Home » Modeling » EMF » The definitive truth about multiple inheritance
The definitive truth about multiple inheritance [message #431103] |
Sun, 28 June 2009 21:43 |
Originally posted by: gvauvert.gmail.com
Happy to join the team of EMF's users !
After many searches, I have found no clear answer to my basic question
about multiple inheritance.
The EMF documentation
( http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.html
, chapter "EMF developper guide", section "EMF developper guide",
subsection "EMF Framework Programmer's Guide") saids :
"As in Java itself, multiple interface inheritance is supported, but
each EMF class can only extend one implementation base class. Therefore,
when we have a model with multiple inheritance, we need to identify
which of the multiple bases should be used as the implementation base
class. The others will then be simply treated as mixin interfaces, with
their implementations generated into the derived implementation class."
The example shows a model with a class [SchoolBook] that inherits
<<extends>> [Book] and that inherits [Asset]; this class should be
implemented by extending (Java) the class Book and implenting the
methods of the class Asset by copying them from Asset.
I tried to apply that to my model :
D inherits from A that inherits from Action, and C that inherits from Class.
The implementation of class D does provide implementations for methods
found in A and C, but does provide no implementations for methods coming
from inheritance of the class not extended (Action or Class depending on
the class (C or A) that D extends).
Have I missed something ?
If not, why isn't it possible for EMF to automatically generate the
"good" implementation ?
What can I do to solve my problem ?
Thank you very much for clarify my knowledge ...
Guillaume Vauvert
http://www.ixmas.org
Re: The definitive truth about multiple inheritance [message #431104 is a reply to message #431103] |
Sun, 28 June 2009 22:07 |
Ed Merks Messages: 33142 Registered: July 2009 |
Guillaume,
Comments below.
Welcome. :-)
> Therefore, when we have a model with multiple inheritance, we need to
> identify which of the multiple bases should be used as the
> implementation base class. The others will then be simply treated as
> mixin interfaces, with their implementations generated into the
> Class.
> coming from inheritance of the class not extended (Action or Class
> depending on the class (C or A) that D extends).
I keep reading this and it's making my brain hurt. Maybe you could draw
a picture or make explicit what methods you're talking about. Is D
inheriting from C or is it A that's doing that, or is the comma implying
that C inherits from Class but is otherwise unrelated?
So far it's probably me that's missed something.
The point that is that if you consider the super types Y and Z of an
EClass X, XImpl will extend YImpl and will generate a clone of what's in
ZImpl. So it should indeed be possible to generate a complete
implementation.
Are you saying that's generated doesn't compile?
> Guillaume Vauvert
Ed Merks
Re: The definitive truth about multiple inheritance [message #431127 is a reply to message #431104] |
Mon, 29 June 2009 20:37 |
Ed,
I will try to decrease your headache ...
You are right : my explanation is more complex than what I want to describe.
So :
- A inherits from Action
- C inherits from Class
- D inherits from both A and C
So simple when it is clear !
The generated code :
- the class DImpl extends the class AImpl : it is OK.
- the class DImpl implements the interface D ; the interface D extends
the interface A and the interface C.
- the class DImpl inherits methods from AImpl : so it implements the
interface A;
- the class DImpl contains methods that are declared in the interface C ;
- BUT DImpl does not contain methods that are inherited by the
interface C from the interface Class.
So, the class DImpl should be declared abstract, because it does not
implements the methods inherited by the interface C that it should
implement.
> implementation.
It is exactly what I expect. Instead, I get a partial implementation.
Yes, it does not compile, because the class lacks some methods, those
from the class Class inherited by the interface C.
Do you see what is my problem now ?
And do you see a solution ... ?
Guillaume Vauvert
Re: The definitive truth about multiple inheritance [message #431132 is a reply to message #431127] |
Mon, 29 June 2009 23:02 |
Guillaume,
Comments below...
> Ed,
>> draw a picture or make explicit what methods you're talking about.
>> Is D inheriting from C or is it A that's doing that, or is the comma
>> implying that C inherits from Class but is otherwise unrelated?
> describe.
> So :
Class is a bit of a confusing name.
> the interface A;
> interface C ;
Did you declare all these methods in Ecore's version of Class? I'm
suspicious about that name...
> implement.
I have this suspicion that perhaps Class has methods in Java, that you
didn't actually declare as EOperation in the Ecore wrapper...
>> in ZImpl. So it should indeed be possible to generate a complete
>> implementation.
You've not been entirely clear if you're talking about EOperations or
EStructuralFeatures, which leads to my suspicion about what you declared
in Ecore verses what's there in Java....
Yes, but I'm more suspicious that there's something you've not stated
explicitly. EMF won't know to implement a method if there's no
EOperation declared for it in Class. I'm pretty sure if you specify the
right EOperations, there's at least be stub methods generated.
I'd suggest you provide an example model that I can use to reproduce the
problem. Then I can tell you if the problem is your model or in the
framework.
