 is a reply to message #437395] |
Wed, 28 July 2004 23:55 |
Originally posted by: mlopez.voicerite.com
Roberto Nucera wrote:
> Thanks Eric,
> roberto
I agree with you, with the addition that if Instantiations wants to
really bowl over people...support the same ( or as near as possible )
level of control over the creation of your form as you would under VS.
As a hint, I would suggest you look at SharpDevelop, look at their
handling of events, and ability to set properties. After all, the code
to their visual editor is "gratis", as it's open source, and ideas begat
ideas.
Good luck.
Marcelo
Current Time: Fri Apr 26 01:21:29 GMT 2024
Powered by FUDForum. Page generated in 0.04078 seconds
