Home » Modeling » EMF » Teneo Parent/Child fetching
| Teneo Parent/Child fetching [message #427178] |
Thu, 05 February 2009 03:10  |
Hello Martin
I modeled a Parent/Child relationship in an object called TreeNode.
In my Server/Client application (using Riena to transfer objects) I want
to read the child TreeNodes by my self.
Right now if I read a TreeNode some where in the tree, the whole tree is
loaded.
Well I can not use PersistenceOptions, because this needs to apply only
for this Entity and PersistenceOptions.SET_PROXY wouldn't work anyway
since the objects on the client wouldn't know how to resolve the proxy.
As far as I know using the "FetchType Lazy" also creates proxies.
So what would be the best way to block Teneo/Hibernate to load the childs?
Here the ecore declaration of TreeNode:
<eClassifiers xsi:type="ecore:EClass" name="TreeNode"
eSuperTypes="#//BasicObject">
<eOperations name="addChild">
<eParameters name="node" eType="#//TreeNode"/>
</eOperations>
<eOperations name="getChild" eType="#//TreeNode">
<eParameters name="id" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eOperations>
<eOperations name="hasChilds" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="childs"
upperBound="-1"
eType="#//TreeNode" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="object"
eType="#//ObjectRef"
<eStructuralFeatures xsi:type="ecore:EReference" name="parent"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type"
</eClassifiers>
I appreciate any help, I searched the web but couldn't find a fitting
solution.
| Re: Teneo Parent/Child fetching [message #427184 is a reply to message #427181] |
Thu, 05 February 2009 05:48   |
Hi Flavio,
There is an issue that econtainer parent relations are eagerly loaded (this issue has not been solved at the moment..).
This should however not lead to the load of the children in the whole tree.
On the server where running Teneo, do you need to persist the econtainer relations? This can be disabled through an
option in PersistenceOptions.
Then why does it load the children... A reason that I can think of is that the code that sends the object over the wire
touches the children collection and thereby forces its load. This can be prevented, but can you check if this is indeed
the case?
gr. Martin
Flavio Donzé wrote:
> Hey Martin
> Thanks for the quick reply!
> Both the childs and the parent are read (the whole tree).
> The main problem is the children, I could make a workaround (only use
> the parent Id instead of a direct TreeNode reference) or even remove the
> parent reference.
> But if there is a way to block Teneo from reading the parent reference
> it would be great.
> thanks and greets
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
>> Is also the parent of the treenode read? Or 'only' the children?
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hello Martin
>>> want to read the child TreeNodes by my self.
>>> is loaded.
>>> only for this Entity and PersistenceOptions.SET_PROXY wouldn't work
>>> anyway since the objects on the client wouldn't know how to resolve
>>> the proxy.
>>> childs?
>>> </eOperations>
>>> </eOperations>
>>> upperBound="-1"
>>> </eClassifiers>
>>> solution.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Teneo Parent/Child fetching [message #427200 is a reply to message #427184] |
Thu, 05 February 2009 09:39   |
Hi Martin
Ok so i did some testing. Here a few code snippets:
Properties hibernateProperties = new Properties();
hibernateProperties
.setProperty(Environment.DRIVER,
preferences.getString(ServerPreferencesConstants.DB_DRIVER)) ;
hibernateProperties.setProperty(Environment.URL,
preferences.getString(ServerPreferencesConstants.DB_URL));
hibernateProperties.setProperty(Environment.USER,
preferences.getString(ServerPreferencesConstants.DB_USER));
hibernateProperties.setProperty(Environment.PASS,
preferences.getString(ServerPreferencesConstants.DB_PASS));
hibernateProperties.setProperty(Environment.DIALECT, preferences
.getString(ServerPreferencesConstants.DB_DIALECT));
hibernateProperties.setProperty(Environment.SHOW_SQL,
showSQL.toString());
hibernateProperties.setProperty(PersistenceOptions.INHERITAN CE_MAPPING,
InheritanceType.TABLE_PER_CLASS.name());
hibernateProperties.setProperty(PersistenceOptions.DEFAULT_I D_FEATURE_NAME,
ID_FIELD_NAME);
hibernateProperties.setProperty(PersistenceOptions.ALWAYS_VE RSION,
Boolean.FALSE.toString());
hibernateProperties.setProperty(PersistenceOptions.ADD_INDEX _FOR_FOREIGN_KEY,
Boolean.TRUE.toString());
hibernateProperties.setProperty(PersistenceOptions.FETCH_CON TAINMENT_EAGERLY,
I added PersistenceOptions.FETCH_CONTAINMENT_EAGERLY to my normal settings.
