Home » Archived » Buckminster » Build fails after headless resolve using p2
Build fails after headless resolve using p2 [message #436288] Thu, 30 July 2009 18:55 Go to next message
Hi All,
I'm doing a headless build, as described in the "test" target at the end
of the following ant script:
http://tps.ics.uci.edu/svn/projects/infrastructure/trunk/edu .uci.isr.infrastructure.buckminster_build_test/build.xml
During the resolve step, I can resolve everything using a simple cquery,
which places the dependent "org.eclipse.emf" plugin in the workspace. But,
then when I build the workspace in the command following the resolve, I
get an error:
Error: file
C:\Users\scott\eclipse\workspaces\buck-test\edu.uci.isr.infr astructure.buckminster_build_test\temp\buckminster\workspace \plugins\org.eclipse.emf:
build.properties does not exist
If I instead resolve using the alternative mspec in the ant script, the
"org.eclipse.emf" plugin is placed in buckminster's plugin's folder, and
the build fails because of the following error:
Error: file
C:\Users\scott\eclipse\workspaces\buck-test\edu.uci.isr.infr astructure.buckminster_build_test\temp\buckminster\workspace \plugins\edu.uci.isr.infrastructure.project_requiring_emf\ME TA-INF\MANIFEST.MF,
line 7: Bundle 'org.eclipse.emf' cannot be resolved
What I'd like to have happen is for the "org.eclipse.emf" plugin to be
placed in the target platform. But, I'm not sure how to do that. Any ideas?
Thank you,
-- Scott
Re: Build fails after headless resolve using p2 [message #468274 is a reply to message #436288] Tue, 04 August 2009 14:51 Go to previous messageGo to next message
Any suggestions? Is anyone else able to successfully perform this build
(note: this is very small. It checks out a feature, which includes a
single prodjct, which depends on org.eclipse.emf). I'll include the
relevant files, below, in case that helps anyone in figuring out what's
going on.
I made the ant build script so that it would be easy for someone else to
see what I'm doing and reproduce the error. I hope it helps!
Thank you,
-- Scott
------------------------------ Target Platform:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.5"?>
<target name="Eclipse SDK with delta pack">
<locations>
<location includeAllPlatforms="true" includeMode="slicer"
type="InstallableUnit">
<unit id="org.eclipse.sdk.ide" version="3.4.2.M20090211-1700"/>
<repository location="http://download.eclipse.org/eclipse/updates/3.4"/>
</location>
</locations>
</target>
------------------------------ MSPEC:
<md:mspec xmlns:md="http://www.eclipse.org/buckminster/MetaData-1.0"
name="workspace materializer by default, P2 otherwise"
shortDesc="update_site_workspace_p2"
materializer="workspace"
conflictResolution="UPDATE"
url="./update_site.cquery" >
<md:property key="eclipse.version" value="3.4"/>
<md:mspecNode namePattern="^org\.eclipse(\.[^\.]+)*$" materializer="p2"
conflictResolution="UPDATE" />
</md:mspec>
------------------------------ CQUERY:
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap=" http://tps.ics.uci.edu/svn/projects/infrastructure/trunk/inf rastructure/tps.ics.uci.edu.rmap">
<cq:rootRequest
name="edu.uci.isr.infrastructure.update_site_with_feature"
componentType="buckminster"/>
<cq:property key="eclipse.version" value="3.4"/>
<cq:advisorNode namePattern="^edu\.uci\.isr\..*$"
useTargetPlatform="false" branchTagPath="main"/>
</cq:componentQuery>
------------------------------ Result from build:
"Error: file
line 7: Bundle 'org.eclipse.emf' cannot be resolved"
------------------------------ Result from running the action (and
skipping the build):
${sp:manifest} is undefined
Re: Build fails after headless resolve using p2 [message #468344 is a reply to message #468274] Wed, 05 August 2009 03:49 Go to previous messageGo to next message
Hi Scott,
You don't have any installLocation set for your p2 materializer so you probably hit what's described here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285449
You can try the following:
1. Create an empty folder that will be the destination for the things you want to materialize into your TP.
2. Add this folder as a "Directory" to your active TP.
That should do the trick.
HTH,
Thomas Hallgren
> going on.
> Thank you,
> -- Scott
> <locations>
> </location>
> </locations>
> </target>
> materializer="p2" conflictResolution="UPDATE" />
> </md:mspec>
> <cq:componentQuery
> <cq:rootRequest
> "Error: file
Re: Build fails after headless resolve using p2 [message #470843 is a reply to message #468344] Wed, 05 August 2009 14:25 Go to previous messageGo to next message
Hi Thomas,
Thanks for your response. I've done as you suggested and the
org.eclipse.emf plugin is now placed in a "target" folder that I've added
to the target platform definition. However, when I still get the following
error:
1) edu.uci.isr.infrastructure.update_site_with_feature/${sp:man ifest}
doesn't exist (details below: [1])
NOTE: I updated the build script to insert the local path manually for the
location using an xstl.
