Retrieve EditingModel from EObject [message #425142] |
Sun, 16 November 2008 20:53 |
Originally posted by: nuclearpsyche.gmail.com
Is it possible to find out which EditingDomain a certain EObject belongs
to? (for example can I get the EditingDomain by only knowing the root
object?)
tamer
Re: Retrieve EditingModel from EObject [message #425143 is a reply to message #425142] |
Mon, 17 November 2008 00:47 |
Originally posted by: cdamus.zeligsoft.com
Hi, Tamer,
If you are working with a TransactionalEditingDomain, then you can use
TransactionUtil::getEditingDomain(EObject) to find your answer.
In a non-transactional editing domain, I don't think that there is
traceability from the ResourceSet to the EditingDomain, though. You
will need to know the workbench part that you're dealing with and adapt
it to IEditingDomainProvider to get the editing domain from it.
HTH,
Christian
Tamer wrote:
> Hello,
> object?)
> tamer
Re: Retrieve EditingModel from EObject [message #425169 is a reply to message #425143] |
Tue, 18 November 2008 06:54 |
Ed Merks Messages: 33147 Registered: July 2009 |
Guys,
You can use AdapterFactoryEditingDomain.getEditingDomainFor...
Christian W. Damus wrote:
> Hi, Tamer,
> adapt it to IEditingDomainProvider to get the editing domain from it.
> HTH,
> Christian
> Tamer wrote:
>> Hello,
>> belongs to? (for example can I get the EditingDomain by only knowing
>> the root object?)
>> Thanks,
>> tamer
Ed Merks
Re: Retrieve EditingModel from EObject [message #425180 is a reply to message #425169] |
Tue, 18 November 2008 14:20 |
Ah! The same adapter approach. Silly me; I should have looked more
closely.
cW
Ed Merks wrote:
> Guys,
-----8<-----
Re: Retrieve EditingModel from EObject [message #425217 is a reply to message #425143] |
Wed, 19 November 2008 22:20 |
Thank you very much Christian,
That's exactly what I needed.
tamer
> Hi, Tamer,
> HTH,
> Christian
> Tamer wrote:
>> Hello,
>> the root object?)
>> Thanks,
>> tamer
FUDForum. Page generated in 0.03701 seconds
