Re: [CDO] FactoryNotFoundException: Factory not found: org.eclipse.net4j.serverProtocols[cdo] [message #431753 is a reply to message #431729] |
Thu, 23 July 2009 17:06 |
Kai,
Comments below...
Kai Schlamp schrieb:
> Hi.
> I just switched to the latest CDO CVS Head as target for my RCP
> application. When I start the app now I get the below exception.
> I included those plugins as dependencies:
> org.eclipse.emf.cdo
> org.eclipse.emf.cdo.common
> org.eclipse.emf.cdo.net4j
^ This one is only needed for client-side sessions.
But this one is missing for a server setup: org.eclipse.emf.cdo.server.net4j
HTH
Cheers
/Eike
> org.eclipse.emf.cdo.server.db
> org.eclipse.net4j
> org.eclipse.net4j.db
> org.eclipse.net4j.db.h2
> org.eclipse.net4j.jvm
> org.eclipse.net4j.tcp
> org.eclipse.net4j.util
> What else do I need to add to get those mentioned server protocols?
> Regards,
> Kai
> The exception:
> org.eclipse.net4j.channel.ChannelException:
> org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not
> at
> org.eclipse.net4j.internal.jvm.JVMConnector.registerChannelW ithPeer(JVMConnector.java:128)
> at
> org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:156)
> at
> org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(Channel Multiplexer.java:1)
> at
> org.eclipse.net4j.signal.failover.NOOPFailOverStrategy.handl eOpen(NOOPFailOverStrategy.java:53)
> at
> org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol. java:167)
> at
> org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtoco l.openSession(CDOClientProtocol.java:82)
> at
> org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurat ionImpl.activateSession(CDONet4jSessionConfigurationImpl.jav a:156)
> at
> org.eclipse.emf.internal.cdo.session.CDOSessionImpl.doActiva te(CDOSessionImpl.java:711)
> at
> org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:65)
> at
> org.eclipse.emf.internal.cdo.session.CDOSessionConfiguration Impl.openSession(CDOSessionConfigurationImpl.java:121)
> at
> org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurat ionImpl.openSession(CDONet4jSessionConfigurationImpl.java:11 6)
> at
> org.pubcurator.core.managers.ServerManager.createSession(Ser verManager.java:166)
> at
> org.pubcurator.core.managers.ServerManager.connectToServer(S erverManager.java:208)
> at
> org.pubcurator.core.managers.ServerManager.connectToLocalSer ver(ServerManager.java:186)
> at
> org.pubcurator.core.ApplicationWorkbenchAdvisor$1$1.run(Appl icationWorkbenchAdvisor.java:87)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
> Caused by: org.eclipse.net4j.util.container.FactoryNotFoundException:
> at
> org.eclipse.net4j.util.container.ManagedContainer.getFactory (ManagedContainer.java:193)
> at
> org.eclipse.net4j.util.container.ManagedContainer.createElem ent(ManagedContainer.java:490)
> at
> org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:281)
> at
> org.eclipse.net4j.ContainerProtocolProvider.getProtocol(Cont ainerProtocolProvider.java:51)
> at
> org.eclipse.spi.net4j.ChannelMultiplexer.createProtocol(Chan nelMultiplexer.java:245)
> at
> org.eclipse.spi.net4j.ChannelMultiplexer.inverseOpenChannel( ChannelMultiplexer.java:179)
> at
> org.eclipse.net4j.internal.jvm.JVMConnector.registerChannelW ithPeer(JVMConnector.java:116)
> ... 15 more
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.06471 seconds
