Possible to reference a xml simple type`? [message #431665] |
Tue, 21 July 2009 10:46 |
Originally posted by: formatzeh.gmx.de
I'm just wondering if it is possible to import anyhow the xml simple
types. I mean I don't want to create them in my metamodel but rather
want to use them in my generated editor as references. In the ecore
diagram editor I tried to load resources... but I only can load ecore
models in the workspace or filesystem and not in the registry. Is it
possible anyhow?
Re: Possible to reference a xml simple type`? [message #431701 is a reply to message #431678] |
Wed, 22 July 2009 10:23 |
Ed Merks wrote:
> XMLTypePackage has EDataTypes for the XML Schema built-in simple types...
found it
> Perhaps if you use the Sample Ecore Editor to load it and make your
> first reference to it, after that the diagram editor will let you work
> with it...
Ok so it works. If you add a reference in the sample editor first you
can work with the imported package in the ecore diagram editor as well.
But now I have another problem. In my genmodel the imported package
appears as well - understandable. The generation of the editor worked
fine except an error in one test class. For now I commented the line out
where a not existent method is to be invoked. But in the new eclipse
instance, where I want to work with my editor, I get the following error
when starting the creation wizard:
Plug-in "myplugin.editor" was unable to instantiate class
"myplugin.presentation.ModelWizard".
Could not initialize class myplugin.MyModelPackage
that's caused by the following line in the init method of my package impl:
TypePackageImpl theTypePackage =
(TypePackageImpl)(EPackage.Registry.INSTANCE.getEPackage(Typ ePackage.eNS_URI)
instanceof TypePackageImpl ?
EPackage.Registry.INSTANCE.getEPackage(TypePackage.eNS_URI) :
TypePackage.eINSTANCE);
and by the following line in my imported TypePackageImpl:
XMLTypePackage theXMLTypePackage =
(XMLTypePackage)EPackage.Registry.INSTANCE.getEPackage(XMLTy pePackage.eNS_URI);
What can I do to avoid this?
Re: Possible to reference a xml simple type`? [message #431705 is a reply to message #431701] |
Wed, 22 July 2009 11:24 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------020309040302040608060207
Gilbert,
How exactly do those lines cause a problem? The XMLTypePackage does
exist. When you created your GenModel, did you choose the existing
GenModel for XMLTypePackage in the final wizard or create a new
GenPackage for it?
Gilbert Mirenque wrote:
> found it
>> with it...
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
GenPackage for it? <br>
<br>
<br>
<blockquote cite="mid:h46pa9$fpk$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">XMLTypePackage has EDataTypes for the XML Schema built-in simple types...
</pre>
</blockquote>
<pre wrap=""><!---->found it
</pre>
<pre wrap="">Perhaps if you use the Sample Ecore Editor to load it and make your
with it...
</pre>
</blockquote>
<pre wrap=""><!---->Ok so it works. If you add a reference in the sample editor first you
</pre>
</blockquote>
</body>
</html>
--------------020309040302040608060207--
Ed Merks
Re: Possible to reference a xml simple type`? [message #431713 is a reply to message #431705] |
Wed, 22 July 2009 14:58 |
Ed Merks wrote:
> Gilbert,
> GenPackage for it?
In my genmodel appeared a new package for the XMLTypePackage
automatically when adding references to it in my metamodel. How can I
specify to choose an existing genmodel and where do I find it?
Re: Possible to reference a xml simple type`? [message #431778 is a reply to message #431743] |
Sat, 25 July 2009 12:47 |
Ed Merks wrote:
> Gilbert,
> The bottom 1/2 of the wizard should support that. Have a look at how a
> model generated from an XSD looks and try to make it look like that...
Ok, it works in that way if you delete the genmodel and generate it
again. But you can't reference the other genmodel if your own genmodel
already exists - or I didn't find it.
But I think my explanation from my first post was a little bit
underinformed (nice word ;) ). I try to explain in other words what I
want to do:
I start from behind. With the generated editor I want to create a model
for my domain. In this domain I need datatypes as well. My idea was that
it would be nice if one can reference existing XML simple datatypes such
as xs:string for example. Or one has the option to create special types
and reference those. That's why I thought that I can create a class
(AbstractDatatype) in my metamodel inheriting from a root class of the
XMLTypes package. I thought there is a class from which all simple xml
types inherit, which I can use as parent class for my AbstractDatatype.
Furthermore my idea was that now I simply can reference the parent class
of all simple XML types in my metamodel. I thought that by that I can
then reference all XML simple types or an own special type (inheriting
from the parent XML simple type). That means I don't want to use the
metaelements from the XMLTypes package and the concrete types in my
generated editor or alternatively some special types. Is it
udnerstandable? And the more important question: is it possible?
best regards,
Gilbert
Re: Possible to reference a xml simple type`? [message #431779 is a reply to message #431778] |
Sat, 25 July 2009 13:00 |
I have another idea. Maybe the following scenario is possible:
in the second Eclipse instance where the generated editor is available:
- create a new XML schema
- create an instance of my metamodel with the generated editor
- in that instance load the created xml schema as resource
- in that instance reference a type contained in the xml schema
Is that possible or is it to freaky?
Re: Possible to reference a xml simple type`? [message #431879 is a reply to message #431743] |
Tue, 28 July 2009 15:44 |
I'm interested in how to reference an existing genmodel in my own
existing genmodel? If I load a resource in the ecore file I can add
references to the loaded model. But by that my genmodel won't contain a
reference to the genmodel from which the model was loaded. I have real
packages. How do I do this when my genmodel already exists? How do I
reference a genmodel from the emf registry?
Re: Possible to reference a xml simple type`? [message #431895 is a reply to message #431886] |
Tue, 28 July 2009 19:08 |
Ed Merks wrote:
> The last page of the wizard should allow you to locate GenModels for any
> packages being loaded.
This is right - but the wizard can only be used when I want to create a
new genmodel. My genmodel exists already so I can't use it :/
Re: Possible to reference a xml simple type`? [message #431897 is a reply to message #431895] |
Tue, 28 July 2009 23:04 |
--------------010309040502030107050409
Gilbert,
Reload... uses the same wizard.
<html>
<head>
</head>
Gilbert,<br>
<br>
Reload... uses the same wizard.<br>
<br>
<blockquote cite="mid:h4nibi$4qd$1@build.eclipse.org" type="cite">
</pre>
<pre wrap="">The last page of the wizard should allow you to locate GenModels for any
</pre>
</blockquote>
<pre wrap=""><!---->This is right - but the wizard can only be used when I want to create a
</pre>
</blockquote>
</body>
</html>
--------------010309040502030107050409--
Ed Merks
FUDForum. Page generated in 0.43777 seconds
