Home » Eclipse Projects » Dali » persistence.xml and orm.xml are not copied to build folder
persistence.xml and orm.xml are not copied to build folder [message #434932] |
Wed, 16 July 2008 06:59 |
Originally posted by: sessaid.aol.com
I am having a problem with the persistence.xml file not being copied to
the build output folder. It does work in a clean install of Ganymede but
the Eclipse setup I have is not working. If I add any other file to the
/src/META-INF/ folder it will get copied but the persistence.xml and
orm.xml files are not copied.
Here is my setup:
*** Date: Tuesday, July 15, 2008 11:46:22 PM PT
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20080617-2000
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\eclipseroot\eclipse\Ganymede\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipseroot\eclipse\Ganymede\eclipse\plugins\org.eclipse. equinox.launcher.win32.win32.x86_1.0.100.v20080509-1800\ecli pse_1114.dll
-startup
C:\eclipseroot\eclipse\Ganymede\eclipse\plugins\org.eclipse. equinox.launcher_1.0.100.v20080509-1800.jar
-exitdata
8d0_7c8
-framework
plugins\org.eclipse.osgi_3.4.0.v20080605-1900.jar
-clean
-vm
C:\Program Files\Java\jdk1.6.0_06\jre\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/eclipseroot/eclipse/Ganymede/ eclipse/
eclipse.launcher=C:\eclipseroot\eclipse\Ganymede\eclipse\ecl ipse.exe
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=PlatformProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1216190060336
eclipse.vm=C:\Program Files\Java\jdk1.6.0_06\jre\bin\javaw.exe
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms128m
-Xmx512m
-XX:MaxPermSize=256M
-jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipseroot\eclipse\Ganymede\eclipse\plug ins\org.eclipse.equinox.launcher_1.0.100.v20080509-1800.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jdk1.6.0_06\jre\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jdk1.6.0_06\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\e xt
java.home=C:\Program Files\Java\jdk1.6.0_06\jre
java.io.tmpdir=C:\DOCUME~1\sam\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Java\jdk1.6.0_06\jre\bin;.;C:\WINDOWS\Sun\Java\bin;C:\ WINDOWS\system32;C:\WINDOWS;c:\gtk\bin;c:\os\imagemagick;C:\ Perl\site\bin;C:\Perl\bin;C:\OS\perl\site\bin;C:\OS\perl\bin ;C:\Program
Files\Windows Resource
Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;c:\OS\PHP\;C:\OS\Mysql\bin;C:\OS\doxygen\doxygen\bin ; "C:\OS\graphviz\Bin";C:\OS\doxygen\doxygen146\bin;c:\Program
Files\Microsoft SQL Server\90\Tools\binn\;C:\Program
Files\QuickTime\QTSystem\;;C:\Program
Files\Java\jdk1.6.0_06\bin;C:\OS\ant\apache-ant-1.7.0\bin;C: \OS\glassfish\devel2ur2\bin;C:\Program
Files\smartmontools\bin;C:\OS\ant\apache-ant-1.7.0\bin;C:\Pr ogram
Files\CVSNT\;C:\OS\Maven\apache-maven-2.0.9\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_06-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b22
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=c:\eclipseroot\ eclipse\Ganymede\eclipse\plugins\org.eclipse.platform_3.3.10 0.v200806172000\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator\bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.eve nts,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w 3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\eclipseroot\eclipse\Ganymede\eclipse\con figuration\org.eclipse.osgi\bundles
osgi.clean=true
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/eclipseroot/eclipse/Ganymed e/eclipse/configuration/
osgi.framework=file:/c:/eclipseroot/eclipse/Ganymede/eclipse /plugins/org.eclipse.osgi_3.4.0.v20080605-1900.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.4.0.v20080605-1900
osgi.install.area=file:/C:/eclipseroot/eclipse/Ganymede/ecli pse/
osgi.instance.area=file:/C:/eclipseroot/eclipse/Ganymede/wor kspace/
osgi.instance.area.default=file:/C:/Documents and Settings/sam/workspace/
osgi.launcherIni=eclipse
osgi.launcherPath=.
