Re: passing a hibernate.cfg.xml to teneo [message #431504 is a reply to message #431503] |
Tue, 14 July 2009 12:42 |
Hi Alex,
I would expect that it is picked up automatically when the file is in the root of the classpath. Are you sure that the
cfg.xml is present in the root of the classpath? Often to get this done such a file needs to be explicitly added to the
build.properties or not excluded in the source folder (non-plugin projects).
gr. Martin
Alex Gfeller wrote:
> Dear Martin, dear all,
> I would like to use hibernate search for some reason. As we can not work
> with annotations,
> we have to configured the corresponding listeners in the hibernate.cfg.xml.
> In my application, I initializing teneo like this (using spring):
> <!-- Teneo Session Factory -->
> <bean id="sessionFactory"
> class="org.eclipse.emf.teneo.hibernate.HbSessionDataStore"
> init-method="initialize">
> <property name="name" value="hbDataStore" />
> <property name="properties">
> <props>
> <prop
> key="hibernate.connection.datasource">java:/comp/env/jdbc/arts </prop>
> <prop
> key="hibernate.dialect">org.hibernate.dialect.SQLServerDialect </prop>
> <prop key="hibernate.hbm2ddl.auto">update</prop>
> <prop
> key="teneo.mapping.mapping_file_name">/hibernate.hbm.xml</prop >
> <prop
> key="hibernate.search.default.indexBase">c:/tmp/index</prop >
> </props>
> </property>
> <property name="EPackageClasses">
> <list>
> <value>com.inventage.emf.ebo.impl.EboPackageImpl</value>
> <value>com.swissfinancial.arts.model.base.impl.BasePackageImpl </value>
> <value>com.swissfinancial.arts.model.fund.impl.FundPackageImpl </value>
> </list>
> </property>
> </bean>
> <!-- Transaction Manager -->
> <bean id="transactionManager"
> class=" org.springframework.orm.hibernate3.HibernateTransactionManag er "
> p:sessionFactory-ref="sessionFactory" />
> Now my question:
> How can I tell teneo to load the hibernate stuff out of my
> hibernate.cfg.xml? I looked around in the
> news groups but couldn't find anything really helpful!
> Thanks for your help,
> Alex
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: passing a hibernate.cfg.xml to teneo [message #431506 is a reply to message #431505] |
Tue, 14 July 2009 13:13 |
Hi Alex,
Yes it is possible that the way Teneo creates the configuration interferes, although I did not expect it.
Yes in the HbSessionDataStore there is a createConfiguration method. It is best to also have the hibernate sources
available so you can debug into them. I often manually add the java source files to the hibernate jar file to be sure
that they are available.
Let me know if you find something special! I am open to suggestions if it eases configuration.
gr. Martin
Alex Gfeller wrote:
> Hi Martin,
> Yes, the file is in the root of my classpath. We run teneo in a web app
> and we have placed the file in the WEB-INF/classes subfolder.
> Can you give me a hint, where I could start debugging? (somewhere in the
> HbSessionDataStore..)?
> I see an other potential problem: Some of the hibernate properties are
> passed as configuration to the HbSessionDataStore (see pervious post)
> and some would then be in the hibernate.cfg.xml. Would it make sense to
> put everything to the hibernate.cfg.xml and pass only the epackages
> directly to the HbSessionDataStore?
> Alex
The Netherlands
FUDForum. Page generated in 0.02897 seconds