To create some test nodes i did the following:
TreeNode parent = create();
parent.setName("parent");
TreeNode c1 = create();
c1.setName("c1");
TreeNode c2 = create();
c2.setName("c2");
parent.addChild(c1);
parent.addChild(c2);
TreeNode cc1 = create();
cc1.setName("cc1");
TreeNode cc2 = create();
cc2.setName("cc2");
c1.addChild(cc1);
c1.addChild(cc2);
EntityTransaction transaction = beginTransaction();
entityManager.merge(parent);
entityManager.merge(c1);
entityManager.merge(c2);
entityManager.merge(cc1);
entityManager.merge(cc2);
transaction.commit();
Basically the following structure:
parent
-c1
-cc1
-cc2
-c2
Then I added some prints in the getChilds() method (I didn't want to
inspect the object, thought that some magical way the childs might get
loaded through that :-) )
public List<TreeNode> getChilds()
System.out.println(getName() + " childs: " + childs);
if (childs != null) {
System.out.println(getName() + " size: " + childs.size());
if (childs.size() > 0) {
System.out.println(getName() + " first: " + childs.get(0));
if (childs == null) {
childs = new EObjectContainmentEList<TreeNode>(TreeNode.class, this,
SoftmodelerPackage.TREE_NODE__CHILDS);
Now I execute the query:
Criteria criteria = session.createCriteria(TreeNode.class);
criteria.add(Restrictions.isNull("parent"));
TreeNode result = (TreeNode) criteria.uniqueResult();
result.getChilds().get(0).getChilds();
Both the creation of the TreeNodes and the query happens on the server.
I tried modeling the 'childs' as containment and as not containment.
I always get the following output:
parent childs: [c1, c2]
parent size: 2
parent first: c1
c1 childs: [cc1, cc2]
c1 size: 2
c1 first: cc1
I guess that this is the way it should behave, loading the whole object
which also contains the childs. Then the child nodes are loaded which also
load the whole object ... and so on.
But I would like to have some kind of annotation to block the loading of
references.
greets
Flavio
Martin Taal wrote:
> Hi Flavio,
> the case?
> gr. Martin
> Flavio Donzé wrote:
>> Hey Martin
>> parent reference.
>> it would be great.
>> thanks and greets
>> Flavio
>> Martin Taal wrote:
>>> Hi Flavio,
>>> gr. Martin
>>> Flavio Donzé wrote:
>>>> Hello Martin
>>>> is loaded.
>>>> the proxy.
>>>> childs?
>>>> </eOperations>
>>>> </eOperations>
>>>> upperBound="-1"
>>>> </eClassifiers>
>>>> solution.
| Re: Teneo Parent/Child fetching [message #427202 is a reply to message #427200] |
Thu, 05 February 2009 10:02   |
Hi Flavio,
You can also completely remove the explicit econtainer mapping (to the relational db) completely by setting
PersistenceOptions.DISABLE_ECONTAINER_MAPPING to true. Then if you load a single object from the database it will never
have its container set, if you load it through the parent (by accessing for example the getChilds collection) then the
object will have the container set.
But to your code snippet. It is true that debugging loads the list (encountered this myself a few times). A really
confusing behavior!
However to test if a list is set you shouldn't test on nullable, you can do the following:
boolean childsAreLoaded = !(child instanceof PersistableEList) || ((PersistableEList<?>) child).isLoaded();
Normally it should return false, if you didn't touch the childs list.