osgi.logfile=C:\eclipseroot\eclipse\Ganymede\workspace\.meta data\.log
osgi.manifest.cache=C:\eclipseroot\eclipse\Ganymede\eclipse\ configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\eclipseroot\eclipse\Ganymede\eclipse\ plugins\org.eclipse.platform_3.3.100.v200806172000\splash.bm p
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipseroot\eclipse\Ganymede\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jdk1.6.0_06\jre\lib\resources.jar;C:\Program
Files\Java\jdk1.6.0_06\jre\lib\rt.jar;C:\Program
Files\Java\jdk1.6.0_06\jre\lib\sunrsasign.jar;C:\Program
Files\Java\jdk1.6.0_06\jre\lib\jsse.jar;C:\Program
Files\Java\jdk1.6.0_06\jre\lib\jce.jar;C:\Program
Files\Java\jdk1.6.0_06\jre\lib\charsets.jar;C:\Program
Files\Java\jdk1.6.0_06\jre\classes
sun.boot.library.path=C:\Program Files\Java\jdk1.6.0_06\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipseroot\eclipse\Ganymede\eclipse
user.home=C:\Documents and Settings\sam
user.language=en
user.name=sam
user.timezone=America/Los_Angeles
user.variant=
*** Features:
org.eclipse.cvs (1.1.0.v20080603-7C79E8M9EI99m9c9S) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.6.0.v200806101-15-3119171723535_)
"Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.6.0.v200806101-27A-7733I3E3E57A7AK) "Data Tools Platform Connectivity"
org.eclipse.datatools.connectivity.feature
(1.6.0.v200805151245-7_7K0Dn-QXuj8_GoX7JfPiBEG) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.0.v200804260945-7C67HCYQCD4CnIkMYha) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.0.v200804021-7F27KBcMAAwAeIeHbVf) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.6.0.v200806171040-37_-8w95CKAECFAEGI_)
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.0.v200804021-650AlJAKaLeL1NnfvBEKK) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.0.v200804021-7D8H09FSoK_ZabCz-1W8blbFlWui) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.0.v200804021-57_0_pF9IQJXHvLeamBEKK) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.6.0.v200804021-7D40EB7sQS9RWfUjJLb) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.0.v200805301340-3-09oA55S5J8JADJJ) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.0.v200804021-441_kE77c7QARCMOS) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.0.v200804021-441_kE77c7QASCMPN) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.0.v200804021-21-8s733I3C7F4K63) "Eclipse Data Tools Platform XML ODA
Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.0.v200804021-797P4CYQCD4CpIiDmMN) "Eclipse Data Tools Platform XML
ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.0.v200804021-440_kE77c7QBPCFPL) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.0.v200804021-441_kE77c7R_RCIOP) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.0.v200804021-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.0.v200805310538-7A-5E9IgKLhLCdtRvz0F) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.intro (1.6.0.v200806091-15-3119171_2) "pluginName"
org.eclipse.datatools.modelbase.feature
(1.6.0.v200804021-6-0BcMAAwAfFgKSbi) "Eclipse Data Tools Platform SQLModel
Plug-in"
org.eclipse.datatools.sdk.feature
(1.6.0.v200804021-67S-9KdPR15OSayAbpo-sh4sd-fY) "DTP Connectivity
Templates Plug-in"
org.eclipse.datatools.sdk.feature.source (1.6.0.v200804021) "Eclipse
Datatools Source"
org.eclipse.datatools.sqldevtools.feature
(1.6.0.v200805301340-7F7d-E8yz-SHrDBONwUwXwIyxYSZ) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqltools.doc.user
(1.6.0.v200806101-15-3119171723535_) "Data Tools Platform SQL Development
Tools"
org.eclipse.draw2d (3.4.0.v20080115-33-7w3119163_) "Graphical Editing
Framework Draw2d"
org.eclipse.ecf.core (2.0.0.v20080623-0046) "Eclipse Communication
Framework (ECF)"
org.eclipse.ecf.examples (2.0.0.v20080623-0046) "ECF Collaboration
Examples"
org.eclipse.emf (2.4.0.v200806091234) "EMF - Eclipse Modeling Framework"
org.eclipse.emf.codegen (2.4.0.v200806091234) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.4.0.v200806091234) "EMF Ecore Code
Generator"
org.eclipse.emf.codegen.ecore.ui (2.4.0.v200806091234) "EMF Ecore Code
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200806091234) "EMF Code Generation UI"
org.eclipse.emf.common (2.4.0.v200806091234) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200806091234) "EMF Common UI"
org.eclipse.emf.converter (2.4.0.v200806091234) "EMF Model Converter"
org.eclipse.emf.databinding (1.0.0.v200806091234) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.0.0.v200806091234) "EMF Edit Data
Binding"
org.eclipse.emf.doc (2.4.0.v200806091234) "EMF Developer Guide"
org.eclipse.emf.ecore (2.4.0.v200806091234) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.0.v200806091234) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.4.0.v200806091234) "EMF Sample Ecore
Editor"
org.eclipse.emf.ecore.sdo (2.4.0.v200806091234) "EMF SDO - EMF's Service
Data Objects Implementation"