I also noticed that when I execute a lsprefs command, I now get the
following exception:
2) "Active target 'Eclipse SDK with delta pack' is too complex to be
represented by a single path" (details below: [2]). This should probably
report the issue, but not throw an exception - halting the process.
The second issue is not a show stopper, I just commented out these
commands. But, I'm not sure what to do to fix the fist issue.
The update site's buckminster.cspec was created using the instructions
here:
http://wiki.eclipse.org/Building_an_Update_Site_using_Buckmi nster
So, I think I have everything in there (and this used to work), but I'm
not sure what I need to do to fix it.
Any ideas?
-- Scott
-------------- [1] --------------
[java] !ENTRY org.eclipse.buckminster.core 4 293 2009-08-05
09:06:09.085
[java] !MESSAGE org.eclipse.core.runtime.CoreException:
/home/scott/infrastructure/bitten/slaves/java1.5-eclipse3.4/ buckminster/configuration/org.eclipse.osgi/bundles/80/1/.cp/ org/eclipse/buckminster/pde/antscripts/build.xml:117:
The following error occurred while executing this line:
[java]
/home/scott/infrastructure/bitten/slaves/java1.5-eclipse3.4/ buckminster/configuration/org.eclipse.osgi/bundles/80/1/.cp/ org/eclipse/buckminster/pde/antscripts/build.xml:53:
/home/scott/infrastructure/bitten/slaves/java1.5-eclipse3.4/ buckminster/workspace/edu.uci.isr.infrastructure.update_site _with_feature/${sp:manifest}
doesn't exist
[java] !STACK 1
[java] org.eclipse.core.runtime.CoreException:
[java]
doesn't exist
[java] at
org.eclipse.buckminster.ant.AntRunner.handleInvocationTarget Exception(AntRunner.java:189)
[java] at
org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:352 )
[java] at
org.eclipse.buckminster.ant.actor.AntActor.internalPerform(A ntActor.java:281)
[java] at
org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:201)
[java] at
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:361)
[java] at
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:405)
[java] at
org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:118)
[java] at
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:191)
[java] at
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
[java] at
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
[java] at
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
[java] at
org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
[java] at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
[java] at
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at
[java] at
[java] at java.lang.reflect.Method.invoke(Method.java:585)
[java] at
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
[java] Caused by:
[java]
doesn't exist
[java] at
org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:508)
[java] at
org.apache.tools.ant.taskdefs.MacroInstance.execute(MacroIns tance.java:397)
[java] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
[java] at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
[java] at
[java] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
[java] at org.apache.tools.ant.Task.perform(Task.java:348)
[java] at org.apache.tools.ant.Target.execute(Target.java:357)
[java] at org.apache.tools.ant.Target.performTasks(Target.java:385)
[java] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
[java] at
org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
[java] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[java] at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
[java] at
org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
[java] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:622)
[java] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:455)
[java] at
[java] at
[java] at
org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:344 )
[java] ... 23 more
[java] Caused by:
doesn't exist
[java] at
org.apache.tools.ant.taskdefs.LoadResource.execute(LoadResou rce.java:142)
[java] at
[java] at
[java] at
[java] at
org.apache.tools.ant.taskdefs.Sequential.execute(Sequential. java:62)
[java] at
[java] at
[java] at
[java] at
org.apache.tools.ant.taskdefs.MacroInstance.execute(MacroIns tance.java:394)
[java] ... 43 more
-------------- [2] --------------
[java] org.eclipse.buckminster.pde.targetPlatformPath
[java] Description: Set the active Target Platform to a definition
that appoints a path
[java] org.eclipse.core.runtime.CoreException: Active target 'Eclipse
SDK with delta pack' is too complex to be represented by a single path
[java] at
org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:64)
[java] at
org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:59)
[java] at
org.eclipse.buckminster.pde.prefs.TargetPlatformPathHandler. get(TargetPlatformPathHandler.java:51)
[java] at
org.eclipse.buckminster.core.commands.ListPreferences.run(Li stPreferences.java:93)
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
Method)
[java] at
[java] at
[java] at
[java] at
[java] Active target 'Eclipse SDK with delta pack' is too complex to
Thomas Hallgren wrote:
> Hi Scott,
> HTH,
> Thomas Hallgren
>> going on.
