Home » Eclipse Projects » Dali » Unalble to see the list of tables to map to my Entity
Unalble to see the list of tables to map to my Entity [message #433656] |
Mon, 10 April 2006 19:38 |
Rajesh Messages: 15 Registered: July 2009 |
I have installed eclipse (Eclipse SDK Version: 3.1.2 Build id:
M20060118-1600). I have installed the required software for enabling ejb
3.0 annotations (please see below for the configuration details).
I was able to create and test the database connection, but could not map
to the tables. The dropdown does not list the list of tables in my schema.
I have found another post where Neil (Neil Hauge) mentioned that he
created a bug to resolve this issue, because the current implementation
tries to connect to the db using the userid as a qualifier. In my case the
userid and schema name are same so that bug should not effect me.
Also eclipse shows errors for the annotations, it doesn't recognise
them. What jar files do I need to add to the classpath for my project?
I am getting the following exceptions from the IDE.
Exceptions
!ENTRY org.eclipse.ui.workbench 4 2 2006-04-10 15:26:37.785
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
at
org.eclipse.dali.db.wrappers.DatabaseWrapper.getSchemaNamed( DatabaseWrapper.java:89)
at
org.eclipse.dali.db.wrappers.ConnectionInfoWrapper.getSchema Named(ConnectionInfoWrapper.java:271)
at
org.eclipse.dali.db.wrappers.ConnectionInfoWrapper.getUserTa bles(ConnectionInfoWrapper.java:294)
at
org.eclipse.dali.db.wrappers.ConnectionInfoWrapper.userTable s(ConnectionInfoWrapper.java:300)
at
org.eclipse.dali.db.wrappers.ConnectionInfoWrapper.userTable Names(ConnectionInfoWrapper.java:307)
at
org.eclipse.dali.ui.views.TableComposite.populateTableCombo( TableComposite.java:188)
at
org.eclipse.dali.ui.views.TableComposite.populate(TableCompo site.java:171)
at
org.eclipse.dali.ui.views.EntityComposite.populateTablePanel (EntityComposite.java:310)
at
org.eclipse.dali.ui.views.EntityComposite.populate(EntityCom posite.java:283)
at
org.eclipse.dali.ui.views.PersistentTypeComposite.populate(P ersistentTypeComposite.java:173)
at
org.eclipse.dali.ui.views.PersistentTypeComposite.populate(P ersistentTypeComposite.java:156)
at
org.eclipse.dali.ui.views.PersistencePropertiesView.populate (PersistencePropertiesView.java:69)
at
org.eclipse.dali.ui.views.PersistencePropertiesView.setPersi stenceFile(PersistencePropertiesView.java:97)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.setPersiste nceFile(PersistenceOutlineView.java:335)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.setActiveIn put(PersistenceOutlineView.java:297)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.handlePartR ef(PersistenceOutlineView.java:125)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.access$0(Pe rsistenceOutlineView.java:118)
at
org.eclipse.dali.ui.views.PersistenceOutlineView$1.partBroug htToTop(PersistenceOutlineView.java:85)
at
org.eclipse.ui.internal.PartListenerList2$2.run(PartListener List2.java:83)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at
org.eclipse.ui.internal.PartListenerList2.fireEvent(PartList enerList2.java:54)
at
org.eclipse.ui.internal.PartListenerList2.firePartBroughtToT op(PartListenerList2.java:81)
at
org.eclipse.ui.internal.PartService.firePartBroughtToTop(Par tService.java:90)
at
org.eclipse.ui.internal.WorkbenchPagePartList.firePartBrough tToTop(WorkbenchPagePartList.java:75)
at
org.eclipse.ui.internal.WorkbenchPagePartList.fireActiveEdit orChanged(WorkbenchPagePartList.java:51)
at org.eclipse.ui.internal.PartList.setActiveEditor(PartList.ja va:143)
at
org.eclipse.ui.internal.WorkbenchPage.makeActiveEditor(Workb enchPage.java:1128)