org.eclipse.emf.edit (2.4.0.v200806091234) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.0.v200806091234) "EMF Edit UI"
org.eclipse.emf.mapping (2.4.0.v200806091234) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.4.0.v200806091234) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200806091234) "EMF Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.4.0.v200806091234) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.100.v200805130238-108Y7w311916241349) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.2.0.v200805130238-11-7w311916241349) "EMF Model
Query"
org.eclipse.emf.transaction (1.2.0.v200805130238-23-8s733I3C59379I) "EMF
Model Transaction Core"
org.eclipse.emf.validation (1.2.0.v200805130238-35-9oA55S5J8H5ADM) "EMF
Validation Framework Core"
org.eclipse.emf.workspace (1.2.0.v200805130238-23-8s733I3C59379I) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.gef (3.4.0.v20080115-677-8082A5696H274A) "Graphical Editing
Framework GEF"
org.eclipse.gmf (1.1.0.v20080223-0300-7c7a-EWvhJvgb_r0Gh_dz08rmLgQ)
"Graphical Modeling Framework"
org.eclipse.gmf.doc (1.2.0.v20080501-1739-11-7w3119162702254) "Graphical
Modeling Framework Documentation"
org.eclipse.gmf.runtime.notation (1.1.0.v20080223-0300-21-8s733I3C3G1597E)
"GMF Notation Model Support"
org.eclipse.help (1.0.0.v20080603-7r7xEHJEJkZu5nE6Q4Qrtvu6JZ9L) "Help
System Base"
org.eclipse.jdt (3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq) "Eclipse
Java Development Tools"
org.eclipse.jst (3.0.0.v200806111800-7U-8Y9LIrwYBUV7sHGjhtz0LTrMd) "J2EE
Standard Tools (JST)"
org.eclipse.jst.ws.axis2tools.feature
(1.0.0.v200805191452-77-E_5CYQCD4ClWDK1Wj) "J2EE Standard Tools (JST)"
org.eclipse.mylyn_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.context_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.extras_sdk_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.ide_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.java_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.jira_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.pde_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.team_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.mylyn.trac_feature (3.0.0.v20080619-1900) "Mylyn"
org.eclipse.pde (3.4.0.v20080603-7T7U-E_EkMNrNKb39WcMC) "PDE"
(3.4.0.v20080610-9I96EhtEm-T_5LxIsybz-3MdGZmOA3uwv7Ka_M) "Eclipse Platform"
org.eclipse.rcp (3.4.0.v20080324a-989JERhEk-jWnd5IY8K5tjxB) "Eclipse RCP"
org.eclipse.rse (3.0.0.v20080609-7H3-8qfbaJJZCz-G-QT8RWUC6) "Remote System
Explorer End-User Runtime"
org.eclipse.rse.core (3.0.0.v20080609-7Z3-EB7sQS9RiVd) "Remote System
Explorer Core"
org.eclipse.rse.dstore (3.0.0.v20080609-7J3-DUUEFDEyF) "RSE DStore
Services"
org.eclipse.rse.ftp (3.0.0.v20080609-78478_kE77c7O7W5I55) "RSE FTP Service"
org.eclipse.rse.local (2.1.0.v20080604-7_4-AgI99m9c9S) "RSE Local Services"
org.eclipse.rse.ssh (2.1.0.v20080604-783-_kE77c7U7M) "RSE SSH Services"
org.eclipse.rse.telnet (2.1.0.v20080604-6678AgI99m9W9W5I55) "RSE Telnet
Service"
org.eclipse.rse.terminals (0.1.0.v20080610-22-9sB6EO_O8X2842) "RSE
Terminals UI (Incubation)"
org.eclipse.tm.terminal (2.0.0.v20080609-2--7w31191731) "Target Management
Terminal Widget"
org.eclipse.tptp.examples (4.5.0.v200803191201-7B7_CE87CDJE2D9EFFDD7CF_4)
"TPTP Examples"
org.eclipse.tptp.lta.gla.ui.epi (4.5.0.v200805132041-44-7w311916271211)
"Generic Adapter UI"
org.eclipse.tptp.lta.log.epi (4.5.0.v200805132041-44-7w311916243152) "TPTP
LTA Log Extension Instances"
org.eclipse.tptp.lta.runtime
(4.5.0.v200805132041-7V7c-8xB1XGKgsZUxUTKoV-R75LO) "TPTP Log and Trace
Analyzer"
org.eclipse.tptp.lta.sdb.epi (4.5.0.v200805132041-44-7w311916243152) "TPTP
LTA Log SDB Extension Instances"
org.eclipse.tptp.lta.symptom.epi (4.5.0.v200805132041-44-7w311916243152)
"TPTP LTA Log Symptom Catalog Extension Instances"
org.eclipse.tptp.monitoring (4.4.100.v200805120832-7d7OEINE8McIJXIvZtNAa2)
"TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.4.0.v200804180100-784CF8s733I3C684B7A) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.200.v200803201123-44-7w311916231943) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation
(4.3.100.v200805120832-7B79Ag9oA55S5L8H7796) "TPTP Instrumentation
Monitoring "
org.eclipse.tptp.monitoring.la.core
(4.4.100.v200806121215-7B78CE9oA55S5GAA8MAM) "Monitoring Log Analyzer Core
backward compatibility"
org.eclipse.tptp.monitoring.lta.examples
(4.5.0.v200805132041-7879-8s733I3C5973A5) "User examples for the TPTP Log
and Trace Analyzer"
org.eclipse.tptp.monitoring.lta.profile.server
(4.5.0.v200805132041-7B7D-9oA55S5J_M7C_B) "TPTP Profile On Server Logging
Utility"
org.eclipse.tptp.monitoring.managedagent
(4.4.100.v200805120832-7F7DCF_kE77c7MBH7H_9) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.100.v200805120832-4307w311916231943) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.1.v200802291616-3-27w3119133_2562) "MX4J"
org.eclipse.tptp.monitoring.profile.server
(4.2.200.v200805271330-7B78Dp9oA55S5GAA8MAM) "TPTP Profile On Server