> Guillaume Vauvert
Ed Merks
Re: The definitive truth about multiple inheritance [message #431222 is a reply to message #431132] |
Thu, 02 July 2009 21:36 |
Ed,
Ed Merks a écrit :
>> So :
>> the interface A;
>> interface C ;
I am building a Modeling Language that extends UML.
I am using platform:/plugin/org.eclipse.uml2.uml/model/UML.core as model
of UML.
The metaclass Class (using ECore) declares the EOperation "ownedOperation".
In the generated class DImpl, I obtain a class that should contains the
implementation of getOwnedReception() (from the interface C). Instead, I
have a class DImpl that lacks this method ; so, Eclipse Java IDE saids :
"The type DImpl must implement the inherited abstract method
Class.getOwnedReception(String, EList<String>, EList<Type>)"
> framework.
Even if my example is exactly what I descrived before, I can provide it,
but how (future generations of newsgroups users must be able to see
the model !) ?
I feel the light closer ...
Thanks !
Guillaume Vauvert
Re: The definitive truth about multiple inheritance [message #431223 is a reply to message #431222] |
Thu, 02 July 2009 21:53 |
Guillaume,
The UML project has an extended GenModel and has specialized some of the
templates for generating the code. Perhaps that's part of what's going
on...
I do have UML installed, so if you export to a zip the project with your
model, I should be able to reproduce what you're seeing and determine if
there's a bug in how EOperations are handled in a multiple inheritance
scenario...
I suspect that you need to use UML's extended GenModel if you extend the
UML model. I've added the UML2 newsgroup to the "to"list of the reply
for their comments about how one should extend UML2...
> Ed,
> Ed Merks a écrit :
>>> So :
>>> extends the interface A and the interface C.
>>> the interface A;
>>> interface C ;
> model of UML.
> "ownedOperation".
> the implementation of getOwnedReception() (from the interface C).
> Instead, I have a class DImpl that lacks this method ; so, Eclipse
> Java IDE saids :
>> the problem. Then I can tell you if the problem is your model or in
>> the framework.
> it, but how (future generations of newsgroups users must be able to
> see the model !) ?
> Thanks !
> Guillaume Vauvert
Ed Merks
Re: The definitive truth about multiple inheritance [message #431234 is a reply to message #431223] |
Sat, 04 July 2009 09:10 |
--------------040407050404070808060007
Guillaume,
This definitely sounds UML specific. Try using the text editor to
replace this
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel"
with this
xmlns:genmodel="http://www.eclipse.org/uml2/2.2.0/GenModel"
I.e., trying changing it to be the UML project's derived GenModel. That
should ensure that UML's generator specializations kick in.
Also, try avoid doing reply-all on newsgroup postings so they don't also
end up in my personal in-box. :-P
Try to avoid doing reply-all
> Hello MDT/UML2 users,
> I had a question on model code generation, but, thanks to Ed, I now
> believe that the question is more MDT/UML2 specific.
> The model contains a class TempleteableActivityNode that inherits from
> both the class Templeteable and the class ActivityNode. The class
> ActivityNode contains the attribute "incoming" with multiplicty 0..* .
> This attribute "incoming" is implemented in ActivityNodeImpl as :
> public EList<ActivityEdge> getIncomings()
> and as :
> public ActivityEdge getIncoming(String name)
> In the generated model code class TempleteableActivityNode, the method
> "public EList<ActivityEdge> getIncomings()" is implemented, but not
> the method "public ActivityEdge getIncoming(String name)", what leads
> to an error :
> "The type TempleteableActivityNodeImpl must implement the inherited
> abstract method ActivityNode.getIncoming(String)"
> Have you an idea of where I am wrong ?
> Thank you ...
> Guillaume Vauvert
> Thanks you Ed for your help : you guide me to investigate more deeply
> my problem.
> Ed Merks a
Ed Merks
Re: The definitive truth about multiple inheritance [message #431235 is a reply to message #431223] |
Sat, 04 July 2009 10:38 |
and as :
"public EList<ActivityEdge> getIncomings()" is implemented, but not the
method "public ActivityEdge getIncoming(String name)", what leads to an
error :
Thank you ...
Guillaume Vauvert
my problem.
Ed Merks a écrit :
> Guillaume,
the templates for generating the code. Perhaps that's part of what's
going on...
your model, I should be able to reproduce what you're seeing and
determine if there's a bug in how EOperations are handled in a multiple
inheritance scenario...
the UML model. I've added the UML2 newsgroup to the "to"list of the
reply for their comments about how one should extend UML2...
>> Ed,
>> Ed Merks a écrit :
>>>> So :
implements the interface A;
interface C ;
model of UML.
"ownedOperation".
Instead, I have a class DImpl that lacks this method ; so, Eclipse Java
IDE saids :
reproduce the problem. Then I can tell you if the problem is your model
or in the framework.
it, but how (future generations of newsgroups users must be able to see
the model !) ?
>> Thanks !
>> Guillaume Vauvert
Current Time: Fri Apr 26 12:04:45 GMT 2024
Powered by FUDForum. Page generated in 0.04038 seconds