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2903)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:552)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2371)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2295)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2268)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2249)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at
org.eclipse.dali.ui.wizards.NewElementWizard$1.run(NewElemen tWizard.java:57)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui.workbench 4 0 2006-04-10 15:26:38.255
!MESSAGE WARNING: Prevented recursive attempt to activate part
org.eclipse.pde.runtime.LogView while still in the middle of activating
part org.eclipse.jdt.ui.CompilationUnitEditor
!STACK 0
java.lang.RuntimeException: WARNING: Prevented recursive attempt to
activate part org.eclipse.pde.runtime.LogView while still in the middle of
activating part org.eclipse.jdt.ui.CompilationUnitEditor
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2859)
at
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2512)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:249)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:295)
at org.eclipse.ui.internal.FastViewPane.showView(FastViewPane.j ava:422)
at org.eclipse.ui.internal.Perspective.showFastView(Perspective .java:1632)
at
org.eclipse.ui.internal.Perspective.setActiveFastView(Perspe ctive.java:1520)
at
org.eclipse.ui.internal.Perspective.setActiveFastView(Perspe ctive.java:1533)
at org.eclipse.ui.internal.Perspective.bringToTop(Perspective.j ava:173)
at
org.eclipse.ui.internal.WorkbenchPage.internalBringToTop(Wor kbenchPage.java:720)
at
org.eclipse.ui.internal.WorkbenchPage.bringToTop(WorkbenchPa ge.java:775)
at
org.eclipse.pde.internal.runtime.logview.LogView$19.run(LogV iew.java:604)
at
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:319)
at
org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:59)
at
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalPlatform.java:715)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1046)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui.workbench 4 0 2006-04-10 15:26:40.230
!STACK 0
at
at
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:2 14)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:99 8)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1855)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:1961)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:363 0)
at org.eclipse.swt.widgets.Tree.WM_SETFOCUS(Tree.java:3238)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3102 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:2391)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3751 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:651)
at org.eclipse.swt.widgets.Control.setSavedFocus(Control.java:2 360)
at org.eclipse.swt.widgets.Decorations.restoreFocus(Decorations .java:806)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1623)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:1476)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3036 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.internal.win32.OS.DestroyWindow(Native Method)
at org.eclipse.swt.widgets.Control.destroyWidget(Control.java:5 27)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:383)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :441)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:499)
at org.eclipse.jface.window.Window.close(Window.java:321)
at org.eclipse.jface.dialogs.Dialog.close(Dialog.java:891)
at
org.eclipse.jface.dialogs.MessageDialog.buttonPressed(Messag eDialog.java:167)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jface 4 2 2006-04-10 15:27:07.295
"org.eclipse.jface".