A completely another solution>>
There is a very specific Hibernate feature (never used it myself): the stateless session interface:
StatelessSession session = sessionFactory.openStatelessSession();
it does not load collections at all, you really get the single object and that's all.
gr. Martin
Flavio Donzé wrote:
> Hi Martin
> hibernateProperties
> ID_FIELD_NAME);
> c1.setName("c1");
> c2.setName("c2");
> cc1.setName("cc1");
> cc2.setName("cc2");
> c1.addChild(cc1);
> c1.addChild(cc2);
> parent
> -c1
> -cc1
> -cc2
> -c2
> childs = new
> parent size: 2
> parent first: c1
> c1 size: 2
> c1 first: cc1
> also load the whole object ... and so on.
> references.
> greets
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
>> (this
>> tree.
>> that
>> the case?
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hey Martin
>>> the parent reference.
>>> reference it would be great.
>>> thanks and greets
>>> Flavio
>>> Martin Taal wrote:
>>>> Hi Flavio,
>>>> gr. Martin
>>>> Flavio Donzé wrote:
>>>>> Hello Martin
>>>>> tree is loaded.
>>>>> the proxy.
>>>>> childs?
>>>>> </eOperations>
>>>>> </eOperations>
>>>>> upperBound="-1"
>>>>> </eClassifiers>
>>>>> fitting solution.
The Netherlands
| Re: Teneo Parent/Child fetching [message #427214 is a reply to message #427202] |
Fri, 06 February 2009 04:25   |
ciao Martin
Ok so I tested:
And it returns false. The debugger tricked me, as mentioned I was
suspecting something like that. Because there I can step through the whole
tree, all TreeNodes are loaded.
Hmm what would you suggest, Riena will definitely access the collection,
on the client side I have an ArrayList instead of an PersistableEList.
Maybe adding a setChilds(List<TreeNode> childs) method to the TreeNode and
calling setChilds(null) before transferring the TreeNode over the wire?
Kind of ugly...
Just as info, I tried using the StatelessSession. But as soon as I want to
access the childs, an exception is thrown:
HessianServiceException: failed to lazily initialize a collection of role:
TreeNode.childs, no session or session was closed
greets
Flavio
Martin Taal wrote:
> Hi Flavio,
> confusing behavior!
the following:
that's all.
> gr. Martin
> Flavio Donzé wrote:
>> Hi Martin
>> hibernateProperties
>> ID_FIELD_NAME);
>> c1.setName("c1");
>> c2.setName("c2");
>> cc1.setName("cc1");
>> cc2.setName("cc2");
>> c1.addChild(cc1);
>> c1.addChild(cc2);
>> parent
>> -c1
>> -cc1
>> -cc2
>> -c2
>> childs = new
>> parent size: 2
>> parent first: c1
>> c1 size: 2
>> c1 first: cc1
>> references.
>> greets
>> Flavio
>> Martin Taal wrote:
>>> Hi Flavio,
>>> (this
>>> tree.
>>> that
>>> the case?
>>> gr. Martin
>>> Flavio Donzé wrote:
>>>> Hey Martin
>>>> thanks and greets
>>>> Flavio
>>>> Martin Taal wrote:
>>>>> Hi Flavio,
>>>>> gr. Martin
>>>>> Flavio Donzé wrote:
>>>>>> Hello Martin
>>>>>> tree is loaded.
>>>>>> the proxy.
>>>>>> childs?
>>>>>> </eOperations>
>>>>>> </eOperations>
>>>>>> upperBound="-1"
>>>>>> </eClassifiers>
>>>>>> fitting solution.
| Re: Teneo Parent/Child fetching [message #427217 is a reply to message #427214] |
Fri, 06 February 2009 05:18   |
Hi Flavio,
Can you override the Rienna serializing so that you can implement your own non-resolving serialization?
gr. Martin
Flavio Donzé wrote:
> ciao Martin
> Ok so I tested:
> whole tree, all TreeNodes are loaded.
> and calling setChilds(null) before transferring the TreeNode over the
> wire? Kind of ugly...
> to access the childs, an exception is thrown:
> role: TreeNode.childs, no session or session was closed
> greets
> Flavio
> Martin Taal wrote:
>> Hi Flavio,
>> accessing for
>> confusing behavior!
>> can do
> the following:
> that's all.
>> gr. Martin
>> Flavio Donzé wrote:
>>> Hi Martin
>>> hibernateProperties
>>> ID_FIELD_NAME);
>>> normal settings.
