Probem getting basic sample running [message #434919] |
Fri, 04 July 2008 09:11 |
Apologies, I know I am probably going to feel silly in the end, but I
am having a problem getting a sample EclipseLink project running. I
have a Derby driver defined and the embedded driver is on the
classpath. When I execute the "JPA Tools --> Genertate DDL" I get the
exception below. Note that the complaint is "Class
[sun.jdbc.odbc.JdbcOdbcDriver] not found" not my defined driver.
Here is my persistence.xml:
<persistence version="1.0"
xmlns="http://java.sun.com/xml/ns/persistence"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="spring.prova.jpa.model"
transaction-type="RESOURCE_LOCAL">
<class>
spring.prova.jpa.model.BaseEntity</class>
<class>
spring.prova.jpa.model.NamedEntity</class>
<class>
spring.prova.jpa.model.Owner</class>
<class>
spring.prova.jpa.model.Person</class>
<class>
spring.prova.jpa.model.Pet</class>
<class>
spring.prova.jpa.model.PetType</class>
<class>
spring.prova.jpa.model.Specialty</class>
<class>
spring.prova.jpa.model.Vet</class>
<class>
spring.prova.jpa.model.Visit</class>
<properties>
<property name="eclipselink.jdbc.url"
value="jdbc:derby:/Users/joel/scratch/derby/myDB;create=true " />
<property name="eclipselink.jdbc.user" value="joel" />
<property name="eclipselink.jdbc.password" value="joel" />
<property name="eclipselink.jdbc.driver"
value="org.apache.derby.jdbc.EmbeddedDriver" />
<property name="eclipselink.logging.level" value="FINE" />
<property name="eclipselink.target-database" value="Derby" />
<property name="eclipselink.ddl-generation"
value="drop-and-create-tables" />
<property name="eclipselink.ddl-generation.output-mode"
value="both" />
<property name="eclipselink.application-location"
value=" /Users/joel/projects/Etish-340/spring.prova.jpa.model/genera ted/db "
</properties>
</persistence-unit>
</persistence>
and the exception.
[TopLink Info]: 2008.07.04
08:37:26.214--ServerSession(10018556)--TopLink, version: Oracle TopLink
Essentials - 2.0 (Build b41-beta2 (03/30/2007))
Exception in thread "main" Local Exception Stack:
Exception [TOPLINK-4003] (Oracle TopLink Essentials - 2.0 (Build
b41-beta2 (03/30/2007))):
oracle.toplink.essentials.exceptions.DatabaseException
Exception Description: Configuration error. Class
[sun.jdbc.odbc.JdbcOdbcDriver] not found.
at
oracle.toplink.essentials.exceptions.DatabaseException.confi gurationErrorClassNotFound(DatabaseException.java:86)
at
oracle.toplink.essentials.sessions.DefaultConnector.loadDriv er(DefaultConnector.java:168)
at
oracle.toplink.essentials.sessions.DefaultConnector.connect( DefaultConnector.java:83)
at
oracle.toplink.essentials.sessions.DatasourceLogin.connectTo Datasource(DatasourceLogin.java:170)
at
oracle.toplink.essentials.internal.sessions.DatabaseSessionI mpl.loginAndDetectDatasource(DatabaseSessionImpl.java:537)
at
oracle.toplink.essentials.ejb.cmp3.EntityManagerFactoryProvi der.login(EntityManagerFactoryProvider.java:206)
at
oracle.toplink.essentials.internal.ejb.cmp3.EntityManagerSet upImpl.deploy(EntityManagerSetupImpl.java:212)
at
oracle.toplink.essentials.internal.ejb.cmp3.base.EntityManag erFactoryImpl.getServerSession(EntityManagerFactoryImpl.java :78)
at
oracle.toplink.essentials.internal.ejb.cmp3.base.EntityManag erFactoryImpl.createEntityManagerImpl(EntityManagerFactoryIm pl.java:111)
at
oracle.toplink.essentials.internal.ejb.cmp3.base.EntityManag erFactoryImpl.createEntityManagerImpl(EntityManagerFactoryIm pl.java:105)
at
oracle.toplink.essentials.internal.ejb.cmp3.EntityManagerFac toryImpl.createEntityManager(EntityManagerFactoryImpl.java:7 6)
at
org.eclipse.jpt.eclipselink.core.ddlgen.Main.perform(Main.ja va:87)
at org.eclipse.jpt.eclipselink.core.ddlgen.Main.execute(Main.ja va:78)
at org.eclipse.jpt.eclipselink.core.ddlgen.Main.main(Main.java: 65)
Any idea of what I have configured incorrectly?
Joel
Re: Probem getting basic sample running [message #434922 is a reply to message #434920] |
Tue, 08 July 2008 07:15 |
Hi Peter,
Thanks for the suggestion, I will do some digging. Actually, though,
this is a brand new Ganymede install and the code is new project I
created to get familiar with Dali JPA and EclipseLink. The entity
classes I did copy from another example, but not the persistence.xml.
Joel
Re: Probem getting basic sample running [message #434926 is a reply to message #434923] |
Tue, 08 July 2008 15:22 |
On 2008-07-08 16:22:45 +0200, douglas.clarke@oracle.com (Doug Clarke) said:
> Joel,
> there is no JPA implementation included in Ganymede so you must have
> TopLink Essentials defined in your project's libraries or through its
> dependent projects. Please setup a new user library for EclipseLink and
> ensure that it is the only one used in your test case.
> If the error persists please post the new error message. You are
> looking for org.eclipse.persistence in the stack trace to indicate that
> EclipseLink is being used.
> Doug
Doug,
That is already the case. I have a user library using EclipseLink set
up as my default for JPA. The user library contains eclipselink.jar and
javax.persistence_1.0.0.jar from eclipselink-M10 .
Your reply pointed to me to the problem though. It was that I also had
my Spring user library included and it had TopLink Essentials defined.
Well, I knew I was doing something silly :-(
Thanks for the assistance,
Joel
Re: Probem getting basic sample running [message #610601 is a reply to message #434920] |
Hi Peter,
Joel
Re: Probem getting basic sample running [message #610612 is a reply to message #434923] |
> Joel,
> Doug
Doug,
Joel
FUDForum. Page generated in 0.03792 seconds