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.dali.ui.views.PersistenceOutlineView$2.selection Changed(PersistenceOutlineView.java:159)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:1784)
at
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1452)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:37 9)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.setSelectio n(PersistenceOutlineView.java:396)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.setSelectio nFromEditor(PersistenceOutlineView.java:368)
at
org.eclipse.dali.ui.views.PersistenceOutlineView$3.selection Changed(PersistenceOutlineView.java:193)
at
org.eclipse.ui.internal.AbstractSelectionService.firePostSel ection(AbstractSelectionService.java:179)
at
org.eclipse.ui.internal.AbstractSelectionService$2.selection Changed(AbstractSelectionService.java:71)
at
org.eclipse.jface.text.TextViewer.firePostSelectionChanged(T extViewer.java:2302)
at
org.eclipse.jface.text.TextViewer.firePostSelectionChanged(T extViewer.java:2254)
at org.eclipse.jface.text.TextViewer$4.run(TextViewer.java:2233 )
at org.eclipse.swt.widgets.Display.runTimer(Display.java:3167)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:250 3)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2756)
at
at
at
at
at
at
Configuration Details
*** Date: Mon Apr 10 15:30:31 EDT 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20060118-1600
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse312\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
3e0_44
-vm
C:\jdk15005\bin\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1144697038560
eclipse.vm=C:\jdk15005\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\eclipse312\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse312\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\jdk15005\jre\lib\endorsed
java.ext.dirs=C:\jdk15005\jre\lib\ext
java.home=C:\jdk15005\jre
java.io.tmpdir=C:\DOCUME~1\SRIKAN~1\LOCALS~1\Temp\
java.library.path=C:\jdk15005\bin;.;C:\WINDOWS\system32;C:\W INDOWS;C:\jdk15005\bin;C:\WINDOWS\System32\Wbem;C:\WINDOWS\S ystem32;C:\Program
Files\Centura;C:\Program Files\Centura\Samples;C:\Program
Files\Centura\Tutorial;c:\oracle\ora92\bin;N:\JavaSoft\ant\b in;C:\Program
Files\Rational\common;C:\Oc4J1012\OPatch;C:\Oc4J1012\perl\5. 6.1\bin\MSWin32-x86;;C:\Program
Files\JProbe Suite 6.0\bin;C:\cygwin\bin;
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_05-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_05
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_05-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=c:\eclipse312\configuration\org.eclipse.osg i\bundles
osgi.configuration.area=file:/c:/eclipse312/configuration/
osgi.framework=file:/c:/eclipse312/plugins/org.eclipse.osgi_ 3.1.2.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.2
osgi.install.area=file:/c:/eclipse312/
osgi.instance.area=file:/C:/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/srikanthm/workspace/
osgi.logfile=C:\workspace\.metadata\.log
osgi.manifest.cache=c:\eclipse312\configuration\org.eclipse. osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\eclipse312\plugins\org.eclipse.platfo rm_3.1.2\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse312\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\jdk15005\jre\lib\rt.jar;C:\jdk15005\j re\lib\i18n.jar;C:\jdk15005\jre\lib\sunrsasign.jar;C:\jdk150 05\jre\lib\jsse.jar;C:\jdk15005\jre\lib\jce.jar;C:\jdk15005\ jre\lib\charsets.jar;C:\jdk15005\jre\classes
sun.boot.library.path=C:\jdk15005\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse
user.home=C:\Documents and Settings\srikanthm
user.language=en
user.name=srikanthm
user.timezone=America/New_York
user.variant=
*** Features:
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.2) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.1.2) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.1.1) "GEF Examples"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.jst (1.0.1.v200602130105) "J2EE Standard Tools (JST)"
org.eclipse.jst.common_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Common Core Source"
org.eclipse.jst.enterprise_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Enterprise Core Source"
org.eclipse.jst.enterprise_ui.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Enterprise UI Source"
org.eclipse.jst.sdk (1.0.1.v200602130105) "J2EE Standard Tools (JST)"
org.eclipse.jst.server_adapters.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Server Adapters Source"
org.eclipse.jst.server_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Server Core Source"
org.eclipse.jst.server_ui.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Server UI Source"
org.eclipse.jst.web_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Web Core Source"
org.eclipse.jst.web_ui.feature.source (1.0.1.200602171631) "J2EE Standard
