Re: Proper Dali use in EJB modules (client jars) [message #434601 is a reply to message #434599] |
Thu, 27 September 2007 13:28 |
Karen Butzke Messages: 220 Registered: July 2009 |
This is a feature that 1.0 Dali does not support. Please enter an
enhancement request for this use case as we want to support more JPA
project setups in a future Dali release.
thanks,
Karen
Alexandros Karypidis wrote:
> I'm using Eclipse WTP and Dali to write EJB 3.0 modules for JBoss 4.2.
> All my EJB projects have "client JAR" projects, as I also use them from
> an RCP client. My problem is that Dali/WTP forces me to put Entities in
> the "server" project and not the "client JAR" project, as follows:
> my.ejb.prj
> MyBean
> MyEntity
> my.ejb.prjClient
> MyBeanRemote (interface)
> Short story: I need to move MyEntity to the client project, but this
> breaks Dali.
> Long story: Under EJB 3.0, it is acceptable to pass entities back and
> forth among the application server / remote client: they just become
> detached (and must be merged if returned to the server for use). To do
> this, I just move MyEntity from my.ejb.prj to my.ejb.prjClient (it is
> still available to MyBean because the server side implicitly depends on
> the client project and has it in its classpath). But then Dali stops
> working (the "JPA Details" view is no longer attached to the editor as
> if I am no longer editing an Entity).
> As a result, I now have 2 copies (one in each project) and I edit the
> one in my.ejb.prj, having to update my.ejb.prjClient every time I make a
> change.
Re: Proper Dali use in EJB modules (client jars) [message #434603 is a reply to message #434599] |
Fri, 28 September 2007 15:51 |
Paul Fullbright Messages: 201 Registered: July 2009 |
Hi Alexandros,
How does Dali prevent you from editing your entities in your client
project? Have you tried adding the JPA facet to your client project
instead of your EJB project?
(It is true that the standard EJB project wizard doesn't help you to do
this.)
- Paul
> my.ejb.prj
> MyBean
> MyEntity
> my.ejb.prjClient
> breaks Dali.
> change.
Re: Proper Dali use in EJB modules (client jars) [message #606113 is a reply to message #434599] |
thanks,
Karen
> my.ejb.prj
> MyBean
> MyEntity
> my.ejb.prjClient
> breaks Dali.
> change.
Re: Proper Dali use in EJB modules (client jars) [message #606118 is a reply to message #434599] |
Hi Alexandros,
this.)
- Paul
> my.ejb.prj
> MyBean
> MyEntity
> my.ejb.prjClient
> breaks Dali.
> change.
FUDForum. Page generated in 0.03680 seconds
