Home » Modeling » EMF » [CDO] Second CDOResource with name=null
[CDO] Second CDOResource with name=null [message #425432] |
Wed, 26 November 2008 09:44 |
Bjoern Sundin Messages: 47 Registered: July 2009 |
Member |
Today I wanted to move my project from CDO/NET4J version I200810161652 to
2.0.0M3.
Without modifying any of my code yet, I encountered two problems of which I
could solve the first (missing element 'jdbcDelegate' in cdo-server.xml).
For the second problem I haven't found a solution yet and so I turn to the
community for assistance:
Out of my IDE (3.5 M3) I successfully start the server instance (creating a
new derby db), however when I start the client and read in some initial data
the server gets a problem during the commit which I didn't have with the
I200810161652 version:
Thread-3 [debug] Writing revision: CDOResource@OID1v1
Thread-3 [debug] SELECT cdo_id FROM CDOResourceFolder WHERE cdo_container=0
AND name='kgk' AND ((cdo_revised=0 OR cdo_revised>=1227689750645) AND
1227689750645>=cdo_created)
Thread-3 [debug] SELECT cdo_id FROM CDOResource WHERE cdo_container=0 AND
Thread-3 [debug] INSERT IGNORE INTO CDOResource VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?,
?) (CDOResource@OID1v1)
Thread-3 [debug] INSERT IGNORE INTO CDOResource_contents_refs VALUES (?, ?, ?, ?)
(0,1,1,0,58)
Thread-3 [debug.sql] CREATE TABLE cdo_objects (cdo_id BIGINT, cdo_class
INTEGER)
Thread-3 [debug.sql] CREATE INDEX cdo_objects_idx0 ON cdo_objects (cdo_id)
Thread-3 [debug.sql] INSERT IGNORE INTO cdo_objects VALUES (1, -2)
Thread-3 [debug] Writing revision: CDOResource@OID2v1
AND name IS NULL AND ((cdo_revised=0 OR cdo_revised>=1227689750645) AND
?) (CDOResource@OID2v1)
[ERROR] SQL Exception: An attempt was made to get a data value of type
'VARCHAR' from a data value of type 'null'.
It is obvious that the problem is that the CDOResource name is NULL. What I
cannot see though, is why there is an apparent second CDOResource to be
inserted to...?
Attached is the complete server trace log.
Thanks!
Bjoern
Re: [CDO] Second CDOResource with name=null [message #425437 is a reply to message #425432] |
Wed, 26 November 2008 10:31 |
Bjoern,
I discovered this regression only yesterday and filed:
256462: [DB] preparedStatement problem during commit
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256462
Stefan has found a fix and will commit it later today.
As a work-around in the meantime please change back the
jdbcDelegate from preparedStatement to statement in the cdo-server.xml.
Cheers
/Eike
> 2.0.0M3.
> (0,1,1,0,58)
> INTEGER)
> inserted to...?
> Thanks!
> Bjoern
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Second CDOResource with name=null [message #425441 is a reply to message #425437] |
Wed, 26 November 2008 10:41 |
Member |
Great, thanks for the fast reply and fix!
Greetings
Bjoern
"Eike Stepper" <stepper@esc-net.de> schrieb im Newsbeitrag
news:ggj8ia$aop$1@build.eclipse.org...
> Bjoern,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> 2.0.0M3.
>> I could solve the first (missing element 'jdbcDelegate' in
>> cdo-server.xml). For the second problem I haven't found a solution yet
>> and so I turn to the community for assistance:
>> a new derby db), however when I start the client and read in some initial
>> data the server gets a problem during the commit which I didn't have with
>> the I200810161652 version:
>> cdo_container=0 AND name='kgk' AND ((cdo_revised=0 OR
>> cdo_revised>=1227689750645) AND 1227689750645>=cdo_created)
>> ?, ?) (CDOResource@OID1v1)
>> ?) (0,1,1,0,58)
>> INTEGER)
>> (cdo_id)
>> cdo_container=0 AND name IS NULL AND ((cdo_revised=0 OR
>> ?, ?) (CDOResource@OID2v1)
>> I cannot see though, is why there is an apparent second CDOResource to be
>> inserted to...?
>> Thanks!
>> Bjoern
Re: [CDO] Second CDOResource with name=null [message #425443 is a reply to message #425441] |
Wed, 26 November 2008 12:06 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Fix is available in HEAD now. (The problem seemed only to occur with
Derby DB ...)
> Greetings
> Bjoern
>> Bjoern,
>> Cheers
>> /Eike
>>> 2.0.0M3.
>>> ?) (0,1,1,0,58)
>>> INTEGER)
>>> (cdo_id)
>>> inserted to...?
>>> Thanks!
>>> Bjoern
Current Time: Fri Sep 20 15:49:29 GMT 2024
Powered by FUDForum. Page generated in 0.02801 seconds
