Home » Modeling » EMF » TENEO: Problems with AttributeOverride
Re: TENEO: Problems with AttributeOverride [message #431162 is a reply to message #431160] |
Tue, 30 June 2009 22:10 |
Hi Roberto,
To understand better, do the classes/mapping below work or fail (with the error you describe)?
If it works, but Teneo fails, can you show the generated mapping for this case for Teneo? It can be retrieved from the
datastore using the method getMappingXml.
gr. Martin
Roberto Leibman wrote:
> I'm having a problem with an attribute override where the attribute I
> want to override is in a doubly contained class.
> Long story, I'm using the hibernate eclipse plugin to reverse engineer
> java classes from hibernate mapping files. From the Java classes I'll
> get the necessary teneo annotations that I'll put in the xsd's, from
> which I'll generate an emf model.
> Given the example below, for some reason, when I do a query the
> persistence layer insists on using BAR_KEY instead of FOO_KEY.
> Thanks a lot
> Roberto Leibman
> Code follows.
> The original mapping file looks something like this
> <hibernate-mapping package="com.example">
> <class
> name="Foo"
> table="FOO"
> dynamic-update="false"
> dynamic-insert="false"
> lazy="false">
> <component
> name="bar"
> class="com.example.Bar">
> <component
> name="yoyo"
> class="com.example.Yoyo">
> <property
> name="key"
> column="FOO_KEY"/>
> </component>
> </component>
> </class>
> </hibernate-mapping>
> The generated classes, look like this:
> @Entity
> @Table(name = "FOO")
> public class Foo {
> @Embedded
> @AttributeOverrides( {@AttributeOverride(name = "yoyo.key", column =
> @Column(name = "FOO_KEY")) })
> public Bar getBar() {
> return bar;
> public void setBar(Bar bar) {
> this.bar = bar;
> private Bar bar;
> @Embeddable
> public class Bar {
> private Yoyo yoyo;
> @Embedded
> @AttributeOverrides( {@AttributeOverride(name = "key", column =
> @Column(name = "BAR_KEY")) })
> public Yoyo getYoyo() {
> return yoyo;
> public void setYoyo(Yoyo yoyo) {
> this.yoyo = yoyo;
> @Embeddable
> public class Yoyo {
> private String key;
> @Column(name="KEY")
> public String getKey() {
> return key;
> public void setKey(String key) {
> this.key = key;
> The XSD files are direct translations of the classes.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: TENEO: Problems with AttributeOverride [message #431163 is a reply to message #431162] |
Tue, 30 June 2009 22:20 |
Roberto Leibman Messages: 6 Registered: July 2009 |
Hi Martin, Thanks for the quick response.
I'm not sure what it is that's failing, but what I see in the log is sql
with the wrong column name being used. I see bar.key instead of foo.key.
If I do a getMappingXml, I get something similar to the following (as
you can understand, I'm doing some heavy editing to give you sample code
without the complexities of the real code)
<class
name="FooImpl"
table="FOO"
lazy="false">
<component
name="bar"
class="com.example.BarImpl">
<component
name="yoyo"
class="com.example.YoyoImpl">
<property
name="key"
column="BAR_KEY"/>
</component>
</component>
</class>
Martin Taal wrote:
> Hi Roberto,
> this case for Teneo? It can be retrieved from the datastore using the
> gr. Martin
>> Thanks a lot
>> Roberto Leibman
>> Code follows.
>> <class
>> name="Foo"
>> table="FOO"
>> lazy="false">
>> <component
>> name="bar"
>> <component
>> name="yoyo"
>> <property
>> name="key"
>> column="FOO_KEY"/>
>> </component>
>> </component>
>> </class>
>> @Entity
>> public class Foo {
>> @Embedded
>> return bar;
>> this.bar = bar;
>> private Bar bar;
>> @Embeddable
>> public class Bar {
>> private Yoyo yoyo;
>> @Embedded
>> return yoyo;
>> this.yoyo = yoyo;
>> @Embeddable
>> public class Yoyo {
>> private String key;
>> @Column(name="KEY")
>> return key;
>> this.key = key;
Re: TENEO: Problems with AttributeOverride [message #431164 is a reply to message #431163] |
Tue, 30 June 2009 22:28 |
Hi Roberto,
I am pretty sure that Teneo does not support a path like construct (like yoyo.key) in the @AttributeOverride name
attribute, also in this case there is an order of resolving the overrides also. This can be added ofcourse, can you
enter a bugzilla for this? It would be best if you can also provide a test ecore model with annotations reflecting this
case...
Hopefully I have time around the weekend to add this behavior.
Also if you can let me know which version of Teneo you are using (tbe best is 1.1.1), as I prefer to limit the changes
to older releases.
gr. Martin
> <class
> name="FooImpl"
> table="FOO"
> lazy="false">
> <component
> name="bar"
> <component
> name="yoyo"
> <property
> name="key"
> column="BAR_KEY"/>
> </component>
> </component>
> </class>
> Martin Taal wrote:
>> Hi Roberto,
>> gr. Martin
>>> Thanks a lot
>>> Roberto Leibman
>>> Code follows.
>>> <class
>>> name="Foo"
>>> table="FOO"
>>> lazy="false">
>>> <component
>>> name="bar"
>>> <component
>>> name="yoyo"
>>> <property
>>> name="key"
>>> column="FOO_KEY"/>
>>> </component>
>>> </component>
>>> </class>
>>> @Entity
>>> public class Foo {
>>> @Embedded
>>> return bar;
>>> this.bar = bar;
>>> private Bar bar;
>>> @Embeddable
>>> public class Bar {
>>> private Yoyo yoyo;
>>> @Embedded
>>> return yoyo;
>>> this.yoyo = yoyo;
>>> @Embeddable
>>> public class Yoyo {
>>> private String key;
>>> @Column(name="KEY")
>>> return key;
>>> this.key = key;
The Netherlands
Current Time: Fri Apr 26 20:38:44 GMT 2024
Powered by FUDForum. Page generated in 0.02954 seconds