>>> c1.setName("c1");
>>> c2.setName("c2");
>>> cc1.setName("cc1");
>>> cc2.setName("cc2");
>>> c1.addChild(cc1);
>>> c1.addChild(cc2);
>>> parent
>>> -c1
>>> -cc1
>>> -cc2
>>> -c2
>>> get loaded through that :-) )
>>> childs.get(0));
>>> childs = new
>>> parent size: 2
>>> parent first: c1
>>> c1 size: 2
>>> c1 first: cc1
>>> object which also contains the childs. Then the child nodes are
>>> loaded which also load the whole object ... and so on.
>>> of references.
>>> greets
>>> Flavio
>>> Martin Taal wrote:
>>>> Hi Flavio,
>>>> loaded (this
>>>> whole tree.
>>>> econtainer
>>>> is that
>>>> can be
>>>> the case?
>>>> gr. Martin
>>>> Flavio Donzé wrote:
>>>>> Hey Martin
>>>>> use the parent Id instead of a direct TreeNode reference) or even
>>>>> remove the parent reference.
>>>>> thanks and greets
>>>>> Flavio
>>>>> Martin Taal wrote:
>>>>>> Hi Flavio,
>>>>>> gr. Martin
>>>>>> Flavio Donzé wrote:
>>>>>>> Hello Martin
>>>>>>> I want to read the child TreeNodes by my self.
>>>>>>> tree is loaded.
>>>>>>> apply only for this Entity and PersistenceOptions.SET_PROXY
>>>>>>> wouldn't work anyway since the objects on the client wouldn't
>>>>>>> the childs?
>>>>>>> </eOperations>
>>>>>>> </eOperations>
>>>>>>> upperBound="-1"
>>>>>>> </eClassifiers>
>>>>>>> fitting solution.
The Netherlands
| Re: Teneo Parent/Child fetching [message #427275 is a reply to message #427217] |
Tue, 10 February 2009 11:40   |
Hello Martin, Tom
Riena does provide an ExtensionPoint to override the serialization:
org.eclipse.riena.communication.hessian.AbstractSerializerFa ctory
Here the implemented class:
public class TestSerializerFactory extends
com.caucho.hessian.io.AbstractSerializerFactory {
@SuppressWarnings("unchecked")
public Deserializer getDeserializer(Class arg0) throws
HessianProtocolException {
System.out.println("de " + arg0);
return null;
public Serializer getSerializer(Class arg0) throws
if (arg0.equals(HibernatePersistableEList.class)) {
return new CollectionSerializer() {
public void writeObject(Object obj, AbstractHessianOutput out) throws
IOException {
HibernatePersistableEList list = (HibernatePersistableEList) obj;
if (list.getEObject() instanceof TreeNode) {
list.clear();
out.writeNull();
} else {
super.writeObject(obj, out);
return null;
After I Nulled the childs I approached the problem of saving client
changes on the server. Since the TreeNode looses his references.
So I decided to go a totally different way. I just modeled the
'connection'.
Here the ecore:
upperBound="-1"
eType="#//TreeNodeChild" containment="true"
eOpposite="#//TreeNodeChild/parent"
eKeys="#//TreeNodeChild/nodeId"/>
eType="#//TreeNode"
transient="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="TreeNodeChild">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="nodeId"
iD="true"/>
eType="#//TreeNode"
eOpposite="#//TreeNode/childs" eKeys="#//BasicObject/id"/>
</eClassifiers>
Also not the best solution but it works :-).
Now I transfer the TreeNode and its TreeNodeChild collection to the
client. If I need to read the childs I pass the TreeNode back to the
server and query the childs using the TreeNodeChild collection.
Thanks guys for your inputs/ideas!
Martin Taal wrote:
> Hi Flavio,
> gr. Martin
> Flavio Donzé wrote:
>> ciao Martin
>> Ok so I tested:
>> greets
>> Flavio
>> Martin Taal wrote:
>>> Hi Flavio,
>>> accessing for
>>> confusing behavior!
>>> can do
>> the following:
>> that's all.
>>> gr. Martin
>>> Flavio Donzé wrote:
>>>> Hi Martin
>>>> hibernateProperties
>>>> ID_FIELD_NAME);
>>>> normal settings.
