Re: [CDO] CDORevisionImpl.eIsSet() works incorrectly [message #426091 is a reply to message #426085] |
Tue, 16 December 2008 09:45 |
Saulius,
It looks like a bug. More generally it seems that we should check
against the default value rather than against null.
Can you please file a bugzilla?
Cheers
/Eike
Saulius Tvarijonas schrieb:
> I am using CDO 2.0.0M3 build. I am using EObject.eIsSet() to check if
> certain feature is set. It seems CDOObject always returns true, even
> if there is no value set.
> Debugging shows that eIsSet goes to CDORevisionImpl.eIsSet().
> Implementation is:
> public boolean isSet(CDOFeature feature)
> return getValue(feature) != null;
> It seems checking here is incorrect, because value is CDOIDNULLImpl
> instance. If I use eGet() method, I get as expected null.
> Is it normal behavior?
> Regards,
> Saulius
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] CDORevisionImpl.eIsSet() works incorrectly [message #426105 is a reply to message #426091] |
Tue, 16 December 2008 14:23 |
Saulius Tvarijonas Messages: 34 Registered: July 2009 |
Member |
I registered bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258933
Saulius
On 12/16/2008 11:45 AM, Eike Stepper wrote:
> Saulius,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi,
>> Implementation is:
>> Regards,
>> Saulius
FUDForum. Page generated in 0.03226 seconds
