Home » Eclipse Projects » Dali » New to JPA
New to JPA [message #434520] Wed, 18 July 2007 16:19 Go to next message
When trying to set up I get errors:
"The import java.persistence cannot be resolved"
which of course gives Entity cannot be resolved to a type etc.....
I can't find any jar that has this
Any ideas where to look?
Re: New to JPA [message #434521 is a reply to message #434520] Wed, 18 July 2007 18:12 Go to previous messageGo to next message
You can download TopLink Essentials, which is the JPA reference
implementation:
http://www.oracle.com/technology/products/ias/toplink/jpa/do wnload.html
Or any other runtime implementation of JPA would include the annotation
definitions.
Karen
Re: New to JPA [message #434523 is a reply to message #434521] Fri, 20 July 2007 00:32 Go to previous messageGo to next message
you can use hibernate too.
Re: New to JPA [message #434524 is a reply to message #434523] Fri, 20 July 2007 08:06 Go to previous messageGo to next message
Installed top-link
Installed glassfish
Still the same - cannot import java.persistence
Where is it?
Re: New to JPA [message #434525 is a reply to message #434524] Fri, 20 July 2007 10:32 Go to previous messageGo to next message
Now that you have glassfish persistence installed you will need to add the
toplink-essentials.jar to your eclipse project classpath.
When creating a new JPA project, we provide 2 options to help specify the
JPA implementation.
1. Use implementation provided by server runtime
2. Use implementation library - this includes links to set up a library
and a JPA preference for the default JPA implementation library. This
will just make it easier the next time you create a new JPA project.
Since you already have a project, you can set up a library that points to
the toplink-essentials.jar and add it to your project. Or you can just
add the jar directly ro your project if you don't want a library.
Karen
Re: New to JPA [message #434526 is a reply to message #434525] Fri, 20 July 2007 15:36 Go to previous messageGo to next message
I added toplink-essentials.jar to my project and got the same error
I opened the jar and found that it contained javax.persistance so I
changed the import and most of the errors went away.
Now I get "This mapped class is not contained in any persistence unit" on
the @Entity
that preceeds
public class Entities implements Serializable {....
Re: New to JPA [message #434527 is a reply to message #434526] Fri, 20 July 2007 16:30 Go to previous message
Have you taken a look at the Dali tutorials and docs on our website?
http://www.eclipse.org/webtools/dali/docs/tutorial_1.0/dali_ jsf_tutorial.htm
You need a persistence.xml file and you need to specify your entities in a
persistence unit.
thanks,
Karen
Re: New to JPA [message #602461 is a reply to message #434520] Wed, 18 July 2007 18:12 Go to previous message
implementation:
definitions.
Karen
Re: New to JPA [message #602470 is a reply to message #434521] Fri, 20 July 2007 00:32 Go to previous message
Re: New to JPA [message #605056 is a reply to message #434523] Fri, 20 July 2007 08:06 Go to previous message
Installed top-link
Installed glassfish
Where is it?
Re: New to JPA [message #605060 is a reply to message #434524] Fri, 20 July 2007 10:32 Go to previous message
JPA implementation.
Karen
Re: New to JPA [message #605064 is a reply to message #434525] Fri, 20 July 2007 15:36 Go to previous message
the @Entity
that preceeds
Re: New to JPA [message #605068 is a reply to message #434526] Fri, 20 July 2007 16:30 Go to previous message
persistence unit.
thanks,
Karen
Previous Topic:BEA releases WebLogic Server Tools for Eclipse 3.3
Next Topic:one to one mapping problems
Current Time: Mon Nov 10 07:15:42 EST 2025
Powered by FUDForum. Page generated in 0.06464 seconds
