| How to run generated EMF editor [message #429045] |
Tue, 07 April 2009 03:12  |
Hi there,
I did several examples with EMF, designed the model and generated the
necessary source files and rightclicking the editor project -> "Run as" ->
"Eclipse Application" just worked fine.
Even when I created a new project with a different model, I did not have
to change any configuration to get it to run.
Now I seem to have changed something and when I start the editor like
that, the desired object is not listed in the "New"-dialog.
Do you run your applications using "Run as"?
Do you use "Run a product" or "Run an application" in Run Configurations?
Thanks in advance,
Peter
FUDForum. Page generated in 0.04127 seconds
