Home » Modeling » EMF » EMF Maps and useEquals()
| Re: EMF Maps and useEquals() [message #428976 is a reply to message #428975] |
Mon, 06 April 2009 07:58   |
Hi Ed
Thanks for your answer.
I use a command to add the map entry:
EClass eClass= XyzModelPackage.Literals.STRING_TO_EOBJECT_MAP_ENTRY;
entry= XyzModelFactory.eINSTANCE.create(eClass);
entry.setKey(key);
entry.setValue(value);
Command addCommand= AddCommand.create(editingDomain, owner,
XyzModelPackage.Literals.MYPROPERTIES, entry);
commandStack.execute(addCommand);
Obviously there is something wrong with that, but currently I can't
figure out what. Which part of EMaps am I getting wrong?
I'm happy with some pointers to where I can find help.
On 6.4.2009 13:20 Uhr, Ed Merks wrote:
> Bruno,
> Comments below.
> Bruno Ziswiler wrote:
>> Hello
>> I use EMF together with Hibernate and I encounter a similar problem to
>> the one discussed here
>> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 8544.html
>> I have modeled a StringToEObjectMap map in my ECore model according to
>> this recipe
>> http://wiki.eclipse.org/index.php/EMF/FAQ#How_do_I_create_a_ Map_in_EMF.3F
>> The problem that arises is that everytime I insert a new (key,value)
>> pair into this map a new entry is created even if the key already exists.
> If you use put, that won't happen. If you insert new entries, yes, but
> why are you doing that?
>> This is due to the fact that internally the map uses a
>> DelegateEObjectContainmentEList for its keys. This (super-)class's
>> useEquals()-method always returns false. Of course this doesn't work
>> for all strings (depending on how they are created).
> This applies for the map entries themselves. The keys are compared using
> equals. But an EMap is just a list of entries and it's possible to add
> entries with conflicting keys. The validator will complain about that
> though.
>> Is there a solution for this or am I using the map wrongly?
> You've not actually explained how you've used the map, other than to say
> you insert a new key/value pair, which is not generally the best way to
> use a map, and not even possible with a regular Java map where you must
> use put.
>> Thanks
>> Bruno
| Re: EMF Maps and useEquals() [message #428978 is a reply to message #428976] |
Mon, 06 April 2009 08:12   |
Bruno,
Comments below.
> Hi Ed
> entry.setKey(key);
That's fine if you want to add a new entry, but if you want to update an
existing entry you must find it and update (set) the value feature of
that existing entry with a set command or replace that entry with a new
one with a set command at the index of the existing entry.
I.e., you need to do what put does under the covers...
>> Bruno,
>> Comments below.
>>> Hello
>>> this recipe
>>> exists.
>> though.
>> use put.
>>> Thanks
>>> Bruno
| Re: EMF Maps and useEquals() [message #428984 is a reply to message #428978] |
Mon, 06 April 2009 10:05   |
That's exactly what I tried in the first place. The problem arises when
I run ChangeRecorder.beginRecording() and call
ChangeRecorder.endRecording(). BasicEList.validate() then throws an
assertion error saying "The 'no null' constraint is violated".
The first version of the code that I had, and of which I believe did
exactly what you say, was:
int idx= owner.getProperties().indexOf(key);
StringToEObjectMapEntryImpl entry= null;
Command command= null;
if (idx < 0) {
entry= (StringToEObjectMapEntryImpl)
entry.setKey(key);
command= AddCommand.create(editingDomain, owner,
XyzModelPackage.Literals.MYELEMENT__MYPROPERTIES, entry);
} else {
command= SetCommand.create(editingDomain, entry,
XyzModelPackage.Literals.STRING_TO_EOBJECT_MAP_ENTRY__VALUE, value);
commandStack.execute(command);
Does this look as if it should work?
On 6.4.2009 14:12 Uhr, Ed Merks wrote:
> Bruno,
> Comments below.
>> Hi Ed
>> entry.setKey(key);
>>> Bruno,
>>> Comments below.
>>>> Hello
>>>> this recipe
>>>> exists.
>>> though.
>>> use put.
>>>> Thanks
>>>> Bruno
| Re: EMF Maps and useEquals() [message #428986 is a reply to message #428984] |
Mon, 06 April 2009 10:18   |
Bruno,
Comments below.
> when I run ChangeRecorder.beginRecording() and call
Did you mean this to be indexOfKey? I imagine the above would return -1
always.
> if (idx < 0) {
> entry.setKey(key);
> } else {
>> Bruno,
>> Comments below.
>>> Hi Ed
>>> entry.setKey(key);
>>>> Bruno,
>>>> Comments below.
>>>>> Hello
>>>>> problem to
>>>>> according to
>>>>> this recipe
>>>>> exists.
>>>> using
>>>> though.
>>>> to say
>>>> way to
>>>> must
>>>> use put.
>>>>> Thanks
>>>>> Bruno
| Re: EMF Maps and useEquals() [message #429033 is a reply to message #428986] |
Tue, 07 April 2009 01:20   |
That's it! I'm terribly sorry you had to waste your time by helping me
debug such a trivial mistake. I owe you a drink at EclipseCon 2010! :-)
On 6.4.2009 16:18 Uhr, Ed Merks wrote:
> Bruno,
> Comments below.
> always.
>> if (idx < 0) {
>> entry.setKey(key);
>> } else {
>>> Bruno,
>>> Comments below.
>>>> Hi Ed
>>>> entry.setKey(key);
>>>>> Bruno,
>>>>> Comments below.
>>>>>> Hello
>>>>>> problem to
>>>>>> according to
>>>>>> this recipe
>>>>>> exists.
>>>>> using
>>>>> though.
>>>>> to say
>>>>> way to
>>>>> must
>>>>> use put.
>>>>>> Thanks
>>>>>> Bruno
| Re: EMF Maps and useEquals() [message #429059 is a reply to message #429033] |
Tue, 07 April 2009 06:17  |
Bruno,
Let's blame Java. If the indexOf method were of type E rather than
Object, the compiler would have caught the mistake. :-P
Maybe you'll be at Eclipse Summit Europe this year. I hope to be there...
>> Bruno,
>> Comments below.
>> always.
>>> if (idx < 0) {
>>> entry.setKey(key);
>>> } else {
>>>> Bruno,
>>>> Comments below.
>>>>> Hi Ed
>>>>> entry.setKey(key);
>>>> update an
>>>> new
>>>>>> Bruno,
>>>>>> Comments below.
>>>>>>> Hello
>>>>>>> problem to
>>>>>>> according to
>>>>>>> this recipe
>>>>>>> (key,value)
>>>>>>> exists.
>>>>>> yes, but
>>>>>>> work
>>>>>> using
>>>>>> to add
>>>>>> that
>>>>>> though.
>>>>>> to say
>>>>>> way to
>>>>>> must
>>>>>> use put.
>>>>>>> Thanks
>>>>>>> Bruno
Current Time: Wed Nov 05 07:46:41 EST 2025
Powered by FUDForum. Page generated in 0.06505 seconds