>>>> c1.setName("c1");
>>>> c2.setName("c2");
>>>> cc1.setName("cc1");
>>>> cc2.setName("cc2");
>>>> c1.addChild(cc1);
>>>> c1.addChild(cc2);
>>>> parent
>>>> -c1
>>>> -cc1
>>>> -cc2
>>>> -c2
>>>> childs.get(0));
>>>> childs = new
>>>> parent size: 2
>>>> parent first: c1
>>>> c1 size: 2
>>>> c1 first: cc1
>>>> of references.
>>>> greets
>>>> Flavio
>>>> Martin Taal wrote:
>>>>> Hi Flavio,
>>>>> loaded (this
>>>>> whole tree.
>>>>> econtainer
>>>>> is that
>>>>> can be
>>>>> the case?
>>>>> gr. Martin
>>>>> Flavio Donzé wrote:
>>>>>> Hey Martin
>>>>>> thanks and greets
>>>>>> Flavio
>>>>>> Martin Taal wrote:
>>>>>>> Hi Flavio,
>>>>>>> gr. Martin
>>>>>>> Flavio Donzé wrote:
>>>>>>>> Hello Martin
>>>>>>>> tree is loaded.
>>>>>>>> the childs?
>>>>>>>> </eOperations>
>>>>>>>> </eOperations>
>>>>>>>> upperBound="-1"
>>>>>>>> </eClassifiers>
>>>>>>>> fitting solution.
| Re: Teneo Parent/Child fetching [message #427277 is a reply to message #427275] |
Tue, 10 February 2009 12:50   |
Hi Flavio,
Thanks for the update, always interesting!
One remark (let me know if I miss the point), you do list.clear(), if you then commit the transaction then the list will
also be cleared in the db. Or did you not encounter this behavior? Do you need to do list.clear() or would just
out.writeNull be enough?
gr. Martin
Flavio Donzé wrote:
> Hello Martin, Tom
> @Override
> return null;
> @Override
> @Override
> AbstractHessianOutput out) throws IOException {
> list.clear();
> out.writeNull();
> } else {
> return null;
> changes on the server. Since the TreeNode looses his references. So I
> decided to go a totally different way. I just modeled the 'connection'.
> Here the ecore:
> upperBound="-1"
> eType="#//TreeNode"
> transient="true"/>
> </eClassifiers>
> iD="true"/>
> eType="#//TreeNode"
> </eClassifiers>
> Martin Taal wrote:
>> Hi Flavio,
>> own
>> gr. Martin
>> Flavio Donzé wrote:
>>> ciao Martin
>>> Ok so I tested:
>>> collection, on the client side I have an ArrayList instead of an
>>> PersistableEList.
>>> TreeNode and calling setChilds(null) before transferring the TreeNode
>>> over the wire? Kind of ugly...
>>> want to access the childs, an exception is thrown:
>>> greets
>>> Flavio
>>> Martin Taal wrote:
>>>> Hi Flavio,
>>>> load a
>>>> accessing for
>>>> confusing behavior!
>>>> can do
>>> the following:
>>>> object and
>>> that's all.
>>>> gr. Martin
>>>> Flavio Donzé wrote:
>>>>> Hi Martin
>>>>> hibernateProperties
>>>>> preferences
>>>>> ID_FIELD_NAME);
>>>>> normal settings.
>>>>> c1.setName("c1");
>>>>> c2.setName("c2");
>>>>> cc1.setName("cc1");
>>>>> cc2.setName("cc2");
>>>>> c1.addChild(cc1);
>>>>> c1.addChild(cc2);
>>>>> parent
>>>>> -c1
>>>>> -cc1
>>>>> -cc2
>>>>> -c2
>>>>> to inspect the object, thought that some magical way the childs
>>>>> might get loaded through that :-) )
>>>>> childs.get(0));
>>>>> childs = new
>>>>> server.
>>>>> parent size: 2
>>>>> parent first: c1
>>>>> c1 size: 2
>>>>> c1 first: cc1
>>>>> loading of references.
>>>>> greets
>>>>> Flavio
>>>>> Martin Taal wrote:
>>>>>> Hi Flavio,
>>>>>> loaded (this
>>>>>> whole tree.
