Re: JMERGE without Eclipse [message #428590 is a reply to message #428375] |
Tue, 24 March 2009 20:58 |
Stefan Ocke Messages: 3 Registered: July 2009 |
I had some success with code like this. Perhaps its useful for others.
Please note especially setting of JavaCore options:
public void merge(File src, File target) {
JControlModel model = new JControlModel();
ASTFacadeHelper astFacadeHelper = new ASTFacadeHelper() {
Map options;
@SuppressWarnings("unchecked")
public Map getJavaCoreOptions() {
if (options == null) {
options = new HashMap();
options.put(JavaCore.COMPILER_COMPLIANCE,
JavaCore.VERSION_1_6);
options.put(JavaCore.COMPILER_SOURCE, JavaCore.VERSION_1_6);
options.put(JavaCore.COMPILER_CODEGEN_TARGET_PLATFORM,
options.put(JavaCore.COMPILER_PB_ASSERT_IDENTIFIER,
JavaCore.ERROR);
options.put(JavaCore.COMPILER_PB_ENUM_IDENTIFIER,
JavaCore.ERROR);
options.put(JavaCore.COMPILER_CODEGEN_INLINE_JSR_BYTECODE,
JavaCore.ENABLED);
options.put(JavaCore.COMPILER_DOC_COMMENT_SUPPORT, JavaCore.ENABLED);
Map cfo = DefaultCodeFormatterConstants
.getEclipseDefaultSettings();
options.putAll(cfo);
options
.put(
DefaultCodeFormatterConstants.FORMATTER_BLANK_LINES_AFTER_PA CKAGE,
"1");
return options;
String mergexml = this.getClass().getClassLoader().getResource(
"merge.xml").getFile();
model.initialize(astFacadeHelper, mergexml);
JMerger jMerger = new JMerger(model);
String sourceCnt = "package jmerge; \npublic class Foobar{
java.lang.String s; int x; \n\n/**\n * @generated\n */\npublic void
doIt(){System.out.println(\"Hello\");}}";
jMerger.setSourceCompilationUnit(jMerger
.createCompilationUnitForContents(sourceCnt));
String targetCnt = "package jmerge; \npublic class Foobar{ public double
y; private int x;public void doIt(){} }";
jMerger.setTargetCompilationUnit(jMerger
.createCompilationUnitForContents(targetCnt));
jMerger.merge();
String result = jMerger.getTargetCompilationUnit().getContents();
System.out.println(result);
Re: JMERGE without Eclipse [message #428592 is a reply to message #428590] |
Tue, 24 March 2009 21:40 |
Ed Merks Messages: 33142 Registered: July 2009 |
Stefan,
Thanks for sharing! :-)
> others. Please note especially setting of JavaCore options:
> Map options;
> @Override
> JavaCore.ERROR);
> JavaCore.ERROR);
> JavaCore.ENABLED);
> JavaCore.ENABLED);
> options
> .put(
> "1");
> return options;
> public double y; private int x;public void doIt(){} }";
> jMerger.merge();
Ed Merks
FUDForum. Page generated in 0.03475 seconds