Tools - Web UI Source"
org.eclipse.pde (3.1.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.2) "Eclipse Platform"
org.eclipse.platform.source (3.1.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.2) "Eclipse RCP"
org.eclipse.rcp.source (3.1.2) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.2) "Eclipse Project SDK"
org.eclipse.wst (1.0.1.v200602130105) "Web Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source (1.0.1.200602171545) "Web
org.eclipse.wst.common_ui.feature.source (1.0.1.200602171545) "Web
Standard Tools - Common UI"
org.eclipse.wst.rdb_adapters.feature.source (1.0.1.200602171545) "Web
Standard Tools SDK - RDB Component"
org.eclipse.wst.sdk (1.0.1.v200602130105) "Web Standard Tools (WST)"
org.eclipse.wst.server_core.feature.source (1.0.1.200602171545) "Web
org.eclipse.wst.server_ui.feature.source (1.0.1.200602171545) "Web
org.eclipse.wst.web_core.feature.source (1.0.1.200602171545) "Web Standard
org.eclipse.wst.web_ui.feature.source (1.0.1.200602171545) "Web Standard
org.eclipse.wst.ws_core.feature.source (1.0.1.200602171545) "Web Standard
Tools - Web Service Core Source"
org.eclipse.wst.ws_ui.feature.source (1.0.1.200602171545) "Web Standard
Tools - Web Service UI Source"
org.eclipse.wst.xml_core.feature.source (1.0.1.200602171545) "Web Standard
Tools - XML Core Source"
org.eclipse.wst.xml_ui.feature.source (1.0.1.200602171545) "Web Standard
Tools - XML UI Source"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1.v200602062208) "Axis121 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200602062000) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0.v200602052214) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.2) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Active]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.2) "File Buffers" [Active]
org.eclipse.core.resources (3.1.2) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.2) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.dali.core (1.0.0) "Dali Core" [Active]
org.eclipse.dali.db (1.0.0) "pluginName" [Active]
org.eclipse.dali.db.ddl (0.5.0) "Dali DDL Plug-in (Temporary)" [Resolved]
org.eclipse.dali.edit (1.0.0) "Dali Edit" [Active]
org.eclipse.dali.ui (1.0.0) "Dali UI" [Active]
org.eclipse.dali.utility (1.0.0) "pluginName" [Active]
org.eclipse.debug.core (3.1.2) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.2) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.2) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Active]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.2) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)" [Active]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Active]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.2) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.2) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.1.1) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.1) "GEF Logic Editor Example"
[Resolved]
org.eclipse.gef.examples.shapes (3.1.1) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.1) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.1) "GEF Text Editor Example" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.2) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.2) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.2) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Active]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.2) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.2) "JFace Text" [Active]
org.eclipse.jst (1.0.1.v200602130115) "J2EE Standard Tools (JST)"
[Resolved]
org.eclipse.jst.common_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Common Core Source" [Resolved]
org.eclipse.jst.common.annotations.controller (1.0.1.v200602070050)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.0.1.v200602070050) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.0.1.v200602070050) "Annotations
UI Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.0.1.v200602070050) "Integration
Plug-in" [Resolved]
org.eclipse.jst.common.navigator.java (1.0.1.v200602070050) "Navigator
Plug-in" [Active]
org.eclipse.jst.common.project.facet.core (1.0.1.v200602070050) "Project
Facet Core (Java Support)" [Resolved]
org.eclipse.jst.doc.isv (1.0.1.v1) "WST ISV Documentation" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.0.v200602140535) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.0.1.v200602070050) "WTP EJB UI Plug-in"
[Resolved]
org.eclipse.jst.enterprise_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Enterprise Core Source" [Resolved]
org.eclipse.jst.enterprise_ui.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Enterprise UI Source" [Resolved]
org.eclipse.jst.j2ee (1.0.1.v200602162141) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.0.1.v200602070050) "J2EE Core Component"
[Active]
