Home » Modeling » EMF » Which query language is it and how to change it?
Which query language is it and how to change it? [message #431856] |
Tue, 28 July 2009 10:25 |
Originally posted by: formatzeh.gmx.de
I'm curious about the query language which is used in the xml of
metamodel instances created with an emf generated editor. For example,
look at the following line:
<column locate="//@model.0/@component.5" unit="percent" width="33"/>
The attribute "locate" references another element in the model/xml. You
can read from the reference that my model contains several elements
called "model" and it is located in the first one (index 0). There it is
the sixth component (index 5). The syntax reminds a little bit on xpath
but it isn't. So I'm interested in the query language. That was the
first issue. The second one is that those references, as they are used
now, are not very readable for human. That's why I'm interested in
changing it anyhow. For example the first model has the type
"ccm:ConceptualModel" and the sixth component has the type "ccm:Service"
and name="BuildingMap" - it would be nice that those more expressive
data of the elements could be used as references. I imagine that I have
to identify some kind of primary key? And if yes, is it possible to
specify those keys hierarchically? I mean it would be nice if two
elements contained in different branches in the model can have the same
key as the can be identified unique by the parent id. Is this issue
possible at all?
best regards,
Gilbert
Re: Which query language is it and how to change it? [message #431858 is a reply to message #431856] |
Tue, 28 July 2009 10:38 |
Gilbert,
Isn't that XPath?
Cheers
/Eike
> possible at all?
> best regards,
> Gilbert
Cheers
/Eike
http://www.esc-net.de
Re: Which query language is it and how to change it? [message #431884 is a reply to message #431856] |
Tue, 28 July 2009 16:06 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------040203070905080700030008
Gilbert,
Comments below.
It's not a query language. It's just an EMF path with segments
documented like this in InternalEObject.
String
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82String >
org.eclipse.emf.ecore.InternalEObject
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct >.eURIFragmentSegment(EStructuralFeature
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82EStructuralFeature >
eFeature, EObject
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82EObject >
eObject)
Returns the fragment segment that, when passed to
|eObjectForURIFragmentSegment
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82%E2%98%82eObjectForURIFragmentSegment >|,
will resolve to the given object in this object's given feature.
The feature argument may be |null| in which case it will be deduced, if
possible. The default result will be of the form:
"@<feature-name>[.<index>]"
> changing it anyhow.
You can specialize eObjectForURIFragmentSegment and eURIFragmentSegment
in your AbcImpl. EModelElementImpl shows a good example. You might
also want to take advantage of EReference.eKeys so you get thing like
@model[name='value] instead of an index.
Yes, you can do that by identifying an attribute on the referenced type
as being unique within that containment EReference.
> possible at all?
Keys must be unique only within one given reference, unlike IDs which
must be unique for the whole resource.
> best regards,
> Gilbert
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:h4mjm2$k1m$1@build.eclipse.org" type="cite">
<pre wrap="">I'm curious about the query language which is used in the xml of
<column locate=<a class="moz-txt-link-rfc2396E" href="mailto://@model.0/@component.5">"//@model.0/@component.5"</a> unit="percent" width="33"/>
</pre>
</blockquote>
documented like this in InternalEObject.<br>
<br>
<h5>
<div style="margin-top: 0px; margin-left: 22px;"><a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82String ">String</a>
org.eclipse.emf.ecore.<a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct ">InternalEObject</a>.eURIFragmentSegment(<a
class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82EStructuralFeature ">EStructuralFeature</a>
eFeature, <a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82EObject ">EObject</a>
eObject)</div>
</h5>
<p>Returns the fragment segment that, when passed to <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore%7BInternalEObject.java%E2%98%83InternalEObje ct%7EeURIFragmentSegment%7EQEStructuralFeature;%7EQEObject;% E2%98%82%E2%98%82eObjectForURIFragmentSegment ">eObjectForURIFragmentSegment</a></code>,
will resolve to the given object in this object's given feature. </p>
<p>The feature argument may be <code>null</code> in which case it will
be deduced, if possible. The default result will be of the form: </p>
<pre> "@<feature-name>[.<index>]"
</pre>
<br>
<pre wrap="">
changing it anyhow.</pre>
</blockquote>
@model[name='value] instead of an index.<br>
<pre wrap=""> For example the first model has the type
to identify some kind of primary key? </pre>
</blockquote>
as being unique within that containment EReference.<br>
<pre wrap="">And if yes, is it possible to
possible at all?
</pre>
</blockquote>
must be unique for the whole resource.<br>
<pre wrap="">
best regards,
Gilbert
</pre>
</blockquote>
</body>
</html>
--------------040203070905080700030008--
Ed Merks
Re: Which query language is it and how to change it? [message #431890 is a reply to message #431884] |
Tue, 28 July 2009 17:10 |
Nice, that sounds promising,
where do I get this class? From the svn repository?
You mean the property "Unique" on the elements? This is true by default.
Re: Which query language is it and how to change it? [message #431899 is a reply to message #431890] |
Tue, 28 July 2009 23:08 |
--------------060206020101010806010101
Gilbert,
Comments below.
If you have the EMF SDK installed you can get at it that way. Ctrl-Shift-T.
No, I mean that within the objects being referenced by that one
reference, only one object has that key value. E.g., in an EPackage,
the name of the eClassifiers must be unique, but different packages can
have classifiers with the same name.
<html>
<head>
</head>
Gilbert,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:h4nbda$o0n$1@build.eclipse.org" type="cite">
<pre wrap="">Nice, that sounds promising,
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">You can specialize eObjectForURIFragmentSegment and eURIFragmentSegment
</pre>
</blockquote>
<pre wrap=""><!---->where do I get this class? From the svn repository?
</pre>
</blockquote>
Ctrl-Shift-T.<br>
<pre wrap="">
</pre>
<pre wrap="">Yes, you can do that by identifying an attribute on the referenced type
</pre>
</blockquote>
</pre>
<pre wrap="">Keys must be unique only within one given reference, unlike IDs which
</pre>
</blockquote>
<pre wrap=""><!---->You mean the property "Unique" on the elements? This is true by default.
</pre>
</blockquote>
have classifiers with the same name.<br>
</body>
</html>
--------------060206020101010806010101--
Ed Merks
Re: Which query language is it and how to change it? [message #431906 is a reply to message #431899] |
Wed, 29 July 2009 08:14 |
> Ctrl-Shift-T.
I got it :) looks nicer now. The aforementioned example now looks so:
<column locate="//@model.0/@component[name='TestService']"/>
Thank you a lot Ed.
best regards,
Gilbert
Current Time: Fri Apr 26 09:05:53 GMT 2024
Powered by FUDForum. Page generated in 0.03479 seconds
