Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to reuse Help System window from standalone SWT application
How to reuse Help System window from standalone SWT application [message #433465] Thu, 08 April 2004 15:24 Go to next message
Originally posted by: doublexia.hotmail.com
I'm trying to invoke Eclipse Help system from my standalone SWT application
based on Eclipse 2.1. I'm using following code:
import org.eclipse.help.standalone.Help;
public class MyHelpClass {
Help helpSystem;
public void displayHelp(String object) {
if (helpSystem == null) {
String[] options =
new String[] { "-eclipsehome", myEclipseHomeDirectory };
helpSystem = new Help(options);
try {
helpSystem.start();
} catch (Exception e) {
e.printStackTrace();
try {
helpSystem.displayHelp(object);
Everytime when I call to displayHelp(href) to display a topic, it starts a
help window. How can I reuse one help window?
Re: How to reuse Help System window from standalone SWT application [message #433473 is a reply to message #433465] Thu, 08 April 2004 16:55 Go to previous messageGo to next message
Assuming you are on Windows, if you launch Eclipse Workbench 2.1 you will
notice there are three browser adapters to chose from in the help
preferences. (1) SWT Embedded IE, and (2) System browser adapters reuse
browser. The third one (3) custom browser launches an full IE every time.
If your standalone does not include org.eclipse.help.ui.win32 fragment (with
all its required plugins), help has only (3) available. If
org.eclipse.help.ui.win32 fragment is working, then you should get (1) that
will be reused the window for every call do displayHelp.
You can set preference a to use (2) or (3) without a UI, by overriding help
preferences using plugin_customization.ini. For example, to set browser to
(2) use:
org.eclipse.help/default_browser=org.eclipse.help.ui.systemb rowser. You can
also provide your own browser adapter implementation to
org.eclipse.help.browser extension point.
Konrad
"Double Xia" <doublexia@hotmail.com> wrote in message
news:c548j7$4m4$1@eclipse.org...
application
> Help helpSystem;
> String[] options =
> try {
> helpSystem.start();
> try {
Re: How to reuse Help System window from standalone SWT application [message #433476 is a reply to message #433473] Thu, 08 April 2004 23:56 Go to previous messageGo to next message
Thank you Konrad, the help system works fine now.
But I have one more question: I didn't see any difference by defining
system_browser in plugin_customization.ini. I put this ini file under
org.eclipse.help_2.1.0. Is this right?
Double
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:c54du3$bbb$1@eclipse.org...
(with
that
help
to
> (2) use:
can
> Konrad
> application
> > Help helpSystem;
> > String[] options =
> > try {
> > helpSystem.start();
> > try {
a
Re: How to reuse Help System window from standalone SWT application [message #433628 is a reply to message #433476] Sat, 10 April 2004 23:47 Go to previous message
No, default plug-in preferences are specified in preferences.ini file in
plug-in installation directory. A product built without modifiying plug-in
files can override preferences using plugin_customization.ini placed in its
primary feature plug-in. See:
http://help.eclipse.org/help21/topic/org.eclipse.platform.do c.isv/guide/product_config.htm
http://help.eclipse.org/help21/topic/org.eclipse.platform.do c.isv/guide/product_def_primary.htm
Konrad
news:c556jd$32o$1@eclipse.org...
> Double
will
time.
> (with
> that
> help
> to
> > (2) use:
> can
> > Konrad
> > application
> > > Help helpSystem;
> > > String[] options =
> > > try {
> > > helpSystem.start();
> > > try {
starts
> a
Previous Topic:Swing Dialog
Next Topic:Problems with buttons and groups
Current Time: Fri Nov 07 01:36:31 EST 2025
Powered by FUDForum. Page generated in 0.04690 seconds