Logging Utility backward compatibility"
org.eclipse.tptp.monitoring.report.birt
(4.5.0.v200806050100-7B7D-9oA55S5L7H686A) "TPTP Business Intelligence and
Reporting Tools (BIRT) Log Reports"
org.eclipse.tptp.platform.analysis
(4.4.100.v200806050100-7F7_EAU_kE77c7U7Q7A77) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.200.v200806050100-7877_78s733I3E3C3533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.200.v200806050100-784Ag8s733I3C5_4_59) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core
(4.5.0.v200806121215-8Z8DEm8ELRXmpromDKxVI_) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.200.v200804180100-7B6E9w9oA55S5K8H686A) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.doc.user
(4.3.200.v200802291616-7B77E9w8_JKQTvMuLIBdBQBTCD7B) "TPTP Platform
Project Documentation"
org.eclipse.tptp.platform.examples
(4.3.200.v200806121215-42_77w311916231943) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.100.v200805120832-78778Y8s733I3D684549) "TPTP Instrumentation UI Core"
org.eclipse.tptp.platform.integration.pde
(4.4.1.v200806121215-4307w311916231943) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti
(4.3.100.v200805120832-7877_78s733I3E5C3C4B) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.200.v200806121215-42_77w311916342227) "Log Analysis Core backward
compatibility"
org.eclipse.tptp.platform.lta (4.3.200.v200805201414-783CF8s733I3B674G8A)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit
(4.3.200.v200805120832-7F5EFB_kE77c7RCG8TEA) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.200.v200802291616-41_77w311916231943) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server
(4.3.100.v200805120832-7F79E8M_kE77c7PAN9NH_) "TPTP Profile on Server"
org.eclipse.tptp.platform.report
(4.2.200.v200805120832-7B5Dq9oA55S5K9B7F_H) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt
(4.3.200.v200805120832-7877_78s733I3B5A4B8C) "TPTP Business Intelligence
and Reporting Tools (BIRT) Reporting Infrastructure"
org.eclipse.tptp.platform.samples
(4.3.200.v200805120832-7B4E9x9oA55S5G9H5LA9) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.report.birt
Reporting Tools (BIRT) Statistical Reports"
org.eclipse.tptp.platform.statistical.ui
(4.1.400.v200805120832-783Ag8s733I3_6A3B65) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace
(4.3.200.v200805120832-7J7EEAVAgI99m9YEV9SCJ) "TPTP Platform Trace"
org.eclipse.tptp.test (4.3.300.v200805120832-7J7DE9wAgI99m9XGN_RGJ) "TPTP
Test Framework"
org.eclipse.tptp.test.doc.user (4.3.200.v200804100100-428Y7w311916421211)
"TPTP Test Tools User Documentation"
org.eclipse.tptp.test.recorders.url
(4.5.0.v200805120832-7879-8s733I3C763B65) "TPTP URL Recorder"
org.eclipse.tptp.test.report.birt
(4.4.0.v200806050100-7B7D-9oA55S5L7H686A) "TPTP Business Intelligence and
Reporting Tools (BIRT) Test Reports"
org.eclipse.tptp.test.runtime
(4.3.200.v200805091443-7F7_EAU7SnbjlBGPQ2r6Nij2r6Np) "TPTP Test Framework"
org.eclipse.tptp.test.samples (4.2.100.v200805120832-418Y7w311916421211)
"TPTP Test Framework and Tools Samples"
org.eclipse.tptp.test.tools
(4.3.200.v200805120832-7J7J_7_5cMYfOO2cJovVaMPMWLA) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit
(4.5.0.v200805120832-7F7G_7_kE77c7QDJ8ND_) "TPTP JUnit Plug-in Test Tools"
org.eclipse.tptp.trace (4.2.100.v200805120832-781EC48s733I3D4A4FAB) "TPTP
Trace"
org.eclipse.tptp.trace.arm (4.2.100.v200805120832-782_78s733I3_6D3B65)
"TPTP ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.100.v200805120832-7858Z8s733I3D684549)
"Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.100.v200805120832-438Y7w311917273154)
"TPTP Trace JVMTI Client"
org.eclipse.tptp.trace.report.birt
Reporting Tools (BIRT) Trace Reports"
org.eclipse.uml2 (2.2.0.v200805201126) "UML2"
org.eclipse.uml2.doc (2.2.0.v200805201350) "UML2 Documentation"
org.eclipse.uml2tools (0.8.0.v200806112132) "UML2 Tools Plug-in
(Incubation)"
org.eclipse.wst (3.0.0.v200806092130-7A-8Y8QqN2lf4VSWrI2ek5Pf4k7s) "Web
Standard Tools (WST)"
org.eclipse.wst.ws_wsdl14.feature (1.4.0.v200802280619-13-7w311917141518)
"Web Standard Tools (WST)"
org.eclipse.wst.ws_wsdl15.feature (1.5.1.v200802280619-1407w311917141519)
org.eclipse.xsd (2.4.0.v200806091234) "XSD - XML Schema Definition Model"
org.eclipse.xsd.edit (2.4.0.v200806091234) "XSD Edit"
org.maven.ide.eclipse.book.feature (0.9.5.20080627-1152) "Maven
Integration for Eclipse"
org.maven.ide.eclipse.editor.feature (0.9.5.20080627-1152) "Maven
org.maven.ide.eclipse.editor.xml.feature (0.9.5.20080627-1152) "Maven
org.maven.ide.eclipse.feature (0.9.5.20080627-1152) "Maven Integration for
Eclipse"
org.maven.ide.eclipse.mylyn.feature (0.9.5.20080627-1152) "Maven
org.maven.ide.eclipse.scm.feature (0.9.5.20080627-1152) "Maven Integration
for Eclipse"
org.maven.ide.eclipse.subclipse.feature (0.9.5.20080627-1152) "Maven
org.maven.ide.eclipse.wtp.feature (0.9.5.20080627-1152) "Maven Integration
for Eclipse"
org.tigris.subversion.clientadapter.feature (1.5.0) "Subversion Client
