Re: isComposite and isId usage ? [message #431510 is a reply to message #431498] |
Tue, 14 July 2009 15:06 |
Ed Merks Messages: 33218 Registered: July 2009 |
It's not possible for a reference to be an ID and this bogus isID
attribute is confusing the deserializer.
gitanjali punj wrote:
> I have a piece of code which is like this in emof form:
> <?xml version="1.0" encoding="ASCII"?>
> <http..schema.omg.org.spec.mof.2.0.emof.xmi:Package xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:http..schema.omg.org.spec.mof.2.0.emof.xmi="http://schema.omg.org/spec/mof/2.0/emof.xmi"
> xmi:id="52f8f618a87fa09e-fa530014308425db" name="demo1" uri="demo1">
> <ownedType xmi:type="http..schema.omg.org.spec.mof.2.0.emof.xmi:Class"
> xmi:id="ac0e71bc79c947d3-b7218d94f8a048e" name="a">
> <ownedAttribute xmi:id="7121ffbf696ffc1d-a98b40ab37b25392"
> name="a1" isComposite="true" lower="0" upper="-1"
> opposite="651e805d78e316a4-62f43bd50dec76bd"
> type="2cd2fd45437ed37b-cca79a448b73c6a"/>
> </ownedType>
> <ownedType
> xmi:id="2cd2fd45437ed37b-cca79a448b73c6a" name="b">
> <ownedAttribute xmi:id="651e805d78e316a4-62f43bd50dec76bd"
> name="b1" isID="true" lower="0" upper="-1"
> opposite="7121ffbf696ffc1d-a98b40ab37b25392"
> type="ac0e71bc79c947d3-b7218d94f8a048e"/>
> </ownedType>
> </http..schema.omg.org.spec.mof.2.0.emof.xmi:Package>
> Now from the data it is visible that only a1 of a has
> isComposite="true" but when I paste this in emf and validate it gives
> an error saying "opposite of a containmemnt reference must not be a
> containment reference".Automatically its making both sides as
> isComposite="true".
> But when i remove the isId feature from b1 it takes only 1 side as
> isComposite="true".
> Can you explain me what is the realation between isId and isComposite ?
> And this behaviour is seen only when both sides of the association are
> navigable ?
Ed Merks
FUDForum. Page generated in 0.03626 seconds
