Home » Eclipse Projects » Rich Client Platform (RCP) » -Dosgi.parentClassloader=ext - Error
-Dosgi.parentClassloader=ext - Error [message #435626] Fri, 19 August 2005 05:37 Go to next message
Originally posted by: sulf.upb.de
i have the following problem. My RCP needs a file from the java "ext"
directory. With the command -Dosgi.parentClassloader=ext my application
finds that what it need. In Windows* my programm runs with that parameter
correct, but under linux comes:
java.lang.UnsatisfiedLinkError: no swt-pi-gtk-3064 in java.library.path
Interesting, because if i do not use the -Dosgi.parentClassloader=ext
Parameter my application starts (but without functionality).
Then i give him all the librarys and linked them with -Djava.library.path=
Re: -Dosgi.parentClassloader=ext - Error [message #435627 is a reply to message #435626] Fri, 19 August 2005 07:46 Go to previous messageGo to next message
hmm my text is missing...
if I give him the librarys I get an SWT error
Re: -Dosgi.parentClassloader=ext - Error [message #435633 is a reply to message #435626] Fri, 19 August 2005 11:16 Go to previous messageGo to next message
Setting the OSGi parent loader is generally not recommend, because this
alters the classpath of every plugin in your application. If it's only
your plugin that needs the ext directory, you can specify this in your
plugin's MANIFEST.MF with the line:
Eclipse-BuddyPolicy: ext
This is much safer because only your plugin will be affected. See Help >
Help Contents and search for "buddy" for more details.
Ulf Schwekendiek wrote:
> Hello,
> parameter correct, but under linux comes:
Re: -Dosgi.parentClassloader=ext - Error [message #435662 is a reply to message #435633] Mon, 22 August 2005 04:41 Go to previous message
THANKS!!! It works.
Previous Topic:Building RCP Applications
Next Topic:Any tips on using jUnit to test RCP application?
Current Time: Thu Nov 06 23:40:35 EST 2025
Powered by FUDForum. Page generated in 0.04333 seconds
