Home » Eclipse Projects » Rich Client Platform (RCP) » classloader or packaging problem?
classloader or packaging problem? [message #436593] Tue, 13 September 2005 04:10 Go to next message
since currently the modify event of Spinner does not allow
access to the current content of the spinner, (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=100363
) I tried to workaround this by performing the following
steps:
In my ui-helper plugin I created a Workaround class in
the org.eclipse.swt.widgets package (to get access to the default
visible Spinner.getSelectionText() method), as described below:
package org.eclipse.swt.widgets;
public class Workaround {
public final static int getSelectionText(Spinner spinner) {
final int result = spinner.getSelectionText();
return result;
but calling this static function in my client code leads to an
java.lang.IllegalAccessError, as seen below in the abridged log file.
Do I stumble about a language corner-case or is this a packaging problem?
Thank you in advance,
Daniel Krügler
!SESSION 2005-09-13 10:01:27.280
eclipse.buildId=unknown
java.version=1.5.0_04
Framework arguments: -product MyProduct.client.ui.ide -pdelaunch
Command-line arguments: -product MyProduct.client.ui.ide -data
MyPath\MyProduct -dev
file:AnyPath/workspace/.metadata/.plugins/org.eclipse.pde.co re/MyProduct/dev.properties
-pdelaunch -os win32 -ws win32 -arch x86 -data @noDefault
!ENTRY org.eclipse.ui 4 0 2005-09-13 10:01:40.936
!MESSAGE tried to access method
org.eclipse.swt.widgets.Spinner.getSelectionText()I from class
org.eclipse.swt.widgets.Workaround
!STACK 0
java.lang.IllegalAccessError: tried to access method
at org.eclipse.swt.widgets.Workaround.getSelectionText(Workarou nd.java:31)
WhatEver.common.ui.binding.SpinnerAdapter$1.modifyText(Spinn erAdapter.java:56)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:188)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Spinner.wmCommandChild(Spinner.java: 1171)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:3164 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3041 )
at org.eclipse.swt.widgets.Spinner.windowProc(Spinner.java:1042 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:158 0)
at org.eclipse.swt.widgets.Spinner.callWindowProc(Spinner.java: 88)
at org.eclipse.swt.widgets.Spinner.windowProc(Spinner.java:1040 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at WhatEver.MyApp.client.ui.AppMain.run(AppMain.java:60)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: classloader or packaging problem? [message #436601 is a reply to message #436593] Tue, 13 September 2005 11:12 Go to previous messageGo to next message
I think you need to either patch the SWT jar, or provide a fragment with the
additional class.
Boris
"Daniel Kr
Re: classloader or packaging problem? [message #436611 is a reply to message #436601] Wed, 14 September 2005 03:07 Go to previous messageGo to next message
> additional class.
Thank you very much for your answer, Boris! Would you be so nice and
explain somewhat more detailed the reasons for this behaviour?
And what do you mean by patching the SWT jar? (Actually I used the swt
package as an language "trick" to get access to the
Spinner.getSelectionText() method. To my opinion this is a legal one.
Is the reason to use a fragment (project) related to another
class-loader policy of fragments?
Thank you very much and
Greetings from Bremen,
Daniel
> Boris
> "Daniel Krügler" <dsp@bdal.de> wrote in message
> news:dg61hl$kfd$1@news.eclipse.org...
>>Hello,
>>steps:
>> return result;
>>Daniel Krügler
>>BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
>>!STACK 0
>>at
> 6)
>>at
>>at
>>at
> java:226)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>at java.lang.reflect.Method.invoke(Unknown Source)
Re: classloader or packaging problem? [message #436662 is a reply to message #436611] Wed, 14 September 2005 08:53 Go to previous messageGo to next message
The problem is that the SWT jar will be loaded in a seperate classloader to your patch, and thus will be seen as a different package (although the names are the same) resulting in the IllegalAccesError.
