Home » Eclipse Projects » Dali » [Persistence Properties] Mapping entity attributes is not working
[Persistence Properties] Mapping entity attributes is not working [message #433986] Thu, 29 June 2006 10:01 Go to next message
I've just downloaded RC1 (running on OS X using the latest download
from the Callisto site), and I'm trying to create a simple Entity. I
create the following:
@Entity
public class Foo
private int id;
I select id in the Persistence Outline and then select Map As: Id in
the Persistence Properties and nothing happens. If I manually add @Id
to the id attribute, the Persistence Properties changes to allow me to
set the other properties of an id field. Have I done something wrong
or is this broken? There are no entries in the error log.
Bryan
Re: [Persistence Properties] Mapping entity attributes is not working [message #433988 is a reply to message #433986] Thu, 29 June 2006 16:25 Go to previous messageGo to next message
We haven't had any OS X feedback yet, so this sounds like a platform
specific bug. Can you choose any mapping type or is Id the only one that
doesn't work? Could you file a bug for this problem?
thanks,
Karen
Re: [Persistence Properties] Mapping entity attributes is not working [message #433989 is a reply to message #433988] Thu, 29 June 2006 19:23 Go to previous messageGo to next message
All mapping types are broken. I'll create a bugzilla for this. If
someone can tell me where to set a breakpoint, I'll try to look into
the problem further over the weekend if I get time.
Bryan
> that doesn't work? Could you file a bug for this problem?
> thanks,
> Karen
Re: [Persistence Properties] Mapping entity attributes is not working [message #433990 is a reply to message #433989] Fri, 30 June 2006 10:02 Go to previous message
Bryan,
I'm imagining that it is a JFact/SWT issue, not sure if there is a
workaround. There are a decent amount of complaints on google if you
search for issues with swt on Mac. If you want to take a look, that
particular combo box can be found in
org.eclipse.dali.ui.views.PersistentAttributeComposite
Karen
Re: [Persistence Properties] Mapping entity attributes is not working [message #588925 is a reply to message #433986] Thu, 29 June 2006 16:25 Go to previous message
thanks,
Karen
Re: [Persistence Properties] Mapping entity attributes is not working [message #588939 is a reply to message #433988] Thu, 29 June 2006 19:23 Go to previous message
Bryan
> thanks,
> Karen
Re: [Persistence Properties] Mapping entity attributes is not working [message #588946 is a reply to message #433989] Fri, 30 June 2006 10:02 Go to previous message
Bryan,
Karen
Previous Topic:ArrayIndexOutOfBoundsEx. w/o ManyToMany
Next Topic:Dali 0.5 Release now available
Current Time: Sun Nov 09 18:36:07 EST 2025
Powered by FUDForum. Page generated in 0.04529 seconds
