Home » Modeling » EMF » [Teneo] c3p0 and open connections
[Teneo] c3p0 and open connections [message #429000] Mon, 06 April 2009 14:15 Go to next message
When I use the following properties to enable c3p0
props.put(Environment.C3P0_MIN_SIZE, "1");
props.put(Environment.C3P0_MAX_SIZE, "20");
props.put(Environment.C3P0_TIMEOUT, "1800");
props.put(Environment.C3P0_MAX_STATEMENTS,"50");
The attached test program (hbds.initialize() method)creates 14 connections
to the oracle schema.
Although I have set the minimum pool size to 1.
I have attached the test program, ecore file and log file.
Re: [Teneo] c3p0 and open connections [message #429012 is a reply to message #429000] Mon, 06 April 2009 15:33 Go to previous messageGo to next message
Hi RJ,
The datastore.initialize() updates the database schema (if the corresponding hibernate option is set). Searching on the
internet gave me this one:
http://opensource.atlassian.com/projects/hibernate/browse/HH H-2343
The log shows that you are using Hibernate 3.2.1, apparently this is also what they talk about in that issue, which is
solved in hibernate 3.2.3.
gr. Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] c3p0 and open connections [message #429019 is a reply to message #429012] Mon, 06 April 2009 16:00 Go to previous message
thanks a lot.
"Martin Taal" <mtaal@elver.org> wrote in message
news:grdldo$aps$1@build.eclipse.org...
> Hi RJ,
> corresponding hibernate option is set). Searching on the internet gave me
> this one:
> what they talk about in that issue, which is solved in hibernate 3.2.3.
> gr. Martin
>> connections to the oracle schema.
> The Netherlands
Previous Topic:Bug in Generation with Feature Delegation Dynamic and unsettable opposites
Next Topic:Importing and referecing metamodels
Current Time: Wed Nov 05 07:46:26 EST 2025
Powered by FUDForum. Page generated in 0.03989 seconds