Adapter"
org.tigris.subversion.clientadapter.javahl.feature (1.5.0) "Subversion
JavaHL"
org.tigris.subversion.subclipse (1.4.0) "SVN Team Provider Core"
org.tigris.subversion.subclipse.mylyn (3.0.0) "Subclipse Integration for
Mylar"
*** Plug-in Registry:
ch.ethz.iks.r_osgi.remote (1.0.0.RC2_v20080623-0046) "R_OSGi Remote
Service" [Starting]
ch.ethz.iks.slp (1.0.0.RC4_v200806091030) "jSLP" [Starting]
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
com.lowagie.itext (1.5.4.v20080228) "Lowagie Itext" [Resolved]
com.sun.enterprise.jst.server.sunappsrv (1.0.3) "Sun Application Servers
and GlassFish Servers support" [Starting]
javax.activation (1.1.0.v200804101140) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.wsdl (1.4.0.v200806030407) "WSDL4J" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
javax.xml.rpc (1.1.0.v200806030420) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200806030421) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
[Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200806030120) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik Extension"
[Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing"
[Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.cactus (1.7.2.v200805140145) "Cactus Resource Plug-in"
[Starting]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200806030120) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.net (1.4.1.v200803061811) "Apache Commons Net"
[Resolved]
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.log4j (1.2.13.v200806030600) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.oro (2.0.8.v200803061811) "Apache Jakarta ORO" [Resolved]
org.apache.ws.commons.util (1.0.0.v20080530-1550) "WS Commons Util
Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200806040330) "WSIL4J" [Resolved]
org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver"
[Resolved]
org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20080530-1550) "Apache XML-RPC Plug-in"
[Resolved]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.3.0.v20080529) "Ant UI" [Starting]
org.eclipse.birt.chart.engine (2.3.0.v20080606) "BIRT Chart Engine"
[Starting]
org.eclipse.birt.core (2.3.0.v20080606) "BIRT Core Package" [Starting]
org.eclipse.birt.data (2.3.0.v20080606) "BIRT Data Engine" [Starting]
org.eclipse.birt.data.aggregation (2.3.0.v20080606) "Build-in Aggregation
Plug-in" [Starting]
org.eclipse.birt.report.data.adapter (2.3.0.v20080606) "BIRT Data Adapter"
[Starting]
org.eclipse.birt.report.data.oda.xml (2.3.0.v20080606) "BIRT ODA-XML
Driver" [Starting]
org.eclipse.birt.report.engine (2.3.0.v20080616) "BIRT Engine" [Starting]
org.eclipse.birt.report.engine.fonts (2.3.0.v20080606) "BIRT Engine fonts"
[Resolved]
org.eclipse.birt.report.model (2.3.0.v20080605) "BIRT Model" [Starting]
org.eclipse.compare (3.4.0.I20080604) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.1.0.I20080527-2000) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.1.0.I20080508-2000a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.4.0.v20080603-2000) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
[Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.0.v20080512) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
[Active]
org.eclipse.core.net.win32.x86 (1.0.0.I20080521) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.4.0.v20080604-1400) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32.x86 (3.4.0.v20071204) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
[Active]
org.eclipse.cvs (1.0.100.v20080603) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.6.0.20080606124249) "Data Tools
Platform User Documentation" [Resolved]
org.eclipse.datatools.connectivity (1.1.0.v200805160228) "Data Tools
Platform Connectivity Plug-in" [Active]
org.eclipse.datatools.connectivity.apache.derby (1.0.1.v200805152355)
"Eclipse Data Tools Platform Derby Plug-in" [Active]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.v200805152355)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.v200805152355) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.6.0.20080606124249) "Data
Tools Platform Connectivity" [Resolved]
org.eclipse.datatools.connectivity.doc.user.contexts
(1.6.0.20080606124249) "Data Tools Platform Connectivity for
context-sensitive help" [Resolved]
org.eclipse.datatools.connectivity.oda (3.1.2.v200805152355) "DTP Open
Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.2.v200805230718) "DTP
ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.6.v200805152355) "DTP
ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.6.v200805152355)
"DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.6.v200805261930)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.6.v200805261930)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.v200805152355) "DTP
ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.1.v200806041052) "Eclipse