org.eclipse.jst.j2ee.doc.user (1.0.1.v200602140535) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.0.1.v200602070050) "EJB component Plug-in"
[Resolved]
org.eclipse.jst.j2ee.ejb.annotation.model (1.0.0.v200602071827) "EJB
Annotation Model Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.0.0.v200602071827) "EJB
Emitter Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.0.0.v200502162142) "EJB
Annotations Ui Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.0.0.v200602071827)
"Xdoclet Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.1.v200602151541) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.0.1.v200602070050) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.0.1.v200602070050) "WTP JCA UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.0.1.v200602070050) "J2EE Extensions
to Common Navigator" [Active]
org.eclipse.jst.j2ee.ui (1.0.1.v200602070050) "WTP J2EE UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.web (1.0.1.v200602070050) "Web Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice (1.0.1.v200602070050) "Web Service
Plug-in" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.0.1.v200602070050) "WTP Webservice
org.eclipse.jst.j2ee.xdoclet.runtime (1.0.0.v200602111615) "XDocletRuntime
Plug-in" [Resolved]
org.eclipse.jst.jsp.core (1.0.1.v2006021502002350) "Structured Source JSP
Model" [Resolved]
org.eclipse.jst.jsp.ui (1.0.1.v200602062130) "SSE JSP Source Editor"
[Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.0.v200602140535) "JSP tools infopops"
[Resolved]
org.eclipse.jst.server_adapters.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Server Adapters Source" [Resolved]
org.eclipse.jst.server_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Server Core Source" [Resolved]
org.eclipse.jst.server_ui.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Server UI Source" [Resolved]
org.eclipse.jst.server.core (1.0.0.v20060131b) "Java Server Support"
[Resolved]
org.eclipse.jst.server.generic.core (1.0.0.v200602112126) "Generic Server
Plugin" [Resolved]
org.eclipse.jst.server.generic.serverdefinitions (1.0.0.v20060131b)
"Oracle OC4J v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.1.v200602131705) "Generic Server
Plugin UI" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.0.v20060213) "Apache Tomcat
Support" [Resolved]
org.eclipse.jst.server.tomcat.ui (1.0.0.v20060131b) "Apache Tomcat UI
Support" [Resolved]
org.eclipse.jst.server.ui (1.0.0.v20060131b) "Java Server UI Support"
[Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.1.v200602140535) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.1.v200602140535) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.0.v20060131b) "WebSphere
org.eclipse.jst.servlet.ui (1.0.1.v200602070050) "WTP Servlet UI Plug-in"
[Resolved]
org.eclipse.jst.servlet.ui.infopop (1.0.1.v200602130315) "Servlet infopop"
[Resolved]
org.eclipse.jst.web_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Web Core Source" [Resolved]
org.eclipse.jst.web_ui.feature.source (1.0.1.v200602151554) "J2EE Standard
Tools - Web UI Source" [Resolved]
org.eclipse.jst.ws (1.0.1.v200602061953) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.1.v200602062208) "Web
service Axis Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.1.v200602062208) "Webservice
Axis Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.1.v200602062000) "Webservice Axis
Creation UI" [Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.0.v200602140535) "Web services Axis
UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.1.v200602140535) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.1.v200602061953) "Web Services
Consumption" [Resolved]
org.eclipse.jst.ws.consumption.infopop (1.0.0.v200602140535) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.1.v200602061953) "Web Services
Consumption Graphical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.1.v200602140535) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200602062000) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.1.v200602061953) "Web Services
Creation Graphical User Interface" [Resolved]
org.eclipse.jst.ws.doc.user (1.0.1.v200602140535) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.0.v200602140535) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.0.v200602062000) "Web Services
Universal Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.0.v200602062000) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.2) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
[Resolved]
org.eclipse.pde.build (3.1.2) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.2) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"
[Active]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.2) "Plug-in Development UI" [Active]