A fragment is like a plugin, but the contents of the fragment are merged with the plugin before being loaded by the classloader, so anything that's visible/accessible in the plugin is visible from the fragment, and vice versa. Additionally, where files that are the same in both the fragment and plugin, the ones in the fragment will take precedence, so it's a great way of shipping 'delta' patches for plugins.
In this example, you want to fix the SWT, so create a fragment to the SWT plugin and enclose your spinner class. It should then be able to access the package-level methods, and give you the result you're looking for.
http://help.eclipse.org/help31/topic/org.eclipse.pde.doc.use r/guide/pde_fragment_example.htm
Re: classloader or packaging problem? [message #436667 is a reply to message #436662] Wed, 14 September 2005 09:52 Go to previous messageGo to next message
> IllegalAccesError.
OK, now I see that my assumption was right concerning the class loader,
although I was not aware of the details, buts please wait...
> plugins.
> looking for.
Hmmh, actually I really don't want to enclose my **own** Spinner class,
I really **only** want to get access to the getSelectionText method,
which has package (default) accessibility. Can I realize this task with
the same procedure? I tried the following:
I created a fragment project Whatever.swtpatch (I hope the name of the
fragment is not importand - is it??) to the host plugin
org.eclipse.swt
with the proposed host version range 3.1.0. Than I created a package
(to which Spinner belongs) in the corresponding src directory of
the fragment project and created the following class:
return result;
but the fragment cannot **resolve** the identifier "Spinner". Even after
I added org.eclipse.swt.widgets to the list of imported packages on the
dependencies page, I could not resolve the name Spinner.
I would appreciate any help!
Thank you very much,
Daniel
Re: classloader or packaging problem? [message #436685 is a reply to message #436667] Wed, 14 September 2005 18:34 Go to previous messageGo to next message
> plugin
> org.eclipse.swt
> created a package
You're definitely going in the right direction with this. It doesn't matter what the fragment name is, as long as the host plugin is set to the right version.
Is the resolution a compile-time problem, or a run-time problem?
Re: classloader or packaging problem? [message #436714 is a reply to message #436685] Thu, 15 September 2005 04:36 Go to previous messageGo to next message
>>plugin
>>org.eclipse.swt
>>created a package
OK.
It is (it was ;-)) a compile-time problem. I needed half a day to found
out, that the current Eclipse version (3.1.0 release version) obviously
is sensible to nasty caching (?) problems.
The problem is, that by simply adding org.eclipse.swt to the list of
requirered bundles is not enough, because Eclipse dos not recognize that
Spinner also depends on the org.eclipse.swt.win32.win32.x86 plugin. This
problem only occurred, if I use the new osgi bundles mechanism.
You will not believe me how I could convince Eclipse to properly
recognize that there exist a plugin dependency to
org.eclipse.swt.win32.win32.x86:
1) I added a dependency to org.eclipse.swt. This is actually not
possible using the dependency editor (!), because org.eclipse.swt is not
shown there in the list, but choosing another plugin and modifying its
name to org.eclipse.swt in the raw manifest editor works.
2) I replaced the fragment host "org.eclipse.swt" by
"org.eclipse.swt.win32.win32.x86". In this case Eclipse plugin editor
signals me, that this id is invalid because
org.eclipse.swt.win32.win32.x86 itself is a fragment.
3) I replaced now the errornous org.eclipse.swt.win32.win32.x86 fragment
host by the "parent" host id org.eclipse.swt again - and the
plugin dependency to org.eclipse.swt.win32.win32.x86 is visible in the
package explorer!
Yes, it is some kind of magic and I really don't understand the actual
problem, but I could reproduce this phenomenon several times! (The
plugin becomes invalid at the point I remove the dependency on
org.eclipse.swt again).
This **must** be a severe bug of the manifest editor!