Data Tools Platform SQM Core Plug-in" [Active]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.0.v200806070326)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.0.v200806050117)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.0.v200806040132) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.0.v200805152355) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.templates (1.0.0.v200805152355) "DTP
Connectivity Templates Plug-in" [Starting]
org.eclipse.datatools.doc.isv (1.6.0.200806091108) "Data Tools
Documentation Plug-in" [Resolved]
org.eclipse.datatools.doc.user (1.6.0.20080606124249) "Data Tools Platform
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse Data
Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse
Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform HSQLDB Database Definition Enablement
Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.v200806100223) "DB2 UDB iSeries Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform DB2 UDB Database
Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.v200805152355) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355)
"Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200805152355) "pluginName"
[Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200805152355) "Data
Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200805152355)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.0.v200805152355) "Eclipse Data
Tools Platform MySQL Enablement Plug-in" [Active]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.v200805170742)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.0.v200805261930) "Eclipse
Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.0.v200805261930) "Eclipse
Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.0.v200805270900) "Eclipse
Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.0.v200805270900) "Eclipse
Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.0.v200805240040) "Eclipse
Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.0.v200805152355) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355) "Eclipse
Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition
Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355)
"Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538) "High-level
Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200805310538) "Sybase
ASA Plug-in" [Active]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538)
"Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200806040735)
"JDBC/Sybase ASE Connection Profile Plug-in" [Active]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200805310538) "ASE
Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355)
"Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200806041138)
"pluginName" [Starting]
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform Help
org.eclipse.datatools.intro (1.6.0.200806091) "pluginName" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby
Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.v200805152355) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200805152355) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329) "SQL
Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200805152355)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.0.0.v200805152355) "DTP ODA
Context-sensitive Help" [Starting]
Datatools Source" [Resolved]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.v200805152355) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.0.v200805310400) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse
Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200805152355)
"Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.6.0.20080606124249) "Data Tools
Platform SQL Development Tools" [Resolved]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200805152355) "Eclipse
Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200805152355)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200805152355)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200805152355)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200805152355) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200805301309) "Eclipse Data
Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200805261703)
"Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200805152355) "Eclipse Data
Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200806070500) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200806021003) "Eclipse
Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200805240400)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200805152355) "Eclipse
Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.debug.core (3.4.0.v20080612) "Debug Core" [Active]
org.eclipse.debug.ui (3.4.0.v20080529-1300) "Debug UI" [Active]
org.eclipse.draw2d (3.4.0.v20080529) "Graphical Editing Framework Draw2d"
[Starting]
org.eclipse.dstore.core (3.0.0.v20080604) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.0.v20080406) "RSE DStore Platform Support"
[Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Starting]
org.eclipse.ecf.core.source (2.0.0.v20080623-0046) "ECF Core Source"
[Resolved]
org.eclipse.ecf.datashare (1.3.0.v20080623-0046) "ECF DataShare API"
[Resolved]
org.eclipse.ecf.discovery (2.0.0.v20080623-0046) "ECF Discovery API"
[Starting]
org.eclipse.ecf.discovery.ui (2.0.0.v20080623-0046) "ECF Discovery UI"
[Starting]
org.eclipse.ecf.doc (1.3.0.v20080623-0046) "ECF Documentation" [Starting]
org.eclipse.ecf.docshare (2.0.0.v20080623-0046) "ECF DocShare Plugin"
[Starting]
org.eclipse.ecf.example.clients (1.3.0.v20080623-0046) "ECF Clients
Example" [Resolved]
org.eclipse.ecf.example.collab (1.3.0.v20080623-0046) "ECF Collaboration
Examples" [Starting]
org.eclipse.ecf.example.collab.editor (1.0.200.v20080623-0046) "ECF Shared
Editor Example" [Starting]
org.eclipse.ecf.examples.remoteservices.client (1.0.100.v20080623-0046)
"ECF RemoteServices Example Client" [Starting]
org.eclipse.ecf.examples.remoteservices.common (1.0.100.v20080623-0046)
"ECF RemoteServices Example Common" [Starting]
org.eclipse.ecf.examples.remoteservices.server (1.0.100.v20080623-0046)
"ECF RemoteServices Example Server" [Starting]
org.eclipse.ecf.examples.source (2.0.0.v20080623-0046) "ECF Examples
Source" [Resolved]
org.eclipse.ecf.examples.updatesite.client (1.0.100.v20080623-0046) "ECF
Updatesite Example Client" [Starting]
org.eclipse.ecf.examples.updatesite.server (1.0.100.v20080623-0046) "ECF
Updatesite Example Server" [Starting]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
[Starting]
org.eclipse.ecf.filetransfer.ui (1.4.0.v20080623-0046) "ECF File Transfer
UI" [Starting]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API"
[Starting]
org.eclipse.ecf.presence (1.3.0.v20080623-0046) "ECF Presence API"
[Starting]
org.eclipse.ecf.presence.bot (1.2.0.v20080623-0046) "ECF Presence Bot API"
[Starting]
org.eclipse.ecf.presence.collab.ui (1.2.0.v20080623-0046) "ECF Presence
Collaboration UI" [Starting]
org.eclipse.ecf.presence.ui (1.2.0.v20080623-0046) "ECF Presence UI"
[Starting]
org.eclipse.ecf.protocol.bittorrent (0.3.0) "ECF BitTorrent Protocol
Implementation" [Resolved]
org.eclipse.ecf.protocol.msn (1.2.0.v20080623-0046) "ECF MSN Protocol
org.eclipse.ecf.provider (1.3.0.v20080623-0046) "ECF Provider API"
[Starting]
org.eclipse.ecf.provider.bittorrent (0.3.0.v20080623-0046) "ECF Bittorrent
Provider" [Starting]
org.eclipse.ecf.provider.bittorrent.ui (0.2.0.v20080623-0046) "ECF
Bitorrent Provider UI" [Starting]
org.eclipse.ecf.provider.datashare (1.3.0.v20080623-0046) "ECF Datashare
org.eclipse.ecf.provider.discovery (2.0.0.v20080623-0046) "ECF Discovery
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.efs (1.5.0.v20080623-0046) "ECF EFS
org.eclipse.ecf.provider.filetransfer.scp (2.0.0.v20080623-0046) "ECF SCP
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.irc (1.3.0.v20080623-0046) "ECF IRC Provider"
[Starting]
org.eclipse.ecf.provider.irc.ui (1.3.0.v20080623-0046) "ECF IRC UI"
[Starting]
org.eclipse.ecf.provider.jmdns (2.0.0.v20080623-0046) "ECF Discovery
org.eclipse.ecf.provider.jslp (2.0.0.v20080623-0046) "ECF SLP Discovery
org.eclipse.ecf.provider.msn (1.2.0.v20080623-0046) "ECF MSN Provider"
[Starting]
org.eclipse.ecf.provider.msn.ui (1.3.0.v20080623-0046) "ECF MSN Provider
UI" [Starting]
org.eclipse.ecf.provider.r_osgi (2.0.0.v20080623-0046) "ECF R-OSGi
Remoteservice Provider" [Starting]
org.eclipse.ecf.provider.remoteservice (1.3.0.v20080623-0046) "ECF
org.eclipse.ecf.provider.ui (1.3.0.v20080623-0046) "ECF Provider UI"
[Starting]
org.eclipse.ecf.provider.xmpp (2.0.0.v20080623-0046) "ECF XMPP Provider"
[Starting]
org.eclipse.ecf.provider.xmpp.ui (2.0.0.v20080623-0046) "ECF XMPP Provider
UI" [Starting]
org.eclipse.ecf.remoteservice (2.0.0.v20080623-0046) "ECF Remoteservice
API" [Starting]
org.eclipse.ecf.remoteservice.ui (2.0.0.v20080623-0046) "ECF Remote
Services UI" [Starting]
org.eclipse.ecf.server (1.3.0.v20080623-0046) "ECF Server API" [Starting]
org.eclipse.ecf.server.generic (1.2.0.v20080623-0046) "ECF Generic Server"
[Starting]
org.eclipse.ecf.sharedobject (1.3.0.v20080623-0046) "ECF Sharedobject API"
[Starting]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication
Framework (ECF)" [Resolved]
org.eclipse.ecf.telephony.call (1.2.0.v20080623-0046) "ECF Telephony Call
API" [Starting]
org.eclipse.ecf.telephony.call.ui (1.2.0.v20080623-0046) "ECF Call UI"
[Starting]
org.eclipse.ecf.ui (2.0.0.v20080623-0046) "ECF UI" [Starting]
[Starting]
org.eclipse.emf.ant (2.4.0.v200806091234) "EMF Ant Tasks" [Starting]
org.eclipse.emf.cheatsheets (2.4.0.v200806091234) "EMF Cheat Sheets"
[Starting]
[Starting]
Generator" [Starting]
Generator UI" [Starting]
[Starting]
org.eclipse.emf.common (2.4.0.v200806091234) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.4.0.v200806091234) "EMF Common UI" [Starting]
org.eclipse.emf.commonj.sdo (2.4.0.v200806091234) "CommonJ SDO - Service
