Home » Modeling » EMF » EMap
EMap [message #431097] Fri, 26 June 2009 13:44 Go to next message
hi,
i am having problem the way EMap is used in the modelling. My requirement
is as follows
* @model
EMap getEmployeeDetails();
In the EMap the key should be employeeid (BigInteger). Value should be
Employee Object which is an EObject. I have a problem as to how i should
be giving the annotations for specifying the key and value types.
Re: EMap [message #431098 is a reply to message #431097] Fri, 26 June 2009 14:03 Go to previous messageGo to next message
Jagadish,
You can use keyType and valueType to specify those things.
jagadish suri wrote:
> hi,
> requirement is as follows
> * @model
> should be giving the annotations for specifying the key and value types.
> Thanks
Re: EMap [message #431107 is a reply to message #431098] Mon, 29 June 2009 07:40 Go to previous messageGo to next message
Thanks for the reply. when i used the annotation and tried to reload the
genmodel from the annotated java it is giving the following exceptions.
java.lang.reflect.InvocationTargetException
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard.performFinish(ModelConverterWizard.java:246)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterW izard.performFinish(ModelImporterWizard.java:157)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:115)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:105)
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Caused by: org.eclipse.core.runtime.CoreException: An error occurred while
performing this operation.
org.eclipse.emf.common.util.DiagnosticException.toCoreExcept ion(DiagnosticException.java:47)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:235)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
... 46 more
and there is a child exceptions under the above exception which is
mentioned below.
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object
'org.eclipse.emf.ecore.impl.EClassImpl@1fde6fb (name:
EStringToEStringMapEntry) (instanceClassName: java.util.Map$Entry)
(abstract: false, interface: false)' is not contained in a resource.
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.endSave(XMLSaveIm pl.java:303)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:267)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1253)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfC hangedWithMemoryBuffer(ResourceImpl.java:1083)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:956)
org.eclipse.emf.importer.ModelImporter.saveGenModelAndEPacka ges(ModelImporter.java:770)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterW izard.doPerformFinish(ModelImporterWizard.java:150)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:228)
Caused by: org.eclipse.emf.ecore.xmi.DanglingHREFException: The object
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingH REF(XMLHelperImpl.java:759)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getHREF(XMLHelp erImpl.java:793)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveEObjectSingle (XMLSaveImpl.java:1796)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1240)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2590)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1105)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:986)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2291)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1464)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:653)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:581)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:253)
... 56 more
Re: EMap [message #431108 is a reply to message #431107] Mon, 29 June 2009 08:39 Go to previous messageGo to next message
Jagadish,
What exactly did you try and which version of EMF are you using?
> the genmodel from the annotated java it is giving the following
> exceptions.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> while performing this operation.
> at
> at
> at
> at
> at
> ... 46 more
> mentioned below.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 56 more
Re: EMap [message #431112 is a reply to message #431108] Mon, 29 June 2009 10:03 Go to previous messageGo to next message
This is the annotation that i used and the eclipse i am using is 3.3 and
emf-sdo-xsd-SDK-2.3.0.
* @model keyType="java.lang.String" valueType="java.lang.String"
Map<String, String> getScoScoMap();
When i reload the model from the annotated java then i am having the
exception mentioned in the previous message.
Re: EMap [message #431113 is a reply to message #431112] Mon, 29 June 2009 10:33 Go to previous message
Jagadish,
The issue sounds familiar. I suggest using something more recent, like
2.5 or 2.4.
> and emf-sdo-xsd-SDK-2.3.0.
> * @model keyType="java.lang.String" valueType="java.lang.String" */
Previous Topic:obtain ecore form of an instance model
Next Topic:Enum modelisation in ecore
Current Time: Wed Nov 05 05:04:25 EST 2025
Powered by FUDForum. Page generated in 0.03783 seconds