(The reason for attempting the org.eclipse.swt.win32.win32.x86 route was
that I had used the non-osgi bundle at another time. In this case I
simply set org.eclipse.swt.win32.win32.x86 as fragement host and all was
fine)
Thank you very much for your help!
Daniel Krügler
Re: classloader or packaging problem? [message #436870 is a reply to message #436593] Mon, 19 September 2005 10:00 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Neither, its a threading problem. You can't access GUI methods outside
of a GUI thread. You need to create a small Runnable that will read out
the values from the GUI object that you need. Then run the runnable
inside the GUI thread. Alternately you can have an event on your GUI
that writes its data when the GUI is changed, to a variable outside of
the GUI object. But then you must ensure its read in a thread safe manner.
CL
Daniel Krügler wrote:
> Hello,
> steps:
> return result;
> Daniel Krügler
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
Re: classloader or packaging problem? [message #436918 is a reply to message #436870] Tue, 20 September 2005 03:12 Go to previous messageGo to next message
How do you come to this conclusion? The problem has nothing to do with
threads, but is class-loader related. After defining the fragment for
org.eclipse.swt according to the proposals of Alex Blewitt and Boris
Bokowski the problem was solved.
Greetings,
Daniel
Re: classloader or packaging problem? [message #437054 is a reply to message #436918] Wed, 21 September 2005 10:08 Go to previous messageGo to next message
>> outside of a GUI thread. You need to create a small Runnable that
>> will read out the values from the GUI object that you need. Then run
>> the runnable inside the GUI thread. Alternately you can have an event
>> on your GUI that writes its data when the GUI is changed, to a
>> variable outside of the GUI object. But then you must ensure its read
> Greetings,
> Daniel
if it worked then they are correct. I came to the conclusiotn based on
your access of the GUI element spinner and the refusal of the workbench
to allow it. This has always been an issue of which thread you are
accessing it from. But I guess with the new osgi stuff in 3.1 perhaps
you are being prevented from accessing it where you wouldnt be in
pre-released versions.
Re: classloader or packaging problem? [message #437055 is a reply to message #436714] Wed, 21 September 2005 10:14 Go to previous messageGo to next message
>>> realize this task with the same procedure? I tried the following:
>>> hope the name of the fragment is not importand - is it??) to the host
>>> plugin
>>> org.eclipse.swt
>>> created a package
> OK.
> package explorer!
> fine)
> Daniel Krügler
why don't you ask in the swt forum. You seem to be doing the equivalent
of creating your own version of an swt class and need that level of
plugin access.
CL
Re: classloader or packaging problem? [message #437268 is a reply to message #436714] Mon, 26 September 2005 12:48 Go to previous messageGo to next message
Daniel,
please enter a bug against PDE, describing the problems you faced and how
you solved it.
Boris.
"Daniel Kr
Re: classloader or packaging problem? [message #437319 is a reply to message #437268] Tue, 27 September 2005 07:08 Go to previous message
Hello Boris Bokowski,
> Daniel,
> you solved it.
I entered a bug report which can be found at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=110013
Please note that the problem seems to be more complicated than I
thought. A follow-up thread "Export problems (fragment related)"
revealed that it is not clear whether fragments should be feasible
as dependencies in the osgi manifest or not.
To my opinion there exists strong needs for such capability because
otherwise its not possible to extend/fix fragment based Eclipse
implementations. There exists a lot of these, practically all widget
classes are part of fragements (on my system it is the
org.eclipse.swt.win32.win32.x86 fragment) as well as the Ole control
classes. Currently it seems not possible to get access to
package-visible members like Spinner.getSelectionText() or the 'hidden'
constructor OleAutomation(IDispatch), AFAIK.
Daniel Krügler
Previous Topic:Slides from EclipseWorld talks
Next Topic:Customizing Progress Monitor
Current Time: Sat Sep 06 19:17:42 EDT 2025
Powered by FUDForum. Page generated in 0.07118 seconds