>>>>>> econtainer
>>>>>> is that
>>>>>> can be
>>>>>> the case?
>>>>>> gr. Martin
>>>>>> Flavio Donzé wrote:
>>>>>>> Hey Martin
>>>>>>> thanks and greets
>>>>>>> Flavio
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Flavio,
>>>>>>>> gr. Martin
>>>>>>>> Flavio Donzé wrote:
>>>>>>>>> Hello Martin
>>>>>>>>> TreeNode.
>>>>>>>>> objects) I want to read the child TreeNodes by my self.
>>>>>>>>> whole tree is loaded.
>>>>>>>>> the childs?
>>>>>>>>> </eOperations>
>>>>>>>>> </eOperations>
>>>>>>>>> name="childs" upperBound="-1"
>>>>>>>>> name="object" eType="#//ObjectRef"
>>>>>>>>> name="parent" eType="#//TreeNode"/>
>>>>>>>>> </eClassifiers>
>>>>>>>>> fitting solution.
The Netherlands
| Re: Teneo Parent/Child fetching [message #427278 is a reply to message #427277] |
Tue, 10 February 2009 13:05  |
hey Martin
writeNull would be enough.
Nothing happens to the db doing list.clear(). I just thought I could help
the garbage collector a little :-)
cheers
flavio
Martin Taal wrote:
> Hi Flavio,
> gr. Martin
> Flavio Donzé wrote:
>> Hello Martin, Tom
>> @Override
>> return null;
>> @Override
>> @Override
>> list.clear();
>> out.writeNull();
>> } else {
>> return null;
>> Here the ecore:
>> upperBound="-1"
>> eType="#//TreeNode"
>> transient="true"/>
>> </eClassifiers>
>> iD="true"/>
>> eType="#//TreeNode"
>> </eClassifiers>
>> Martin Taal wrote:
>>> Hi Flavio,
>>> own
>>> gr. Martin
>>> Flavio Donzé wrote:
>>>> ciao Martin
>>>> Ok so I tested:
>>>> PersistableEList.
>>>> greets
>>>> Flavio
>>>> Martin Taal wrote:
>>>>> Hi Flavio,
>>>>> load a
>>>>> accessing for
>>>>> confusing behavior!
>>>>> can do
>>>> the following:
>>>>> object and
>>>> that's all.
>>>>> gr. Martin
>>>>> Flavio Donzé wrote:
>>>>>> Hi Martin
>>>>>> hibernateProperties
>>>>>> preferences
>>>>>> ID_FIELD_NAME);
>>>>>> normal settings.
>>>>>> c1.setName("c1");
>>>>>> c2.setName("c2");
>>>>>> cc1.setName("cc1");
>>>>>> cc2.setName("cc2");
>>>>>> c1.addChild(cc1);
>>>>>> c1.addChild(cc2);
>>>>>> parent
>>>>>> -c1
>>>>>> -cc1
>>>>>> -cc2
>>>>>> -c2
>>>>>> childs.get(0));
>>>>>> childs = new
>>>>>> server.
>>>>>> parent size: 2
>>>>>> parent first: c1
>>>>>> c1 size: 2
>>>>>> c1 first: cc1
>>>>>> greets
>>>>>> Flavio
>>>>>> Martin Taal wrote:
>>>>>>> Hi Flavio,
>>>>>>> loaded (this
>>>>>>> whole tree.
>>>>>>> econtainer
>>>>>>> is that
>>>>>>> can be
>>>>>>> the case?
>>>>>>> gr. Martin
>>>>>>> Flavio Donzé wrote:
>>>>>>>> Hey Martin
>>>>>>>> thanks and greets
>>>>>>>> Flavio
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi Flavio,
>>>>>>>>> gr. Martin
>>>>>>>>> Flavio Donzé wrote:
>>>>>>>>>> Hello Martin
>>>>>>>>>> TreeNode.
>>>>>>>>>> the childs?
>>>>>>>>>> </eOperations>
>>>>>>>>>> </eOperations>
>>>>>>>>>> </eClassifiers>
>>>>>>>>>> fitting solution.
Current Time: Wed Oct 29 11:51:15 EDT 2025
Powered by FUDForum. Page generated in 0.05836 seconds
