Home » Modeling » EMF » Referencing and referenced EObject
Referencing and referenced EObject [message #431290] Tue, 07 July 2009 12:40 Go to next message
I can use the method eCrossReferences() to get the referencing EObjects of
a EObject, but if i want to get the referenced EObject, what should i do?
regards
Re: Referencing and referenced EObject [message #431291 is a reply to message #431290] Tue, 07 July 2009 12:52 Go to previous messageGo to next message
lancel lau schrieb:
> EObjects of a EObject, but if i want to get the referenced EObject,
> what should i do?
eCrossReferences() is not what you think it to be. It's what you're
looking for ;-)
An object can have two sorts of references to other objects: containment
references and cross references. eCrossReferences() returns, guess, the
latter.
You might be interested in
org.eclipse.emf.ecore.util.EcoreUtil.UsageCrossReferencer, though.
Cheers
/Eike
Re: Referencing and referenced EObject [message #431292 is a reply to message #431290] Tue, 07 July 2009 12:54 Go to previous message
Lancel,
Comments below.
lancel lau wrote:
It returns all the objects referenced by non-container/containment
references the given EObject.
If you want to find all references to an EObject you need to use
something like a EcoreUtil.UsageCrossReferencer or ECrossReferenceAdapter.
> regards
Previous Topic:[EMF Databinding] How to specify additional triggers for the update of a binding?
Next Topic:[Teneo][EMF][BIRT] Is it possible to create Reports with a Teneo Datasource?
Current Time: Thu Oct 30 05:12:41 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