Data Objects" [Starting]
[Starting]
[Starting]
Binding" [Starting]
org.eclipse.emf.doc (2.4.0.v200806091234) "EMF Developer Guide" [Starting]
org.eclipse.emf.ecore (2.4.0.v200806091234) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.4.0.v200806091234) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200806091234) "EMF Change Edit"
[Starting]
[Starting]
Editor" [Starting]
Data Objects Implementation" [Starting]
org.eclipse.emf.ecore.xmi (2.4.0.v200806091234) "EMF XML/XMI Persistence"
[Active]
org.eclipse.emf.edit (2.4.0.v200806091234) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.4.0.v200806091234) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.4.0.v200806091234) &q
Re: persistence.xml and orm.xml are not copied to build folder [message #434933 is a reply to message #434932] |
Wed, 16 July 2008 07:10 |
Here are .classpath, .project, and org.eclipse.wst.common.component
classpath
<classpath>
<classpathentry kind="src" path="src" />
<classpathentry kind="con"
path=" org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.inte rnal.debug.ui.launcher.StandardVMType/jdk1.6.0_06 "
path=" org.eclipse.jst.server.core.container/com.sun.enterprise.jst .server.runtimeTarget/GlassFish
V2 Java EE 5" />
path="org.eclipse.jst.j2ee.internal.module.container" />
<classpathentry kind="lib"
path="C:/OS/Mysql/mysql-connector-java-5.1.5-bin.jar" />
<classpathentry kind="output" path="build/classes" />
</classpath>
Here is .project
<projectDescription>
<name>jpaPractice</name>
<comment></comment>
<projects>
</projects>
<buildSpec>
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.wst.common.project.facet.core.builder</name >
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.wst.validation.validationbuilder</name>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
<nature>org.eclipse.wst.common.project.facet.core.nature</nature >
<nature>org.eclipse.jdt.core.javanature</nature>
<nature>org.eclipse.wst.common.modulecore.ModuleCoreNature</nature >
<nature>org.eclipse.jem.workbench.JavaEMFNature</nature>
</natures>
</projectDescription>
Here is org.eclipse.wst.common.component
<project-modules id="moduleCoreId" project-version="1.5.0">
<wb-module deploy-name="jpaPractice">
<wb-resource deploy-path="/" source-path="/src"/>
</wb-module>
</project-modules>
Re: persistence.xml and orm.xml are not copied to build folder [message #434936 is a reply to message #434935] |
Wed, 16 July 2008 15:43 |
Paul,
I reinstalled Ganymede and I think the only difference at this point from
the previous one is TPTP.
Using this new setup, if I import the problem project into the new
Eclipse/workspace setup it works fine. If I open the previous workspace
(it has few other projects but they are all closed) using the new Eclipse
setup, it does not work. Also, if I create a new workspace using the
previous Eclipse setup, it also works. So it looks like there is
something in the previous workspace (not Eclipse setup) that is causing
the problem. Where should I look for problems in the old workspace?
This is a very simple JPA/Utility project with default settings and a main
class and an Entity. I think the other information you are asking for is
in my second post (the facets and other project/classpath settings).
At this point I do not need this problem solved because I can just move to
the new workspace but I will keep the old workspace (or send it to you) if
it can help fix a bug.
Shahim
Re: persistence.xml and orm.xml are not copied to build folder [message #434937 is a reply to message #434936] |
Wed, 16 July 2008 16:12 |
Paul Fullbright Messages: 201 Registered: July 2009 |
Shahim,
It sounds like there *could* be an exception happening in the background
that might be related to your setup. Have you checked the error log? If
they're the same versions of WTP/Dali in both cases, then only the
workspace or extra plugins (though I'm not sure how those could be the
culprit) are at fault.
In either case, it would be helpful if you could enter a bug on this. To
this bug, I would attach the simplest workspace (i.e. workspace and
project, but no other projects) that demonstrates the error case.
Thanks for bringing this to our attention,
- Paul
Shahim wrote:
> Paul,
> Shahim
Re: persistence.xml and orm.xml are not copied to build folder [message #611114 is a reply to message #434932] |
classpath
<classpath>
V2 Java EE 5" />
</classpath>
Here is .project
<comment></comment>
<projects>
</projects>
<buildSpec>
<buildCommand>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
</natures>
</wb-module>
</project-modules>
Re: persistence.xml and orm.xml are not copied to build folder [message #611117 is a reply to message #434935] |
Paul,
Shahim
Re: persistence.xml and orm.xml are not copied to build folder [message #611118 is a reply to message #434936] |
Shahim,
- Paul
Shahim wrote:
> Paul,
> Shahim
Current Time: Thu Sep 19 11:35:41 GMT 2024
Powered by FUDForum. Page generated in 0.05045 seconds
