Home » Modeling » EMF » Bug in Generation with Feature Delegation Dynamic and unsettable opposites
Bug in Generation with Feature Delegation Dynamic and unsettable opposites [message #428980] Mon, 06 April 2009 08:40 Go to next message
Using Eclipse Modeling Framework (EMF) All-In-One
SDK 2.5.0.v200903161215 org.eclipse.emf.all.feature.group
I have a bug generating with Feature Delegation set to Dynamic;
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Bug"
nsURI="http://test.bug/Bug" nsPrefix="bug">
<eClassifiers xsi:type="ecore:EClass" name="A">
<eStructuralFeatures xsi:type="ecore:EReference" name="one"
eType="#//B" unsettable="true"
containment="true" eOpposite="#//B/inverseOne"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="two"
eType="#//B" eOpposite="#//B/inverseTwo"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="B">
<eStructuralFeatures xsi:type="ecore:EReference" name="inverseOne"
eType="#//A"
unsettable="true" eOpposite="#//A/one"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="inverseTwo"
eType="#//A"
eOpposite="#//A/two"/>
</eClassifiers>
</ecore:EPackage>
Gives rise to
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public NotificationChain basicUnsetOne(NotificationChain msgs) {
B oldOne = one;
one = null;
boolean oldOneESet = oneESet;
oneESet = false;
if (eNotificationRequired()) {
ENotificationImpl notification = new ENotificationImpl(this,
Notification.UNSET, BugPackage.A__ONE, oldOne, null, oldOneESet);
if (msgs == null) msgs = notification; else msgs.add(notification);
return msgs;
which is called by
public NotificationChain eInverseRemove(InternalEObject otherEnd, int
featureID, NotificationChain msgs) {
switch (featureID) {
case BugPackage.A__ONE:
return basicUnsetOne(msgs);
case BugPackage.A__TWO:
return basicSetTwo(null, msgs);
return super.eInverseRemove(otherEnd, featureID, msgs);
I'm sure we have spoken about this before, apologies .
1) What's the best workaround;
2) Should I report it as a bug ( can't find it on bugzilla )
Re: Bug in Generation with Feature Delegation Dynamic and unsettable opposites [message #428983 is a reply to message #428980] Mon, 06 April 2009 10:03 Go to previous messageGo to next message
JF,
No doubt a case that was overlooked. Please open a bugzilla.
JF wrote:
> Using Eclipse Modeling Framework (EMF) All-In-One SDK
> xmlns:xmi="http://www.omg.org/XMI"
> </eClassifiers>
> eType="#//A"
> eType="#//A"
> </eClassifiers>
> </ecore:EPackage>
> Gives rise to
> * @generated
> B oldOne = one;
> one = null;
> oneESet = false;
> ENotificationImpl(this, Notification.UNSET, BugPackage.A__ONE, oldOne,
> null, oldOneESet);
> return msgs;
> which is called by
Re: Bug in Generation with Feature Delegation Dynamic and unsettable opposites [message #428996 is a reply to message #428983] Mon, 06 April 2009 11:10 Go to previous message
Bugs 271316, 271328
Previous Topic:error msg in validation framework
Next Topic:[Teneo] c3p0 and open connections
Current Time: Wed Nov 05 07:46:39 EST 2025
Powered by FUDForum. Page generated in 0.04339 seconds
