Re: problem mapping to DB [message #433454 is a reply to message #433453] |
Sun, 08 January 2006 06:29 |
Originally posted by: gkatz.allot.com
thanks;
would you be so kind as to explain to me how to bypass my problem for the
time being? i am not sure i understand what to do or if i have any choice
here?
thanks in advance
Re: problem mapping to DB [message #433456 is a reply to message #433454] |
Mon, 09 January 2006 09:28 |
Originally posted by: dibyendu.mazumdar.demon.co.uk
I had the same problem when trying out Dali. To resolve this you need to
connect to the database using the schema that contains the table -
assuming that the id and schema are the same thing. For example, in Apache
Derby, the default JDBC connect id is APP. But if I create a table called
EMP under schema SCOTT, it won't be visible. I have to change the JDBC
connection id to SCOTT for this table to become visible.
Re: problem mapping to DB [message #433458 is a reply to message #433456] |
Mon, 09 January 2006 12:18 |
guys;
i did not understand what i should do in order to overcome this.
i never encountered the term 'schema name' so i dont know how to define it.
can someone please explain what exacly i should do here.
any help would be great.
thanks in advance.
Re: problem mapping to DB [message #433459 is a reply to message #433458] |
Mon, 09 January 2006 13:31 |
hi;
i just created a database named 'gkatz' and now the schema name is the
'gkatz' and this is also the connection username so everything is ok now
but of course in my reallife situation i cant do this so hopefully yhe bug
will be resolved soon.
tnanks.
Re: problem mapping to DB [message #562079 is a reply to message #433453] |
thanks;
here?
thanks in advance
Re: problem mapping to DB [message #562122 is a reply to message #433454] |
Re: problem mapping to DB [message #562169 is a reply to message #433456] |
guys;
thanks in advance.
Re: problem mapping to DB [message #562192 is a reply to message #433458] |
hi;
tnanks.
FUDForum. Page generated in 0.04530 seconds
