org.eclipse.swt.SWTException: Unsupported or unrecognized format [message #436426] |
Thu, 08 September 2005 04:52  |
I have exported an RCP application in Eclipse 3.1
When I tried to run the application, i get this error. Can anyone
explain this error? It doesnt seem to be on our code. The application
works fine if run from eclipse though.
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 26)
org.eclipse.swt.graphics.ImageDataLoader.load(ImageDataLoade r.java:18
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:327)
org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDe
scriptor.java:57)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descripto
r.java:279)
org.eclipse.jface.resource.ImageDescriptor.createResource(Im ageDescri
ptor.java:171)
org.eclipse.jface.resource.DeviceResourceManager.allocate(De viceResou
rceManager.java:56)
org.eclipse.jface.resource.AbstractResourceManager.create(Ab stractRes
ourceManager.java:87)
org.eclipse.jface.resource.LocalResourceManager.allocate(Loc alResourc
eManager.java:83)
org.eclipse.jface.resource.ResourceManager.createImageWithDe fault(Res
ourceManager.java:107)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionCo
ntributionItem.java:898)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContribu
tionItem.java:705)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributi
onItem.java:330)
org.eclipse.jface.action.ToolBarManager.update(ToolBarManage r.java:31
3)
org.eclipse.jface.action.ToolBarManager.createControl(ToolBa rManager.
java:101)
org.eclipse.jface.action.ToolBarContributionItem.fill(ToolBa rContribu
tionItem.java:190)
org.eclipse.jface.action.CoolBarManager.update(CoolBarManage r.java:90
7)
org.eclipse.jface.action.CoolBarManager.createControl(CoolBa rManager.
java:244)
org.eclipse.jface.window.ApplicationWindow.createCoolBarCont rol(Appli
cationWindow.java:446)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(Workben
chWindow.java:946)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultConten
ts(WorkbenchWindowConfigurer.java:575)
org.eclipse.ui.application.WorkbenchAdvisor.createWindowCont ents(Work
benchAdvisor.java:685)
org.eclipse.ui.internal.application.CompatibilityWorkbenchWi ndowAdvis
or.createWindowContents(CompatibilityWorkbenchWindowAdvisor. java:85)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindo
w.java:897)
at org.eclipse.jface.window.Window.create(Window.java:418)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.j
ava:663)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.jav
a:1282)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:
1223)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(Workb
enchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvi
sor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav
a:367)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
com.las.platf.cl.ui.main.RCPApplication.run(RCPApplication.j ava:26)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformAct
ivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:376)
va:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.02973 seconds