>> Thank you,
>> -- Scott
>> <locations>
>> </location>
>> </locations>
>> </target>
>> <?xml version="1.0" encoding="UTF-8"?>
>> <md:mspecNode namePattern="^org.eclipse(.[^.]+)*$"
>> </md:mspec>
>> <cq:componentQuery
>> <cq:rootRequest
>> <cq:advisorNode namePattern="^edu.uci.isr..*$"
>> "Error: file
C:Usersscotteclipseworkspacesbuck-testedu.uci.isr.infrastruc ture.buckminster_build_testtempbuckminsterworkspacepluginsed u.uci.isr.infrastructure.project_requiring_emfMETA-INFMANIFE ST.MF,
Re: Build fails after headless resolve using p2 [message #478257 is a reply to message #470843] Thu, 06 August 2009 05:03 Go to previous messageGo to next message
Hi Scott,
The second problem looks as a bug. Can you please enter a bugzilla on that so we don't loose track of it?
I'm on vacation now (back on Monday) so some things are moving slower then others. I'll take a look problem #1 when I
get back.
Thomas Hallgren
> Hi Thomas,
> added to the target platform definition. However, when I still get the
> following error:
> the location using an xstl.
> here:
> Any ideas?
> -- Scott
> 09:06:09.085
> [java]
> doesn't exist
> [java] !STACK 1
> [java]
> doesn't exist
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
> [java] Caused by:
> [java]
> doesn't exist
> [java] at
> [java] at
> [java] at
> Source)
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
> [java] ... 23 more
> [java] Caused by:
> doesn't exist
> [java] at
> [java] at
> Source)
> [java] at
> [java] at
> [java] at
> [java] at
> Source)
> [java] at
> [java] at
> [java] at
> [java] ... 43 more
> 'Eclipse SDK with delta pack' is too complex to be represented by a
> single path
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
>> Hi Scott,
>> HTH,
>> Thomas Hallgren
>>> build (note: this is very small. It checks out a feature, which
>>> includes a single prodjct, which depends on org.eclipse.emf). I'll
>>> include the relevant files, below, in case that helps anyone in
>>> figuring out what's going on.
>>> to see what I'm doing and reproduce the error. I hope it helps!
>>> Thank you,
>>> -- Scott
>>> <locations>
>>> </location>
>>> </locations>
>>> </target>
>>> </md:mspec>
>>> <cq:componentQuery
>>> <cq:rootRequest
>>> "Error: file
Re: Build fails after headless resolve using p2 [message #480600 is a reply to message #478257] Mon, 17 August 2009 15:45 Go to previous messageGo to next message
> Hi Scott,
Done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286860
Let me know if you need any help reproducing the first issue.
Thank you,
-- Scott
> get back.
> Thomas Hallgren
>> Hi Thomas,
>> following error:
>> here:
>> Any ideas?
>> Thanks,
>> -- Scott
>> 09:06:09.085
>> [java]
>> doesn't exist
>> [java] !STACK 1
>> [java]
>> doesn't exist
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] Caused by:
>> [java]
>> doesn't exist
>> [java] at
>> [java] at
>> [java] at
>> Source)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>> [java] ... 23 more
>> [java] Caused by:
>> doesn't exist
>> [java] at
>> [java] at
>> Source)
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Source)
>> [java] at
>> [java] at
>> [java] at
>> [java] ... 43 more
>> single path
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Method)
>> [java] at
>> [java] at
>> [java] at
>>> Hi Scott,
>>> HTH,
>>> Thomas Hallgren
>>>> Thank you,
>>>> -- Scott
>>>> <locations>
>>>> </location>
>>>> </locations>
>>>> </target>
>>>> </md:mspec>
>>>> <cq:componentQuery
>>>> <cq:rootRequest
>>>> "Error: file
Re: Build fails after headless resolve using p2 [message #481147 is a reply to message #480600] Wed, 19 August 2009 14:20 Go to previous messageGo to next message
Thanks Thomas for fixing the second issue. Any ideas on the first?
The build script is here:
-- Scott
>> Hi Scott,
> Done:
> Thank you,
> -- Scott
>> get back.
>> Regards,
>> Thomas Hallgren
>>> Hi Thomas,
>>> following error:
>>> here:
>>> Any ideas?
