Re: [CDO/EMF] Missing serialized package: myPackage.ecore [message #425824 is a reply to message #425822] |
Tue, 09 December 2008 13:17 |
Hi Stefan,
I know I had this error once long ago but I can#t remeber the cause
anymore ;-(
Let's hear if Ed can explain it...
Cheers
/Eike
Stefan Winkler schrieb:
> can anyone say something about this exception?
> java.lang.ExceptionInInitializerError
> at sun.misc.Unsafe.ensureClassInitialized(Native Method)
> at sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unkn own
> Source)
> at sun.reflect.ReflectionFactory.newFieldAccessor(Unknown Source)
> at java.lang.reflect.Field.acquireFieldAccessor(Unknown Source)
> at java.lang.reflect.Field.getFieldAccessor(Unknown Source)
> at java.lang.reflect.Field.get(Unknown Source)
> at
> org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:255)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.getGeneratedEPac kage(ModelUtil.java:348)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.createEPackage(M odelUtil.java:330)
> at
> org.eclipse.emf.internal.cdo.util.CDOPackageRegistryImpl$Rem otePackageDescriptor.getEPackage(CDOPackageRegistryImpl.java :181)
> at
> at
> org.eclipse.emf.internal.cdo.CDOSessionPackageManagerImpl.lo adPackage(CDOSessionPackageManagerImpl.java:152)
> at
> org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loa d(CDOPackageImpl.java:401)
> at
> org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loo kupClass(CDOPackageImpl.java:288)
> at
> org.eclipse.emf.cdo.internal.common.model.CDOClassRefImpl.re solve(CDOClassRefImpl.java:71)
> at
> org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO ClassRefAndResolve(CDODataInputImpl.java:218)
> at
> org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl . <init>(CDORevisionImpl.java:114)
> at
> org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO Revision(CDODataInputImpl.java:309)
> at
> org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:116)
> at
> org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:1)
> at
> org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClientRequest.java:103)
> at
> org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:118)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:317)
> at
> org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:98)
> at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:68)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:237)
> at
> org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:392)
> at
> org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:82)
> at
> org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
> at
> org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.send(CDO RevisionManagerImpl.java:149)
> at
> org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.loadRevi sions(CDORevisionManagerImpl.java:125)
> at
> org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevisions(CDORevisionResolverImpl.java:186)
> at
> org.eclipse.emf.internal.cdo.CDOStore.convertToEMF(CDOStore. java:374)
> at org.eclipse.emf.internal.cdo.CDOStore.get(CDOStore.java:175)
> at
> org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreELis t.delegateGet(EStoreEObjectImpl.java:225)
> at
> org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:396)
> at
> de.feuh.st.requipse.ui.views.TraceabilityView$LabelProviderW rapper.isReferenceSet(TraceabilityView.java:83)
> at
> de.feuh.st.requipse.ui.views.TraceabilityView$LabelProviderW rapper.getFont(TraceabilityView.java:70)
> at
> org.eclipse.jface.viewers.ColumnLabelProvider.update(ColumnL abelProvider.java:41)
> at
> org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
> at
> org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(A bstractTableViewer.java:386)
> at
> org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:880)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at
> org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2041)
> at
> org.eclipse.jface.viewers.AbstractTableViewer.createItem(Abs tractTableViewer.java:264)
> at
> org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:741)
> at
> org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:633)
> at
> org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:620)
> at
> org.eclipse.jface.viewers.AbstractTableViewer$2.run(Abstract TableViewer.java:576)
> at
> org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1365)
> at
> org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1328)
> at
> org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(A bstractTableViewer.java:574)
> at
> org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
> at
> org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
> at
> de.feuh.st.requipse.ui.views.TraceabilityView.selectionChang ed(TraceabilityView.java:167)
> at
> org.eclipse.ui.internal.AbstractSelectionService.firePostSel ection(AbstractSelectionService.java:179)
> at
> org.eclipse.ui.internal.AbstractSelectionService$2.selection Changed(AbstractSelectionService.java:71)
> at
> org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
> at
> org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
> at
> org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
> at
> org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
> at
> org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
> at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
> at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> Caused by: java.lang.RuntimeException: Missing serialized package:
> weightedLinks.ecore
> at
> de.feuh.st.requipse.tracer.links.weighted.weightedLinks.impl .WeightedLinksPackageImpl.loadPackage(WeightedLinksPackageIm pl.java:219)
> at
> de.feuh.st.requipse.tracer.links.weighted.weightedLinks.impl .WeightedLinksPackageImpl.init(WeightedLinksPackageImpl.java :122)
> at
> de.feuh.st.requipse.tracer.links.weighted.weightedLinks.Weig htedLinksPackage. <clinit>(WeightedLinksPackage.java:63)
> ... 97 more
> This is what I do:
> Create a model on another (Linux-) PC with CDO/HSQLDB, then copy the
> HSQLDB to my (Windows-)PC, read the model (which works for several
> elements) but as soon as I want to read a WeightedLink (instance of a
> different metamodel than the rest) I get the error above.
> Where does EMF look for the .ecore file and why does it not find it
> (it is in the model/ folder of the plugin-project ...).
> Any hints?
> Cheers,
> Stefan
Cheers
/Eike
http://www.esc-net.de
Re: [CDO/EMF] Missing serialized package: myPackage.ecore [message #425901 is a reply to message #425899] |
Thu, 11 December 2008 13:28 |
Stefan,
I know that it's currently not so easy as usual to maintain the newsgroup.
So I suggest htat you file a bugzilla on CDO and cc Ed.
Cheers
/Eike
> I still got this issue :-(
> Should I open a bugzilla?
> Ed?
> Cheers,
> Stefan
> Eike Stepper schrieb:
>> Hi Stefan,
>> anymore ;-(
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>>> Hi,
>>> at
>>> sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unkn own Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> weightedLinks.ecore
>>> at
>>> at
>>> at
>>> ... 97 more
>>> This is what I do:
>>> a different metamodel than the rest) I get the error above.
>>> Any hints?
>>> Cheers,
>>> Stefan
Cheers
/Eike
Re: [CDO/EMF] Missing serialized package: myPackage.ecore [message #425935 is a reply to message #425901] |
Fri, 12 December 2008 13:39 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
I found a solution which is ok for me.
For some reason which I can't reconstruct (maybe just turning the
scrollwheel at the wrong time) I had the "Initialize by loading"
property in that package set to true - in all other packages it was false.
So while I still don't know why the bundle class loader is looking in
the wrong place for the .ecore file, if I use initialize by
loading=false, it does not try to find the package in the first place
and everything is fine ;-)
Stefan
> Stefan,
> newsgroup.
> Cheers
> /Eike
>> Hi,
>> Ed?
>> Cheers,
>> Stefan
>>> Hi Stefan,
>>> anymore ;-(
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> weightedLinks.ecore
>>>> at
>>>> at
>>>> at
>>>> ... 97 more
>>>> This is what I do:
>>>> the HSQLDB to my (Windows-)PC, read the model (which works for
>>>> several elements) but as soon as I want to read a WeightedLink
>>>> (instance of a different metamodel than the rest) I get the error
>>>> above.
>>>> Any hints?
>>>> Cheers,
>>>> Stefan
FUDForum. Page generated in 0.03868 seconds
