Home » Modeling » EMF » [CDO] Metamodel change -> migration path?
[CDO] Metamodel change -> migration path? [message #426086] |
Tue, 16 December 2008 09:04 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
I don't know if this topic has been discussed earlier, but is there a
way to migrate CDO-backed data to a new metamodel?
I know that metamodels cannot be changed once stored in CDO, but is
there a way, like, to export the database contents into a file, then
delete the database, restart so the DB is created with the new metamodel
and reimport the data from the file?
Well, this should at least work, if I write my own custom data-exporter
which would not care about models and metamodels, but is this by chance
possible with the builtin CDO UI tools?
Cheers
Stefan
Re: [CDO] Metamodel change -> migration path? [message #426089 is a reply to message #426086] |
Tue, 16 December 2008 09:12 |
Xingxiao Lu Messages: 91 Registered: July 2009 |
Member |
Eike has openned a bug about this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256856
"Stefan Winkler" <stefan.winkler-et@fernuni-hagen.de>
> I don't know if this topic has been discussed earlier, but is there a way
> I know that metamodels cannot be changed once stored in CDO, but is there
> a way, like, to export the database contents into a file, then delete the
> database, restart so the DB is created with the new metamodel and reimport
> Cheers
> Stefan
Re: [CDO] Metamodel change -> migration path? [message #426094 is a reply to message #426086] |
Tue, 16 December 2008 10:10 |
Stefan,
Currently CDO has neither core-level nor a UI-level support for
automatic data migration after model evolution.
As Xxlu pointed out we have started sorting our minds with respect to
the requirements and implications.
I have the feeling that the approach you sketched has some flaws. See my
inline comments...
Stefan Winkler schrieb:
This should be possible already with *backend-specific* facilities.
> then delete the database, restart so the DB is created with the new
> metamodel
I'm not sure if you really mean the DB or the repository.
This way or that way I'd say there is not meta data created or
re-created automatically.
In CDO meta data is not a self-purpose and is thus only created
*together* with the instances that need this meta data.
Well, this is the most cloudy step of the process ;-)
what exactly would you expect to happen here?
Cheers
/Eike
> data-exporter which would not care about models and metamodels, but is
> this by chance possible with the builtin CDO UI tools?
> Cheers
> Stefan
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Metamodel change -> migration path? [message #426110 is a reply to message #426094] |
Tue, 16 December 2008 16:00 |
Eike,
I should have been more specific. Most of my metamodel changes are
simply adding an attribute. So the migration should in Theroy be
automatable by simply assigning the values of the old objects to the new
ones and set the added attribute's value to a default.
>> metamodel
Since I have only one repository, this should have read: drop all my
tables :-)
No, but the old package data is erased and the objects are inserted as
objects of the new model. I also should have said, that I don't care
about revised revisions :-)
Well, see above. But generally, I could imagine a UI which does a best
guess for mappings and then suggests a transformation from the old model
to the new one. (old and new meaning conformant to the old/new metamodel
in this post .. I'm just being lazy ... ;-))
Stefan
Re: [CDO] Metamodel change -> migration path? [message #426135 is a reply to message #426110] |
Wed, 17 December 2008 08:17 |
Stefan,
Comments below...
> Eike,
> new ones and set the added attribute's value to a default.
I see.
>>> metamodel
> tables :-)
But I still see a minor challenge there. As you know, there are two
types of tables in a DBStore-managed database:
1) System tables (repo info, package infos, class infos, ...)
2) Model tables (revision data)
If you drop *all* tables and don't have the state of the system tables
in your export (because this part will change for the new model
versions), then you need to re-create them somehow manually. Maybe it
helps to commit a dummy transaction with a dummy resource and some
classes of the new models. This would populate the system tables with
needed infos...
> I also should have said, that I don't care about revised revisions :-)
Then I suggest that you lift the priority of
253110: [DB] Support non-auditing mode
https://bugs.eclipse.org/bugs/show_bug.cgi?id=253110
:P
> model to the new one. (old and new meaning conformant to the old/new
> metamodel in this post .. I'm just being lazy ... ;-))
Generally I also can imagine fancy things like UI and mapping guesses ;-)
We have this bugzilla for general discussion of this sensible topic (not
to say complex):
256856: Support model evolution
Btw. is the approach you have in mind store-specific (i.e. DBStore) or
would it act more generally on the repository level?
Cheers
/Eike
Cheers
/Eike
Current Time: Fri Apr 26 12:55:21 GMT 2024
Powered by FUDForum. Page generated in 0.03774 seconds
