Re: Generating EMF EPackages for all xsd URIs [message #431889 is a reply to message #431880] |
Tue, 28 July 2009 16:41 |
Derek Palma Messages: 141 Registered: July 2009 |
Ed,
Thanks for your help!
Just to clarify, I don't rely on a specific EObject implementation. I just
take whatever I get back and extract the EPackage from it and move on. I
just happenned to notice in the debugger that different implementations
correlate with different EPackages. Sorry for the confusion. I am just
expecting to find EPackages for the .xsds referenced.
I using the same XML file in both my Ecplise instances so I would not expect
anything in the file to affect the behavior. Could there be a variant across
the different Eclipse instance? One is Ganymede and the other is Galileo
RC2. It seems highly unlikely this functionality would vary.
Maybe I just need to step through the code which makes the decision about
converting the .xsd to and Ecore model. Would you happen to know which area
of the source I should start from?
I have attached the beginning of my test file below.
Derek
<domain xsi:schemaLocation="http://www.bea.com/ns/weblogic/90/security
http://www.bea.com/ns/weblogic/90/security.xsd
http://www.bea.com/ns/weblogic/90/security/wls
http://www.bea.com/ns/weblogic/90/security/wls.xsd
http://www.bea.com/ns/weblogic/90/security/xacml
http://www.bea.com/ns/weblogic/90/security/xacml.xsd
http://www.bea.com/ns/weblogic/920/domain
http://www.bea.com/ns/weblogic/920/domain.xsd"
xmlns="http://www.bea.com/ns/weblogic/920/domain"
xmlns:sec="http://www.bea.com/ns/weblogic/90/security"
xmlns:wls="http://www.bea.com/ns/weblogic/90/security/wls"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<name>medrec</name>
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:h4n6p6$dhg$1@build.eclipse.org...
> Derek,
> Comments below.
> Derek Palma wrote:
>> Hi,
>> I am loading xml files with the code shown below. The code was originally
>> from Binding XML to Java. I have a problem where I am getting
>> inconsistent results. Specifically I expect the document root to be a
>> DynamicEObjectImpl
> There's no reason why you should ever rely on a specific EObjectImpl...
>> if the xsds could be resolved and the EPackages generated. I noticed when
>> the schema cannot be found I get and XMLTypeDocumentRootImpl. If I simply
>> prevent resolution of the XSDs I can force this to happen, of course.
>> My problem is that on a particular machine I am getting an
>> XMLTypeDocumentRootImpl when I expect a DynamicEObjectImpl and need a way
>> to troubleshoot this.
>> I am looking for a way I can determine whether or not the XML Resource
>> was able to get the schemas and create the EMF model automatically. I
>> presume the only reason the EMF model is not generated is that the
>> schemas were not found or could not be parsed. Is this correct?
> Yes.
>> How can the reason XMLTypeDocumentRootImpl was generated?
> That sounds like the case where the root element's name space isn't
> recognized and a demand created feature is used to process it. But as I
> said, you should not make assumptions beyond assuming the instance
> implements EObject/InternalEObject...
>> Any pointers are appreciated.
>> Thanks in advance.
>> Derek
>> ResourceSet resourceSet = new ResourceSetImpl();
>> final ExtendedMetaData extendedMetaData = new
>> BasicExtendedMetaData(resourceSet.getPackageRegistry());
>> resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED _META_DATA,
>> extendedMetaData);
>> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put
>> (Resource.Factory.Registry.DEFAULT_EXTENSION,
>> new GenericXMLResourceFactoryImpl());
>> // Demand load the resource.
>> Resource resource = resourceSet.getResource(URI.createFileURI(DATA_FOLDER
>> + fileName), true);
>> // Display what was loaded.
>> resource.save(System.out, null);
>> System.out.println();
>> System.out.println("Traversing EMF AnyType");
>> // Get the document root instance from the resource
>> // and get the root object from that.
>> // We'll assume that it's an instance of AnyType (which isn't a good
>> general assumption).
>> EObject documentRoot = (EObject)resource.getContents().get(0);
Re: Generating EMF EPackages for all xsd URIs [message #431900 is a reply to message #431889] |
Tue, 28 July 2009 23:10 |
Ed Merks Messages: 33216 Registered: July 2009 |
Derek,
Maybe try setting a breakpoint in BasicExtendedMetaData.demandPackage
since that will be called in the case that a package is created when no
existing package matches properly.
Derek Palma wrote:
> Ed,
> just take whatever I get back and extract the EPackage from it and
> move on. I just happenned to notice in the debugger that different
> implementations correlate with different EPackages. Sorry for the
> confusion. I am just expecting to find EPackages for the .xsds
> referenced.
> expect anything in the file to affect the behavior. Could there be a
> variant across the different Eclipse instance? One is Ganymede and the
> other is Galileo RC2. It seems highly unlikely this functionality
> would vary.
> about converting the .xsd to and Ecore model. Would you happen to know
> which area of the source I should start from?
> Derek
> <name>medrec</name>
>> Derek,
>> Comments below.
>> Derek Palma wrote:
>>> Hi,
>>> originally from Binding XML to Java. I have a problem where I am
>>> getting inconsistent results. Specifically I expect the document
>>> root to be a DynamicEObjectImpl
>>> when the schema cannot be found I get and XMLTypeDocumentRootImpl.
>>> If I simply prevent resolution of the XSDs I can force this to
>>> happen, of course.
>>> a way to troubleshoot this.
>>> Resource was able to get the schemas and create the EMF model
>>> automatically. I presume the only reason the EMF model is not
>>> generated is that the schemas were not found or could not be parsed.
>>> Is this correct?
>> Yes.
>> as I said, you should not make assumptions beyond assuming the
>> instance implements EObject/InternalEObject...
>>> Thanks in advance.
>>> Derek
>>> extendedMetaData);
>>> Resource resource =
>>> resourceSet.getResource(URI.createFileURI(DATA_FOLDER + fileName),
>>> true);
Ed Merks
FUDForum. Page generated in 0.05968 seconds