>>> Thanks,
>>> -- Scott
>>> 09:06:09.085
>>> [java]
>>> doesn't exist
>>> [java] !STACK 1
>>> [java]
>>> doesn't exist
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] Caused by:
>>> [java]
>>> doesn't exist
>>> [java] at
>>> [java] at
>>> [java] at
>>> Source)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] ... 23 more
>>> [java] Caused by:
>>> doesn't exist
>>> [java] at
>>> [java] at
>>> Source)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Source)
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] ... 43 more
>>> single path
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> Method)
>>> [java] at
>>> [java] at
>>> [java] at
>>>> Hi Scott,
>>>> HTH,
>>>> Thomas Hallgren
>>>>> Thank you,
>>>>> -- Scott
>>>>> <locations>
>>>>> </location>
>>>>> </locations>
>>>>> </target>
>>>>> </md:mspec>
>>>>> <cq:componentQuery
>>>>> <cq:rootRequest
>>>>> "Error: file
Re: Build fails after headless resolve using p2 [message #481159 is a reply to message #481147] Wed, 19 August 2009 16:42 Go to previous messageGo to next message
Hi Scott,
I looked at your build. Apparently you have handcrafted a cspec that calls the create.site task in the
buckminster.pdetasks script. That particular task did undergo significant changes when we moved to p2 which begs the
question, what type of update site is it that you want to create? A legacy update site or a p2 repository? If it's the
latter, then you can simplify the creation of that update site a great deal by using the "Update sites using the 3.5
release" section rather then the "Update sites using the 3.4.x and earlier releases" on the
http://wiki.eclipse.org/Building_an_Update_Site_using_Buckmi nster page.
Thomas Hallgren
>>>> 1)
>>>> for the location using an xstl.
> -- Scott
Re: Build fails after headless resolve using p2 [message #481182 is a reply to message #481159] Wed, 19 August 2009 22:01 Go to previous messageGo to next message
Hi Thomas,
Unfortunately, I am wanting to create a legacy update site. The cspec is
what results from directly following the instructions for the "Update
sites using the 3.4.x and earlier releases" on the page that you mentioned
(without any of the optional features like groups; but, the error occurs
when groups are present as well).
If you follow the instructions on the page to create a legacy update site,
you'll run in to the same error.
-- Scott
> Hi Scott,
releases" on the
> Thomas Hallgren
>>>>> 1)
>> -- Scott
Re: Build fails after headless resolve using p2 [message #481183 is a reply to message #481182] Wed, 19 August 2009 22:37 Go to previous messageGo to next message
> Hi Thomas,
Oh, there is one modification. The "build.site" action in the cspec is
what you get when you follow the instructions. It calls the "create.site"
task. However, in (headless) buckminster 3.5, there is no "create.site"
task. So, I created a duplicate called "build.site.5", which calls the
"create.site.zip" task, which does exist in headless buckminster 3.5 (and
3.4 as well, iirc).
This all started with this message:
http://dev.eclipse.org/newslists/news.eclipse.tools.buckmins ter/msg01114.html
(I accidentally replied only to you and not the newsgroup that I was using
3.4, and you suggested trying out 3.5). Since then, as I've had time, I've
been transitioning to the headless buckminster 3.5. But, it seems to be
broken with respect to building legacy update sites.
I hope that helps :)
-- Scott
> -- Scott
>> Hi Scott,
> releases" on the
>> Regards,
>> Thomas Hallgren
>>>>>> 1)
>>> -- Scott
Re: Build fails after headless resolve using p2 [message #481243 is a reply to message #481183] Thu, 20 August 2009 04:43 Go to previous messageGo to next message
Hi Scott,
We dropped the support for building legacy update sites in our Galileo release. The rationale for this was that legacy
sites were no longer provided with Galileo and even with Ganymede, P2 was available. Only users on 3.3 or older are
confined to use legacy update sites and our Ganymede release was still there if you wanted to do that.
I can see how that was a bad decision. P2 wasn't very mature in Ganymede so a lot of users still use the legacy UM. We
don't want to force users like yourself to use our old Ganymede release to accommodate that. I therefore reinstated the
support for legacy update sites. The task names are slightly different ('create.legacy.site' instead of 'create.site'). See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287146
I tested your build.xml and it seems to run just fine after changing the task names.
I'm uploading updated bundles to our update sites right now. They will be available in an hour or so.
Thomas Hallgren
Re: Build fails after headless resolve using p2 [message #481385 is a reply to message #481243] Thu, 20 August 2009 13:29 Go to previous message
This is great. Thank you Thomas for hanging in there while I tried to
articulate what the problem was and for getting a fix in :) The result is
perfectly suitable for me.
-- Scott
> Hi Scott,
task names.
> Thomas Hallgren
Previous Topic:How to include component version with an action path
Next Topic:Hudson Plugin for Buckminster
Current Time: Sat Nov 01 16:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.05747 seconds
