Re: [CDO] SQL Exception: A lock could not be obtained within the time requested [message #430390 is a reply to message #430388] |
Tue, 19 May 2009 15:49 |
Kai,
I suspect that both issues result from the same problem, possibly a
synchronization problem in the cache. But since we're not sure please
file a separate bugzilla with this stack trace. Stefan will later decide
if it's a duplicate...
Cheers
/Eike
Kai Schlamp schrieb:
> Hi again.
> Another exception that sometimes occurs (it also seems to occur
> sporadic).
> It happens during a commit. It hangs about a minute or so and then
> that exception is thrown.
> If it occurs once, then it occurs afterwards everytime I try to commit
> to that repo.
> Best regards,
> Kai
> [ERROR] SQL Exception: A lock could not be obtained within the time
> requested
> !ENTRY org.eclipse.net4j.db.DBException: SQL Exception: A lock could
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.putObjectType(ObjectTypeCache.java:137)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalMappingStrategy.putObjectType(AbstractHorizo ntalMappingStrategy.java:69)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.writeRevision(AbstractHorizonta lClassMapping.java:326)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write Revision(DBStoreAccessor.java:359)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write Revisions(DBStoreAccessor.java:341)
> at
> org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:142)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.acces s$4(DBStoreAccessor.java:1)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:80)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:1)
> at
> org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write (DBStoreAccessor.java:298)
> at
> org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl.write(TransactionCommitContextImpl.java:269)
> at
> org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication$1.runLoop(CommitTransactionIndication.java:73)
> at
> org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication$1.runLoop(CommitTransactionIndication.java:1)
> at
> at
> org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicatingCommit(CommitTransactionIndication.ja va:325)
> at
> org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:198 )
> at
> org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:140 )
> at
> org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
> at
> org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:317)
> at
> org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
> at
> org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:237)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:145)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
> at java.lang.Thread.run(Thread.java:619)
> Caused by: SQL Exception: A lock could not be obtained within the time
> requested
> at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn
> Source)
> at
> org.apache.derby.impl.jdbc.TransactionResourceImpl.wrapInSQL Exception(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.TransactionResourceImpl.handleExc eption(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedConnection.handleException(U nknown
> Source)
> at
> org.apache.derby.impl.jdbc.ConnectionChild.handleException(U nknown
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(U nknown
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeSta tement(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpd ate(Unknown
> Source)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.putObjectType(ObjectTypeCache.java:128)
> ... 27 more
> org.eclipse.emf.cdo.server 4 0 2009-05-19 17:15:00.655
> !MESSAGE SQL Exception: A lock could not be obtained within the time
> requested
> !STACK 0
> org.eclipse.net4j.db.DBException: SQL Exception: A lock could not be
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> requested
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 27 more
> [ERROR] Rollback in DBStore: org.eclipse.net4j.db.DBException: SQL
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> requested
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 27 more
> !ENTRY org.eclipse.emf.cdo 4 0 2009-05-19 17:15:00.658
> !MESSAGE Rollback in DBStore: org.eclipse.net4j.db.DBException: SQL
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> requested
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 27 more
> !ENTRY org.eclipse.ui 4 0 2009-05-19 17:15:00.663
> !MESSAGE Unhandled event loop exception
> !STACK 0
> org.eclipse.net4j.util.transaction.TransactionException: Rollback in
> DBStore: org.eclipse.net4j.db.DBException: SQL Exception: A lock could
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> requested
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 27 more
> at
> org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactio nStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:6 3)
> at
> org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:598)
> at
> org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:612)
> at
> org.pubcurator.docs.importers.wizards.EutilsWizard.performFi nish(EutilsWizard.java:41)
> at
> org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:752)
> at
> org.pubcurator.ui.jface.wizard.ExtendedWizardDialog.finishPr essed(ExtendedWizardDialog.java:62)
> at
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3485)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at
> org.pubcurator.docs.handlers.ImportDocumentsHandler.execute( ImportDocumentsHandler.java:24)
> at
> org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:294)
> at
> org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
> at
> org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
> at
> org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
> at
> org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
> at
> org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:770)
> at
> org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:756)
> at
> org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:746)
> at
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at org.pubcurator.core.Application.start(Application.java:20)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.03422 seconds