org.eclipse.platform (3.1.2) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.2) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.2) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.2) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.2) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.2) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.2) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Active]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.2) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.2) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.2) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.2) "Text Editor Framework"
[Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.2) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.1.v200602130115) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.1.v200602062000) "Environment Command
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.1.v200602062000) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.ui (1.0.1.v200602062000) "Environment Command
Framework (GUI)" [Resolved]
org.eclipse.wst.common_core.feature.source (1.0.1.v200602151554) "Web
org.eclipse.wst.common_ui.feature.source (1.0.1.v200602151554) "Web
Standard Tools - Common UI" [Resolved]
org.eclipse.wst.common.emf (1.0.1.v200602070050) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.0.1.v200602070050) "EMF
Workbench Edit Plug-in" [Active]
org.eclipse.wst.common.environment (1.0.0.v200602151541) "Enviornment
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.0.1.v200602070050)
"org.eclipse.wst.common.frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (1.0.1.v200602070050) "WTP UI
Plug-in" [Active]
org.eclipse.wst.common.infopop (1.0.0.v200602140544) "Common WST infopops"
[Resolved]
org.eclipse.wst.common.modulecore (1.0.1.v200602162141) "Modulecore
Plug-in" [Active]
org.eclipse.wst.common.navigator.views (1.0.1.v200602070050) "Common
Navigator View" [Active]
org.eclipse.wst.common.navigator.workbench (1.0.1.v200602070050)
"Navigator Workbench Components" [Active]
org.eclipse.wst.common.project.facet.core (1.0.1.v200602070050) "Project
Facet Core" [Active]
org.eclipse.wst.common.project.facet.ui (1.0.1.v200602070050) "Project
Facet UI" [Resolved]
org.eclipse.wst.common.snippets (1.0.0.v200602062130) "Snippets View"
[Resolved]
org.eclipse.wst.common.ui (1.0.0.v200602061610) "Eclipse Base UI
extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.0.v200602061610) "Common
Properties UI" [Active]
org.eclipse.wst.common.uriresolver (1.0.1.v200601310800) "Common URI
Resolver Framework" [Resolved]
org.eclipse.wst.css.core (1.0.0.v200602062135) "Structured Source CSS
Model" [Resolved]
org.eclipse.wst.css.ui (1.0.0.v200602062135) "SSE CSS Source Editor"
[Resolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.1.v200602130315)
"Data documentation" [Resolved]
org.eclipse.wst.datatools.data.ui.doc.user (1.0.1.v200602130315) "Data
tools data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.1.v200602130315) "Data
org.eclipse.wst.datatools.server.ui.doc.user (1.0.1.v200602151541)
"Database Explorer documentation" [Resolved]
org.eclipse.wst.doc.isv (1.0.1.v1) "WST ISV Documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.1.v200602130315) "Master User Doc TOC"
[Resolved]
org.eclipse.wst.dtd.core (1.0.1.v200602041933) "Structured Source DTD
Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.1.v200602041933) "SSE DTD Source Editor"
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200602140544) "DTD Editor infopops"
[Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.1.v200602130310) "DTD Editor
org.eclipse.wst.html.core (1.0.0.v200602062135) "Structured Source HTML
Model" [Resolved]
org.eclipse.wst.html.standard.dtds (1.0.0.v200602130315) "Known DTDs"
[Resolved]
org.eclipse.wst.html.ui (1.0.0.v200602062135) "HTML UI Source Editor"
[Resolved]
org.eclipse.wst.html.ui.infopop (1.0.0.v200602140544) "HTML editor
infopops" [Resolved]
org.eclipse.wst.internet.cache (1.0.0.v200602131700) "Cache URI Resolver
Plug-in" [Resolved]
org.eclipse.wst.internet.monitor.core (1.0.0.v20060131b) "Monitor"
[Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0.v20060131b) "TCP/IP Monitor"
[Resolved]
org.eclipse.wst.internet.proxy (1.0.0.v200602061953) "Internet Proxy
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200602140544) "Internet
Proxy Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.0.v200602062135) "Structured Source
JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.0.v200602062135) "SSE JavaScript Source
Editor" [Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.0.v200602140544) "Javascript
infopop" [Resolved]
org.eclipse.wst.rdb_adapters.feature.source (1.0.1.v200602130145) "Web
Standard Tools SDK - RDB Component" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.0.v200602061859) "RDB
Connection.ui" [Active]
org.eclipse.wst.
Current Time: Fri Apr 26 17:32:47 GMT 2024
Powered by FUDForum. Page generated in 0.04970 seconds
